637NH/2
637NH/2
    APEM(埃斐)
    钮子开关 单刀双掷 1万次 面板安装 10A 250V -20℃~+55℃
637NH/2 数据手册
7000 Series Miniature Toggle Switches Features/Benefits • Multi-pole and multi-position • Wide variety of actuator and termination options Typical Applications • Telecommunications • Instrumentation • Medical equipment • Epoxy terminal-seal compatible with bottom wash cleaning • RoHS complaint models available Models Available Specifications CONTACT RATING: B contact material: 0.4 VA max. @ 20 V AC or DC max. Q contact material: 5 AMPS @ 120 V AC or 28 V DC; 2 AMPS @ 250 V AC. See page G-16 for additional ratings. ELECTRICAL LIFE: 7X01 and UX1 models: 100,000 make-and-break cycles at full load. All other models: 40,000 cycles. CONTACT RESISTANCE: Below 10 m Ω typ. initial @ 2-4 V DC, 100 mA, for both silver and gold plated contacts. INSULATION RESISTANCE: 109 Ω min. DIELECTRIC STRENGTH: 1000 Vrms min. @ sea level. OPERATING TEMPERATURE: –30ºC to 85ºC. SOLDERABILITY: Per MIL-STD-202F method 208D, or EIA RS-186E method 9 (1 hour steam aging). For materials see page G-4. NOTE: Any models supplied with P, S R, Q, B or G contact material are RoHS compliant and compatible. NOTE: Specifications listed above are for switches with standard options. For information on specific and custom switches, consult Customer Service Center. Build-A-Switch To order, simply select desired option from each category and place in the appropriate box. Available options are shown and described on pages G–4 thru G–16. For additional options not shown in catalog, consult our Customer Service Center. Switch Function 7101 SP On-None-On 7103 SP On-Off-On 7105 SP Mom.-Off-Mom. 7107 SP On-Off-Mom. 7108 SP On-None-Mom. 7109 SP None-On-Mom. 7201 DP On-None-On 7203 DP On-Off-On 7205 DP Mom.-Off-Mom. 7207 DP On-Off-Mom. 7208 DP On-None-Mom. 7211 DP On-On-On 7213 DP On-On-Mom. 7215 DP Mom.-On-Mom. 7301 3P On-None-On 7303 3P On-Off-On 7305 3P Mom.-Off-Mom. 7308 3P On-None-Mom. 7401 4P On-None-On 7403 4P On-Off-On 7405 4P Mom.-Off-Mom. 7408 4P On-None-Mom. 7411 4P On-On-On 7413 4P On-On-Mom. 7415 4P Mom.-On-Mom. Note: UL/CSA models available, see pages G-4 & G-5. Actuator M .200" high P3 Flatted, anti-rotation, .450" high S .420" high T .687" high, 15/32 bushing K2 Locking lever, .704" high K9 Locking lever, .704" high K12 Locking lever, .732" high K19 Locking lever, .732" high L .840" high L1 .640" high L1P Anti-rotation, .640" high L2 .550" high L2P Anti-rotation, .550" high L3 Plastic .940” inch L40 Lever handle without cap L41 .531" high lever handle with cap L42 .838" high lever handle with cap MP Anti-rotation, .200" high P1 Flatted, anti-rotation, .840" high P4 Flatted, anti-rotation, .250" high SP Anti-rotation, .420" high T1 .487" high, 15/32 bushing T1P Anti-rotation, .487" high, 15/32 bushing T2P Flatted, anti-rotation, .610” high, 15/32 bushing, TP Anti-rotation, .687" high, 15/32 bushing Bushing D .280 high, keyway H .296 high, flat Y .350 high, keyway NONE No bushing choice required CW Splashproof D8 .280" high, flat D9 .280" high, keyway H3 .315" high, keyway H4 8mm high, keyway Y1 .378" high, keyway Y3 8.9mm high, keyway Y4 .378" high, flat Y9 .350" high, keyway Contact Material B Gold Seal P Gold, matte-tin E Epoxy Q Silver I Epoxy potted S Silver, matte-tin base G Gold over silver R Gold over silver, matte-tin KXX Actuator Color/Finish NONE Natural aluminum 2 Black anodized aluminum 3 Red anodized aluminum 7 Blue anodized aluminum Bushing Finish NONE Nickel on all bushings (except D8, satin chrome) 2 Black .750" long, wire wrap .964" long, wire wrap .425" long, wire wrap 1.062" long, wire wrap 1.305" long, wire wrap Quick connect Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–3 www.ck-components.com G Toggle Terminations A Right angle, PC thru-hole AV2 Vert. right angle, PC thru-hole C PC Thru-hole V3 .460 high, V-bracket Z Solder lug A2 Right angle, PC thru-hole A3 Right angle, PC thru-hole A4 Right angle, PC thru-hole AW1 Right angle, extended, PC thru-hole AW4 Right angle, extended, PC thru-hole V2 .555" high, V-bracket V4 .630" high, V-bracket V6 .460" high, V-bracket V7 .630" high, V-bracket V8 .953" high, V-bracket W V9 1.150" high, V-bracket V21 .555" high, snap-in V-bracket W1 V31 .460" high, snap-in V-bracket W3 V41 .630" high, snap-in V-bracket W4 W5 V71 .630" high, snap-in V-bracket Z3 V81 .953" high, snap-in V-bracket Actuator Color/Finish NONE Bright chrome 2 Black 3 Red S Satin chrome 7000 Series Miniature Toggle Switches Materials CASE: Glass filled nylon 6/6, flame retardant, heat stabilized, or diallyl phthalate (DAP) (UL 94V-0). ACTUATOR: Brass, chrome plated. BUSHING: Brass or zinc, nickel plated. HOUSING: Stainless steel. SWITCH SUPPORT: Brass or steel, tin plated. END CONTACTS: B contact material: Copper alloy, with gold plate over nickel plate. Q contact material: Coin silver, silver plated. See page G-15 for additional contact materials. CENTER CONTACTS & ALL TERMINALS: B contact material: Copper alloy, with gold plate over nickel plate. Q contact material: Copper alloy, silver plated. See above for additional contact materials. TERMINAL SEAL: Epoxy. HARDWARE: Nut & Locking Ring: Brass, nickel plated. Lockwasher: Steel, nickel plated. NOTE: Materials listed above are for switches with standard options. For information on specific and custom switches, consult Customer Service Center. SWITCH FUNCTION SWITCH FUNCTION NO. POLES SP MODEL NO. CONNECTED TERMINALS POS. 1 POS. 2 POS. 3 POS. 1 POS. 2 POS. 3 ON NONE ON 2-3 N/A 2-1 2-3 OPEN 2-1 UL/CSA** MODEL NO. SCHEMATIC 7101 U11 7103 U13 ON OFF ON 7105 U15 MOM. OFF MOM. 7107 U17 ON OFF MOM. 7108 U18 ON NONE MOM. 2-3 N/A 2-1 7109 U19 NONE ON MOM. N/A 2-3 2-1 SPDT SPDT 1/4-40 UNS-2A KEYWAY Terminal Numbers For Reference Only Part number shown: 7101SYZBE DP 7201 U21 ON NONE ON 7203 U23 ON OFF ON 7205 U25 MOM. OFF MOM. 7207 U27 ON OFF MOM. 7208 U28 ON NONE MOM. 7211 * U211* ON ON ON 7213* U213* ON ON MOM. 7215* U215* MOM. ON MOM. 2-3,5-6 N/A 2-1,5-4 2-3,5-6 OPEN 2-1,5-4 2-3,5-6 N/A 2-1,5-4 2-3,5-6 2-3,5-4 2-1,5-4 DPDT DPDT 1/4-40 UNS-2A KEYWAY Toggle G Terminal Numbers For Reference Only Part number shown: 7201SYZQE MOM. = Momentary ** U11–U415 model nos. with all options when ordered with G, L, R, M, Q or S contact material. * Wiring for 3-way switch, see Section O. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–4 www.ck-components.com 7000 Series Miniature Toggle Switches SWITCH FUNCTION SWITCH FUNCTION POS. 1 NO. POLES 3P MODEL NO. POS. 2 CONNECTED TERMINALS POS. 3 POS. 1 POS. 2 POS. 3 UL/CSA** MODEL NO. SCHEMATIC 7301 U31 ON NONE ON 7303 U33 ON OFF ON 7305 U35 MOM. OFF MOM. 7307 U37 ON OFF MOM. 7308 U38 ON NONE MOM. 2-3,5-6,8-9 N/A 2-1,5-4,8-7 2-3,5-6,8-9 OPEN 2-1,5-4,8-7 2-3,5-6,8-9 N/A 2-1,5-4,8-7 3PDT 3PDT 1/4-40 UNS-2A KEYWAY Terminal Numbers For Reference Only Part number shown: 7301SYZQE 7401 U41 7403 7405 ON NONE ON 2-3,5-6,8-9,11-12 N/A 2-1,5-4,8-7,11-10 U43 ON OFF ON U45 MOM. OFF MOM. 7408 U48 ON NONE 2-3,5-6,8-9,11-12 OPEN 2-1,5-4,8-7,11-10 MOM. 2-3,5-6,8-9,11-12 N/A 2-1,5-4,8-7,11-10 7411* U411* ON ON ON 7413* U413* ON ON MOM. 7415* U415* MOM. ON MOM. 2-3,5-6,8-9,11-12 2-3,5-4,8-9,11-10 2-1,5-4,8-7,11-10 4P 4PDT 4PDT 1/4-40 UNS-2A KEYWAY Terminal Numbers For Reference Only Part number shown: 7401SYZQE MOM. = Momentary * Wiring for 3-way switch, see Section O. ** U11–U415 model nos. with all options when ordered with G, L, M, Q, R or S contact material. G Toggle Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–5 www.ck-components.com 7000 Series Miniature Toggle Switches ACTUATOR FINISH ACTUATOR ACTUATOR S SP M MP .420" HIGH 1 ANTIROTATION, .420" HIGH 2,3 L, L1, L2 L1P, L2P .200" HIGH 1 ANTIROTATION, .200" HIGH 2,3 .840", .640", .550" HIGH 1 ANTIROTATION, .840", .640", .550" HIGH 2,3 * OPTION CODE *DIM. ‘A’ * S actuator standard when ordered with C, W-W5, Z & Z3 terminations. Caps are available separately, see page G-16. M actuator standard when ordered with all terminations except C, W-W5, Z & Z3. Caps are available separately, see page G-16. P1 P3 FLATTED WITH ANTIROTATION, .840" HIGH 2,3 DIM ‘A’ L .840 (21,34) L1, L1P .640 (16,26) L2, L2P .550 (13,97) Caps are available separately, see page G-16. P4 FLATTED WITH ANTIROTATION, .450" HIGH 2,3 FLATTED WITH ANTIROTATION, .250" HIGH 2,3 * * * Dress nut part number 709901201 supplied standard with threaded bushing. (Part number 709903201 with metric threaded bushings.) T TP T1 T1P .675 (17,15) HIGH 1,2 ANTIROTATION, .675 (17,15) HIGH, 15/32 BUSHING 1,2,3 .687 (17,45) FLATTED, ANTIROTATION, .610" HIGH, 15/32 BUSHING 1,2,3 ANTIROTATION, .475 (12,07) HIGH, 15/32 BUSHING 1,2,3 15/32-32 UNS-2A .475 (12,07) 15/32-32 UNS-2A T2P .475 (12,07) HIGH 1,2 15/32-32 UNS-2A .448 (11,38) Bushing option code not required unless CW splashproof bushing ordered. TP & T1P actuators not available with CW splashproof bushing. All TXX actuators not available on single pole models with A-A4, AW1-AW4 terminations. Toggle G 1 L, L1, L2, M, S & TXX actuators not available with Y1 bushing. OPTION CODE 2 L1P, L2P, MP, P1, P3, P4, SP & TXX actuators not available with D8 & H4 bushing. NONE 3 Antirotation: Provides anti-‘push-in’ feature on actuator. * Add .070 (1,78) for D, D8 & D9 bushings, subtract .020 (0,51) for H3 bushing. Bushing option code not required. T2P actuator not available with CW splashproof bushing or single pole models with A-A4, AW1-AW4 terminations. ACTUATOR FINISH NOTE: Black hardware is supplied when either black actuators or bushings are specified. For additional hardware, see Section O. BRIGHT CHROME-With Nickel Plated Bushing 2 BLACK S SATIN CHROME Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–6 www.ck-components.com 7000 Series Miniature Toggle Switches ACTUATOR FINISH/COLOR ACTUATOR ACTUATOR K2 K9 K12 LOCKING LEVER, .704" HIGH (threaded) LOCKING LEVER, .732" HIGH (threaded) K19 LOCKING LEVER, .704" HIGH (unthreaded) LOCKING LEVER, .732" HIGH (unthreaded) OPTION CODE ACTUATOR CAP FINISH NONE NATURAL ALUMINUM–With Nickle Plated Bushing 2 BLACK ANODIZED ALUMINUM 3 RED ANODIZED ALUMINUM 7 BLUE ANODIZED ALUMINUM Replaces K1, K18 Replaces K, K8 Locking Positions NOTE: To prevent accidental actuation, toggle must be lifted before being actuated. When released, toggle will lock in place. Overtightening mounting nut may cause actuator to bind. Locking levers supplied with bushing shown. –01 Models 2 Position lock L40 –03 & –11 Models 3 Position lock –05, –09 & –15 Models 1 Position lock LEVER HANDLE WITHOUT CAP –07 & –13 Models 2 Position lock L41 L42 PLASTIC LEVER HANDLE WITH ANTIROTATION AND CAP, P/N 4810 No color choice required L3 Bushing option code not required unless CW splashproof bushing ordered. –08 Models 1 Position lock PLASTIC LEVER HANDLE WITH ANTIROTATION AND CAP, P/N 4811 Finish: Matte (L41 & L42). PLASTIC .940” HIGH Gloss Plastic * Chrome Finish OPTION CODE PLASTIC ACTUATOR COLORS NONE No Actuator Color (L40 option) 2 BLACK 3 RED G NOTE: Lever handle for L41 & L42 actuators supplied, but not installed. For interchangeability, order L40 actuator option and lever handles separately, see page G-16. L4X actuators not available with H4, Y1, Y4 bushings. Antirotation: Provides anti-‘push-in’ feature on actuator. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–7 www.ck-components.com Toggle * Add .070 (1,78) for D, D8 & D9 bushings, subtract .020 (0,51) for H3 bushing. 7000 Series Miniature Toggle Switches BUSHING FINISH BUSHING BUSHING Y Y9 .350" HIGH, THREADED, KEYWAY NONE NO BUSHING D D8 .350" HIGH, UNTHREADED, KEYWAY H .280" HIGH, THREADED, KEYWAY D9 .296" HIGH, FLAT THREADED, HIGH TORQUE 1,2 H3 .315" HIGH, KEYWAY THREADED, HIGH TORQUE 1,2 .280" HIGH, UNTHREADED, FLAT 3 .280" HIGH, UNTHREADED, KEYWAY No bushing choice required with KXX, TXX actuators. (exception: Specify CW if splashproof bushing desired). D8 1/4-40 UNS-2A D, D9 1/4-40 UNS-2A 1/4-40 UNS-2A 1/4-40 UNS-2A D9 bushing standard with all terminations except C, W-W5, Z or Z3. Add .070 (1,78) to all actuators lengths with D, D8 & D9 bushings. Y bushing standard with C, W-W5, Z or Z3 terminations. H4 8mm HIGH, KEYWAY, THREADED, METRIC HIGH TORQUE 1,2,3 Y1 .378" HIGH, KEYWAY, THREADED, HIGH TORQUE 1,2,4 Y3 Subtract .020 (0,51) from all actuator lengths for H3 bushing. Y4 8.9mm HIGH, KEYWAY, THREADED, METRIC 1/4-40 UNS-2A CW .378" HIGH, FLAT, THREADED, HIGH TORQUE 1,2,5 1/4-40 UNS-2A THREADED, SPLASHPROOF 1,2 For T & T1 actuators. For actuators other than T & T1. OPTION CODE NONE 2 15/32-32 UNS-2A 1/4-40 UNS-2A BUSHING FINISH NICKEL on all bushings except ‘D8’ satin chrome. BLACK 1 Will withstand 12 in.-lbs. of torque with no distortion. 2 CW. H, H3, H4, Y1 & Y4 bushings not available on single pole models with A4 terminations. 3 D8 & H4 bushings available only with L, L1, L2, M & S actuators. 4 Y1 bushing available only with LXP, MP, PX & SP actuators. IP67 Degree of protection, totally protected against dust, full-scale voltage protection, temporary immersion. Internal actuator seal standard. External bushing seal washer available separately, order from: APM Hexseal Englewood, N. J. Part Number: 60225 5 Y4 bushing not available with L4X actuators. IP67 Degree of protection, totally protected against dust, full-scale voltage protection, temporary immersion. Internal actuator seal and external bushing seal washer standard. NOTE: Two mounting nuts, locking ring and lockwasher supplied standard with threaded bushings. Black hardware is supplied when either black bushings or actuators are specified. Optional mounting nut and locking ring styles and finishes available, see Section O. PANEL MOUNTING 1/4 INCH BUSHING METRIC BUSHING 15/32 INCH BUSHING Toggle G Without locking ring. With standard locking ring. With small locking ring. Without locking ring. With locking ring. Without locking ring. With standard locking ring. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–8 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS Z C SOLDER LUG PC THRU-HOLE PC MOUNTING .030 (0,76) Thk. SPDT thru 4PDT Z3 SPDT thru 4PDT Not available with P, R or S contact materials. W, W1, W3, W4, W5 QUICK CONNECT Dim 'A' .030 (0,76) Thk. WIRE WRAP OPTION CODE DIM ‘A’ W .750 (19,05) W1 .964 (24,48) W3 .425 (10,80) W4 1.062 (26,97) W5 1.305 (33,15) .030 (0,76) Thk. SPDT thru 4PDT A Not available with P, R or S contact materials. Mating quick connector available, order part number 530100000, page G-16. SPDT thru 4PDT RIGHT ANGLE, PC THRU-HOLE Actuator Shown In Pos. 1 SECTION A-A 7101MD9ABE Horizontal Actuation Terminal Nos. For Reference Only SPDT Switch support with CW, H, H3, H4, Y1, Y4 bushings and KXX actuators. Part No. Shown: 7101MHABE A3 RIGHT ANGLE, SNAP-IN, PC THRU-HOLE AW1, AW4 RIGHT ANGLE, EXTENDED, PC THRU-HOLE Dim 'A' PC MOUNTING OPTION CODE DIM ‘A’ AW1 .72 (18,3) AW4 .83 (21,1) G Toggle Not available with I seal option. Terminal bend radii and lead-in manufacturing option. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–9 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS A RIGHT ANGLE, PC THRU-HOLE 7201MD9ABE Horizontal Actuation Actuator Shown In Pos. 1 Terminals & Support SECTION A-A DPDT A3 AW1, AW4 RIGHT ANGLE, SNAP-IN, PC THRU-HOLE RIGHT ANGLE, EXTENDED, PC THRU-HOLE PC MOUNTING DIM 'A' OPTION CODE DIM ‘A’ AW1 .40 (10,2) AW4 .50 (12,7) .33 (8,4) Not available with I seal option. Terminal bend radii and lead-in manufacturing option. A RIGHT ANGLE, PC THRU-HOLE 7301MD9ABE Horizontal Actuation 3PDT AW4 Actuator Shown In Pos. 1 Terminals & Support SECTION A-A RIGHT ANGLE, EXTENDED, PC THRU-HOLE PC MOUNTING .18 (4,6) Toggle G .33 TYP. (8,4) Not available with I seal option. Terminal bend radii and lead-in manufacturing option. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–10 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS A2 RIGHT ANGLE, PC THRU-HOLE, .156" PITCH PC MOUNTING 7101MHA2BE Horizontal Actuation Terminals & Support Actuator Shown In Pos. 1 SPDT Switch support with CW, H, H3, H4, Y1, Y4 bushings and KXX actuators. Not available with TXX actuators and I seal. Terminal bend radii and lead-in manufacturing option. A4 Part No. Shown: 7101MHA2BE RIGHT ANGLE, PC THRU-HOLE .156" PITCH PC MOUNTING 7101MD9A4BE Horizontal Actuation SPDT Actuator Shown In Pos. 1 Not available with KXX & TXX actuators, CW, H, H3, H4, Y1 & Y4 bushings, and I seal. Terminal bend radii and lead-in manufacturing option. AV2 NOTE: The A4 option is available with any contact material and can be UL recognized and CSA certified. The PC pattern must clear switch support legs. VERTICAL RIGHT ANGLE, PC THRU-HOLE, .150" PITCH PC MOUNTING 7101MD9AV2BE Horizontal Actuation Actuator Shown In Pos. 1 SPDT SECTION A-A Not available with I seal option. Terminal bend radii and lead-in manufacturing option. AV2 PC MOUNTING VERTICAL RIGHT ANGLE, PC THRU-HOLE, .150" PITCH 7201MD9AV2BE Vertical Actuation DPDT G Toggle SECTION A-A Actuator Shown In Pos. 1 Not available with I seal option. Terminal bend radii and lead-in manufacturing option. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–11 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS AV2 VERTICAL RIGHT ANGLE, PC THRU-HOLE, .150" PITCH 7301MD9AV2BE Vertical Actuation PC MOUNTING Actuator Shown In Pos. 1 SECTION A-A 3PDT Not available with I seal option. Terminal bend radii and lead-in manufacturing option. AV2 VERTICAL RIGHT ANGLE, PC THRU-HOLE, .150" PITCH PC MOUNTING 7401MD9AV2BE Vertical Actuation 4PDT Actuator Shown In Pos. 1 SECTION A-A Not available with I seal option. Terminal bend radii and lead-in manufacturing option. V2, V6, V7, V8 V21, V71, V81 VERTICAL MOUNT, V-BRACKET VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim ‘A’ 7101MD9__BE Snap-In SPDT Actuator Shown In Pos. 1 Not available with I seal option. DIM ‘A’ V2, V21 .555 (14,10) V6 .460 (11,68) V7, V71 .630 (16,00) V8, V81 .953 (24,21) Toggle G OPTION CODE Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–12 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS V2, V6, V7, V8 PC MOUNTING VERTICAL MOUNT, V-BRACKET V21, V61, V71, V81 VERTICAL MOUNT, V-BRACKET, SNAP-IN Dim ‘A’ Snap-In Actuator Shown In Pos. 1 OPTION CODE DIM ‘A’ 7201MD9__BE V2, V21 .555 (14,10) DPDT V6, V61 .460 (11,68) V7, V71 .630 (16,00) V8, V81 .953 (24,21) Not available with I seal option. V2, V7, V8 VERTICAL MOUNT, V-BRACKET V21, V71, V81 VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim ‘A’ 7301MD9__BE 3PDT Snap-In Actuator Shown In Pos. 1 OPTION CODE DIM ‘A’ V2, V21 .555 (14,10) V7, V71 .630 (16,00) V8, V81 .953 (24,21) Not available with I seal option. V2, V7, V8 VERTICAL MOUNT, V-BRACKET V21, V71, V81 VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim ‘A’ Snap-In OPTION CODE DIM ‘A’ V2, V21 .555 (14,10) V7, V71 .630 (16,00) V8, V81 .953 (24,21) 7401MD9__BE 4PDT Not available with I seal option. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–13 www.ck-components.com Toggle Actuator Shown In Pos. 1 G 7000 Series Miniature Toggle Switches TERMINATIONS V3, V4, V9 V31, V41 VERTICAL MOUNT, V-BRACKET PC MOUNTING VERTICAL MOUNT, V-BRACKET, SNAP-IN Dim ‘A’ Snap-In 7101MD9__BE SPDT OPTION CODE DIM ‘A’ V3, V31 .460 (11,68) V4, V41 .630 (16,00) V9 1.150 (29,21) Actuator Shown In Pos. 1 Not available with I seal option. V3, V4, V9 V31, V41 VERTICAL MOUNT, V-BRACKET VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim ‘A’ 7201MD9__BE DPDT Snap-In Actuator Shown In Pos. 1 OPTION CODE DIM ‘A’ V3, V31 .460 (11,68) V4, V41 .630 (16,00) V9 1.150 (29,21) Not available with I seal option. V4, V9 VERTICAL MOUNT, V-BRACKET V41 VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim ‘A’ 7301MD9__BE 3PDT Toggle G OPTION CODE Snap-In Actuator Shown In Pos. 1 DIM ‘A’ V4, V41 .630 (16,00) V9 1.150 (29,21) Not available with I seal option. Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–14 www.ck-components.com 7000 Series Miniature Toggle Switches TERMINATIONS V4, V9 VERTICAL MOUNT, V-BRACKET V41 VERTICAL MOUNT, V-BRACKET, SNAP-IN PC MOUNTING Dim 'A' 7401MD9__BE 4PDT Snap-In OPTION CODE Actuator Shown In Pos. 1 Not available with I seal option. DIM ‘A’ V4, V41 .630 (16,00) V9 1.150 (29,21) CONTACT MATERIAL OPTION CODE CONTACT MATERIAL B GOLD 1 Q SILVER 4,5 S R GOLD 1 MATTE-TIN 6 P G TERMINAL PLATING RATINGS LOW LEVEL/ 0.4 VA MAX. @ 20 V AC OR DC MAX. DRY CIRCUIT SILVER 5 MATTE-TIN 6 POWER 5 AMPS @ 120 V AC OR 28 V DC; 2 AMPS @ 250 V AC. GOLD OVER GOLD 3 LOW LEVEL/DRY SILVER 2,3 MATTE-TIN 6 CIRCUIT OR POWER 0.4 VA MAX @ 20 V AC OR DC MAX. OR 5 AMPS @ 120 V AC OR 28 V DC; 2 AMPS @ 250 V AC. * Note: See Technical Data section of this catalog for RoHS compliant and compatible definitions and specifications. 1 CONTACTS & TERMINALS: Copper alloy, with gold plate over nickel plate. NOTE: Any models supplied with P, S, R, Q, B or G contact material are RoHS compliant. 2 END CONTACTS: Coin silver, with gold plate over nickel plate. U11-U415 model numbers S, R, M or Q contact material. 3 CENTER CONTACTS & ALL TERMINALS: Copper alloy, with gold plate over nickel plate. with all options when ordered with G, L, B contact material standard with all terminations except C, Z & Z3. 4 END CONTACTS: Coin silver, silver plated. Q contact material standard with C, Z & Z3 terminations. 5 CENTER CONTACT & ALL TERMINALS: Copper alloy, silver plated. P, S & R contact materials not available with Z & Z3 terminations. 6 TERMINALS: Copper alloy, with matte tin alloy nickel plate. K, L and M options represent Non RoHS tin lead product and are not recommended for new designs. For additional information please contact Customer Service. G Toggle Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–15 www.ck-components.com 7000 Series Miniature Toggle Switches SEAL E I EPOXY SEAL EPOXY POTTED BASE Dim. 'A' Compatible with “bottom-wash” PC board cleaning methods. NO. POLES DIM ‘A’ SP .410 (10,41) DP .440 (11,18) 3P .505 (12,83) 4P .505 (12,83) Available with C, W-W5, Z & Z3 terminations only. AVAILABLE HARDWARE Cap Cap .383 (9,73) PART NO. PART NO. PART NO. 896801000 WHITE 896802000 BLACK 896803000 RED 763701000 WHITE 763702000 BLACK 763703000 RED 706201000 WHITE 706202000 BLACK 706203000 RED Material: Polyethylene Finish: Matte Material: Vinyl Finish: Matte Material: Vinyl Finish: Matte L41 Lever handle L42 Lever handle Fits Z3 Termination female connector .477 (12,12) .777 (19,74) PART NO. PART NO. PART NO. 481001000 WHITE 481002263 BLACK 481003000 RED 481101000 WHITE 481102263 BLACK 481103000 RED 530100000 Material: Nylon Finish: Matte Material: Nylon Finish: Matte 759D02000 Sealing Boot 703D02000 Sealing Boot ø 12 [0.472] 16 [0.630] NOTE: For use with T and TP style actuators 11 [0.433] 6 [0.250] ø 15.9 [0.626] 0.8 [0.031] 24.0 3.0 Inner thread 15/32-32 NS-2A 1] .72 2 [0 3 18. ø 16.34 NOTE: For use with S actuator style when combined with D, H, H3, Y, and Y4 bushings ø 2 [0.079] ø 8.4 0.8 G Other colors available, consult Customer Service Center. 704D02000 Sealing Boot 16.7 16.7±1.0 Ø 13.3 NOTE: Additional nuts, locking rings and lockwashers available separately, see Section O. Available in loose pieces. 1/4-40 uns-2A nut Toggle .312 (7,92) .687 (17,45) 4 [0.157] Cap 15/32-32, NS-2A NOTE: For use with T, TP and T2P style actuators Dimensions are shown: Inch (mm) Specifications and dimensions subject to change G–16 www.ck-components.com
637NH/2
1. 物料型号:文档中提到了7000系列微型拨动开关,包括多种型号,例如7101、7103、7105等,具体型号取决于所需的开关功能。
2. 器件简介:7000系列微型拨动开关适用于电信、仪表和医疗设备等应用场景,具有多极和多位选项,以及多种操作器和终止选项。它们还兼容底洗清洁的环氧终端密封,并且有符合RoHS标准的型号。
3. 引脚分配:文档中详细列出了不同型号的开关的引脚分配,例如7101型号的SPST(单极单掷)功能,以及7201型号的DPST(双极单掷)功能等。
4. 参数特性:包括了绝缘强度、工作温度、焊接性、接触评级、电气寿命、接触电阻和绝缘电阻等。例如,B接触材料的接触电阻最大为0.4 VA,Q接触材料的电流评级为5安培在120伏交流或28伏直流下,或2安培在250伏交流下。
5. 功能详解:文档提供了各种开关功能的详细描述,如SPST、DPST、3PDT(三极双掷)和4PDT(四极双掷)等。
6. 应用信息:开关适用于需要多种操作选项和环境适应性的应用,如电信设备、医疗设备和工业控制。
7. 封装信息:文档提供了关于开关的物理尺寸和安装选项的详细信息,包括面板安装、PC通孔、环氧密封等。
637NH/2 价格&库存
很抱歉,暂时无法提供与“637NH/2”相匹配的价格&库存,您可以联系我们找货
637NH/2
  • 100+51.35701100+6.64440
637NH/2
  • 25+95.3870525+12.34086
  • 50+75.6355450+9.78548
库存:100
