High Temperature Resistant Silicone Wire (18AWG
0.75mm2 1m Red & Black)
SKU:FIT0585
INTRODUCTION
This product is high temperature resistant silicone rubber copper wire with 18AWG and
0.75mm2. It is made of fine tin-plated copper material and not easily oxidized. It adopts the
process of mutual twisting , which reduces the signal interference and improves the conductive
property. The allowable load voltage is AC600V/DC3KV and the load current reaches 22A. The
insulating layer is a silica gel material with excellent performance. The insulating layer is thin
but not easy to be broke down. It has elasticity, toughness and acid and alkali resistance.
Normally, it can be used at temperatures from -60 ° C to +200 ° C, can be used for robots ,
ESC, motors, robot arms, aeromodelling, car models, and ship models which require high wire
performance.
NOTE:
The power supply should not exceed the rated voltage to avoid affecting the wire life.
It should be avoided using over the temperature range of ‐60 ° C ~ +200 ° C
FEATURES
High temperature resistant, low temperature resistant , not easy to breakdown, high voltage and high
current resistant
SPECIFICATION
Rated voltage: AC600V/DC3KV
Allowable current: 22A
Temperature range: ‐60 ° C ~ +200 ° C
Model: 18AWG 0.75mm2
Inner core material: 0.08mm (diameter) tinned copper wire
Insulation material: silica gel
SHIPPING LIST
High Temperature Resistant Silicone Wire (18AWG 0.75mm2 Red 1m) x1
High Temperature Resistant Silicone Wire (18AWG 0.75mm2 Black 1m) x1
https://www.dfrobot.com/product‐1761.html 8‐7‐18
很抱歉,暂时无法提供与“FIT0585”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.282471+3.67663
