GDCX-PN-88K-50
GDCX-PN-88K-50
    KYCON
    插件
    MODJACK PERPEND 8P8C BLK, CAT 5
GDCX-PN-88K-50 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GDCX-PA-44 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GDCX-P Series Vertical Through Hole Product Features Available in 4, 6, and 8 Position Housings Vertical Mount Through Hole Contacts CSA/NRTL Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, UL 94V-0 Rated, Black Color Contact Material Phosphor Bronze Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS, 60Hz Contact Resistance 20 milliohms Max. Voltage Rating 125V DC Current Rating 1.5A Operating Temperature -40°C to +85°C Durability Rating 500 Mating Cycles Min. A Series Panel Stop Option 44 Shield Option Positions & Contacts Keyed Option Plating Option Series GDCX-P - Perpendicular Through Hole Modular Jacks Panel Stops A - With Panel Stops N - Without Panel Stops Shield Options Blank - Non-Shielded S - Shielded (Available Only with 8P8C Option) Number of Positions / Contacts 44 - 4 Postions / 4 Contacts 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts 88 - 8 Positions / 8 Contacts Keyed Option Blank - Not Keyed K - Keyed (Only for 8P8C) Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Other Options GDCX-Px-88 Dimensions in mm 17.5 (optional panel stops) 15.26±0.25 8 1 9.0 ref. (optional panel stops) 3.4 ref. Optional panel stops 16.6 16.29±0.25 15.78±0.25 3.0 (optional panel stops) 3.25±0.25 Electrical Characteristics GDCX-P 6.35 ref. 6.35 2.54 1.27 typ. Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0116
GDCX-PN-88K-50 价格&库存
很抱歉,暂时无法提供与“GDCX-PN-88K-50”相匹配的价格&库存,您可以联系我们找货
