COM-14968
COM-14968
    SPARKFUNELECTRONICS
    SPARKFUN GATOR:CONTROL PROTOSNAP
COM-14968 数据手册
      SparkFun gator:control ProtoSnap COM-14968 The SparkFun gator:control ProtoSnap is one of a series of gator-clippable accessories called gator:boards that have been created to directly interface with the micro:bit or to other micro controllers! The gator:control ProtoSnap offers a handful of ways to interact with projects you create using only gator-clip cables. Each little board on this ProtoSnap can be kept as a whole while on the board or broken apart for individual use! The gator:control ProtoSnap contains four boards in the main assembly including two buttons, an on/off slide switch and a reed switch, which is activated by a magnet. A button or switch is something that can act as both an open and closed circuit, and either one makes a great addition to your project if you want to add some form of control to your project. You can use buttons or switches as part of a circuit you’re building, or as a digital input for your micro:bit. The pads on either side of the button or switch will be connected while attached to the ProtoSnap. Snapping the board apart can be easily done by twisting each of the control boards side to side until it pops out. This will need to be done if you want to use any of the boards on their own. Keep in mind that the buttons will only close the circuit while it is pressed down; releasing the button opens the circuit. Included on the ProtoSnap    2x gator:button Board 1x gator:switch Board 1x gator:reed Board                                                         https://www.sparkfun.com/products/14968 10‐23‐18
COM-14968 价格&库存
很抱歉,暂时无法提供与“COM-14968”相匹配的价格&库存,您可以联系我们找货
