PT2010FK-7W0R51L
PT2010FK-7W0R51L
    YAGEO(国巨)
    RES 0.51 OHM 1% 1W 2010
PT2010FK-7W0R51L 数据手册
Anti-Sulfurated Thick Film Chip Resistors ERJ S type (Au-based inner electrode type) ERJ S02, S03, S06, S08, S14 series ERJ S12, S1D, S1T series ERJ U type (Ag-Pd-based inner electrode type) ERJ U0X, U01, U02, U03, U06, U08, U14 series ERJ U12, U1D, U1T, U6S, U6Q series Features ● High resistance to sulfurization achieved by adopting an Au-based inner electrode (Series ERJS) and Ag-Pd-based inner electrode (Series ERJU ) : Metal glaze thick film resistive element and three layers of electrodes ● High reliability ● Suitable for both reflow and flow soldering : ERJU6S, U6Q series : 0.1 Ω to 1 Ω ● Low resistance type : IEC 60115-8, JIS C 5201-8, JEITA RC-2134C ● Reference standard ● AEC-Q200 compliant (except ERJU0X, ERJU01) ● RoHS compliant ■ As for packaging methods, land pattern, soldering conditions and safety precautions, please see data files. Explanation of part numbers Note : Please check the "Ratings" for the presence/absence of part numbers for combinations of the symbols below. ● ERJS02 to ERJS1T,ERJU0X to ERJU1T series 1 2 3 4 5 6 7 8 9 10 E R J S 0 6 F 1 0 0 Product code Thick film chip resistors Size, Power rating Code inch U0X 01005 0.031 W 0201 0.05 W 0402 0.1 W 0603 0.1 W 0805 0.125 W U01 S02 U02 S03 U03 S06 U06 Code Power rating S08 U08 S14 U14 S12 U12 S1D U1D S1T U1T inch Power rating 1206 0.25 W 1210 0.5 W 1812 0.75 W 2010 0.75 W 2512 1W Resistance tolerance Code Tolerance D ±0.5 % F ±1 % J ±5 % 0 Jumper 11 12 V 2 Packaging methods Packaging Part No. Code Resistance value The first two or three digits are significant figures of resistance and the third or fourth one denotes number of zeros following. Jumper is expressed by R00. Three digit type (±5 %), four digit type (±0.5 %, ±1 %) (Ex.) 222 : 2.2 kΩ, 1002 : 10 kΩ Y Pressed carrier taping 2 mm pitch, 20,000 pcs ERJU0X C Pressed carrier taping 2 mm pitch, 15,000 pcs ERJU01 X Punched carrier taping 2 mm pitch, 10,000 pcs ERJS02, ERJU02 V Punched carrier taping 4 mm pitch, 5,000 pcs U Embossed carrier taping 4 mm pitch, 5,000 pcs Embossed carrier taping 4 mm pitch, 4,000 pcs ERJS03, ERJU03 ERJS06, ERJU06 ERJS08, ERJU08 ERJS14, ERJU14 ERJS12, ERJU12 ERJS1D, ERJU1D ERJS1T, ERJU1T ● ERJU6S, U6Q series 1 2 3 4 5 6 7 8 9 10 E R J U 6 S J R 2 0 Product code Thick film chip resistors Size, Power rating Code U6 inch 0805 Power rating 0.25 W Resistance value region S Q 0.1 Ω to 0.2 Ω 0.22 Ω to 1 Ω Resistance tolerance Code Tolerance F G ] ±1 % ±2 % ±5 % Resistance value Shown by 3 digits or letters. (Ex.) 11 V Code V Packaging methods Packaging Part No. ERJU6S Punched carrier taping 4 mm pitch, 5,000 pcs ERJU6Q R20 : 0.20 Ω=200 mΩ 1R0 : 1.0 Ω=1000 mΩ Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 1-Sep-20 Anti-Sulfurated Thick Film Chip Resistors Ratings Part No. (inch size) Power rating*1 (70 ℃)(W) ERJU0X (01005) ERJU01 (0201) ERJS02 ERJU02 (0402) ERJS03 ERJU03 (0603) ERJS06 ERJU06 (0805) ERJS08 ERJU08 (1206) ERJS14 ERJU14 (1210) ERJS12 ERJU12 (1812) ERJS1D ERJU1D (2010) ERJS1T ERJU1T (2512) Limiting element Maximum overload voltage (V) voltage (V) *2 0.031 *3 15 30 0.05 25 50 0.1 50 100 0.1 75 150 0.125 150 200 0.25 200 400 0.5 200 400 0.75 200 500 0.75 200 500 1.0 200 500 Resistance tolerance (%) ±1 Resistance range (Ω) 10 to 1 M AECCategory temperature Q200 range (℃) Grade T.C.R. (×10-6/K) (E24, E96) ±5 1 to 1 M (E24) ±1 ±5 ±0.5, ±1 10 to 1 M (E24, E96) 1 to 1 M (E24) 1 to 1 M (E24, E96) ±5 1 to 3.3 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) ±0.5, ±1 1 to 1 M (E24, E96) ±5 1 to 10 M (E24) R
PT2010FK-7W0R51L
物料型号: - Panasonic INDUSTRY 提供了多种型号的Anti-Sulfurated Thick Film Chip Resistors,包括ERJ S型和ERJ U型,具体型号如ERJ S02、ERJ U0X等。
器件简介: - 这些电阻器采用Au基内电极(ERJS系列)和Ag-Pd基内电极(ERJU系列),具有高抗硫化性能和高可靠性,适用于回流焊和波峰焊。
引脚分配: - 文档中没有提供具体的引脚分配图,但提到了不同的封装尺寸,如0402、0603、0805、1206等。
参数特性: - 电阻值范围从0.1 Ω到1 Ω,具有不同的公差等级,如±0.5%、±1%、±5%。 - 温度系数(T.C.R.)在不同电阻值下有不同的规格。 - 符合AEC-Q200标准,RoHS合规。
功能详解: - 文档提供了电阻的详细规格,包括功率等级、电阻公差、尺寸、额定工作电压等。
应用信息: - 适用于一般电子设备,但对于特殊应用,如可能直接威胁人的生命或造成身体伤害的设备,需要与公司讨论适合的规格。
封装信息: - 提供了不同封装类型的电阻,包括厚度、尺寸、质量等信息。
PT2010FK-7W0R51L 价格&库存
很抱歉,暂时无法提供与“PT2010FK-7W0R51L”相匹配的价格&库存,您可以联系我们找货
PT2010FK-7W0R51L
  • 4000+0.99147
库存:3500
PT2010FK-7W0R51L
    PT2010FK-7W0R51L
      • 1+5.70590
      • 100+4.23440
      • 1000+3.02410
      • 2000+2.24490
      • 4000+1.59910
      库存:4070
