SA-7011TA
SA-7011TA
    NIDEC(尼得科)
    SMD
    DIP 开关 BCD 10 位置 表面贴装,直角 用于工具旋转 触动器 100mA 5VDC
SA-7011TA 数据手册
ROTARY CODED SWITCHES (SMD) RoHS compliant SA-7000 INTERNAL STRUCTURE ① ④ ② ⑧ ⑨ ⑤ Part name ■ FEATURES ● RoHS compliant ● Low profile of 3.0 mm ● Wide variety (top or side setting, 10 or 16 positions, J-hook, gull wing or through hole pins) to choose from ● Easy to recognize ● Low-profile side setting type with support terminals is available ● Resin material is UL Recognized 94V-0 ⑥ ③ ⑦ Material ① Marking cover ② Cover ③ “O” ring ④ Rotor ⑤ Spacer ⑥ Slider contact ⑦ Fixed contact ⑧ Housing ⑨ Terminal pin Stainless steel (SUS 304) Silicone rubber Polyphenylenesulfide Stainless steel (SUS 304) Copper alloy, Gold-plated Polyphenylenesulfide Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION S A - 7 0 1 0 T A Series name Shape of terminal Shape of rotor A:J-hook B:Gull wing C:Through hole pins (Only gull wing availabe for Low-profile side setting type) 0:Without knob (Minus slot) 1:With knob 2:Without knob (Cross slot) Code format 1:10 3:10 5:16 7:16 positions, positions, positions, positions, real code complementary code real code complementary code Form of packaging T:Taping (Reel) Blank:Bulk in plastic bag (Only taping availabe for Low-profile side setting type) Setting position 0:Top setting 1:Side setting 2:Low-profile side setting & forward support terminal type 3:Low-profile side setting & sideling support terminal type ※ Please refer to the LIST OF PART NUMBERS when placing orders. SA-7000 ROTARY CODED SWITCHES (SMD) ■ LIST OF PART NUMBERS Setting position Shape of rotor Shape of terminal Binary coded decimal Taping Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag Taping A(J-hook) Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag Taping A(J-hook) Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag Taping A(J-hook) Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag Taping A(J-hook) Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag Taping A(J-hook) Plastic bag Taping B (Gull wing) Plastic bag Taping C (Through hole pins) Plastic bag A(J-hook) Minus slot Top setting With knob Cross slot Minus slot Side setting With knob Cross slot Minus slot Low-profile side setting & forward With knob support terminal type Cross slot Minus slot Low-profile side setting & sideling With knob support terminal type Cross slot B (Gull wing) Binary coded hexadecimal Form of packaging Taping   : Not manufactured ※ Verify the above part numbers when placing orders. Taping version can be supplied only in reel unit. Packaging quantity Real code Complementary code Real code Complementary code SA-7010TA SA-7010A SA-7010TB SA-7010B SA-7030TA SA-7030A SA-7030TB SA-7030B SA-7050TA SA-7050A SA-7050TB SA-7050B SA-7070TA SA-7070A SA-7070TB SA-7070B 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7010C SA-7110TA SA-7110A SA-7110TB SA-7110B SA-7030C SA-7130TA SA-7130A SA-7130TB SA-7130B SA-7050C SA-7150TA SA-7150A SA-7150TB SA-7150 SA-7070C SA-7170TA SA-7170A SA-7170TB SA-7170B 50 pcs./pack 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7110C SA-7210TA SA-7210A SA-7210TB SA-7210B SA-7130C SA-7230TA SA-7230A SA-7230TB SA-7230B SA-7150C SA-7250TA SA-7250A SA-7250TB SA-7250B SA-7270C SA-7071TA SA-7071A SA-7071TB SA-7071B 50 pcs./pack 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7210C SA-7011TA SA-7011A SA-7011TB SA-7011B SA-7230C SA-7031TA SA-7031A SA-7031TB SA-7031B SA-7250C SA-7051TA SA-7051A SA-7051TB SA-7051B SA-7270C SA-7071TA SA-7071A SA-7071TB SA-7071B 50 pcs./pack 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7011C SA-7111TA SA-7111A SA-7111TB SA-7111B SA-7031C SA-7131TA SA-7131A SA-7131TB SA-7131B SA-7051C SA-7151TA SA-7151A SA-7151TB SA-7151B SA-7071C SA-7171TA SA-7171A SA-7171TB SA-7171B 50 pcs./pack 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7111C SA-7211TA SA-7211A SA-7211TB SA-7211B SA-7131C SA-7231TA SA-7231A SA-7231TB SA-7231B SA-7151C SA-7251TA SA-7251A SA-7251TB SA-7251B SA-7171C SA-7271TA SA-7271A SA-7271TB SA-7271B 50 pcs./pack 500 pcs./reel 50 pcs./pack 500 pcs./reel 50 pcs./pack SA-7211C SA-7231C SA-7251C SA-7271C 50 pcs./pack SA-7012TB SA-7032TB SA-7052TB SA-7072TB 500 pcs./reel SA-7112TB SA-7132TB SA-7152TB SA-7172TB 500 pcs./reel SA-7212TB SA-7232TB SA-7252TB SA-7272TB 500 pcs./reel SA-7013TB SA-7033TB SA-7053TB SA-7073TB 500 pcs./reel SA-7113TB SA-7133TB SA-7153TB SA-7173TB 500 pcs./reel SA-7213TB SA-7233TB SA-7253TB SA-7273TB 500 pcs./reel SA-7000 ROTARY CODED SWITCHES (SMD) ■ STANDARD SPECIFICATIONS Circuit type ■ ELECTRICAL CHARACTERISTICS BCD (Real code, complementary code) BCH (Real code, complementary code) Contact rating Non-switching Switching Minimum Operating temp. range − 40 ~ 85 °C Storage temp. range Sealing Net weight Non-washable Approx. 0.32 g (Top setting type without knob) Approx. 0.34 g (Top setting type with knob) Approx. 0.69 g (Side setting type without knob) Approx. 0.71 g (Side setting type with knob) Approx. 0.42 g (Low-profile side setting type without knob) ■ MECHANICAL CHARACTERISTICS No. of positions Adjustment torque Contact resistance 100 mΩ maximum Insulation resistance 100 MΩ (DC100 V) minimum Dielectric strength AC250 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS 10 (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each Vibration 10 mN·m {102 gf·cm} maximum Stepping angle 36° (10 positions) Solderability 245 ± 3 °C, 2 ~ 3 s DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μA 490 m/s2, 11 ms 6 directions for 3 times each Shock Load life 10000 steps minimum, DC5 V, 100 mA Humidity (Steady state) 40 °C, Relative humidity 90 ~ 95 %, 240 h High temp. exposure 85 °C, 96 h Manual soldering: 350 ± 10 °C, 3 ~ 4 s Low temp. exposure −40 °C, 96 h Shear (adhesion) 5 N {0.51 kgf} 10 s Thermal shock Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Reflow:255 °C (Peak temperature) Please refer to the profile below) Pull-off strength 5 N {0.51 kgf} 10 s Stop strength (With knob only) 5 N {0.51 kgf} 10s −40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles 〈Reflow profile for soldering heat evaluation〉 (℃) 250 { } : Reference only Temperature Soldering heat 200 150 100 50 Peak : 250 0 ℃ +5 Over 230℃ 180℃ 150℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Soldering Zone リフロー回数:2回 Reflow : two times maximum SA-7000 ROTARY CODED SWITCHES (SMD) ■ CODE FORMAT ● …Contact closed 16 positions No. of positions 10 positions Position 0 1 2 3 4 5 6 7 8 9 A B C D E F 8 4 2 1 8 4 2 1 Real code Code Complementary code ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● B type ● A type (Unit: mm) ● B type 2.3 2.3 1.9 4.3 2.3 6 – 1.2 62.54 – 1.2 2.54 2.54 2.54 3 2.54 2.54 2.54 6 – 1.6 2.54 6 – 1.62.54 2.54 2.54 2.3 1.9 1.9 3 3.5 6 – 1.6 6 – 1.6 2.54 2.54 2.54 6 – 1.2 6 –2.54 1.2 2.54 1.27 N (N = 1~4) = 5.08 0.761.27 N (N = 1~4) = 5.08 Note) The zero point is the center 0.76 of mounting. 1.27 N (N = 1~4) = 5.08 0.761.27 N (N = 1~4) = 5.08 0.76 1.9 1.9 1.9 1.9 6.6 5 6.6 3.5 5 3.5 0 0 4.3 0 4.3 0 6 0 4.3 0 6 0 0 3.5 3 3 1.9 3.5 3 3.5 3 ● A type 1.6 1.6 1.6 1.6 6 2 2 6 2 10.6 10.6 2 ■ SIZE OF P.C.B. PROCESSING 6 – φ 0.8 Operating face ▼ ● C type 6 – φ 0.8 2.54 2.54 5.08 7.62 ● C type 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7010A (Real code) ● SA-7030A (Complementary code) ● SA-7050A (Real code) ● SA-7070A (Complementary code) Production date code Production date code 6 – 0.8 t = 0.15 ② ① Ⓒ 4.7 7.5 7.2 7.5 4.7 78 45 23 6 23 CD AB E F01 901 7.2 6 – 0.8 t = 0.15 ② ① Ⓒ 456 789 ④ ⑧ Ⓒ 7.2 ④ ⑧ Ⓒ 3 0.6 W × 2.6 L × 0.8 D 2.54 7.2 2.54 Marking appears only with complementary code 3 0.6 W × 2.6 L × 0. 8D 2.54 Marking appears only with complementary code ● SA-7050B (Real code) ● SA-7070B (Complementary code) Production date code Production date code ② ① Ⓒ ② ① Ⓒ Marking appears only with complementary code 0.6 W × 2.6 L × 0.8 D Production Marking appears only with complementary code 6 – 0.5 t = 0.15 Marking appears only with complementary code Marking appears only with complementary code 6 – 0.5 t = 0.15 ② ① Ⓒ 7.62 7.2 7.62 45 23 6 23 CD AB E F01 901 456 789 ④ ⑧ Ⓒ A 0.5 A矢視図 0.6 W × 2.6 L × 0.8 D A Projection 4±1 2.54 2.54 7.2 1.2 2.9 A 0.5 2.9 A矢視図 0.6 W × 2.6 L × 0.8 D A Projection 4±1 2.54 1.2 78 2.54 date code ② ① Ⓒ 7.2 2.54 ● SA-7050C (Real code) ● SA-7070C (Complementary code) date code 7.2 3 7.2 2.54 0.6 min. 0.6 min. ④ ⑧ Ⓒ 2.54 ● SA-7010C (Real code) ● SA-7030C (Complementary code) ④ ⑧ Ⓒ 9.8 7.2 9.8 78 456 789 3 7.2 Production 45 23 6 ④ ⑧ Ⓒ 0.6 W × 2.6 L × 0.8 D CD AB E F01 23 7.2 901 6 – 0.8 t = 0.15 0.6 min. 0.6 min. ● SA-7010B (Real code) ● SA-7030B (Complementary code) 6 – 0.8 t = 0.15 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7110A (Real code) ● SA-7130A (Complementary code) ● SA-7150A (Real code) ● SA-7170A (Complementary code) Production date code ② ① Ⓒ Production date code 6 – 0.8 t = 0.15 2.5 456 3 3 2.54 2.54 7.2 Marking appears only with complementary code 0.6 min. 2.5 ② ① Ⓒ 6 – 0.8 t = 0.15 2.5 9.8 φ3 7.2 9.8 φ3 45 23 6 CD AB E F01 23 456 7.2 3 3 ④ ⑧ Ⓒ 2.54 Marking appears only with complementary code 0.6 W × 1.2 D Production date code ② ① Ⓒ 2.54 ● SA-7150C (Real code) ● SA-7170C (Complementary code) Production date code Marking appears only with complementary code 6 – 0.5 t = 0.15 2.5 2.54 Marking appears only with complementary code 0.6 W × 1.2 D ● SA-7110C (Real code) ● SA-7130C (Complementary code) 3 3 7.2 2.54 0.6 min. 0.6 min. 789 ④ ⑧ Ⓒ ② ① Ⓒ Marking appears only with complementary code 6 – 0.5 t = 0.15 2.5 φ3 7.2 7.62 φ3 45 23 6 456 789 ④ ⑧ Ⓒ ④ ⑧ Ⓒ A 0.5 2.9 A矢視図 A Projection 4±1 2.54 1.2 3 2.54 7.2 0.6 W × 1.2 D A 0.5 3 2.9 A矢視図 A Projection 4±1 2.54 1.2 23 7.62 F01 901 CD AB E 78 4.7 Production date code 6 – 0.8 t = 0.15 901 78 2.54 ● SA-7150B (Real code) ● SA-7170B (Complementary code) Production date code ② ① Ⓒ 2.54 Marking appears only with complementary code 0.6 W × 1.2 D ● SA-7110B (Real code) ● SA-7130B (Complementary code) 3 3 0.6 min. 0.6 W × 1.2 D 7.2 φ3 789 ④ ⑧ Ⓒ 7.2 7.2 7.5 CD AB E 4.7 7.2 φ3 7.5 78 7.2 45 23 6 23 ④ ⑧ Ⓒ 0.6 W × 1.2 D t = 0.15 2.5 F01 901 7.2 6 – 0.8 ② ① Ⓒ 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7210A (Real code) ● SA-7230A (Complementary code) ● SA-7250A (Real code) ● SA-7270A (Complementary code) Production date code Production date code 6 – 0.8 t = 0.15 ② ① Ⓒ 4.7 7.5 7.2 4.7 7.5 78 45 23 6 23 CD AB E F01 901 7.2 6 – 0.8 t = 0.15 ② ① Ⓒ 456 789 ④ ⑧ Ⓒ 7.2 ④ ⑧ Ⓒ 3 0.6 W × 2.8 L × 0.8 D 2.54 7.2 2.54 Marking appears only with complementary code 3 0.6 W × 2.8 L × 0.8 D 2.54 Marking appears only with complementary code ● SA-7210B (Real code) ● SA-7230B (Complementary code) ● SA-7250B (Real code) ● SA-7270B (Complementary code) Production date code Production date code ② ① Ⓒ 456 0.6 min. ④ ⑧ Ⓒ 2.54 2.54 Marking appears only with complementary code 0.6 W × 2.8 L × 0.8 D ● SA-7210C (Real code) ● SA-7230C (Complementary code) Production Marking appears only with complementary code 6 – 0.5 t = 0.15 Marking appears only with complementary code 6 – 0.5 t = 0.15 CD AB E 7.62 7.62 45 23 6 7.2 F01 23 456 789 ④ ⑧ Ⓒ A 0.5 A矢視図 A Projection 4±1 2.54 2.54 7.2 1.2 2.9 A 0.5 2.9 A矢視図 0.6 W × 2.8 L × 0.8 D A Projection 4±1 2.54 1.2 78 Marking appears only with complementary code ② ① Ⓒ 901 7.2 2.54 date code ② ① Ⓒ 0.6 W × 2.8 L × 0.8 D 2.54 ● SA-7250C (Real code) ● SA-7270C (Complementary code) date code 7.2 3 7.2 0.6 min. 789 3 7.2 ④ ⑧ Ⓒ 9.8 7.2 9.8 78 7.2 45 23 6 23 ④ ⑧ Ⓒ Production CD AB E F01 901 0.6 W × 2.8 L × 0.8 D 6 – 0.8 t = 0.15 0.6 min. 6 – 0.8 t = 0.15 0.6 min. ② ① Ⓒ 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7011A (Real code) ● SA-7031A (Complementary code) ● SA-7051A (Real code) ● SA-7071A (Complementary code) コンプリメンタリコードのみ表示 Marking appears only with complementary code Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.6 L × 0.8 D 0.6 W × 2.6 L × 0.8 D 7.2 45 23 6 8.3 901 F01 ● SA-7051B (Real code) ● SA-7071B (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.6 L × 0.8 D 0.6 W × 2.6 L × 0.8 D 7.2 7.2 7.9 45 23 6 8.3 901 F01 2.54 Ⓒ ① ② 1.4 min. 2.54 Ⓒ ⑧ ④ 1.4 min. ④ ● SA-7011C (Real code) ● SA-7031C (Complementary code) 2.54 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.6 L × 0.8 D 0.6 W × 2.6 L × 0.8 D 7.9 7.2 7.9 7.2 456 45 23 6 8.3 CD AB E 789 78 23 2.54 ● SA-7051C (Real code) ● SA-7071C (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 8.3 6 – 0.8 t = 0.15 7.8 7.8 ① ② Production date code 6 – 0.8 t = 0.15 0.5 1.4 min. Production date code 1.4 min. 23 CD AB E 78 8.3 7.9 789 456 Ⓒ ⑧ 2.54 1 min. Ⓒ ⑧ ④ ● SA-7011B (Real code) ● SA-7031B (Complementary code) Ⓒ 2.54 0.9 Ⓒ ① ② 2.54 1 min. ④ 6 – 0.8 t = 0.15 Production date code 7.1 1 min. Ⓒ ⑧ 2.54 0.9 ② 6 – 0.8 t = 0.15 7.1 Ⓒ ① 1 min. Production date code 0.5 23 78 CD AB E 789 456 8.3 7.9 7.2 7.9 901 3.5 3.5 F01 Production date code Ⓒ ① ② Ⓒ ⑧ ④ Production date code 6 – 0.5 t = 0.15 1.9 5.08 2.54 2.54 Ⓒ ① ② Ⓒ ⑧ ④ 6 – 0.5 t = 0.15 1.9 5.08 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7111A (Real code) ● SA-7131A (Complementary code) ● SA-7151A (Real code) ● SA-7171A (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 1.2 D 0.6 W × 1.2 D 3 7.2 7.9 456 φ3 45 23 6 8.3 φ3 901 F01 Ⓒ ① ② 2.54 ● SA-7151B (Real code) ● SA-7171B (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 1.2 D 0.6 W × 1.2 D 3 7.2 φ3 45 23 6 8.3 φ3 CD AB E 901 F01 2.5 2.5 6 – 0.8 t = 0.15 2.54 7.8 2.54 1.4 min. Ⓒ ⑧ ④ ● SA-7111C (Real code) ● SA-7131C (Complementary code) ● SA-7151C (Real code) ● SA-7171C (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 1.2 D 0.6 W × 1.2 D 3 7.2 0.5 Ⓒ ① ② 2.54 1.4 min. 0.5 1.4 min. Ⓒ ⑧ ④ 2.54 6 – 0.8 t = 0.15 Production date code 7.8 Ⓒ ① ② 1.4 min. Production date code 3 7.2 7.9 7.9 φ3 8.3 45 23 6 φ3 78 CD AB E 789 456 23 7.9 789 78 23 3 7.2 7.9 456 8.3 2.54 7.1 Ⓒ ⑧ ④ ● SA-7111B (Real code) ● SA-7131B (Complementary code) 8.3 2.54 1 min. 1 min. Ⓒ ⑧ ④ 6 – 0.8 t = 0.15 0.9 0.9 1 min. 2.54 7.1 Ⓒ ① ② 2.5 Production date code 6 – 0.8 t = 0.15 1 min. 23 CD AB E 2.5 Production date code 901 F01 Production date code Ⓒ ① ② ④ 2.5 3.5 3.5 2.5 Ⓒ ⑧ 7.9 789 78 8.3 3 7.2 1.9 5.08 6 – 0.5 t = 0.15 2.54 Production date code 2.54 Ⓒ ① ② Ⓒ ⑧ ④ 1.9 5.08 6 – 0.5 t = 0.15 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7211A (Real code) ● SA-7231A (Complementary code) ● SA-7251A (Real code) ● SA-7271A (Complementary code) コンプリメンタリコードのみ表示 Marking appears only with complementary code Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.8 L × 0.8 D 0.6 W × 2.8 L × 0.8 D 7.2 7.2 7.9 45 23 6 8.3 901 F01 7.1 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.8 L × 0.8 D 0.6 W × 2.8 L × 0.8 D 45 23 6 8.3 901 F01 0.5 2.54 Ⓒ ① ② 1.4 min. Ⓒ ⑧ ④ Ⓒ ⑧ ④ ● SA-7211C (Real code) ● SA-7231C (Complementary code) 2.54 2.54 ● SA-7251C (Real code) ● SA-7271C (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 Marking appears only with complementary code コンプリメンタリコードのみ表示 0.6 W × 2.8 L × 0.8 D 0.6 W × 2.8 L × 0.8 D 7.9 7.2 7.9 7.2 6 – 0.8 t = 0.15 7.8 2.54 1.4 min. Production date code 6 – 0.8 t = 0.15 7.8 Ⓒ ① ② 1.4 min. Production date code 1.4 min. 23 CD AB E 789 78 8.3 7.9 7.2 7.9 456 45 23 6 8.3 78 CD AB E 789 456 23 2.54 ● SA-7251B (Real code) ● SA-7271B (Complementary code) Marking appears only with complementary code コンプリメンタリコードのみ表示 8.3 2.54 1 min. Ⓒ ⑧ ④ ● SA-7211B (Real code) ● SA-7231B (Complementary code) 7.2 6 – 0.8 t = 0.15 0.9 Ⓒ ① ② 2.54 1 min. 1 min. 0.9 1 min. Ⓒ ⑧ ④ 2.54 7.1 Ⓒ ① ② Production date code 6 – 0.8 t = 0.15 Production date code 0.5 23 78 CD AB E 789 456 8.3 7.9 901 3.5 3.5 F01 Production date code Ⓒ ① ② Ⓒ ⑧ ④ Production date code 6 – 0.5 t = 0.15 1.9 5.08 2.54 2.54 Ⓒ ① ② Ⓒ ⑧ ④ 6 – 0.5 t = 0.15 1.9 5.08 2.54 2.54 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7012B (Real code) ● SA-7032B (Complementary code) Production date code ● SA-7052B (Real code) ● SA-7072B (Complementary code) 0.6 W × 2.6 L × 0.8 D 7.4 Production date code 3.6 901 CD AB E 0.15 7.6 0.18 4 0.15 78 456 0.18 789 Marking appears only with complementary code 45 23 6 7.6 3.6 F01 23 4 0.6 W × 2.6 L × 0.8 D 7.4 5 – 0.5 1.27 5 – 0.5 1.27 Marking appears only with complementary code 5.08 5.08 1 1 5.7 3.4 1.1 1 1.1 3.4 5.7 1 ④ ②⑧ ①Ⓒ ④ ②⑧ ①Ⓒ ● SA-7112B (Real code) ● SA-7132B (Complementary code) Production date code ● SA-7152B (Real code) ● SA-7172B (Complementary code) Production date code 0.6 W × 1.2 D 7.4 3 3.6 0.6 W × 1.2 D 7.4 3 901 3.4 5 – 0.5 1.27 5.08 1 5.7 5.7 1.1 1.1 1 ④ ②⑧ ①Ⓒ ④ ②⑧ ①Ⓒ ● SA-7212B (Real code) ● SA-7232B (Complementary code) Production date code ● SA-7252B (Real code) ● SA-7272B (Complementary code) Production date code 0.6 W × 2.8 L × 0.8 D 7.4 0.15 0.18 5 – 0.5 CD AB E 7.6 4 0.15 0.18 456 Marking appears only with complementary code 789 コンプリメンタリコードのみ表示 45 23 6 78 3.6 F01 23 4 0.6 W × 2.8 L × 0.8 D 7.4 3.6 901 7.6 0.15 Marking appears only with complementary code 5.08 1 CD AB E 7.6 コンプリメンタリコードのみ表示 1.27 0.18 0.18 4 0.15 78 4 456 3.4 5 – 0.5 789 Marking appears only with complementary code 45 23 6 23 7.6 F01 コンプリメンタリコードのみ表示 1 3.6 2.5 2.5 コンプリメンタリコードのみ表示 Marking appears only with complementary code 1.27 1 5.7 3.4 ④ ②⑧ ①Ⓒ ④ ②⑧ ①Ⓒ 1.1 1 1.1 1 5.7 3.4 1.27 5.08 5.08 1 5 – 0.5 SA-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SA-7013B (Real code) ● SA-7033B (Complementary code) Production date code 0.6 W × 2.6 L × 0.8 D 7.4 0.15 CD AB E 7.6 4 0.15 78 456 0.18 789 Marking appears only with complementary code 5 – 0.5 コンプリメンタリコードのみ表示 5 – 0.5 コンプリメンタリコードのみ表示 45 23 6 23 7.6 3.6 F01 901 4 0.6 W × 2.6 L × 0.8 D 7.4 3.6 0.18 Production date code ● SA-7053B (Real code) ● SA-7073B (Complementary code) Marking appears only with complementary code 1.27 1.27 5.08 5.08 9.6 ④ ②⑧ ①Ⓒ ④ ②⑧ ①Ⓒ ● SA-7113B (Real code) ● SA-7133B (Complementary code) ● SA-7153B (Real code) ● SA-7173B (Complementary code) Production date code 0.6 W × 1.2 D 7.4 3 3.6 0.6 W × 1.2 D 7.4 3 2.5 Marking appears only with complementary code 5.08 5.08 0.3 ● SA-7253B (Real code) ● SA-7273B (Complementary code) Production date code 0.6 W × 2.6 L × 0.8 D 7.4 3.6 0.6 W × 2.6 L × 0.8 D 7.4 3.6 0.18 7.6 4 0.15 0.18 789 456 Marking appears only with complementary code 45 23 6 23 5 – 0.5 コンプリメンタリコードのみ表示 CD AB E F01 901 78 1.5 4.6 0.3 1.5 4.6 ④ ②⑧ ①Ⓒ ● SA-7213B (Real code) ● SA-7233B (Complementary code) 7.6 1.27 9.6 ④ ②⑧ ①Ⓒ 4 0.15 5 – 0.5 コンプリメンタリコードのみ表示 1.27 9.6 0.18 7.6 4 0.15 0.18 7.6 78 456 4 789 Marking appears only with complementary code 45 23 6 23 5 – 0.5 コンプリメンタリコードのみ表示 CD AB E F01 901 Production date code 3.6 2.5 5 – 0.5 コンプリメンタリコードのみ表示 Marking appears only with complementary code 1.27 5.08 1.5 4.6 0.3 0.3 9.6 1.5 4.6 1.27 5.08 9.6 ④ ②⑧ ①Ⓒ 0.15 Production date code 1.5 4.6 1.5 4.6 0.3 0.3 9.6 ④ ②⑧ ①Ⓒ SA-7000 ROTARY CODED SWITCHES (SMD) ■ PACKAGING SPECIFICATIONS ● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500, pcs., etc. ● Taping version is boxed with one reel (500 pcs.). Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) B Empty Empty Filled 2 ± 0.5 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed D φ13 ± 0.2 Head A End φ21 ± 0.8 製品表示ラベル Part No. Label C Part number A B C D SA-70□0 • SA-72□0TA/TB φ 254 ± 2 17.4 ± 1 21.4 ± 1 φ 50 min. SA-71□0TA/TB φ 330 ± 2 17.4 ± 1 21.4 ± 1 SA-70□1 • SA-72□1TA/TB φ 330 ± 2 17.4 ± 1 21.4 ± 1 SA-71□1TA/TB φ 330 ± 2 17.4 ± 1 21.4 ± 1 SA-7□□2 • SA-7□□3 TB φ 330 ± 2 25.4 ± 1 29.4 ± 1 ● SA-70□0T□ ● SA-72□0T□ ● SA-71□0T□ φ 80 ± 1 (Unit: mm) φ1.5 +0.1 0 4 ± 0.1 2 ± 0.1 φ1.5 +0.1 0 装着例(SA-7150B) 装着例(SA-7050B) Installation example 7.5 ± 0.1 CD AB E 16 45 23 6 789 CD AB E F01 45 23 6 7.5 ± 0.1 Installation example F01 0.4 ± 0.1 16 4 ± 0.1 2 ± 0.1 12 ± 0.1 0.3 ± 0.1 1.75 ± 0.1 12 ± 0.1 1.75 ± 0.1 (Conforms to JIS C 0806) 789 引き出し方向 Direction of feed 3.4 引き出し方向 Direction of feed 6.6 SA-7000 ROTARY CODED SWITCHES (SMD) ● SA-70□1T□ ● SA-72□1T□ ● SA-71□1T□ (Unit: mm) 12 ± 0.1 4 ± 0.1 φ1.5 +0.1 0 16 ± 0.1 2 ± 0.1 4 ± 0.1 0.5 ± 0.1 φ1.5 +0.1 0 1.75 ± 0.1 2 ± 0.1 1.75 ± 0.1 (Conforms to JIS C 0806-3) 9.3 9.3 0.5 ± 0.1 装着例(SA-7111B) Installation example 16 7.5 ± 0.1 Installation example 16 7.5 ± 0.1 装着例 (SA-7051B) 引き出し方向 引き出し方向 Direction of feed Direction of feed ● SA-7□□2TB ● SA-7□□3TB 2 ± 0.1 12 ± 0.1 4 ± 0.1 φ1.5 +0.1 0 1.75 ± 0.1 (Conforms to JIS C 0806-3) 8.5 0.5 ± 0.1 Installation example 24 11.5 ± 0.1 装着例(SA-7012B) 引き出し方向 Direction of feed ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk pack in a plastic bag is performed with 50 pcs. (Top setting type is 200 pcs., side setting type is 100 pcs.) per box.
SA-7011TA 价格&库存
很抱歉,暂时无法提供与“SA-7011TA”相匹配的价格&库存,您可以联系我们找货
SA-7011TA
    • 1+22.84200
    • 10+19.79640
    • 30+17.99280
    库存:5
