SLIDE SWITCHES (SMD)
RoHS compliant
CAS
INTERNAL STRUCTURE
①
②
⑤
③
⑥
④
Part name
Material
■ FEATURES
①
Cover
Polyphenylenesulphide
● RoHS compliant
● Compatible with most automatic pick & place machinery
● Compact and space saving SMD type
● Excellent contact stability by twin Gold-plated contact
● Low profile design of 2.5 mm
②
Slider
Polyamide
③
Housing
④
Slider contact
⑤
Fixed contact
⑥
Terminal pin
Flammability
UL94V-0
Copper alloy, Gold-plated
■ PART NUMBER DESIGNATION
C A S - 1 2 0 T B 1
Series name
No. of poles
1:(SPDT) 1 pole、2:(2PDT) 2 poles
D:(Dual SPDT) Dual
Structure
1:Non-washable type (Without seal tape)
Standard type
2:Non-washable type (With seal tape)
Blank : Washable type (With seal tape)
No. of contacts
2:2 contacts
Setting position
0:Top setting
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
SPDT : Single Pole Double Throw 2PDT : Two Poles Double Throw
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Shape of terminal
A:J-hook
B:Gull wing
CAS
■ LIST OF PART NUMBERS
No. of
poles
No. of
contacts
Setting
position
Form of
packaging
J-hook
A ( )
Gull wing ) A ( )
J-hook
B(
Gull wing )
B(
Pieces in
package
Taping
CAS-120TA1
CAS-120TB1
CAS-120TA2
CAS-120TB2
1000pcs./reel
Plastic bag
CAS-120A1
CAS-120B1
CAS-120A2
CAS-120B2
100pcs./pack
Taping
CAS-220TA1
CAS-220TB1
CAS-220TA2
CAS-220TB2
1000pcs./reel
Plastic bag
CAS-220A1
CAS-220B1
CAS-220A2
CAS-220B2
100pcs./pack
Taping
CAS-D20TA1
CAS-D20TB1
CAS-D20TA2
CAS-D20TB2
1000pcs./reel
Plastic bag
CAS-D20A1
CAS-D20B1
CAS-D20A2
CAS-D20B2
100pcs./pack
1
2
2
Top setting
Dual
No. of
poles
No. of
contacts
Setting
position
Form of
packaging
J-hook
A ( )
Gull wing )
B(
Pieces in
package
Taping
CAS-120TA
CAS-120TB
1000pcs./reel
Plastic bag
CAS-120A
CAS-120B
100pcs./pack
Taping
CAS-220TA
CAS-220TB
1000pcs./reel
Plastic bag
CAS-220A
CAS-220B
100pcs./pack
Taping
CAS-D20TA
CAS-D20TB
1000pcs./reel
Plastic bag
CAS-D20A
CAS-D20B
100pcs./pack
1
2
2
Top setting
Dual
※ Verify the above part numbers when placing orders.
Taping version can be supplied only in reel unit.
CAS
■ STANDARD SPECIFICATIONS
Operating temp. range
Storage temp. range
Sealing
Net weight
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
− 40 ~ 85 °C
Washable type available with seal tape
Contact resistance
Approx. 0.05g (CAS-120)
Approx. 0.08g (CAS-220/D20)
Insulation resistance
Dielectric strength
■ MECHANICAL CHARACTERISTICS
Operating force
DC50 V 100 mA
DC6 V, 100 mA DC24 V, 25 mA
DC20 mV 1 μ A
50 m Ω maximum
1000 M Ω (DC100 V) minimum
AC500 V, 60 s
■ ENVIRONMENTAL CHARACTERISTICS
0.5 ~ 5 N {0.05 ~ 0.51 kgf}
Vibration
(Amplitude) 1.5 mmor (Acceleration) 98 m/s2,
10-500 Hz, 3 directions for 10 cycles each
Stop strength
10 N {1.02 kgf}, 60 s
Shock
490 m/s2, 11 ms
6 directions for 3 times each
Solderability
245 ± 3 °C, 2 ~ 3 s
Load life
Continuous load 2000 cycles,
DC6 ± 0.5 V, 100 ± 10 mA
Reflow:255 °C (Peak temperature)
(Please refer to the profile below)
Humidity
Soldering heat
− 10 ~ 65 °C, Relative humidity 0 ~ 96 %,
24 h for 10 cycles
Manual soldering:350 ± 10 °C, 3 ~ 4 s
High temp. exposure
85 °C, 96 h
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Low temp. exposure
− 40 °C, 96 h
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Pull-off strength
Thermal shock
5 N {0.51 kgf} 10 s
{ } : Reference only
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
Peak : 250
+5
Over 230 ℃
180 ℃
150 ℃
Pre Heating Zone
90 ± 30 s
30 ± 10 s
Heating time
Soldering Zone
Reflow : two times maximum
− 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
CAS
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● CAS-120A1
● CAS-120B1
3 – 0.6 +0.1
–0.05
C
②
Production date code
2.5
2.5 max.
● CAS-220A1
0.4 min.
3.5
6 – 0.6 +0.1
–0.05
C
④ ⑤ ⑥
5.4
Stroke 0.6
0.1 –0.1
2.5
0.15 +0.1
–0.05
2.5 max.
0.15 +0.1
–0.05
1.75
● CAS-D20A1
1.75
1.75
0.4 min.
0.4 min.
● CAS-D20B1
6 – 0.6 +0.1
–0.05
6 – 0.6 +0.1
–0.05
C
④ ⑤ ⑥
5.4
Stroke 0.6
5.6
3.9
2.5
0.15 +0.1
–0.05
0.1 –0.1
0.15 +0.1
–0.05
2.5 max.
0.3
0.3
5
0.
5
0.
Terminal No.1
4.2 +0.3
① ② ③
C
Schematic
C
C
2.5 max.
1.75
C
④ ⑤ ⑥
2
2
① ② ③
C
Schematic
5.4
Stroke 0.6
0.1
5.6
3.9
0.3
0.3
2.5 max.
0.1 –0.1
5
5
0.
0.
Terminal No.1
4.2 +0.3
① ② ③
C
Schematic
C
C
① ② ③
C
Schematic
5.4
Stroke 0.6
–0.1
C
④ ⑤ ⑥
2
2
Terminal No.1
1.75
0.4 min.
● CAS-220B1
–0.05
6 – 0.6 +0.1
Terminal No.1
0.15 +0.1
–0.05
0.3
4.2
Stroke 0.6
0.15 +0.1
–0.05
0.3
2.5 max.
0.1 –0.1
5
5
5.4
2.5
1.1
③
Schematic
2.8 +0.3
1.75
①
0.
0.
Schematic
Terminal No.1
C
C
5.4
Stroke 0.6
③
2–
①
2–
Terminal No.1
C
②
0.1 –0.1
3 – 0.6
+0.1
–0.05
1.75
1.75
0.4 min.
0.4 min.
CAS
3 –1
1.3
3 –1
3 –1
1.3
3 –1
1.6
1.6
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● CAS-120
2.6
1.3
1.3
2.6
3.5
3.5
1.3
2.6
3.50
2.6
1.3
1.6 0.7
0.7 1.6
3.5
1.3
3.5
1.6
3.5
3 –1
B type
3 –1
1.6 0.7
3 –1
A type
(Unit : mm)
3 –1
3.5
● CAS-220 • D20
1.75
6 –1
1.3
1.3
6 –B
1 type
6 –1
1.75
6 –1
1.3
4
1.3
1.75
6 –1
1.62.1
6 –1
4
1.3
1.6
6 –1
1.3
4
6 –1
2.11.6
2.11.6
1.62.1
1.6
A type
1.75
1.75
1.75
1.75
1.3
1.75
1.3
1.75
1.6
1.6
Note) The zero point is the center of mounting.
1.75
1.75
1.75
CAS
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 1000 pcs. per reel.
Orders will be accepted for units of 1000 pcs., i.e., 1000,
2000, 3000 pcs., etc.
● Taping version is boxed with two reels (2000 pcs.).
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the
diagrams below:
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(Conforms to JIS C 0806-3)
17.4±1
Empty
Filled
φ 13±0.2
End
2±0.5
φ 254±2
φ 50 min.
Empty
Head
40 mm min.
20 pitches min.
Leader
400 mm min.
Direction of feed
φ 21±0.8
21.4±1
● CAS-120TA, TB
● CAS-220TA, TB • D20TA, TB
(Unit: mm)
φ 1.5 +0.1
Terminal No.1
2 ± 0.1
7.5 ± 0.1
(CAS-120B1)
Installation example
8 ± 0.1
4 ± 0.1
1.75 ± 0.1
0.3 ± 0.1
0.3 ± 0.1
(CAS-D20B1)
16
2 ± 0.1
7.5 ± 0.1
8 ± 0.1
4 ± 0.1
16
φ 1.5 +0.1
1.75 ± 0.1
(In accordance with EIAJ ET-7200A)
Terminal No.1
Direction of feed
3
● Boxing of bulk pack in a plastic bag is performed with
100 pcs. (standard 500 pcs.) per box.
Direction of feed
3
很抱歉,暂时无法提供与“CAS-220TB1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+12.09568
- 10+11.73119
- 100+11.38753
- 250+10.84081
- 500+10.29929
- 国内价格
- 10+11.73119
- 100+11.38753
- 250+10.84081
- 500+10.29929
