ODC75-**SC ** Series
75Watt DC/DC Power Supply
SINGLE OUTPUT
4:1 Wide input range VDC
Isolation 2250VDC
Efficiency up to 91%
Wide operating temperature from -40°C to +70°C
EMI class A without external circuit
No minimum load required- Soft Start
Meet EN50155
Available Inputs Voltage (nominal):
24VDC Nom (DC 9~36V) 48 VDC Nom (DC 18 ~ 75V)
110VDC Nom (DC40~160)
3 Year Warranty
INPUT
Nom Voltage
(Range)
Current Typ.
UNIT
V
mA
ODC75-**SC24
DC 24V
(9~36)
95~3551
Start up
VDC
36Vdc
Min. -0.7
Min. -0.7
Min. -0.7
ODC75-5SC24
OUTPUT
40Vdc
16 Vdc
24VDC
48VDC
110VDC
Nominal
Voltage
DC 110V
(40~160)
15~1420
18Vdc
7.5 Vdc
Vdc
ODC75-**SC110
DC 48V
(18~75)
60 - 1776
9Vdc
Voltage
Under Voltage
shutdown
Voltage Surge
ODC75-**SC48
ODC75-125SC24
Max. 50VDC
Max. 100VD
Max. 170
ODC75-15SC24
ODC75-24SC24
5
12
15
24
Capacitive Load
max.
uF
30,000
5200
3300
1300
Current
Total Pwr
Efficiency
Line Regulation
Load
Regulation
A
W
15
75
88
+/-0.2%
+/-0.2%
6.25
75
90
+/-0.2%
+/-0.2%
5
75
90
+/-0.2%
+/-0.2%
3.125
75
90
+/-0.2%
+/-0.2%
Switching
Frequency
KHZ
250
250
250
250
Ripple Noise
mVp-p
Vdc
100
125
125
250
+/- 10%
+/- 10%
+/- 10%
+/- 10%
250
250
250
250
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
OVER VOLTAGE
PROTECTION
Voltage
adjustability
Transient res.
recovery time
25% load step
change
SHORT CIRCUIT
PROTECTION
Cooling
μs
6.2
15
18
Convection
30
OUTPUT
ODC75-5SC48
ODC75-125SC48
ODC75-15SC48
ODC75-24SC48
5
12
15
24
Nominal
Voltage
VDC
Capacitive Load
max.
uF
30,000
5200
3300
1300
Current
Total Pwr
Efficiency
Line Regulation
Load
Regulation
A
W
15
75
88
+/-0.2%
+/-0.2%
6.25
75
90
+/-0.2%
+/-0.2%
5
75
90
+/-0.2%
+/-0.2%
3.125
75
90
+/-0.2%
+/-0.2%
Switching
Frequency
KHZ
250
250
250
250
Ripple Noise
mVp-p
Vdc
100
125
125
250
6.2
15
18
30
+/- 10%
+/- 10%
+/- 10%
+/- 10%
250
250
250
250
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
OVER VOLTAGE
PROTECTION
Voltage
adjustability
Transient res.
recovery time
μs
25% load step
change
SHORT CIRCUIT
PROTECTION
Cooling
Convection
ODC75-5SC110
OUTPUT
Nominal
Voltage
VDC
Capacitive Load
max.
ODC75-125SC110
ODC75-15SC110
ODC75-24SC110
5
12
15
24
uF
30,000
5200
3300
1300
Current
Total Pwr
Efficiency
Line Regulation
Load
Regulation
A
W
15
75
88
+/-0.2%
+/-0.2%
6.25
75
91
+/-0.2%
+/-0.2%
5
75
90
+/-0.2%
+/-0.2%
3.125
75
90
+/-0.2%
+/-0.2%
Switching
Frequency
KHZ
250
250
250
250
Ripple Noise
mVp-p
Vdc
100
125
125
250
6.2
15
18
30
+/- 10%
+/- 10%
+/- 10%
+/- 10%
250
250
250
250
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
AUTO RECOVERY
120~170 %
OVER VOLTAGE
PROTECTION
Voltage
adjustability
Transient res.
recovery time
25% load step
change
SHORT CIRCUIT
PROTECTION
Cooling
μs
Convection
ISOLATION
Voltage input ~output
2250
Resistance
>= 1000 MΩ (500VDC)
Capacitance
Overload Protection
24VDC
Environment
>= 110% full load
48VDC
Operating temp
-40 ~ +70
Storage
-55 ~ +125
MTBF
Dimension
WxHxL
SAFETY
EMS
Case Material
Potting Material
EMI
MIL-HDBK-217F
mm
60.8 X 57.7X 15 mm
Nickel Coated Copper with non-Conductive Base - Case Temp. 100C
Base Plate Material -Non-Conductive FR4
Potting material Epoxy UL94V-0
Pin: Brass Solder Coated
Thermal Shutdown 105 ~115 case
EN55024 ESDEN61000-4-2air
EN55032,EN55011,FCC
part 15
PACKAGING (Parts packaged in tubes of 8)
Dimensions
Pins
PIN Assignment
Pin
Define
Diameter
1
-Vin
1 mm[0.04”]
2
Case
1 mm[0.04”]
3
Ctrl
1 mm[0.04”]
4
+Vin
1 mm[0.04”]
5
-Vout
2 mm[0.08”]
6
-Sense
1 mm[0.04”]
7
Trim
1 mm[0.04”]
8
+Sense
1 mm[0.04”]
9
+Vout
2 mm[0.08”]
很抱歉,暂时无法提供与“ODC75-05SC110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1622.88360
- 200+647.54640
- 500+625.90320
- 1000+615.21120
