ODC75-24SC110
ODC75-24SC110
    ETA-USA
    半砖
    DC-DC SMD THROUGH-HOLE ENCAPSUL
ODC75-24SC110 数据手册
ODC75-**SC ** Series 75Watt DC/DC Power Supply SINGLE OUTPUT 4:1 Wide input range VDC Isolation 2250VDC Efficiency up to 91% Wide operating temperature from -40°C to +70°C EMI class A without external circuit No minimum load required- Soft Start Meet EN50155 Available Inputs Voltage (nominal): 24VDC Nom (DC 9~36V) 48 VDC Nom (DC 18 ~ 75V) 110VDC Nom (DC40~160) 3 Year Warranty INPUT Nom Voltage (Range) Current Typ. UNIT V mA ODC75-**SC24 DC 24V (9~36) 95~3551 Start up VDC 36Vdc Min. -0.7 Min. -0.7 Min. -0.7 ODC75-5SC24 OUTPUT 40Vdc 16 Vdc 24VDC 48VDC 110VDC Nominal Voltage DC 110V (40~160) 15~1420 18Vdc 7.5 Vdc Vdc ODC75-**SC110 DC 48V (18~75) 60 - 1776 9Vdc Voltage Under Voltage shutdown Voltage Surge ODC75-**SC48 ODC75-125SC24 Max. 50VDC Max. 100VD Max. 170 ODC75-15SC24 ODC75-24SC24 5 12 15 24 Capacitive Load max. uF 30,000 5200 3300 1300 Current Total Pwr Efficiency Line Regulation Load Regulation A W % % % 15 75 88 +/-0.2% +/-0.2% 6.25 75 90 +/-0.2% +/-0.2% 5 75 90 +/-0.2% +/-0.2% 3.125 75 90 +/-0.2% +/-0.2% Switching Frequency KHZ 250 250 250 250 Ripple Noise mVp-p Vdc 100 125 125 250 +/- 10% +/- 10% +/- 10% +/- 10% 250 250 250 250 AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % OVER VOLTAGE PROTECTION Voltage adjustability Transient res. recovery time 25% load step change SHORT CIRCUIT PROTECTION Cooling % μs 6.2 15 18 Convection 30 OUTPUT ODC75-5SC48 ODC75-125SC48 ODC75-15SC48 ODC75-24SC48 5 12 15 24 Nominal Voltage VDC Capacitive Load max. uF 30,000 5200 3300 1300 Current Total Pwr Efficiency Line Regulation Load Regulation A W % % % 15 75 88 +/-0.2% +/-0.2% 6.25 75 90 +/-0.2% +/-0.2% 5 75 90 +/-0.2% +/-0.2% 3.125 75 90 +/-0.2% +/-0.2% Switching Frequency KHZ 250 250 250 250 Ripple Noise mVp-p Vdc 100 125 125 250 6.2 15 18 30 +/- 10% +/- 10% +/- 10% +/- 10% 250 250 250 250 AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % OVER VOLTAGE PROTECTION Voltage adjustability Transient res. recovery time % μs 25% load step change SHORT CIRCUIT PROTECTION Cooling Convection ODC75-5SC110 OUTPUT Nominal Voltage VDC Capacitive Load max. ODC75-125SC110 ODC75-15SC110 ODC75-24SC110 5 12 15 24 uF 30,000 5200 3300 1300 Current Total Pwr Efficiency Line Regulation Load Regulation A W % % % 15 75 88 +/-0.2% +/-0.2% 6.25 75 91 +/-0.2% +/-0.2% 5 75 90 +/-0.2% +/-0.2% 3.125 75 90 +/-0.2% +/-0.2% Switching Frequency KHZ 250 250 250 250 Ripple Noise mVp-p Vdc 100 125 125 250 6.2 15 18 30 +/- 10% +/- 10% +/- 10% +/- 10% 250 250 250 250 AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % AUTO RECOVERY 120~170 % OVER VOLTAGE PROTECTION Voltage adjustability Transient res. recovery time 25% load step change SHORT CIRCUIT PROTECTION Cooling % μs Convection ISOLATION Voltage input ~output 2250 Resistance >= 1000 MΩ (500VDC) Capacitance Overload Protection 24VDC Environment >= 110% full load 48VDC Operating temp -40 ~ +70 Storage -55 ~ +125 MTBF Dimension WxHxL SAFETY EMS Case Material Potting Material EMI MIL-HDBK-217F mm 60.8 X 57.7X 15 mm Nickel Coated Copper with non-Conductive Base - Case Temp. 100C Base Plate Material -Non-Conductive FR4 Potting material Epoxy UL94V-0 Pin: Brass Solder Coated Thermal Shutdown 105 ~115 case EN55024 ESDEN61000-4-2air EN55032,EN55011,FCC part 15 PACKAGING (Parts packaged in tubes of 8) Dimensions Pins PIN Assignment Pin Define Diameter 1 -Vin 1 mm[0.04”] 2 Case 1 mm[0.04”] 3 Ctrl 1 mm[0.04”] 4 +Vin 1 mm[0.04”] 5 -Vout 2 mm[0.08”] 6 -Sense 1 mm[0.04”] 7 Trim 1 mm[0.04”] 8 +Sense 1 mm[0.04”] 9 +Vout 2 mm[0.08”]
ODC75-24SC110 价格&库存
很抱歉,暂时无法提供与“ODC75-24SC110”相匹配的价格&库存,您可以联系我们找货
ODC75-24SC110
    ODC75-24SC110
      • 1+1867.44960
      • 200+745.12440
      • 500+720.23040
      • 1000+707.92920
