TS3480
Taiwan Semiconductor
Low Quiescent Current Low-Dropout Linear Voltage Regulator
DESCRIPTION
FEATURES
TS3480 series is an integrated linear voltage regulator.
It can be provided the operation from an input as high
as 30V and a guaranteed maximum dropout of 1.2V at
the full 100mA load. The 1.2V quasi low dropout of
TS3480 series is able to makes them a nice fit in many
applications where the 2 to 2.5V dropout of TS78LXX
series devices precludes their use.
The TS3480 series features 5V & 3.3V output
voltage options. The SOT packaging and quasi low
30V maximum input for operation
2V guaranteed maximum dropout over full load
and temperature ranges
100mA guaranteed minimum load current
±5% guaranteed output voltage tolerance over full
load and temperature ranges
−40 to +125˚C junction temperature range for
dropout features of the TS3480 series converge in
this device to provide a very nice, very tiny 5V &
3.3V, 100mA bias supply that regulates directly off
the system power supply.
APPLICATION
SOT-23
operation
Compliant to RoHS Directive 2011/65/EU and in
accordance to WEEE 2002/96/EC.
Halogen-free according to IEC 61249-2-21
Tiny alternative to TS78LXX series and similar
devices
Tiny 5V±5% to 3.3V, 100mA converter
Post regulator for switching DC/DC converter
Bias supply for analog circuits
Pin Definition:
1. Output
2. Input
3. Ground
Notes: MSL 1 (Moisture Sensitivity Level) per J-STD-020
TYPICAL APPLICATION CIRCUIT
1
Version: D1806
TS3480
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise specified) (Note 1)
PARAMETER
SYMBOL
LIMIT
UNIT
VIN
35
V
VOPER
30
V
IOUT
100
mA
PD
350
mW
TJ
+150
o
-40 ~ +125
o
TSTG
-65 ~ +150
o
TSOLDER
4
Sec
2
kV
Input Voltage
Operating Input Voltage
Output Current Range
Power Dissipation
(Note 2)
Junction Temperature
Operating Temperature Range
TOPER
Storage Temperature Range
o
Lead Soldering Time (260 C)
ESD
(Note 3)
(note 4)
C
C
C
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise specified)
PARAMETER
SYMBOL
CONDITION
MIN
TYP
MAX
UNIT
3.17
3.3
3.43
V
3.3V Output
VIN = 4.8V, Io= 1mA ~ 100mA
Output Voltage
VOUT
Line Regulation
∆VDDLine
4.8V ≤ VIN ≤ 30V, Io= 1mA
10
25
mV
Load Regulation
∆VDDLoad
VIN = 4.8V, Io= 1mA~100mA
mV
Dropout Voltage
VDROP_OUT
Io=10mA
0.75
0.9
V
Io=100mA
0.95
1.1
V
VIN = 4.8V ≤ VIN ≤ 30V, Io=0V
3
5
mA
100
mA
F= 10Hz ~ 100kHz, Io= 0mA,
COUT = 0.1µF, VIN = 10V
100
μVRMS
VIN = 6.5V, Io= 1mA ~ 100mA
4.80
5.0
5.20
V
Quiescent Current
Output Current
IOUT
Ripple Rejection
VIN - VOUT = 20V
5.0V Output
Output Voltage
VOUT
Line Regulation
∆VDDLine
6.5V ≤ VIN ≤ 30V, Io= 1mA
10
25
mV
Load Regulation
∆VDDLoad
VIN = 6.5V, Io= 10mA~100mA
mV
Dropout Voltage
VDROP_OUT
Io=10mA
0.75
0.9
V
Io=100mA
0.95
1.1
V
VIN = 6.5V ≤ VIN ≤ 30V, Io=0V
3
5
mA
100
mA
150
µVrms
Quiescent Current
Output Current
Ripple Rejection
IOUT
VIN - VOUT = 20V
2
Version: D1806
TS3480
Note:
1. Absolute Maximum Ratings are limits beyond which damage to the device may occur. Operating ratings are conditions
under which operation of the device is guaranteed. Operating ratings do not imply guaranteed performance limits. For
guaranteed performance limits and associated test conditions, see the Electrical Characteristics.
2. The Absolute Maximum power dissipation depends on the ambient temperature and can be calculated using P = (TJ -TA) /
RθJA where TJ is the junction temperature, Ta is the ambient temperature, and RθJA is the junction-to-ambient thermal
resistance. The 350mW rating results from substituting the absolute maximum junction temperature, 150°C for TJ, 50°C for
Ta, and 300°C/W for RθJA. More power can be safely dissipated at lower ambient temperatures, and less power can be
safely dissipated at higher ambient temperatures. The absolute maximum power dissipation can be increased by 3.5mW
for each Celsius below 50°C ambient. It must be derated by 3.5mW for each Celsius above 50°C ambient. A RθJA of
300°C/W represents the worst-case condition of no heat sinking of the 3-lead plastic SOT-23 package. Heat sinking
enables the safe dissipation of more power. The TS3480 actively limits its junction temperature to about 150°C.
3. Times shown are dwell times. Temperatures shown are dwell temperatures.
4. For testing purposes, ESD was applied using the Human-Body Model, a 100pF capacitor discharged through a 1.5kΩ
resistor.
5. A typical is the center of characterization data taken with TA =TJ = 25°C. Typical are not guaranteed.
6. All limits are guaranteed. All electrical characteristics having room-temperature limits are tested during production with TA
=TJ = 25°C. All hot and cold limits are guaranteed by correlating the electrical characteristics to process and temperature
variations and applying statistical process control.
7. All voltages except dropout are with respect to the voltage at the GND pin.
ORDERING INFORMATION
OUTPUT VOLTAGE
ORDERING CODE.
PACKAGE
PACKING
3.3V
TS3480CX33 RFG
SOT-23
3,000pcs / 7” Reel
5V
TS3480CX50 RFG
SOT-23
3,000pcs / 7” Reel
3
Version: D1806
TS3480
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
Figure 1. Output Voltage vs. Input Voltage
Figure 2. Line Regulation
Figure 3. Load Regulation
Figure 4. Ground Pin Current vs. Output Current
Figure 5. Ground Pin Current vs. Input Voltage
Figure 6. Dropout Voltage vs. Load Current
4
Version: D1806
TS3480
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-23
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
M
x
Y
M
= Device Code
= Voltage Code (5=5V, S=3.3V)
= Year Code
= Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
5
Version: D1806
TS3480
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: D1806
很抱歉,暂时无法提供与“TS3480CX50 RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.465693000+0.18956
- 6000+1.424186000+0.18419
- 9000+1.403399000+0.18150
- 15000+1.3803615000+0.17852
- 21000+1.3668921000+0.17678
- 30000+1.3539430000+0.17510
- 国内价格 香港价格
- 1+3.447771+0.44589
- 10+2.3920910+0.30937
- 25+2.1327125+0.27582
- 100+1.84130100+0.23813
- 250+1.70258250+0.22019
- 500+1.61926500+0.20942
- 1000+1.550581000+0.20054
