NJM7805FA
NJM7805FA
    NISSHINBO(日清纺)
    TO-220F-3
    PMIC - 稳压器 - 线性 正 固定 1 输出 1.5A TO-220F-3
NJM7805FA 数据手册
Datasheet NJM7800 3-TERMINAL POSITIVE VOLTAGE REGULATOR FEATURES      GENERAL DESCRIPTION Internal Short Circuit Current Limit Excellent Ripple Rejection Guarantee'd 1.5A Output Current Package Outline TO-220F, TO-252 Bipolar Technology NJM7800FA 1. IN 2. GND 3. OUT The NJM7800 series of monolithic 3-Terminal Positive Voltage Regulators is constructed using the Nisshinbo Micro Devices planar epitaxial process. These regulators employ internal current-limiting, thermal-shutdown and safe-area compensation making them essentially indestructible. If adequate heat sinking is provided, they can deliver over 1A output current. They are intended as fixed voltage regulators in a wide range of applications including local (on card) regulation for elimination of distribution problems associated with single point regulation. In addition to use as fixed voltage regulators, these devices can be used with external components to obtain adjustable output voltages and currents. NJM7800DL1A 1. IN 2. GND 3. OUT (note) The radiation fin is connected pin2. EQUIVALENT CIRCUIT Ver.1.0 -1- Datasheet NJM7800 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25ºC) SYMBOL Input Voltage VIN Storage Temperature Range Tstg Operating Temperature Range MAXIMUM RATINGS UNIT 7805 to 7810 7812 to 7815 7818 to 7824 35 35 40 V -40 to +150 ºC Operating Junction Temperature Tj -40 to +150 Operating Junction Temperature Topr -40 to +85 Power Dissipation TO-220F TO-252 PD ºC 16(TC≤70ºC) 10(TC=25ºC) 1(Ta≤25ºC) W ■ ELECTRICAL CHARACTERISTICS (C1=0.33μF, CO=0.1μF, Tj=25ºC) Measurement is to be conducted in pulse testing. RAMETER SYMBOL TEST CONDITIONS TO-220F TO-252 UNIT MIN. TYP. MAX. MIN. TYP. MAX. 4.8 5.0 5.2 4.8 5.0 5.2 V NJM7805FA/DL1A Output Voltage VO VIN=10V, I0=0.5A Line Regulation ΔVO - VIN VIN=7 to 25V, IO=0.5A - 3 50 - 3 100 mV Load Regulation ΔVO - IO VIN=10V, IO=0.005 to 1.5A - 15 50 - 15 100 mV Quiescent Current IQ VIN=10V, IO=0mA - 4.2 6.0 - 4.2 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=10V, IO=5mA - -0.5 - - -0.5 - mV/ºC Ripple Rejection RR VIN=10V, IO=0.5A , ein=2VP-P, f=120Hz 68 78 - 68 78 - dB Output Noise Voltage VNO VIN=10V, BW=10Hz to 100kHz, IO=0.5A - 45 - - 45 - μV Output Voltage VO VIN=11V, I0=0.5A 5.75 6.0 6.25 5.75 6.0 6.25 V Line Regulation ΔVO - VIN VIN=8 to 25V, IO=0.5A - 5 60 - 5 120 mV Load Regulation ΔVO - IO VIN=11V, IO=0.005 to 1.5A - 15 60 - 15 120 mV Quiescent Current IQ VIN=11V, IO=0mA - 4.3 6.0 - 4.3 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=11V, IO=5mA - -0.6 - - -0.6 - mV/ºC Ripple Rejection RR VIN=11V, IO=0.5A , ein=2VP-P, f=120Hz 65 75 - 65 75 - dB Output Noise Voltage VNO VIN=11V, BW=10Hz to 100kHz, IO=0.5A - 45 - - 45 - μV NJM7806FA/DL1A Ver.1.0 -2- Datasheet NJM7800 ■ ELECTRICAL CHARACTERISTICS (C1=0.33μF, CO=0.1μF, Tj=25ºC) Measurement is to be conducted in pulse testing. PARAMETER SYMBOL TEST CONDITIONS TO-220F TO-252 UNIT MIN. TYP. MAX. MIN. TYP. MAX. 7.7 8.0 8.3 7.7 8.0 8.3 V NJM7808FA/DL1A Output Voltage VO VIN=14V, I0=0.5A Line Regulation ΔVO - VIN VIN=10.5 to 25V, IO=0.5A - 6 80 - 6 160 mV Load Regulation ΔVO - IO VIN=14V, IO=0.005 to 1.5A - 15 80 - 15 160 mV Quiescent Current IQ VIN=14V, IO=0mA - 4.3 6.0 - 4.3 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=14V, IO=5mA - -0.8 - - -0.8 - mV/ºC Ripple Rejection RR VIN=14V, IO=0.5A , ein=2VP-P, f=120Hz 62 72 - 62 72 - dB Output Noise Voltage VNO VIN=14V, BW=10Hz to 100kHz, IO=0.5A - 55 - - 55 - μV Output Voltage VO VIN=15V, I0=0.5A 8.65 9.0 9.35 8.65 9.0 9.35 V Line Regulation ΔVO - VIN VIN=11.5 to 25V, IO=0.5A - 7 90 - 7 180 mV Load Regulation ΔVO - IO VIN=15V, IO=0.005 to 1.5A - 15 90 - 15 180 mV Quiescent Current IQ VIN=15V, IO=0mA - 4.3 6.0 - 4.3 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=15V, IO=5mA - -0.9 - - -0.9 - mV/ºC Ripple Rejection RR VIN=15V, IO=0.5A , ein=2VP-P, f=120Hz 62 72 - 62 72 - dB Output Noise Voltage VNO VIN=15V, BW=10Hz to 100kHz, IO=0.5A - 60 - - 60 - μV Output Voltage VO VIN=17V, I0=0.5A 10.0 10.4 V Line Regulation ΔVO - VIN VIN=12.5 to 25V, IO=0.5A - 7 100 - 7 200 mV Load Regulation ΔVO - IO VIN=17V, IO=0.005 to 1.5A - 15 130 - 15 200 mV Quiescent Current IQ VIN=17V, IO=0mA - 4.3 6.0 - 4.3 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=17V, IO=5mA - -0.9 - - -1.0 - mV/ºC Ripple Rejection RR VIN=17V, IO=0.5A , ein=2VP-P, f=120Hz 62 72 - 62 72 - dB Output Noise Voltage VNO VIN=17V, BW=10Hz to 100kHz, IO=0.5A - 60 - - 65 - μV NJM7809FA/DL1A NJM7810FA/DL1A Ver.1.0 9.60 10.0 10.4 9.6 -3- Datasheet NJM7800 ■ ELECTRICAL CHARACTERISTICS (C1=0.33μF, CO=0.1μF, Tj=25ºC) Measurement is to be conducted in pulse testing. PARAMETER SYMBOL TEST CONDITIONS TO-220F TO-252 UNIT MIN. TYP. MAX. MIN. TYP. MAX. 11.5 12.0 12.5 11.5 12.0 12.5 V NJM7812FA/DL1A Output Voltage VO VIN=19V, I0=0.5A Line Regulation ΔVO - VIN VIN=14.5 to 30V, IO=0.5A - 10 120 - 10 240 mV Load Regulation ΔVO - IO VIN=19V, IO=0.005 to 1.5A - 25 120 - 25 240 mV Quiescent Current IQ VIN=19V, IO=0mA - 4.3 6.0 - 4.3 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=19V, IO=5mA - -1.2 - - -1.2 - mV/ºC Ripple Rejection RR VIN=19V, IO=0.5A , ein=2VP-P, f=120Hz 61 71 - 61 71 - dB Output Noise Voltage VNO VIN=19V, BW=10Hz to 100kHz, IO=0.5A - 75 - - 75 - μV Output Voltage VO VIN=23V, I0=0.5A 14.4 15.0 15.6 V Line Regulation ΔVO - VIN VIN=17.5 to 30V, IO=0.5A - 11 150 - 11 300 mV Load Regulation ΔVO - IO VIN=23V, IO=0.005 to 1.5A - 35 150 - 35 300 mV Quiescent Current IQ VIN=23V, IO=0mA - 4.4 6.0 - 4.4 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=23V, IO=5mA - -1.5 - - -1.5 - mV/ºC Ripple Rejection RR VIN=23V, IO=0.5A , ein=2VP-P, f=120Hz 60 70 - 60 70 - dB Output Noise Voltage VNO VIN=23V, BW=10Hz to 100kHz, IO=0.5A - 90 - - 90 - μV Output Voltage VO VIN=27V, I0=0.5A 17.3 18.0 18.7 17.3 18.0 18.7 V Line Regulation ΔVO - VIN VIN=21 to 33V, IO=0.5A - 15 180 - 15 360 mV Load Regulation ΔVO - IO VIN=27V, IO=0.005 to 1.5A - 55 180 - 55 360 mV Quiescent Current IQ VIN=27V, IO=0mA - 4.5 6.0 - 4.5 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=27V, IO=5mA - -1.8 - - -1.8 - mV/ºC Ripple Rejection RR VIN=27V, IO=0.5A , ein=2VP-P, f=120Hz 59 69 - 59 69 - dB Output Noise Voltage VNO VIN=27V, BW=10Hz to 100kHz, IO=0.5A - 100 - - 100 - μV Output Voltage VO VIN=29V, I0=0.5A 19.2 20.0 20.8 V Line Regulation ΔVO - VIN VIN=23 to 35V, IO=0.5A - 16 200 - 16 400 mV Load Regulation ΔVO - IO VIN=29V, IO=0.005 to 1.5A - 61 200 - 61 400 mV Quiescent Current IQ VIN=29V, IO=0mA - 4.5 6.0 - 4.5 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=29V, IO=5mA - -2.0 - - -2.0 - mV/ºC Ripple Rejection RR VIN=29V, IO=0.5A , ein=2VP-P, f=120Hz 58 68 - 58 68 - dB Output Noise Voltage VNO VIN=29V, BW=10Hz to 100kHz, IO=0.5A - 120 - - 120 - μV NJM7815FA/DL1A 14.4 15.0 15.6 NJM7818FA/DL1A NJM7820FA/DL1A Ver.1.0 19.2 20.0 20.8 -4- Datasheet NJM7800 ■ ELECTRICAL CHARACTERISTICS (C1=0.33μF, CO=0.1μF, Tj=25ºC) Measurement is to be conducted in pulse testing. PARAMETER SYMBOL TEST CONDITIONS TO-220F TO-252 UNIT MIN. TYP. MAX. MIN. TYP. MAX. 23.0 24.0 25.0 23.0 24.0 25.0 V NJM7824FA/DL1A Output Voltage VO VIN=33V, I0=0.5A Line Regulation ΔVO - VIN VIN=27 to 38V, IO=0.5A - 18 240 - 18 480 mV Load Regulation ΔVO - IO VIN=33V, IO=0.005 to 1.5A - 65 240 - 65 480 mV Quiescent Current IQ VIN=33V, IO=0mA - 4.6 6.0 - 4.6 6.0 mA Average Temperature Coefficient of Output Voltage ΔVO/ΔT VIN=33V, IO=5mA - -2.4 - - -2.4 - mV/ºC Ripple Rejection RR VIN=33V, IO=0.5A , ein=2VP-P, f=120Hz 56 66 - 56 66 - dB Output Noise Voltage VNO VIN=33V, BW=10Hz to 100kHz, IO=0.5A - 120 - - 120 - μV Ver.1.0 -5- Datasheet NJM7800 ■ POWER DISSIPATION VS. AMBIENT TEMPERATURE NJM7800DL1A ■ TEST CIRCUIT 1. Output Voltage, Line Regulation, Load Regulation, Quiescent Current, Average Temperature Coefficient of Output Voltage, Output Noise Voltage Ver.1.0 2. Ripple Rejection -6- Datasheet NJM7800  Input Capacitor CIN Input Capacitor CIN is required to prevent oscillation and reduce power supply ripple for applications when high power supply impedance or a long power supply line. Therefore, use the recommended CIN value (refer to conditions of ELECTRIC CHARACTERISTIC) or larger and should connect between GND and VIN as shortest path as possible to avoid the problem.  Output Capacitor CO Output capacitor (CO) will be required for a phase compensation of the internal error amplifier. The capacitance and the equivalent series resistance (ESR) influence to stable operation of the regulator. Use of a smaller CO may cause excess output noise or oscillation of the regulator due to lack of the phase compensation. On the other hand, Use of a larger CO reduces output noise and ripple output, and also improves output transient response when rapid load change. Therefore, use the recommended CO value (refer to conditions of ELECTRIC CHARACTERISTIC) or larger and should connect between GND and VOUT as shortest path as possible for stable operation In addition, you should consider varied characteristics of capacitor (a frequency characteristic, a temperature characteristic, a DC bias characteristic and so on) and unevenness peculiar to a capacitor supplier enough. When selecting CO, recommend that have withstand voltage margin against output voltage and superior temperature characteristic though Ver.1.0 -7- Datasheet NJM7800 ■ TYPICAL CHARACTERISTICS NJM7808 Output Voltage vs. Temperature Output Voltage VO (V) Output Voltage VO (V) NJM7805 Output Voltage vs. Temperature Ambient Temperature Ta(°C) Ambient Temperature Ta(°C) NJM78M00 Series Equivalent Series Resistance vs. Output Current 100 Vin=Output voltages of the conditions described in the ELECTRICAL CHARACTERISTICS Ta=25℃,Cin=0.33uF, Co=0.1uF ESR[Ω] 10 STABLE REGION 1 0.1 0.01 0.001 Ver.1.0 0.01 0.1 1 10 Output Current Io [mA] 100 1000 -8- Datasheet NJM7800 ■ TYPICAL CHARACTERISTICS Output Voltage VO (V) NJM7805/15/24 Output Characteristics (Io=0.5A, Tj=25°C) Input Voltage VIN (V) NJM7812 Dropout Characteristics (Tj=25°C) Output Voltage VO (V) Output Voltage VO (V) NJM7805 Dropout Characteristics (Tj=25°C) Input Voltage VIN (V) Input Voltage VIN (V) Output Voltage VO (V) NJM7805/15/24 Load Characteristics (Tj=25°C) Output Current IO (A) Ver.1.0 -9- Datasheet NJM7800 Dropout Voltage VIN –VO (V) NJM7805/24 Quiescent Current vs. Input Voltage (Tj=25°C,) Quiescent Current IQ (mA) Output Current IO (A) ■ TYPICAL CHARACTERISTICS NJM7800 Series Short Circuit Output Current (Tj=25°C, ∞ Heat Sink) Input Voltage VIN (V) Output Voltage VO (V) NJM7805/15/24 Output Voltage vs. Junction Temperature Junction Temperature Tj (°C) Ripple Rejection RR (dB) NJM7805/15/24 Ripple Rejection vs. Frequency VIN = 10V (05) ein = 2VP-P 19V (12) 33V (24) Tj = 25°C Frequency (Hz) Ver.1.0 - 10 - Datasheet NJM7800 ■ REVISION HISTORY Ver.1.0 Date Revision January 08,2023 Ver. 1.0 Changes ・Change of company name and design form. ・Change of revision number (Ver.2019-11-14 → Ver.1.0) ・Added revision history - 11 - Package Information Reflow Profile Ver. PI-REFLOW-E-A Package Surface Temperature(℃) ■ HEAT-RESISTANCE PROFILES 3℃/s MAX. 260℃ MAX. 255℃ 30s MAX. 200℃ 6℃/s MAX. 217℃ 150℃ 60-150s 60-120s Time(s) Reflow profile Package Information TO-220F-3 PI-TO-220F-3-E-B ■ PACKAGE DIMENSIONS 2.8 ±0.3 UNIT: mm 4.7 ±0.3 2.8 ±0.3 6.5 ±0.3 10.0 ±0.3 4.8 ±0.3 9.5 ±0.3 φ3.2 ±0.1 1.3 2.55 ±0.3 12.5MIN. 1.7 0.65 ±0.1 1 2 3 2.54 2.54 0.7 +0.15 -0.10 Package Information TO-220F-3 PI-TO-220F-3-E-B ■ PACKING SPEC UNIT: mm STICK STATE Stick (MAX. 50pcs) Cross section 520 11.8 7 34.4 7 Direction of 1pin. PACKING STATE Label Package Information TO-220F-3 PI-TO-220F-3-E-B ■ PACKING SPEC UNIT: mm 180 BAG STATE Quantity 100pcs/bag 120 PACKING STATE Label Package Information TO-252-3-L1 PI-TO-252-3-L1-E-A ■ PACKAGE DIMENSIONS 1.14 ±0 .1 3 UNIT: mm 6.54 ±0.19 5.34 ± 0.12 0.52 ±0.06 3 0.76 ±0.12 0.76 ±0.12 2.28 0.52 ±0.06 (1.7) 4.15 ~4.50 5.4 ±0 .1 5 (2.5) (4.8) ■ EXAMPLE OF SOLDER PADS DIMENSIONS 1 0. 5 6 .0 6.0 2.0 2 .5 2.0 2.3 (1.4) (0.9) 2.28 5.34 ±0.12 2.3 0.51 1 0 ~0.25 2.5±0.5 0.83 ± 0. 19 6.04 ±0.06 2 2.29 ± 0.09 Package Information TO-252-3-L1 PI-TO-252-3-L1-E-A ■ PACKING SPEC UNIT: mm TAPING DIMENSIONS Feed direction φD0 P0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A T2 φD1 P1 DIMENSION 6.9±0.1 10.5±0.1 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 7.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.3±0.05 3.4 max 16.0±0.3 13.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 E SYMBOL A B C E W W1 A B C DIMENSION φ330±2 φ 80±1 φ 13±0.5 2 17.5±0.5 2±0.5 W TAPING STATE Insert direction Sealing with covering tape (TE1) Feed direction Empty tape Devices Empty tape Covering tape more than 160mm 3000pcs/reel more than 160mm more than 230mm PACKING STATE Label Label Put a reel into a box 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
NJM7805FA 价格&库存
很抱歉,暂时无法提供与“NJM7805FA”相匹配的价格&库存,您可以联系我们找货
NJM7805FA
    • 1+2.39800
    • 50+1.83700
    • 1000+1.70500
    库存:1389
