S-1170B34PD-OTTTFG
S-1170B34PD-OTTTFG
    ABLIC(艾普凌科)
    SMD6_EP
    IC REG LINEAR 3.4V 800MA 6HSON
S-1170B34PD-OTTTFG 数据手册
S-1170 Series www.ablic.com www.ablicinc.com HIGH RIPPLE-REJECTION AND LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 © ABLIC Inc., 2003-2015 The S-1170 Series is a positive voltage regulator with a low dropout voltage, high-accuracy output voltage, and low current consumption developed based on CMOS technology. A built-in low on-resistance transistor provides a low dropout voltage and large output current, a built-in overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor, and a built-in thermal shutdown circuit prevents damage caused by the heat. An ON/OFF circuit ensures a long battery life. Compared with the voltage regulators using the conventional CMOS technology, a larger variety of capacitors are available, including small ceramic capacitors. Small SOT-89-5 and 6-Pin HSON(A) packages realize high-density mounting.  Features  Output voltage:  Output voltage accuracy:  Dropout voltage:  Current consumption:  Output current:  Input and output capacitors:  Ripple rejection:  Built-in overcurrent protection circuit:  Built-in thermal shutdown circuit:  Built-in ON/OFF circuit:  Operation temperature range:  Lead-free, Sn 100%, halogen-free*2 1.5 V to 5.5 V, selectable in 0.1 V step 1.0% 120 mV typ. (3.0 V output product, IOUT = 300 mA) During operation: 80 A typ., 160 A max. During power-off: 0.1 A typ., 1.0 A max. Possible to output 800 mA (VIN  VOUT(S)  1.0 V)*1 A ceramic capacitor of 4.7 F or more can be used. 70 dB typ. (f = 1.0 kHz) Limits overcurrent of output transistor. Prevents damage caused by heat. Ensures long battery life. Ta = 40°C to 85°C *1. Attention should be paid to the power dissipation of the package when the output current is large. *2. Refer to “ Product Name Structure” for details.  Applications  Constant-voltage power supply for DVD and CD-ROM drive  Constant-voltage power supply for battery-powered device  Constant-voltage power supply for personal communication device  Constant-voltage power supply for notebook PC  Packages  SOT-89-5  6-Pin HSON(A) 1 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Block Diagram *1 VIN VOUT Overcurrent protection circuit Thermal shutdown circuit ON/OFF circuit ON/OFF   Reference voltage circuit VSS *1. Parasitic diode Figure 1 2 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Product Name Structure Users can select the product type, output voltage, and package type for the S-1170 Series. Refer to “1. Product name” regarding the contents of product name, “2. Packages” regarding the package drawings, “3. Product name list” regarding details of the product name. 1. Product name (1) SOT-89-5 S-1170 x xx UC  xxx TF x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) IC direction in tape specifications*1 Product name (abbreviation)*2 Package name (abbreviation) UC: SOT-89-5 Output voltage 15 to 55 (E.g., when the output voltage is 1.5 V, it is expressed as 15.) Product type*3 A: ON/OFF pin negative logic B: ON/OFF pin positive logic *1. Refer to the tape drawing. *2. Refer to the product name list. *3. Refer to “3. ON/OFF pin” in “ Operation”. 3 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series (2) 6-Pin HSON(A) S-1170 x xx PD  xxx TF x Environmental code S: Lead-free, halogen-free G: Lead-free (for details, please contact our sales office) IC direction in tape specifications*1 Product name (abbreviation)*2 Package name (abbreviation) PD: 6-Pin HSON(A) Output voltage 15 to 55 (E.g., when the output voltage is 1.5 V, it is expressed as 15.) Product type*3 A: ON/OFF pin negative logic B: ON/OFF pin positive logic *1. Refer to the tape drawing. *2. Refer to the product name list. *3. Refer to “3. ON/OFF pin” in “ Operation”. 2. Packages Package Name SOT-89-5 6-Pin HSON(A) 4 Package UP005-A-P-SD PD006-A-P-SD Drawing Code Tape UP005-A-C-SD PD006-A-C-SD Reel UP005-A-R-SD PD006-A-R-SD HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series 3. Product name list Table 1 Output Voltage SOT-89-5 6-Pin HSON(A) S-1170B15UC-OTATFx S-1170B15PD-OTATFz 1.5 V 1.0% S-1170B16UC-OTBTFx S-1170B16PD-OTBTFz 1.6 V 1.0% S-1170B17UC-OTCTFx S-1170B17PD-OTCTFz 1.7 V 1.0% S-1170B18UC-OTDTFx S-1170B18PD-OTDTFz 1.8 V 1.0% S-1170B19UC-OTETFx S-1170B19PD-OTETFz 1.9 V 1.0% S-1170B20UC-OTFTFx S-1170B20PD-OTFTFz 2.0 V 1.0% S-1170B21UC-OTGTFx S-1170B21PD-OTGTFz 2.1 V 1.0% S-1170B22UC-OTHTFx S-1170B22PD-OTHTFz 2.2 V 1.0% S-1170B23UC-OTITFx S-1170B23PD-OTITFz 2.3 V 1.0% S-1170B24UC-OTJTFx S-1170B24PD-OTJTFz 2.4 V 1.0% S-1170B25UC-OTKTFx S-1170B25PD-OTKTFz 2.5 V 1.0% S-1170B26UC-OTLTFx S-1170B26PD-OTLTFz 2.6 V 1.0% S-1170B27UC-OTMTFx S-1170B27PD-OTMTFz 2.7 V 1.0% S-1170B28UC-OTNTFx S-1170B28PD-OTNTFz 2.8 V 1.0% S-1170B29UC-OTOTFx S-1170B29PD-OTOTFz 2.9 V 1.0% S-1170B30UC-OTPTFx S-1170B30PD-OTPTFz 3.0 V 1.0% S-1170B31UC-OTQTFx S-1170B31PD-OTQTFz 3.1 V 1.0% S-1170B32UC-OTRTFx S-1170B32PD-OTRTFz 3.2 V 1.0% S-1170B33UC-OTSTFx S-1170B33PD-OTSTFz 3.3 V 1.0% S-1170B34UC-OTTTFx S-1170B34PD-OTTTFz 3.4 V 1.0% S-1170B35UC-OTUTFx S-1170B35PD-OTUTFz 3.5 V 1.0% S-1170B36UC-OTVTFx S-1170B36PD-OTVTFz 3.6 V 1.0% S-1170B37UC-OTWTFx S-1170B37PD-OTWTFz 3.7 V 1.0% S-1170B38UC-OTXTFx S-1170B38PD-OTXTFz 3.8 V 1.0% S-1170B39UC-OTYTFx S-1170B39PD-OTYTFz 3.9 V 1.0% S-1170B40UC-OTZTFx S-1170B40PD-OTZTFz 4.0 V 1.0% S-1170B41UC-OUATFx S-1170B41PD-OUATFz 4.1 V 1.0% S-1170B42UC-OUBTFx S-1170B42PD-OUBTFz 4.2 V 1.0% S-1170B43UC-OUCTFx S-1170B43PD-OUCTFz 4.3 V 1.0% S-1170B44UC-OUDTFx S-1170B44PD-OUDTFz 4.4 V 1.0% S-1170B45UC-OUETFx S-1170B45PD-OUETFz 4.5 V 1.0% S-1170B46UC-OUFTFx S-1170B46PD-OUFTFz 4.6 V 1.0% S-1170B47UC-OUGTFx S-1170B47PD-OUGTFz 4.7 V 1.0% S-1170B48UC-OUHTFx S-1170B48PD-OUHTFz 4.8 V 1.0% S-1170B49UC-OUITFx S-1170B49PD-OUITFz 4.9 V 1.0% S-1170B50UC-OUJTFx S-1170B50PD-OUJTFz 5.0 V 1.0% S-1170B51UC-OUKTFx S-1170B51PD-OUKTFz 5.1 V 1.0% S-1170B52UC-OULTFx S-1170B52PD-OULTFz 5.2 V 1.0% S-1170B53UC-OUMTFx S-1170B53PD-OUMTFz 5.3 V 1.0% S-1170B54UC-OUNTFx S-1170B54PD-OUNTFz 5.4 V 1.0% S-1170B55UC-OUOTFx S-1170B55PD-OUOTFz 5.5 V 1.0% Remark 1. Please contact our sales office for products with an output voltage other than those specified above or type A products. 2. x: G or U z: G or S 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 5 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Pin Configurations Table 2 SOT-89-5 Top view 5 4 *1. 1 2 3 Figure 2 Table 3 6-Pin HSON(A) Top view 6 5 4 1 2 3 Bottom view 1 2 3 *1 *2 6 *1. 5 4 Connect the exposed thermal die pad at shadowed area to the board, and set electric potential open or VSS. However, do not use it as the function of electrode. *2. Be careful of the contact with other wires because the pinch lead has the same electric potential as VSS. Figure 6 Pin No. Symbol Description 1 ON/OFF ON/OFF pin 2 VSS GND pin No connection 3 NC*1 4 VIN Input voltage pin 5 VOUT Output voltage pin The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. 3 *1. *2. Pin No. Symbol 1 VOUT*1 2 VOUT*1 3 ON/OFF 4 VSS 5 VIN*2 6 VIN*2 Short pins 1 and 2. Short pins 5 and 6. Description Output voltage pin Output voltage pin ON/OFF pin GND pin Input voltage pin Input voltage pin HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Absolute Maximum Ratings Table 4 Parameter Input voltage Output voltage Power SOT-89-5 dissipation 6-Pin HSON(A) Operation ambient temperature Storage temperature *1. Symbol VIN VON/OFF VOUT (Ta  25C unless otherwise specified) Absolute Maximum Rating Unit V VSS  0.3 to VSS  7 V VSS  0.3 to VIN  0.3 V VSS  0.3 to VIN  0.3 PD 1000 *1 mW Topr Tstg 40 to 85 40 to 125 C C At mounted on printed circuit board [Mounted board] (1) Board size : 40 mm×40 mm×t1.6 mm (2) Cu wiring shear : 180 % at both sides Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1200 SOT-89-5 6-Pin HSON(A) 1000 800 Power Dissipation 600 PD (mW) 400 200 0 0 50 100 150 Ambient Temperature Ta (C) Figure Caution 4 Power Dissipation of Package (Mounted on Printed Circuit Board) Thermal shutdown circuit may operate when junction temperature is 150 C. 7 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Electrical Characteristics Table 5 (Ta  25C unless otherwise specified) Parameter Output voltage*1 Output current *2 Dropout voltage*3 Symbol VOUT(E) 8 1 mA V V V V V V 3 1 1 1 1 1 1 0.3 %/V 1 30 100 mV 1  150  ppm / C 1  80 160 A 2  0.1 1.0 A 2 2.0  6.5 V  VOUT(S)  0.99 800*5       VOUT(S)  0.35 0.30 0.25 0.20 0.15 0.12 VOUT(S)  1.01  0.45 0.35 0.30 0.26 0.22 0.18  0.05  VIN  VOUT(S)  1.0 V, RL  1.0 k 1.5   V 4 VSL VIN  VOUT(S)  1.0 V, RL  1.0 k   0.3 V 4 ISH VIN  6.5 V, VON/OFF  6.5 V 0.1  0.1 A 4 ISL VIN  6.5 V, VON/OFF  0 V 0.1  0.1 A 4 1.5 V  VOUT(S)  3.0 V  70  dB 5 RR VIN  VOUT(S)  1.0 V, f  1.0 kHz, Vrip  0.5 Vrms, IOUT  100 mA 3.1 V  VOUT(S)  5.5 V  65  dB 5 VOUT2 Thermal shutdown detection temperature Thermal shutdown release temperature V Max. VSH Load regulation Short-circuit current Test Circuit Typ. VIN Vdrop VOUT1 VINVOUT Ripple rejection VIN  VOUT(S)  1.0 V, IOUT  100 mA Unit Min. VIN  VOUT(S)  1.0 V VOUT(S)  1.5 V VOUT(S)  1.6 V VOUT(S)  1.7 V IOUT  300 mA 1.8 V  VOUT(S)  2.0 V 2.1 V  VOUT(S)  2.9 V 3.0 V  VOUT(S)  5.5 V VOUT(S)  0.5 V  VIN  6.5 V, IOUT  100 mA VIN  VOUT(S)  1.0 V, 1.0 mA  IOUT  300 mA VIN  VOUT(S)  1.0 V, IOUT  10 mA, 40C  Ta  85C VIN  VOUT(S)  1.0 V, ON/OFF pin  ON, no load VIN  VOUT(S)  1.0 V, ON/OFF pin  OFF, no load  IOUT Line regulation Output voltage *4 temperature coefficient Current consumption during operation Current consumption during power-off Input voltage ON/OFF pin input voltage “H” ON/OFF pin input voltage “L” ON/OFF pin input current “H” ON/OFF pin input current “L” Conditions VOUT TaVOUT ISS1 ISS2 Ishort VIN  VOUT(S)  1.0 V, ON/OFF pin  ON, VOUT  0 V  350  mA 3 TSD Junction temperature  150  C  TSR Junction temperature  120  C  HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT ( 100 mA) and inputting VOUT(S)  1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop  VIN1  (VOUT3  0.98) VOUT3 is the output voltage when VIN  VOUT(S)  1.0 V and IOUT  300 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. VOUT VOUT [mV/°C]*1 = VOUT(S) [V]*2  Ta V [ppm/°C]*3  1000 Ta OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 9 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Test Circuits 1.  VOUT VIN V ON/OFF A  VSS Set to ON Figure 2.  A 5 VOUT VIN ON/OFF VSS Set to VIN or GND Figure 3. VIN 6 VOUT ON/OFF  A V VSS  Set to ON Figure 4. VIN  VOUT  A ON/OFF VSS Figure 5. 7 VIN 8 VOUT ON/OFF VSS Set to ON Figure 10 RL V 9 V  RL HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Standard Circuit Output Input VIN CIN VOUT *2 CL ON/OFF VSS *1 GND Single GND *1. CIN is a capacitor for stabilizing the input. *2. A ceramic capacitor of 4.7 F or more can be used for CL. Figure 10 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant.  Condition of Application Input capacitor (CIN): Output capacitor (CL): ESR of output capacitor: 4.7 F or more 4.7 F or more 0.5  or less Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Check that no oscillation occurs with the application using the above capacitor.  Selection of Input and Output Capacitors (CIN, CL) The S-1170 Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. A ceramic capacitor with a capacitance of 4.7 F or more provides a stable operation in all temperature ranges. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 4.7 F or more, and the ESR must be 0.5  or less. The output overshoot and undershoot values, which are transient response characteristics, vary depending on the output capacitor value. The required capacitance value for the input capacitor differs depending on the application. The recommended value for an application is CIN  4.7 F and CL  4.7 F, however, perform a thorough evaluation using the actual device, including evaluation of temperature characteristics. 11 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Low ESR A capacitor whose ESR (Equivalent Series Resistance) is low. The S-1170 Series enables use of a low ESR capacitor, such as a ceramic capacitor, for the output-side capacitor (CL). A capacitor whose ESR is 0.5  or less can be used. 3. Output voltage (VOUT) The accuracy of the output voltage is ensured at 1.0% under the specified conditions of fixed input voltage*1, fixed output current, and fixed temperature. *1. Differs depending the product. Caution If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data)” for details. VOUT1  VINVOUT  4. Line regulation  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 5. Load regulation (VOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 6. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S)  1.0 V. Vdrop  VIN1  (VOUT3  0.98) 12 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series VOUT  Ta  VOUT  7. Output voltage temperature coefficient  The shaded area in Figure 11 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is 150 ppm/C. Example of S-1170B28 typ. product VOUT [V] 0.42 mV/C VOUT(E)*1 0.42 mV/C 40 25 85 Ta [C] *1. VOUT(E) is the value of the output voltage measured at Ta = 25C. Figure 11 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. V VOUT [mV/°C]*1 = VOUT(S) [V]*2  Ta OUT [ppm/°C]*3  1000 Ta VOUT *1. *2. *3. Change in temperature of output voltage Set output voltage Output voltage temperature coefficient 13 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Operation 1. Basic operation Figure 12 shows the block diagram of the S-1170 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT  Rf  Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 12 2. Output transistor In the S-1170 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN  0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 14 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series 3. ON/OFF pin This pin starts and stops the regulator. When the ON/OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. The VOUT pin becomes the VSS level due to the internally divided resistance of several hundreds k between the VOUT pin and the VSS pin. The structure of the ON/OFF pin is as shown in Figure 13. Since the ON/OFF pin is neither pulled down nor pulled up internally, do not use it in the floating status. In addition, note that the current consumption increases if a voltage of 0.3 V to VIN  0.3 V is applied to the ON/OFF pin. When not using the ON/OFF pin, connect it to the VSS pin in the product A type, and connect it to the VIN pin in B type. Table 6 Product Type ON/OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption A “L”: ON Operate Set value ISS1 A “H”: OFF Stop VSS level ISS2 B “L”: OFF Stop VSS level ISS2 B “H”: ON Operate Set value ISS1 VIN ON/OFF VSS Figure 13 15 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series 4. Thermal shutdown circuit The S-1170 Series implements a thermal shutdown circuit to protect the device from damage due to overheating. When the junction temperature rises to 150C (typ.), the thermal shutdown circuit operates and the regulator operation stops. When the junction temperature drops to 120C (typ.), the thermal shutdown circuit is released and the regulator operation resumes. If the thermal shutdown circuit starts operating due to self-heating, the regulator operation stops and the output voltage falls. When the regulator operation has stopped, no self-heat is generated and the temperature of the IC is lowered. When the temperature has dropped, the thermal shutdown circuit is released, the regulator operation resumes, and self-heat is generated again. By repeating this procedure, the output voltage waveform forms pulses. Stop or restart of regulation continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Table 7 16 Thermal Shutdown Circuit VOUT Pin Voltage Operating: 150C (typ.) VSS level Released: 120C (typ.) Set value HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Precautions  Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible.  Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less).  Note that the output voltage may increase due to the leakage current from an output driver even if the ON/OFF pin is at OFF level when a series regulator is used at high temperature.  Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1170 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Input capacitor (CIN): 4.7 F or more Output capacitor (CL): 4.7 F or more Equivalent series resistance (ESR): 0.5  or less  The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected.  Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device.  The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  In determining the output current, attention should be paid to the output current value specified in Table 5 in “ Electrical Characteristics” and footnote *5 of the table.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 17 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Characteristics (Typical Data) (1) Output voltage vs. Output current (when load current increases) S-1170B30 (Ta  25C) 3.5 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 3.0 2.5 VOUT [V] VOUT [V] S-1170B15 (Ta  25C) VIN  2.0 V 2.5 V 6.5 V VIN  3.5 V 2.0 4.0 V 1.5 6.5 V 1.0 0.5 0 0 200 400 800 600 1000 1200 0 200 IOUT [mA] 400 800 600 1000 1200 IOUT [mA] S-1170B50 (Ta  25C) 6 5 VOUT [V] 4 VIN  5.5 V 6.0 V 6.5 V 3 2 1 0 0 200 400 600 800 1000 1200 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 5 in “ Electrical Characteristics” 2. The package power dissipation IOUT [mA] (2) Output voltage vs. Input voltage S-1170B30 (Ta  25C) 1.6 3.1 1.5 3.0 1.4 IOUT  1 mA 10 mA 100 mA 300 mA 1.3 1.2 1.1 1.0 1.0 VOUT [V] VOUT [V] S-1170B15 (Ta  25C) 1.5 2.0 2.5 3.0 3.5 5.1 5.0 VOUT [V] 4.9 4.6 4.5 4.5 IOUT  1 mA 10 mA 100 mA 300 mA 5.0 5.5 VIN [V] 18 2.7 2.5 2.5 3.0 3.5 VIN [V] S-1170B50 (Ta  25C) 4.7 IOUT  1 mA 10 mA 100 mA 300 mA 2.8 2.6 VIN [V] 4.8 2.9 6.0 6.5 7.0 4.0 4.5 5.0 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series (3) Dropout voltage vs. Output current S-1170B30 0.6 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 25C 25C 0.5 85C Vdrop [V] Vdrop [V] S-1170B15 40C 85C 0.4 0.3 40C 0.2 0.1 0 100 200 300 400 500 600 700 800 900 IOUT [mA] 0 0 100 200 300 400 500 600 700 800 900 IOUT [mA] S-1170B50 0.6 Vdrop [V] 0.5 25C 0.4 85C 0.3 40C 0.2 0.1 0 0 100 200 300 400 500 600 700 800 900 IOUT [mA] Vdrop [V] (4) Dropout voltage vs. Set output voltage 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 800 mA 600 mA 300 mA 10 mA 0 1 2 3 4 5 6 VOUT(S) [V] 19 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series (5) Output voltage vs. Ambient temperature 1.70 1.65 1.60 1.55 1.50 1.45 1.40 1.35 1.30 40 25 S-1170B30 (IOUT  10 mA) VOUT(E) [V] VOUT(E) [V] S-1170B15 (IOUT  10 mA) 25 0 75 85 50 3.20 3.15 3.10 3.05 3.00 2.95 2.90 2.85 2.80 40 25 25 0 Ta [C] 75 85 50 Ta [C] VOUT(E) [V] S-1170B50 (IOUT  10 mA) 5.20 5.15 5.10 5.05 5.00 4.95 4.90 4.85 4.80 40 25 0 50 25 75 85 Ta [C] (6) Current consumption vs. Input voltage 80 70 60 50 40 30 20 10 0 S-1170B30 (Ta  25C) ISS1 [A] ISS1 [A] S-1170B15 (Ta  25C) 0 1 2 3 4 5 6 7 VIN [V] 0 1 2 3 ISS1 [A] VIN [V] 20 4 0 1 2 3 VIN [V] S-1170B50 (Ta  25C) 80 70 60 50 40 30 20 10 0 80 70 60 50 40 30 20 10 0 5 6 7 4 5 6 7 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series (7) Ripple rejection S-1170B15 (Ta  25C) S-1170B30 (Ta  25C) VIN  2.5 V, COUT  4.7 F VIN  4.0 V, COUT  4.7 F 100 IOUT  50 mA Ripple Rejection [dB] Ripple Rejection [dB] 100 80 60 100 mA 40 20 0 10 1k 100 10k 100k 1M Frequency [Hz] IOUT  50 mA 80 60 40 100 mA 20 0 10 100 1k 10k 100k 1M Frequency [Hz] S-1170B50 (Ta  25C) VIN  6.0 V, COUT  4.7 F Ripple Rejection [dB] 100 IOUT  50 mA 80 60 100 mA 40 20 0 10 100 1k 10k 100k 1M Frequency [Hz] 21 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series  Reference Data (1) Input transient response characteristics S-1170B30 IOUT  100 mA, tr  tf  5.0 s, COUT  4.7 F, CIN  4.7 F IOUT  100 mA, tr  tf  5.0 s, COUT  4.7 F, CIN  4.7 F VOUT 20 10 0 10 20 30 40 50 60 6.0 3.08 3.06 5.0 VIN 3.04 4.0 3.0 3.02 3.00 2.98 2.96 2.0 VOUT 20 10 VIN [V] VIN 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] 1.62 1.60 1.58 1.56 1.54 1.52 1.50 1.48 1.46 VIN [V] VOUT [V] S-1170B15 1.0 0 0 10 t [s] 20 30 40 50 60 t [s] S-1170B50 5.12 5.10 5.08 5.06 5.04 5.02 5.00 4.98 4.96 VIN VOUT 20 10 0 10 20 30 40 50 60 8.0 7.0 6.0 5.0 4.0 3.0 2.0 1.0 0 VIN [V] VOUT [V] IOUT  100 mA, tr  tf = 5.0 s, COUT  4.7 F, CIN  4.7 F t [s] (2) Load transient response characteristics S-1170B15 (Ta  25C) S-1170B30 (Ta  25C) VIN  2.5 V, COUT  4.7 F, CIN  4.7 F, IOUT  50 mA 100 mA VIN  4.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  50 mA 100 mA 1.60 1.55 3.20 100 3.15 50 3.10 0 VOUT 20 40 60 80 2.95 100 150 2.90 20 100 120 140 160 t [s] VIN  6.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  50 mA 100 mA 150 IOUT 100 50 VOUT [V] 5.10 5.05 0 VOUT 5.00 50 4.95 100 4.90 20 150 0 20 40 60 80 t [s] 22 100 120 140 160 IOUT [mA] 5.15 0 20 40 60 80 t [s] S-1170B50 (Ta  25C) 5.20 0 VOUT 100 1.45 0 50 50 50 20 100 3.00 1.50 1.40 3.05 150 IOUT 100 120 140 150 160 IOUT [mA] VOUT [V] 1.65 150 VOUT [V] IOUT IOUT [mA] 1.70 HIGH RIPPLE-REJECTION LOW DROPOUT HIGH OUTPUT CURRENT CMOS VOLTAGE REGULATOR Rev.4.1_02 S-1170 Series S-1170B15 (Ta  25C) S-1170B30 (Ta  25C) VIN  2.5 V, COUT  4.7 F, CIN  4.7 F, IOUT  100 mA VIN  4.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  100 mA 5 3 1 2 0 1 1 VOUT VOUT [V] 2 VON/OFF 3 VON/OFF [V] VOUT [V] 4 2 0 1 10 0 10 20 30 40 50 60 70 80 3 90 7 6 5 4 3 2 1 0 1 6 4 2 0 2 4 6 VON/OFF VOUT 10 0 10 20 t [s] 30 40 50 60 70 80 VON/OFF [V] (3) ON/OFF pin transient response characteristics 90 t [s] S-1170B50 (Ta  25C) VIN  6.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  100 mA VOUT [V] 7 3 VON/OFF 5 0 3 3 VOUT 1 VON/OFF [V] 6 9 6 1 10 0 10 20 30 40 50 60 70 80 90 3 4 2 VON/OFF 3 1 2 0 1 1 VOUT 2 0 1 10 0 10 20 30 40 50 60 70 80 3 90 t [s] VOUT [V] 5 VON/OFF [V] VIN  4.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  300 mA VOUT [V] S-1170B30 (Ta  25C) VIN  2.5 V, COUT  4.7 F, CIN  4.7 F, IOUT  300 mA 7 6 5 4 3 2 1 0 1 6 4 2 0 2 4 6 VON/OFF VOUT 10 0 10 20 30 40 50 60 70 80 VON/OFF [V] t [s] S-1170B15 (Ta  25C) 90 t [s] S-1170B50 (Ta  25C) VIN  6.0 V, COUT  4.7 F, CIN  4.7 F, IOUT  300 mA VOUT [V] 7 3 VON/OFF 5 0 3 3 VOUT 1 1 10 0 VON/OFF [V] 6 9 6 10 20 30 40 50 60 70 80 90 t [s] 23 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 +0.1 0.80 -0.05 2.90±0.1 (1.5) 0.15±0.05 0.5typ. +0.1 0.30 -0.05 0.95±0.05 The exposed thermal die pad has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PD006-A-P-SD-5.0 TITLE HSON6A-A-PKG Dimensions No. PD006-A-P-SD-5.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 1.5±0.1 2.0±0.05 ø1.55±0.05 0.2±0.05 3.3±0.1 3 1 4 6 ø1.05±0.05 4.0±0.1 Feed direction No. PD006-A-C-SD-2.0 TITLE HSON6A-A-Carrier Tape No. PD006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PD006-A-R-SD-1.0 TITLE HSON6A-A-Reel No. PD006-A-R-SD-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. 14. For more details on the information described herein, contact our sales office. 2.2-2018.06 www.ablic.com
S-1170B34PD-OTTTFG
物料型号:S-1170 Series
器件简介: S-1170系列是一款基于CMOS技术开发的正电压调节器,具有低 dropout 电压、高准确度输出电压和低电流消耗的特点。内置的低电阻晶体管提供了低dropout电压和大输出电流,同时还有过流保护电路、热关断电路和ON/OFF电路,确保了电池的长寿命和器件的保护。
引脚分配: - SOT-89-5封装:1脚为ON/OFF控制,2脚为GND,3脚无连接,4脚为输入电压VIN,5脚为输出电压VOUT。 - 6-Pin HSON(A)封装:1和2脚为输出电压VOUT1,3脚为ON/OFF控制,4脚为GND,5和6脚为输入电压VIN2。
参数特性: - 输出电压:1.5V至5.5V,以0.1V步进可调 - 输出电压精度:±1.0% - Dropout电压:典型值120mV(3.0V输出,输出电流300mA) - 工作电流:典型值80μA,最大160μA - 关闭电源时电流:典型值0.1μA,最大1.0μA - 输出电流:可达800mA(VIN ≥ VOUT(S) + 1.0V) - 抑制纹波能力:典型值70dB(1kHz频率)
功能详解: - 该系列提供了多种保护机制,包括过流保护、热关断和ON/OFF控制,以提高系统的可靠性和电池寿命。 - 设计了低ESR(等效串联电阻)电容的使用,允许使用陶瓷电容等低ESR电容作为输出端电容。
应用信息: - 适用于DVD和CD-ROM驱动器的恒压电源 - 适用于电池供电设备的恒压电源 - 适用于个人通信设备的恒压电源 - 适用于笔记本电脑的恒压电源
封装信息: - 提供SOT-89-5和6-Pin HSON(A)两种封装选项,支持高密度安装。
S-1170B34PD-OTTTFG 价格&库存
很抱歉,暂时无法提供与“S-1170B34PD-OTTTFG”相匹配的价格&库存,您可以联系我们找货
