TPS54060-Q1
SLVSA25A – JANUARY 2010 – REVISED MARCH 2011
www.ti.com
0.5-A 60-V STEP-DOWN SWIFT™ DC/DC CONVERTER WITH Eco-mode™
Check for Samples: TPS54060-Q1
FEATURES
1
Qualified for Automotive Applications
3.5-V to 60-V Input Voltage Range
200-mΩ High-Side MOSFET
High Efficiency at Light Loads with a Pulse
Skipping Eco-mode™ Control Scheme
116-μA Operating Quiescent Current
1.3-μA Shutdown Current
100-kHz to 2.5-MHz Switching Frequency
Synchronizes to External Clock
Adjustable Slow Start/Sequencing
Undervoltage and Overvoltage Power Good
Output
Adjustable UVLO Voltage and Hysteresis
0.8-V Internal Voltage Reference
Supported by SwitcherPro™ Software Tool
(http://focus.ti.com/docs/toolsw/folders/print/s
witcherpro.html)
For SWIFT™ Documentation, See the TI
Website at http://www.ti.com/swift
APPLICATIONS
12-V, 24-V and 48-V Industrial and Commercial
Low Power Systems
Aftermarket Auto Accessories: Video, GPS,
Entertainment
DESCRIPTION
The TPS54060 device is a 60-V 0.5-A step-down regulator with an integrated high-side MOSFET. Current-mode
control provides simple external compensation and flexible component selection. A low-ripple pulse-skip mode
reduces the no load, regulated output supply current to 116 μA. Using the enable pin, shutdown supply current is
reduced to 1.3 μA, when the enable pin is low.
Under voltage lockout is internally set at 2.5 V, but can be increased using the enable pin. The output voltage
startup ramp is controlled by the slow start pin that can also be configured for sequencing/tracking. An
open-drain power good signal indicates the output is within 93% to 107% of its nominal voltage.
A wide switching frequency range allows efficiency and external component size to be optimized. Frequency fold
back and thermal shutdown protects the part during an overload condition.
The TPS54060 is available in a 10-pin thermally enhanced MSOP PowerPAD™ package (DGQ) and a 10-pin
SON package (DRC).
SIMPLIFIED SCHEMATIC
VIN
EFFICIENCY
vs
LOAD CURRENT
PWRGD
100
TPS54060
90
BOOT
PH
SS /TR
RT /CLK
COMP
Efficiency - %
80
EN
70
60
50
40
30
VI = 12 V,
VO = 3.3 V,
fsw = 500 kHz
VSENSE
10
GND
0.05
0.1 0.15
0.2 0.25 0.3 0.35
Load Current - A
0.4 0.45
0.5
1
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2010–2011, Texas Instruments Incorporated
TPS54060-Q1
www.ti.com
This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with
appropriate precautions. Failure to observe proper handling and installation procedures can cause damage.
ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more
susceptible to damage because very small parametric changes could cause the device not to meet its published specifications.
ORDERING INFORMATION
TJ
–40°C to 150°C
PACKAGE
ORDERABLE PART NUMBER
TOP-SIDE MARKING
MSOP – DGQ
Reel of 2500
TPS54060QDGQRQ1
5406Q
SON – DRC
Reel of 3000
TPS54060QDRCRQ1
5406Q
ABSOLUTE MAXIMUM RATINGS (1)
Over operating temperature range (unless otherwise noted).
VALUE
VIN
–0.3 V to 65 V
EN (2)
–0.3 V to 5 V
BOOT
Input voltage
73 V
VSENSE
–0.3 V to 3 V
COMP
–0.3 V to 3 V
PWRGD
–0.3 V to 6 V
–0.3 V to 3 V
SS/TR
–0.3 V to 3.6 V
RT/CLK
BOOT-PH
8V
–0.6 V to 65 V
Output voltage
PH
200 ns
–1 V to 65 V
30 ns
–2 V to 65 V
Maximum dc voltage, Tj=-40C
Voltage difference
Source current
EN
100 μA
BOOT
100 mA
10 μA
VSENSE
PH
Current Limit
100 μA
RT/CLK
VIN
Sink current
Electrostatic
discharge rating
-0.85V
±200 mV
PAD to GND
Current Limit
100 μA
COMP
PWRGD
10 mA
SS/TR
200 μA
Human-Body Model (HBM) QSS 009-105 (JESD22-A114A)
500 V
Machine Model (MM) QSS 009-105 (JESD22-A115A)
Charged-Device Model (CDM) QSS 009-147 (JESD22-C101B.01)
50 V
1000 V
Operating junction temperature
–40°C to 150°C
Storage temperature
–65°C to 150°C
(1)
(2)
2
Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings
only and functional operation of the device at these or any other conditions beyond those indicated under recommended operating
conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
See Enable and Adjusting Undervoltage Lockout for details.
Submit Documentation Feedback
Product Folder Link(s): TPS54060-Q1
TPS54060-Q1
www.ti.com
THERMAL INFORMATION
TPS54060-Q1
THERMAL METRIC (1) (2)
θJA
DGQ
DRC
10 PINS
10 PINS
62.5
56.5
Junction-to-ambient thermal resistance (standard board)
(3)
θJA
Junction-to-ambient thermal resistance (custom board)
57
61.5
θJCtop
Junction-to-case (top) thermal resistance
83
52.1
θJB
Junction-to-board thermal resistance
28
20.6
ψJT
Junction-to-top characterization parameter
1.7
0.9
ψJB
Junction-to-board characterization parameter
20.1
20.8
θJCbot
Junction-to-case (bottom) thermal resistance
21
5.2
(1)
(2)
(3)
UNITS
°C/W
For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report, SPRA953.
Power rating at a specific ambient temperature TA should be determined with a junction temperature of 150°C. This is the point where
distortion starts to substantially increase. See power dissipation estimate in application section of this data sheet for more information.
Test boards conditions:
(a) 3 inches x 3 inches, 2 layers, thickness: 0.062 inch
(b) 2 oz. copper traces located on the top of the PCB
(c) 2 oz. copper ground plane, bottom layer
(d) 6 thermal vias (13mil) located under the device package
ELECTRICAL CHARACTERISTICS
TJ = –40°C to 150°C, VIN = 3.5 to 60V (unless otherwise noted)
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
SUPPLY VOLTAGE (VIN PIN)
Operating input voltage
3.5
60
Internal undervoltage lockout
threshold
No voltage hysteresis, rising and falling
2.5
Shutdown supply current
EN = 0 V, 25°C, 3.5 V ≤ VIN ≤ 60 V
1.3
4
Operating : nonswitching supply
current
VSENSE = 0.83 V, VIN = 12 V, 25°C
116
136
1.25
1.55
V
V
μA
ENABLE AND UVLO (EN PIN)
Enable threshold voltage
Input current
No voltage hysteresis, rising and falling, 25°C
0.9
Enable threshold +50 mV
–3.8
Enable threshold –50 mV
–0.9
μA
–2.9
Hysteresis current
V
μA
VOLTAGE REFERENCE
Voltage reference
TJ = 25°C
0.792
0.8
0.808
0.784
0.8
0.816
V
HIGH-SIDE MOSFET
On-resistance
VIN = 3.5 V, BOOT-PH = 3 V
300
VIN = 12 V, BOOT-PH = 6 V
200
410
mΩ
ERROR AMPLIFIER
Input current
50
nA
Error amplifier transconductance (gM) –2 μA < ICOMP < 2 μA, VCOMP = 1 V
97
μMhos
Error amplifier transconductance (gM) –2 μA < ICOMP < 2 μA, VCOMP = 1 V,
during slow start
VVSENSE = 0.4 V
26
μMhos
Error amplifier dc gain
VVSENSE = 0.8 V
Error amplifier bandwidth
Error amplifier source/sink
V(COMP) = 1 V, 100 mV overdrive
COMP to switch current
transconductance
10,000
V/V
2700
kHz
±7
μA
1.9
A/V
0.94
A
CURRENT LIMIT
Current limit threshold
VIN = 12 V, TJ = 25°C
0.6
3
TPS54060-Q1
www.ti.com
ELECTRICAL CHARACTERISTICS (continued)
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
THERMAL SHUTDOWN
Thermal shutdown
4
182
°C
TPS54060-Q1
www.ti.com
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
2500
kHz
720
kHz
2200
kHz
TIMING RESISTOR AND EXTERNAL CLOCK (RT/CLK PIN)
fSW
Switching frequency using RT mode
VIN = 12 V
100
Switching frequency
VIN = 12 V, RT = 200 kΩ
450
Switching frequency using CLK mode VIN = 12 V
581
300
Minimum CLK input pulse width
40
RT/CLK high threshold
VIN = 12 V
RT/CLK low threshold
VIN = 12 V
RT/CLK falling edge to PH rising
edge delay
Measured at 500 kHz with RT resistor in series
PLL lock in time
Measured at 500 kHz
1.9
0.45
ns
2.2
V
0.7
V
60
ns
100
μs
SLOW START AND TRACKING (SS/TR)
Charge current
VSS/TR = 0.4 V
2
μA
SS/TR-to-VSENSE matching
VSS/TR = 0.4 V
45
mV
SS/TR-to-reference crossover
98% nominal
1.0
V
SS/TR discharge current (overload)
VSENSE = 0 V, V(SS/TR) = 0.4 V
112
μA
SS/TR discharge voltage
VSENSE = 0 V
54
mV
VSENSE falling
92%
POWER GOOD (PWRGD PIN)
VVSENSE
VSENSE rising
94%
VSENSE rising
109%
VSENSE falling
107%
Hysteresis
VSENSE falling
2%
Output high leakage
VSENSE = VREF, V(PWRGD) = 5.5 V, 25°C
10
nA
On resistance
I(PWRGD) = 3 mA, VSENSE < 0.79 V
50
Ω
Minimum VIN for defined output
V(PWRGD) < 0.5 V, II(PWRGD) = 100 μA
VSENSE threshold
0.95
1.5
V
5
TPS54060-Q1
www.ti.com
DEVICE INFORMATION
PIN CONFIGURATION
MSOP10
(TOP VIEW)
BOOT
1
VIN
2
10
Thermal
Pad
(11)
PH
9
GND
8
COMP
EN
3
SS/TR
4
7
VSENSE
RT/CLK
5
6
PWRGD
PIN FUNCTIONS
PIN
I/O
DESCRIPTION
NAME
NO.
BOOT
1
O
A bootstrap capacitor is required between BOOT and PH. If the voltage on this capacitor is below the
minimum required by the output device, the output is forced to switch off until the capacitor is refreshed.
COMP
8
O
Error amplifier output, and input to the output switch current comparator. Connect frequency compensation
components to this pin.
EN
3
I
Enable pin, internal pull-up current source. Pull below 1.2V to disable. Float to enable. Adjust the input
undervoltage lockout with two resistors.
GND
9
Ground
PH
10
I
The source of the internal high-side power MOSFET.
POWERPAD
11
GND pin must be electrically connected to the exposed pad on the printed circuit board for proper operation.
PWRGD
6
O
An open drain output, asserts low if output voltage is low due to thermal shutdown, dropout, over-voltage or
EN shut down.
RT/CLK
5
I
Resistor Timing and External Clock. An internal amplifier holds this pin at a fixed voltage when using an
external resistor to ground to set the switching frequency. If the pin is pulled above the PLL upper threshold,
a mode change occurs and the pin becomes a synchronization input. The internal amplifier is disabled and
the pin is a high impedance clock input to the internal PLL. If clocking edges stop, the internal amplifier is
re-enabled and the mode returns to a resistor set function.
SS/TR
4
I
Slow-start and Tracking. An external capacitor connected to this pin sets the output rise time. Since the
voltage on this pin overrides the internal reference, it can be used for tracking and sequencing.
VIN
2
I
Input supply voltage, 3.5 V to 60 V.
VSENSE
7
I
Inverting node of the transconductance ( gm) error amplifier.
6
TPS54060-Q1
www.ti.com
FUNCTIONAL BLOCK DIAGRAM
PWRGD
6
EN
3
VIN
2
Shutdown
UV
Thermal
Shutdown
Enable
Comparator
Logic
UVLO
Shutdown
Shutdown
Logic
OV
Enable
Threshold
Boot
Charge
Voltage
Reference
Boot
UVLO
Minimum
Clamp
Pulse
Skip
ERROR
AMPLIFIER
Current
Sense
PWM
Comparator
VSENSE 7
1 BOOT
Logic
And
PWM Latch
SS/TR 4
Shutdown
Slope
Compensation
10 PH
COMP 8
11 POWERPAD
Frequency
Shift
Overload
Recovery
Maximum
Clamp
Oscillator
with PLL
TPS54060 Block Diagram
9 GND
5
RT/CLK
7
TPS54060-Q1
www.ti.com
TYPICAL CHARACTERISTICS
VOLTAGE REFERENCE vs JUNCTION TEMPERATURE
0.816
500
VI = 12 V
VI = 12 V
375
Vref - Voltage Reference - V
RDSON - Static Drain-Source On-State Resistance - mW
ON RESISTANCE vs JUNCTION TEMPERATURE
BOOT-PH = 3 V
250
BOOT-PH = 6 V
125
0.808
0.800
0.792
0.784
-50
-25
50
75
100
TJ - Junction Temperature - °C
125
-25
25
50
75
100
125
150
Figure 1.
Figure 2.
SWITCH CURRENT LIMIT vs JUNCTION TEMPERATURE
SWITCHING FREQUENCY vs JUNCTION TEMPERATURE
1.1
610
VI = 12 V,
RT = 200 kW
VI = 12 V
fs - Switching Frequency - kHz
600
Switch Current - A
1
0.9
0.8
590
580
570
560
0.7
-50
-25
50
75
100
125
550
-50
150
-25
25
50
75
100
Figure 4.
SWITCHING FREQUENCY vs RT/CLK RESISTANCE HIGH
FREQUENCY RANGE
SWITCHING FREQUENCY vs RT/CLK RESISTANCE LOW
FREQUENCY RANGE
2500
500
2000
150
Figure 3.
VI = 12 V,
TJ = 25°C
1500
1000
500
50
75
100
125
RT/CLK - Resistance - kW
150
175
200
VI = 12 V,
TJ = 25°C
400
300
200
100
300
Figure 5.
8
125
400
500
600 700
800
900
1000 1100
1200
Figure 6.
TPS54060-Q1
www.ti.com
TYPICAL CHARACTERISTICS (continued)
EA TRANSCONDUCTANCE DURING SLOW START vs
EA TRANSCONDUCTANCE vs JUNCTION TEMPERATURE
150
40
VI = 12 V
VI = 12 V
130
gm - mA/V
gm - mA/V
30
110
90
10
-50
-25
50
75
100
125
50
-50
150
-25
50
75
100
125
150
Figure 7.
Figure 8.
EN PIN VOLTAGE vs JUNCTION TEMPERATURE
EN PIN CURRENT vs JUNCTION TEMPERATURE
1.40
-3.25
VI = 12 V,
VI(EN) = Threshold +50 mV
VI = 12 V
-3.5
I(EN) - mA
EN - Threshold - V
1.30
-3.75
1.20
-4
1.10
-50
-25
50
75
100
125
150
-4.25
-50
50
75
100
125
150
Figure 9.
Figure 10.
SS/TR CHARGE CURRENT vs JUNCTION TEMPERATURE
-1
-0.8
VI = 12 V,
VI(EN) = Threshold -50 mV
VI = 12 V
-0.85
-1.5
I(SS/TR) - mA
I(EN) - mA
-25
-0.9
-0.95
-1
-50
-2
-2.5
-25
50
75
100
125
150
-3
-50
-25
Figure 11.
50
75
100
125
150
Figure 12.
9
TPS54060-Q1
www.ti.com
SS/TR DISCHARGE CURRENT vs JUNCTION
TEMPERATURE
SWITCHING FREQUENCY vs VSENSE
120
100
VI = 12 V
VI = 12 V,
TJ = 25°C
80
% of Nominal fsw
II(SS/TR) - mA
115
110
60
40
105
-50
50
75
100
125
150
SHUTDOWN SUPPLY CURRENT vs INPUT VOLTAGE (Vin)
2
TJ = 25°C
I(VIN) - mA
1.5
1
0.5
1
0.5
50
75
100
125
150
40
VI - Input Voltage - V
Figure 15.
VIN SUPPLY CURRENT vs JUNCTION TEMPERATURE
60
VIN SUPPLY CURRENT vs INPUT VOLTAGE
140
VI = 12 V,
VI(VSENSE) = 0.83 V
o
TJ = 25 C,
VI(VSENSE) = 0.83 V
130
130
120
120
I(VIN) - mA
I(VIN) - mA
50
Figure 16.
140
110
100
110
100
90
-25
50
75
100
125
150
Figure 17.
10
0.8
SHUTDOWN SUPPLY CURRENT vs JUNCTION
TEMPERATURE
1.5
90
-50
0.6
Figure 14.
VI = 12 V
I(VIN) - mA
0.4
VSENSE - V
Figure 13.
2
0.2
60
Figure 18.
TPS54060-Q1
www.ti.com
PWRGD ON RESISTANCE vs JUNCTION TEMPERATURE
PWRGD THRESHOLD vs JUNCTION TEMPERATURE
115
100
VI = 12 V
PWRGD Threshold - % of Vref
VI = 12 V
RDSON - W
80
60
40
VSENSE Rising
110
VSENSE Falling
105
100
VSENSE Rising
95
VSENSE Falling
90
-25
50
75
100
125
85
-50
150
-25
Figure 20.
BOOT-PH UVLO vs JUNCTION TEMPERATURE
INPUT VOLTAGE (UVLO) vs JUNCTION TEMPERATURE
2.5
3
2.3
2.75
2
1.8
2.50
2.25
1.5
-50
-25
50
75
100
125
2
-50
150
-25
50
75
100
Figure 21.
125
150
Figure 22.
SS/TR TO VSENSE OFFSET vs VSENSE
SS/TR TO VSENSE OFFSET vs TEMPERATURE
600
60
V(SS/TR) = 0.2 V
VI = 12 V
VIN = 12 V
TJ = 25°C
500
55
50
400
Offset - mV
Offset Voltage Threshold (mV)
125
Figure 19.
VI(VIN) - V
VI(BOOT-PH) - V
25
50
75
100
300
45
40
200
35
100
30
-50
400
600
Voltage Sense (mV)
-25
800
Figure 23.
50
75
100
125
150
Figure 24.
11
TPS54060-Q1
www.ti.com
OVERVIEW
The TPS54060 device is a 60-V, 0.5-A, step-down (buck) regulator with an integrated high side n-channel
MOSFET. To improve performance during line and load transients the device implements a constant frequency,
current mode control which reduces output capacitance and simplifies external frequency compensation design.
The wide switching frequency of 100kHz to 2500kHz allows for efficiency and size optimization when selecting
the output filter components. The switching frequency is adjusted using a resistor to ground on the RT/CLK pin.
The device has an internal phase lock loop (PLL) on the RT/CLK pin that is used to synchronize the power
switch turn on to a falling edge of an external system clock.
The TPS54060 has a default start up voltage of approximately 2.5V. The EN pin has an internal pull-up current
source that can be used to adjust the input voltage under voltage lockout (UVLO) threshold with two external
resistors. In addition, the pull up current provides a default condition. When the EN pin is floating the device will
operate. The operating current is 116μA when not switching and under no load. When the device is disabled, the
supply current is 1.3μA.
The integrated 200mΩ high side MOSFET allows for high efficiency power supply designs capable of delivering
0.5 amperes of continuous current to a load. The TPS54060 reduces the external component count by
integrating the boot recharge diode. The bias voltage for the integrated high side MOSFET is supplied by a
capacitor on the BOOT to PH pin. The boot capacitor voltage is monitored by an UVLO circuit and will turn the
high side MOSFET off when the boot voltage falls below a preset threshold. The TPS54060 can operate at high
duty cycles because of the boot UVLO. The output voltage can be stepped down to as low as the 0.8V
reference.
The TPS54060 has a power good comparator (PWRGD) which asserts when the regulated output voltage is less
than 92% or greater than 109% of the nominal output voltage. The PWRGD pin is an open drain output which
deasserts when the VSENSE pin voltage is between 94% and 107% of the nominal output voltage allowing the
pin to transition high when a pull-up resistor is used.
The TPS54060 minimizes excessive output overvoltage (OV) transients by taking advantage of the OV power
good comparator. When the OV comparator is activated, the high side MOSFET is turned off and masked from
turning on until the output voltage is lower than 107%.
The SS/TR (slow start/tracking) pin is used to minimize inrush currents or provide power supply sequencing
during power up. A small value capacitor should be coupled to the pin to adjust the slow start time. A resistor
divider can be coupled to the pin for critical power supply sequencing requirements. The SS/TR pin is discharged
before the output powers up. This discharging ensures a repeatable restart after an over-temperature fault,
UVLO fault or a disabled condition.
The TPS54060, also, discharges the slow start capacitor during overload conditions with an overload recovery
circuit. The overload recovery circuit will slow start the output from the fault voltage to the nominal regulation
voltage once a fault condition is removed. A frequency foldback circuit reduces the switching frequency during
startup and overcurrent fault conditions to help control the inductor current.
12
TPS54060-Q1
www.ti.com
DETAILED DESCRIPTION
Fixed Frequency PWM Control
The TPS54060 uses an adjustable fixed frequency, peak current mode control. The output voltage is compared
through external resistors on the VSENSE pin to an internal voltage reference by an error amplifier which drives
the COMP pin. An internal oscillator initiates the turn on of the high side power switch. The error amplifier output
is compared to the high side power switch current. When the power switch current reaches the level set by the
COMP voltage, the power switch is turned off. The COMP pin voltage will increase and decrease as the output
current increases and decreases. The device implements a current limit by clamping the COMP pin voltage to a
maximum level. The Eco-Mode™ is implemented with a minimum clamp on the COMP pin.
Slope Compensation Output Current
The TPS54060 adds a compensating ramp to the switch current signal. This slope compensation prevents
sub-harmonic oscillations. The available peak inductor current remains constant over the full duty cycle range.
Pulse Skip Eco-Mode
The TPS54060 operates in a pulse skip Eco mode at light load currents to improve efficiency by reducing
switching and gate drive losses. The TPS54060 is designed so that if the output voltage is within regulation and
the peak switch current at the end of any switching cycle is below the pulse skipping current threshold, the
device enters Eco mode. This current threshold is the current level corresponding to a nominal COMP voltage or
500mV.
When in Eco-mode, the COMP pin voltage is clamped at 500mV and the high side MOSFET is inhibited. Further
decreases in load current or in output voltage can not drive the COMP pin below this clamp voltage level.
Since the device is not switching, the output voltage begins to decay. As the voltage control loop compensates
for the falling output voltage, the COMP pin voltage begins to rise. At this time, the high side MOSFET is enabled
and a switching pulse initiates on the next switching cycle. The peak current is set by the COMP pin voltage. The
output voltage re-charges the regulated value (see Figure 25), then the peak switch current starts to decrease,
and eventually falls below the Eco mode threshold at which time the device again enters Eco mode.
For Eco mode operation, the TPS54060 senses peak current, not average or load current, so the load current
where the device enters Eco mode is dependent on the output inductor value. For example, the circuit in
Figure 51 enters Eco mode at about 20 mA of output current. When the load current is low and the output
voltage is within regulation, the device enters a sleep mode and draws only 116μA input quiescent current. The
internal PLL remains operating when in sleep mode. When operating at light load currents in the pulse skip
mode, the switching transitions occur synchronously with the external clock signal.
13
TPS54060-Q1
www.ti.com
DETAILED DESCRIPTION (continued)
VOUT(ac)
IL
PH
Figure 25. Pulse Skip Mode Operation
Low Dropout Operation and Bootstrap Voltage (BOOT)
The TPS54060 has an integrated boot regulator, and requires a small ceramic capacitor between the BOOT and
PH pins to provide the gate drive voltage for the high side MOSFET. The BOOT capacitor is refreshed when the
high side MOSFET is off and the low side diode conducts. The value of this ceramic capacitor should be 0.1μF.
A ceramic capacitor with an X7R or X5R grade dielectric with a voltage rating of 10V or higher is recommended
because of the stable characteristics overtemperature and voltage.
To improve drop out, the TPS54060 is designed to operate at 100% duty cycle as long as the BOOT to PH pin
voltage is greater than 2.1V. When the voltage from BOOT to PH drops below 2.1V, the high side MOSFET is
turned off using an UVLO circuit which allows the low side diode to conduct and refresh the charge on the BOOT
capacitor. Since the supply current sourced from the BOOT capacitor is low, the high side MOSFET can remain
on for more switching cycles than are required to refresh the capacitor, thus the effective duty cycle of the
switching regulator is high.
The effective duty cycle during dropout of the regulator is mainly influenced by the voltage drops across the
power MOSFET, inductor resistance, low side diode and printed circuit board resistance. During operating
conditions in which the input voltage drops and the regulator is operating in continuous conduction mode, the
high side MOSFET can remain on for 100% of the duty cycle to maintain output regulation, until the BOOT to PH
voltage falls below 2.1V.
14
TPS54060-Q1
www.ti.com
Attention must be taken in maximum duty cycle applications which experience extended time periods with light
loads or no load. When the voltage across the BOOT capacitor falls below the 2.1V UVLO threshold, the high
side MOSFET is turned off, but there may not be enough inductor current to pull the PH pin down to recharge the
BOOT capacitor. The high side MOSFET of the regulator stops switching because the voltage across the BOOT
capacitor is less than 2.1V. The output capacitor then decays until the difference in the input voltage and output
voltage is greater than 2.1V, at which point the BOOT UVLO threshold is exceeded, and the device starts
switching again until the desired output voltage is reached. This operating condition persists until the input
voltage and/or the load current increases. It is recommended to adjust the VIN stop voltage greater than the
BOOT UVLO trigger condition at the minimum load of the application using the adjustable VIN UVLO feature with
resistors on the EN pin.
The start and stop voltages for typical 3.3V and 5V output applications are shown in Figure 26 and Figure 27.
The voltages are plotted versus load current. The start voltage is defined as the input voltage needed to regulate
the output within 1%. The stop voltage is defined as the input voltage at which the output drops by 5% or stops
switching.
During high duty cycle conditions, the inductor current ripple increases while the BOOT capacitor is being
recharged resulting in an increase in ripple voltage on the output. This is due to the recharge time of the boot
capacitor being longer than the typical high side off time when switching occurs every cycle.
4
5.6
VO = 3.3 V
VO = 5 V
5.4
3.8
3.6
Start
3.4
Stop
3.2
5.2
Start
5
Stop
4.8
3
4.6
0.10
IO - Output Current - A
0.15
Figure 26. 3.3V Start/Stop Voltage
0.20
0.10
0.15
0.20
Figure 27. 5.0V Start/Stop Voltage
Error Amplifier
The TPS54060 has a transconductance amplifier for the error amplifier. The error amplifier compares the
VSENSE voltage to the lower of the SS/TR pin voltage or the internal 0.8V voltage reference. The
transconductance (gm) of the error amplifier is 97μA/V during normal operation. During the slow start operation,
the transconductance is a fraction of the normal operating gm. When the voltage of the VSENSE pin is below
0.8V and the device is regulating using the SS/TR voltage, the gm is 25μA/V.
The frequency compensation components (capacitor, series resistor and capacitor) are added to the COMP pin
to ground.
Voltage Reference
The voltage reference system produces a precise ±2% voltage reference over temperature by scaling the output
of a temperature stable bandgap circuit.
Adjusting the Output Voltage
The output voltage is set with a resistor divider from the output node to the VSENSE pin. It is recommended to
use 1% tolerance or better divider resistors. Start with a 10 kΩ for the R2 resistor and use the Equation 1 to
calculate R1. To improve efficiency at light loads consider using larger value resistors. If the values are too high
the regulator will be more susceptible to noise and voltage errors from the VSENSE input current will be
noticeable
15
TPS54060-Q1
www.ti.com
æ Vout - 0.8V ö
R1 = R2 ´ ç
0.8 V
è
ø
(1)
The TPS54060 is disabled when the VIN pin voltage falls below 2.5 V. If an application requires a higher
undervoltage lockout (UVLO), use the EN pin as shown in Figure 28 to adjust the input voltage UVLO by using
the two external resistors. Though it is not necessary to use the UVLO adjust registers, for operation it is highly
recommended to provide consistent power up behavior. The EN pin has an internal pull-up current source, I1, of
0.9μA that provides the default condition of the TPS54060 operating when the EN pin floats. Once the EN pin
voltage exceeds 1.25V, an additional 2.9μA of hysteresis, Ihys, is added. This additional current facilitates input
voltage hysteresis. Use Equation 2 to set the external hysteresis for the input voltage. Use Equation 3 to set the
input start voltage.
TPS54060
VIN
Ihys
I1
0.9 mA
R1
2.9 mA
R2
EN
1.25 V
Figure 28. Adjustable Undervoltage Lockout (UVLO)
V
- VSTOP
R1 = START
IHYS
R2 =
(2)
VENA
VSTART - VENA
+ I1
R1
(3)
Another technique to add input voltage hysteresis is shown in Figure 29. This method may be used, if the
resistance values are high from the previous method and a wider voltage hysteresis is needed. The resistor R3
sources additional hysteresis current into the EN pin.
TPS54060
VIN
R1
Ihys
I1
0.9 mA
2.9 mA
R2
EN
1.25 V
R3
VOUT
Figure 29. Adding Additional Hysteresis
16
TPS54060-Q1
www.ti.com
R1 =
R2 =
VSTART - VSTOP
V
IHYS + OUT
R3
(4)
VENA
VSTART - VENA
V
+ I1 - ENA
R1
R3
(5)
Do not place a low-impedance voltage source with greater than 5 V directly on the EN pin. Do not place a
capacitor directly on the EN pin if VEN > 5 V when using a voltage divider to adjust the start and stop voltage.
The node voltage, (see Figure 30) must remain equal to or less than 5.8 V. The zener diode can sink up to 100
μA. The EN pin voltage can be greater than 5 V if the VIN voltage source has a high impedance and does not
source more than 100 μA into the EN pin.
VIN
IA
RUVLO1
EN
10 kW
Node
3
IB
RUVLO2
IC
5.8 V
UDG-10065
Figure 30. Node Voltage
17
TPS54060-Q1
www.ti.com
Slow Start/Tracking Pin (SS/TR)
The TPS54060 effectively uses the lower voltage of the internal voltage reference or the SS/TR pin voltage as
the power-supply's reference voltage and regulates the output accordingly. A capacitor on the SS/TR pin to
ground implements a slow start time. The TPS54060 has an internal pull-up current source of 2μA that charges
the external slow start capacitor. The calculations for the slow start time (10% to 90%) are shown in Equation 6.
The voltage reference (VREF) is 0.8 V and the slow start current (ISS) is 2μA. The slow start capacitor should
remain lower than 0.47μF and greater than 0.47nF.
Tss(ms) ´ Iss(m A)
Css(nF) =
Vref (V) ´ 0.8
(6)
At power up, the TPS54060 will not start switching until the slow start pin is discharged to less than 40 mV to
ensure a proper power up, see Figure 31.
Also, during normal operation, the TPS54060 will stop switching and the SS/TR must be discharged to 40 mV,
when the VIN UVLO is exceeded, EN pin pulled below 1.25V, or a thermal shutdown event occurs.
The VSENSE voltage will follow the SS/TR pin voltage with a 45mV offset up to 85% of the internal voltage
reference. When the SS/TR voltage is greater than 85% on the internal reference voltage the offset increases as
the effective system reference transitions from the SS/TR voltage to the internal voltage reference (see
Figure 23). The SS/TR voltage will ramp linearly until clamped at 1.7V.
EN
SS/TR
VSENSE
VOUT
Figure 31. Operation of SS/TR Pin when Starting
Overload Recovery Circuit
The TPS54060 has an overload recovery (OLR) circuit. The OLR circuit will slow start the output from the
overload voltage to the nominal regulation voltage once the fault condition is removed. The OLR circuit will
discharge the SS/TR pin to a voltage slightly greater than the VSENSE pin voltage using an internal pull down of
100μA when the error amplifier is changed to a high voltage from a fault condition. When the fault condition is
removed, the output will slow start from the fault voltage to nominal output voltage.
18
TPS54060-Q1
www.ti.com
Sequencing
Many of the common power supply sequencing methods can be implemented using the SS/TR, EN and PWRGD
pins. The sequential method can be implemented using an open drain output of a power on reset pin of another
device. The sequential method is illustrated in Figure 32 using two TPS54060 devices. The power good is
coupled to the EN pin on the TPS54060 which will enable the second power supply once the primary supply
reaches regulation. If needed, a 1nF ceramic capacitor on the EN pin of the second power supply will provide a
1ms start up delay. Figure 33 shows the results of Figure 32.
TPS54060
EN
PWRGD
EN
EN1
SS /TR
SS /TR
PWRGD1
PWRGD
VOUT1
VOUT2
Figure 32. Schematic for Sequential Start-Up
Sequence
Figure 33. Sequential Startup using EN and
PWRGD
TPS54160
TPS54060
3
EN
4
SS/TR
6
PWRGD
EN1, EN2
VOUT1
TPS54060
TPS54160
VOUT2
3
EN
4
SS/TR
6
PWRGD
Figure 34. Schematic for Ratiometric Start-Up
Using Coupled SS/TR Pins
Figure 35. Ratio-Metric Startup using Coupled
SS/TR pins
Figure 34 shows a method for ratio-metric start up sequence by connecting the SS/TR pins together. The
regulator outputs will ramp up and reach regulation at the same time. When calculating the slow start time the
pull up current source must be doubled in Equation 6. Figure 35 shows the results of Figure 34.
19
TPS54060-Q1
www.ti.com
TPS54060
EN
VOUT 1
SS/TR
PWRGD
TPS54060
VOUT 2
EN
R1
SS/ TR
R2
PWRGD
R3
R4
Figure 36. Schematic for Ratiometric and Simultaneous Start-Up Sequence
Ratio-metric and simultaneous power supply sequencing can be implemented by connecting the resistor network
of R1 and R2 shown in Figure 36 to the output of the power supply that needs to be tracked or another voltage
reference source. Using Equation 7 and Equation 8, the tracking resistors can be calculated to initiate the Vout2
slightly before, after or at the same time as Vout1. Equation 9 is the voltage difference between Vout1 and Vout2
at the 95% of nominal output regulation.
The deltaV variable is zero volts for simultaneous sequencing. To minimize the effect of the inherent SS/TR to
VSENSE offset (Vssoffset) in the slow start circuit and the offset created by the pullup current source (Iss) and
tracking resistors, the Vssoffset and Iss are included as variables in the equations.
To design a ratio-metric start up in which the Vout2 voltage is slightly greater than the Vout1 voltage when Vout2
reaches regulation, use a negative number in Equation 7 through Equation 9 for deltaV. Equation 9 will result in a
positive number for applications which the Vout2 is slightly lower than Vout1 when Vout2 regulation is achieved.
Since the SS/TR pin must be pulled below 40mV before starting after an EN, UVLO or thermal shutdown fault,
careful selection of the tracking resistors is needed to ensure the device will restart after a fault. Make sure the
calculated R1 value from Equation 7 is greater than the value calculated in Equation 10 to ensure the device can
recover from a fault.
As the SS/TR voltage becomes more than 85% of the nominal reference voltage the Vssoffset becomes larger
as the slow start circuits gradually handoff the regulation reference to the internal voltage reference. The SS/TR
pin voltage needs to be greater than 1.3V for a complete handoff to the internal voltage reference as shown in
Figure 23.
Vout2 + deltaV
Vssoffset
R1 =
VREF
Iss
(7)
VREF ´ R1
R2 =
Vout2 + deltaV - VREF
(8)
deltaV = Vout1 - Vout2
(9)
R1 > 2800 ´ Vout1 - 180 ´ deltaV
(10)
TPS54060-Q1
www.ti.com
EN
EN
VOUT1
VOUT1
VOUT2
Figure 37. Ratiometric Startup with VOUT2 leading
VOUT1
VOUT2
Figure 38. Ratiometric Startup with VOUT1 leading
VOUT2
EN
VOUT1
VOUT2
Figure 39. Simultaneous Startup With Tracking Resistor
21
TPS54060-Q1
www.ti.com
Constant Switching Frequency and Timing Resistor (RT/CLK Pin)
The switching frequency of the TPS54060 is adjustable over a wide range from approximately 100kHz to
2500kHz by placing a resistor on the RT/CLK pin. The RT/CLK pin voltage is typically 0.5V and must have a
resistor to ground to set the switching frequency. To determine the timing resistance for a given switching
frequency, use Equation 11 or the curves in Figure 40 or Figure 41. To reduce the solution size one would
typically set the switching frequency as high as possible, but tradeoffs of the supply efficiency, maximum input
voltage and minimum controllable on time should be considered.
The minimum controllable on time is typically 130ns and limits the maximum operating input voltage.
The maximum switching frequency is also limited by the frequency shift circuit. More discussion on the details of
the maximum switching frequency is located below.
206033
RT (kOhm ) =
¦ sw (kHz )1.0888
(11)
SWITCHING FREQUENCY
vs
RT/CLK RESISTANCE HIGH FREQUENCY RANGE
SWITCHING FREQUENCY
vs
RT/CLK RESISTANCE LOW FREQUENCY RANGE
2500
500
2000
VI = 12 V,
TJ = 25°C
1500
1000
500
50
75
100
125
150
RT/CLK - Clock Resistance - kW
175
200
Figure 40. High Range RT
VI = 12 V,
TJ = 25°C
400
300
200
100
300
400
500
600 700
800
900
1000 1100
1200
Figure 41. Low Range RT
Overcurrent Protection and Frequency Shift
The TPS54060 implements current mode control which uses the COMP pin voltage to turn off the high side
MOSFET on a cycle by cycle basis. Each cycle the switch current and COMP pin voltage are compared, when
the peak switch current intersects the COMP voltage, the high side switch is turned off. During overcurrent
conditions that pull the output voltage low, the error amplifier will respond by driving the COMP pin high,
increasing the switch current. The error amplifier output is clamped internally, which functions as a switch current
limit.
To increase the maximum operating switching frequency at high input voltages the TPS54060 implements a
frequency shift. The switching frequency is divided by 8, 4, 2, and 1 as the voltage ramps from 0 to 0.8 volts on
VSENSE pin.
The device implements a digital frequency shift to enable synchronizing to an external clock during normal
startup and fault conditions. Since the device can only divide the switching frequency by 8, there is a maximum
input voltage limit in which the device operates and still have frequency shift protection.
During short-circuit events (particularly with high input voltage applications), the control loop has a finite minimum
controllable on time and the output has a low voltage. During the switch on time, the inductor current ramps to
the peak current limit because of the high input voltage and minimum on time. During the switch off time, the
inductor would normally not have enough off time and output voltage for the inductor to ramp down by the ramp
up amount. The frequency shift effectively increases the off time allowing the current to ramp down.
22
TPS54060-Q1
www.ti.com
Selecting the Switching Frequency
The switching frequency that is selected should be the lower value of the two equations, Equation 12 and
Equation 13. Equation 12 is the maximum switching frequency limitation set by the minimum controllable on time.
Setting the switching frequency above this value will cause the regulator to skip switching pulses.
Equation 13 is the maximum switching frequency limit set by the frequency shift protection. To have adequate
output short circuit protection at high input voltages, the switching frequency should be set to be less than the
fsw(maxshift) frequency. In Equation 13, to calculate the maximum switching frequency one must take into
account that the output voltage decreases from the nominal voltage to 0 volts, the fdiv integer increases from 1 to
8 corresponding to the frequency shift.
In Figure 42, the solid line illustrates a typical safe operating area regarding frequency shift and assumes the
output voltage is zero volts, and the resistance of the inductor is 0.130Ω, FET on resistance of 0.2Ω and the
diode voltage drop is 0.5V. The dashed line is the maximum switching frequency to avoid pulse skipping. Enter
these equations in a spreadsheet or other software or use the SwitcherPro design software to determine the
æ 1 ö æ (IL ´ Rdc + VOUT + Vd) ö
fSW (max skip ) = ç
÷ ´ çç
è tON ø è (VIN - IL ´ Rhs + Vd) ø
(12)
fSW (hift ) =
fdiv æ (IL ´ Rdc + VOUTSC + Vd) ö
´ç
t ON çè (VIN - IL x Rhs + Vd ) ÷ø
IL
inductor current
Rdc
inductor resistance
VIN
maximum input voltage
VOUT
output voltage
VOUTSC
output voltage during short
Vd
diode voltage drop
RDS(on)
switch on resistance
tON
ƒDIV
frequency divide equals (1, 2, 4, or 8)
(13)
2500
VO = 3.3 V
2000
Shift
1500
Skip
1000
500
40
50
60
Figure 42. Maximum Switching Frequency vs. Input Voltage
23
TPS54060-Q1
www.ti.com
How to Interface to RT/CLK Pin
The RT/CLK pin can be used to synchronize the regulator to an external system clock. To implement the
synchronization feature connect a square wave to the RT/CLK pin through the circuit network shown in
Figure 43. The square wave amplitude must transition lower than 0.5V and higher than 2.2V on the RT/CLK pin
and have an on time greater than 40 ns and an off time greater than 40 ns. The synchronization frequency range
is 300 kHz to 2200 kHz. The rising edge of the PH will be synchronized to the falling edge of RT/CLK pin signal.
The external synchronization circuit should be designed in such a way that the device will have the default
frequency set resistor connected from the RT/CLK pin to ground should the synchronization signal turn off. It is
recommended to use a frequency set resistor connected as shown in Figure 43 through a 50Ω resistor to
ground. The resistor should set the switching frequency close to the external CLK frequency. It is recommended
to ac couple the synchronization signal through a 10 pF ceramic capacitor to RT/CLK pin and a 4kΩ series
resistor. The series resistor reduces PH jitter in heavy load applications when synchronizing to an external clock
and in applications which transition from synchronizing to RT mode. The first time the CLK is pulled above the
CLK threshold the device switches from the RT resistor frequency to PLL mode. The internal 0.5V voltage source
is removed and the CLK pin becomes high impedance as the PLL starts to lock onto the external signal. Since
there is a PLL on the regulator the switching frequency can be higher or lower than the frequency set with the
external resistor. The device transitions from the resistor mode to the PLL mode and then will increase or
decrease the switching frequency until the PLL locks onto the CLK frequency within 100 microseconds.
When the device transitions from the PLL to resistor mode the switching frequency will slow down from the CLK
frequency to 150 kHz, then reapply the 0.5V voltage and the resistor will then set the switching frequency. The
switching frequency is divided by 8, 4, 2, and 1 as the voltage ramps from 0 to 0.8 volts on VSENSE pin. The
device implements a digital frequency shift to enable synchronizing to an external clock during normal startup
and fault conditions. Figure 44, Figure 45 and Figure 46 show the device synchronized to an external system
clock in continuous conduction mode (ccm) discontinuous conduction (dcm) and pulse skip mode (psm).
TPS54060
10 pF
4 kW
PLL
Rfset
EXT
Clock
Source
50 W
RT/CLK
Figure 43. Synchronizing to a System Clock
24
TPS54060-Q1
www.ti.com
PH
PH
EXT
EXT
IL
IL
Figure 44. Plot of Synchronizing in ccm
Figure 45. Plot of Synchronizing in dcm
PH
EXT
IL
Figure 46. Plot of Synchronizing in PSM
Power Good (PWRGD Pin)
The PWRGD pin is an open drain output. Once the VSENSE pin is between 94% and 107% of the internal
voltage reference the PWRGD pin is de-asserted and the pin floats. It is recommended to use a pull-up resistor
between the values of 10 and 100kΩ to a voltage source that is 5.5V or less. The PWRGD is in a defined state
once the VIN input voltage is greater than 1.5V but with reduced current sinking capability. The PWRGD will
achieve full current sinking capability as VIN input voltage approaches 3V.
25
TPS54060-Q1
www.ti.com
The PWRGD pin is pulled low when the VSENSE is lower than 92% or greater than 109% of the nominal internal
reference voltage. Also, the PWRGD is pulled low, if the UVLO or thermal shutdown are asserted or the EN pin
pulled low.
Overvoltage Transient Protection
The TPS54060 incorporates an overvoltage transient protection (OVTP) circuit to minimize voltage overshoot
when recovering from output fault conditions or strong unload transients on power supply designs with low value
output capacitance. For example, when the power supply output is overloaded the error amplifier compares the
actual output voltage to the internal reference voltage. If the VSENSE pin voltage is lower than the internal
reference voltage for a considerable time, the output of the error amplifier will respond by clamping the error
amplifier output to a high voltage. Thus, requesting the maximum output current. Once the condition is removed,
the regulator output rises and the error amplifier output transitions to the steady state duty cycle. In some
applications, the power supply output voltage can respond faster than the error amplifier output can respond, this
actuality leads to the possibility of an output overshoot. The OVTP feature minimizes the output overshoot, when
using a low value output capacitor, by implementing a circuit to compare the VSENSE pin voltage to OVTP
threshold which is 109% of the internal voltage reference. If the VSENSE pin voltage is greater than the OVTP
threshold, the high side MOSFET is disabled preventing current from flowing to the output and minimizing output
overshoot. When the VSENSE voltage drops lower than the OVTP threshold, the high side MOSFET is allowed
to turn on at the next clock cycle.
Thermal Shutdown
The device implements an internal thermal shutdown to protect itself if the junction temperature exceeds 182°C.
The thermal shutdown forces the device to stop switching when the junction temperature exceeds the thermal
trip threshold. Once the die temperature decreases below 182°C, the device reinitiates the power up sequence
by discharging the SS/TR pin.
Small Signal Model for Loop Response
Figure 47 shows an equivalent model for the TPS54060 control loop which can be modeled in a circuit simulation
program to check frequency response and dynamic load response. The error amplifier is a transconductance
amplifier with a gmEA of 97 μA/V. The error amplifier can be modeled using an ideal voltage controlled current
source. The resistor Ro and capacitor Co model the open loop gain and frequency response of the amplifier. The
1mV ac voltage source between the nodes a and b effectively breaks the control loop for the frequency response
measurements. Plotting c/a shows the small signal response of the frequency compensation. Plotting a/b shows
the small signal response of the overall loop. The dynamic loop response can be checked by replacing RL with a
current source with the appropriate load step amplitude and step rate in a time domain analysis. This equivalent
model is only valid for continuous conduction mode designs.
26
TPS54060-Q1
www.ti.com
PH
VO
Power Stage
gmps 1.9 A/V
a
b
RESR
R1
RL
COMP
c
0.8 V
CO
R3
RO
VSENSE
COUT
gmea
C2
R2
97 mA/V
C1
Figure 47. Small Signal Model for Loop Response
Simple Small Signal Model for Peak Current Mode Control
Figure 48 describes a simple small signal model that can be used to understand how to design the frequency
compensation. The TPS54060 power stage can be approximated to a voltage-controlled current source (duty
cycle modulator) supplying current to the output capacitor and load resistor. The control to output transfer
function is shown in Equation 14 and consists of a dc gain, one dominant pole, and one ESR zero. The quotient
of the change in switch current and the change in COMP pin voltage (node c in Figure 47) is the power stage
transconductance. The gmPS for the TPS54060 is 1.9A/V. The low-frequency gain of the power stage frequency
response is the product of the transconductance and the load resistance as shown in Equation 15.
As the load current increases and decreases, the low-frequency gain decreases and increases, respectively. This
variation with the load may seem problematic at first glance, but fortunately the dominant pole moves with the
load current (see Equation 16). The combined effect is highlighted by the dashed line in the right half of
Figure 48. As the load current decreases, the gain increases and the pole frequency lowers, keeping the 0-dB
crossover frequency the same for the varying load conditions which makes it easier to design the frequency
compensation. The type of output capacitor chosen determines whether the ESR zero has a profound effect on
the frequency compensation design. Using high ESR aluminum electrolytic capacitors may reduce the number
frequency compensation components needed to stabilize the overall loop because the phase margin increases
from the ESR zero at the lower frequencies (see Equation 17).
VO
Adc
VC
RESR
fp
RL
gmps
COUT
fz
Figure 48. Simple Small Signal Model and Frequency Response for Peak Current Mode Control
27
TPS54060-Q1
www.ti.com
æ
s ö
ç1 +
2p ´ fZ ø
VOUT
= Adc ´ è
VC
æ
s ö
ç1 +
2
p
´ fP ø
è
Adc = gmps ´ RL
(14)
(15)
1
fP =
COUT ´ RL ´ 2p
(16)
1
fZ =
COUT ´ RESR ´ 2p
(17)
Small Signal Model for Frequency Compensation
The TPS54060 uses a transconductance amplifier for the error amplifier and readily supports three of the
commonly-used frequency compensation circuits. Compensation circuits Type 2A, Type 2B, and Type 1 are
shown in Figure 49. Type 2 circuits most likely implemented in high bandwidth power-supply designs using low
ESR output capacitors. The Type 1 circuit is used with power-supply designs with high-ESR aluminum
electrolytic or tantalum capacitors.. Equation 18 and Equation 19 show how to relate the frequency response of
the amplifier to the small signal model in Figure 49. The open-loop gain and bandwidth are modeled using the RO
and CO shown in Figure 49. See the application section for a design example using a Type 2A network with a
low ESR output capacitor.
Equation 18 through Equation 27 are provided as a reference for those who prefer to compensate using the
preferred methods. Those who prefer to use prescribed method use the method outlined in the application
section or use switched information.
VO
R1
VSENSE
gmea
COMP
Type 2A
Type 2B
Type 1
Vref
R2
RO
CO
R3
C2
C1
R3
C2
C1
Figure 49. Types of Frequency Compensation
28
TPS54060-Q1
www.ti.com
Aol
A0
P1
Z1
P2
A1
BW
Figure 50. Frequency Response of the Type 2A and Type 2B Frequency Compensation
Aol(V/V)
gmea
gmea
2p ´ BW (Hz)
Ro =
CO
(18)
(19)
æ
ö
s
ç1 +
2p ´ fZ1 ø
è
EA = A0 ´
æ
ö æ
ö
s
s
ç1 +
÷ ´ ç1 +
2
2
p
p
f
f
P1 ø è
P2 ø
è
A0 = gmea
A1 = gmea
P1 =
Z1 =
P2 =
P2 =
P2 =
(20)
R2
´ Ro ´
R1 + R2
R2
´ Ro| | R3 ´
R1 + R2
(21)
(22)
1
2p ´ Ro ´ C1
(23)
1
2p ´ R3 ´ C1
(24)
1
type 2a
2p ´ R3 | | RO ´ (C2 + CO )
(25)
1
type 2b
2p ´ R3 | | RO ´ CO
2p ´ R O
(26)
1
type 1
´ (C2 + C O )
(27)
29
TPS54060-Q1
www.ti.com
APPLICATION INFORMATION
Design Guide — Step-By-Step Design Procedure
This example details the design of a high frequency switching regulator design using ceramic output capacitors.
A few parameters must be known in order to start the design process. These parameters are typically determined
at the system level. For this example, we will start with the following known parameters:
Output Voltage
3.3 V
Transient Response 0 to 1.5A load step
ΔVout = 4%
Maximum Output Current
0.5 A
Input Voltage
34 V nom. 12V to 48 V
Output Voltage Ripple
1% of Vout
Start Input Voltage (rising VIN)
8.9 V
Stop Input Voltage (falling VIN)
7.9 V
The first step is to decide on a switching frequency for the regulator. Typically, the user will want to choose the
highest switching frequency possible since this will produce the smallest solution size. The high switching
frequency allows for lower valued inductors and smaller output capacitors compared to a power supply that
switches at a lower frequency. The switching frequency that can be selected is limited by the minimum on-time of
the internal power switch, the input voltage and the output voltage and the frequency shift limitation.
Equation 12 and Equation 13 must be used to find the maximum switching frequency for the regulator, choose
the lower value of the two equations. Switching frequencies higher than these values will result in pulse skipping
or the lack of overcurrent protection during a short circuit.
The typical minimum on time, tonmin, is 130 ns for the TPS54060. For this example, the output voltage is 3.3 V
and the maximum input voltage is 48 V, which allows for a maximum switch frequency up to 616 kHz when
including the inductor resistance, on resistance and diode voltage in Equation 12. To ensure overcurrent
runaway is not a concern during short circuits in your design use Equation 13 or the solid curve in Figure 42 to
determine the maximum switching frequency. With a maximum input voltage of 48 V, assuming a diode voltage
of 0.5 V, inductor resistance of 130mΩ, switch resistance of 400mΩ, a current limit value of 0.94 A and a short
circuit output voltage of 0.1V. The maximum switching frequency is approximately 923 kHz.
Choosing the lower of the two values and adding some margin a switching frequency of 500kHz is used. To
determine the timing resistance for a given switching frequency, use Equation 11 or the curve in Figure 40.
The switching frequency is set by resistor R3 shown in Figure 51.
Figure 51. High Frequency, 3.3V Output Power Supply Design with Adjusted UVLO.
30
TPS54060-Q1
www.ti.com
Output Inductor Selection (LO)
To calculate the minimum value of the output inductor, use Equation 28.
KIND is a coefficient that represents the amount of inductor ripple current relative to the maximum output current.
The inductor ripple current will be filtered by the output capacitor. Therefore, choosing high inductor ripple
currents will impact the selection of the output capacitor since the output capacitor must have a ripple current
rating equal to or greater than the inductor ripple current. In general, the inductor ripple value is at the discretion
of the designer; however, the following guidelines may be used.
For designs using low ESR output capacitors such as ceramics, a value as high as KIND = 0.3 may be used.
When using higher ESR output capacitors, KIND = 0.2 yields better results. Since the inductor ripple current is
part of the PWM control system, the inductor ripple current should always be greater than 30 mA for dependable
operation. In a wide input voltage regulator, it is best to choose an inductor ripple current on the larger side. This
allows the inductor to still have a measurable ripple current with the input voltage at its minimum.
For this design example, use KIND = 0.3 and the minimum inductor value is calculated to be 39.7 μH. For this
design, a nearest standard value was chosen: 47μH. For the output filter inductor, it is important that the RMS
current and saturation current ratings not be exceeded. The RMS and peak inductor current can be found from
Equation 30 and Equation 31.
For this design, the RMS inductor current is 0.501 A and the peak inductor current is 0.563 A. The chosen
inductor is a MSS1048-473ML. It has a saturation current rating of 1.44 A and an RMS current rating of 1.83A.
As the equation set demonstrates, lower ripple currents will reduce the output voltage ripple of the regulator but
will require a larger value of inductance. Selecting higher ripple currents will increase the output voltage ripple of
the regulator but allow for a lower inductance value.
The current flowing through the inductor is the inductor ripple current plus the output current. During power up,
faults or transient load conditions, the inductor current can increase above the calculated peak inductor current
level calculated above. In transient conditions, the inductor current can increase up to the switch current limit of
the device. For this reason, the most conservative approach is to specify an inductor with a saturation current
rating equal to or greater than the switch current limit rather than the peak inductor current.
Vinmax - Vout
Vout
Lo min =
Io ´ KIND
Vinmax ´ ƒsw
(28)
IRIPPLE =
IL(rms) =
VOUT ´
(Vin max
- VOUT )
Vin max ´ L O ´ fSW
1
- VOUT ) ö
Vinmax ´ LO ´ fSW
ø
æ VOUT ´
(IO )2 + 12 ´ çç
è
(29)
(Vinmax
2
(30)
Iripple
ILpeak = Iout +
2
(31)
Output Capacitor
There are three primary considerations for selecting the value of the output capacitor. The output capacitor will
determine the modulator pole, the output voltage ripple, and how the regulators responds to a large change in
load current. The output capacitance needs to be selected based on the more stringent of these three criteria.
The desired response to a large change in the load current is the first criteria. The output capacitor needs to
supply the load with current when the regulator can not. This situation would occur if there are desired hold-up
times for the regulator where the output capacitor must hold the output voltage above a certain level for a
specified amount of time after the input power is removed. The regulator also will temporarily not be able to
supply sufficient output current if there is a large, fast increase in the current needs of the load such as
transitioning from no load to a full load. The regulator usually needs two or more clock cycles for the control loop
31
TPS54060-Q1
www.ti.com
to see the change in load current and output voltage and adjust the duty cycle to react to the change. The output
capacitor must be sized to supply the extra current to the load until the control loop responds to the load change.
The output capacitance must be large enough to supply the difference in current for 2 clock cycles while only
allowing a tolerable amount of droop in the output voltage. Equation 32 shows the minimum output capacitance
necessary to accomplish this.
Where ΔIout is the change in output current, ƒsw is the regulators switching frequency and ΔVout is the
allowable change in the output voltage. For this example, the transient load response is specified as a 4%
change in Vout for a load step from 0A (no load) to 0.5 A (full load). For this example, ΔIout = 0.5-0 = 0.5 A and
ΔVout = 0.04 × 3.3 = 0.132 V. Using these numbers gives a minimum capacitance of 15.2μF. This value does
not take the ESR of the output capacitor into account in the output voltage change. For ceramic capacitors, the
ESR is usually small enough to ignore in this calculation. Aluminum electrolytic and tantalum capacitors have
higher ESR that should be taken into account.
The catch diode of the regulator can not sink current so any stored energy in the inductor will produce an output
voltage overshoot when the load current rapidly decreases, see Figure 52. The output capacitor must also be
sized to absorb energy stored in the inductor when transitioning from a high load current to a lower load current.
The excess energy that gets stored in the output capacitor will increase the voltage on the capacitor. The
capacitor must be sized to maintain the desired output voltage during these transient periods. Equation 33 is
used to calculate the minimum capacitance to keep the output voltage overshoot to a desired value. Where L is
the value of the inductor, IOH is the output current under heavy load, IOL is the output under light load, VF is the
final peak output voltage, and Vi is the initial capacitor voltage. For this example, the worst case load step will be
from 0.5 A to 0 A. The output voltage will increase during this load transition and the stated maximum in our
specification is 4% of the output voltage. This will make Vf = 1.04 × 3.3 = 3.432. Vi is the initial capacitor voltage
which is the nominal output voltage of 3.3 V. Using these numbers in Equation 33 yields a minimum capacitance
of 13.2μF.
Equation 34 calculates the minimum output capacitance needed to meet the output voltage ripple specification.
Where fsw is the switching frequency, Voripple is the maximum allowable output voltage ripple, and Iripple is the
inductor ripple current. Equation 34 yields 1μF.
Equation 35 calculates the maximum ESR an output capacitor can have to meet the output voltage ripple
specification. Equation 35 indicates the ESR should be less than 248mΩ.
The most stringent criteria for the output capacitor is 15.2μF of capacitance to keep the output voltage in
regulation during an load transient.
Additional capacitance de-ratings for aging, temperature and dc bias should be factored in which will increase
this minimum value. For this example, a 47 μF 10V X5R ceramic capacitor with 5 mΩ of ESR will be used.
Capacitors generally have limits to the amount of ripple current they can handle without failing or producing
excess heat. An output capacitor that can support the inductor ripple current must be specified. Some capacitor
data sheets specify the Root Mean Square (RMS) value of the maximum ripple current. Equation 36 can be used
to calculate the RMS ripple current the output capacitor needs to support. For this application, Equation 36 yields
37.7 mA.
2 ´ DIout
Cout >
¦ sw ´ DVout
(32)
((I ) - (I ) )
((V ) - (V ) )
2
OH
COUT > LO
2
OL
2
2
f
Cout >
32
1
i
(33)
1
VORIPPLE
IRIPPLE
(34)
8 ´ ¦ sw
TPS54060-Q1
www.ti.com
V
RESR < ORIPPLE
IRIPPLE
Icorms =
(35)
Vout ´ (Vin max - Vout)
12 ´ Vin max ´ Lo ´ ¦ sw
(36)
Catch Diode
The TPS54060 requires an external catch diode between the PH pin and GND. The selected diode must have a
reverse voltage rating equal to or greater than Vinmax. The peak current rating of the diode must be greater than
the maximum inductor current. The diode should also have a low forward voltage. Schottky diodes are typically a
good choice for the catch diode due to their low forward voltage. The lower the forward voltage of the diode, the
higher the efficiency of the regulator.
Typically, the higher the voltage and current ratings the diode has, the higher the forward voltage will be. Since
the design example has an input voltage up to 48V, a diode with a minimum of 60V reverse voltage will be
selected.
For the example design, the B160A Schottky diode is selected for its lower forward voltage and it comes in a
larger package size which has good thermal characteristics over small devices. The typical forward voltage of the
B160A is 0.50 volts.
The diode must also be selected with an appropriate power rating. The diode conducts the output current during
the off-time of the internal power switch. The off-time of the internal switch is a function of the maximum input
voltage, the output voltage, and the switching frequency. The output current during the off-time is multiplied by
the forward voltage of the diode which equals the conduction losses of the diode. At higher switch frequencies,
the ac losses of the diode need to be taken into account. The ac losses of the diode are due to the charging and
discharging of the junction capacitance and reverse recovery. Equation 37 is used to calculate the total power
dissipation, conduction losses plus ac losses, of the diode.
The B160A has a junction capacitance of 110pF. Using Equation 37, the selected diode will dissipate 0.297
Watts. This power dissipation, depending on mounting techniques, should produce a 5.9°C temperature rise in
the diode when the input voltage is 48V and the load current is 0.5A.
If the power supply spends a significant amount of time at light load currents or in sleep mode consider using a
diode which has a low leakage current and slightly higher forward voltage drop.
2
Pd =
(Vin max - Vout) ´ Iout ´ Vƒd Cj ´ ƒsw ´ (Vin + Vƒd)
2
Vin max
(37)
Input Capacitor
The TPS54060 requires a high quality ceramic, type X5R or X7R, input decoupling capacitor of at least 3 μF of
effective capacitance and in some applications a bulk capacitance. The effective capacitance includes any dc
bias effects. The voltage rating of the input capacitor must be greater than the maximum input voltage. The
capacitor must also have a ripple current rating greater than the maximum input current ripple of the TPS54060.
The input ripple current can be calculated using Equation 38.
The value of a ceramic capacitor varies significantly over temperature and the amount of dc bias applied to the
capacitor. The capacitance variations due to temperature can be minimized by selecting a dielectric material that
is stable over temperature. X5R and X7R ceramic dielectrics are usually selected for power regulator capacitors
because they have a high capacitance to volume ratio and are fairly stable over temperature. The output
capacitor must also be selected with the dc bias taken into account. The capacitance value of a capacitor
decreases as the dc bias across a capacitor increases.
For this example design, a ceramic capacitor with at least a 60V voltage rating is required to support the
maximum input voltage. Common standard ceramic capacitor voltage ratings include 4V, 6.3V, 10V, 16V, 25V,
50V or 100V so a 100V capacitor should be selected. For this example, two 2.2μF, 100V capacitors in parallel
have been selected. Table 1 shows a selection of high voltage capacitors. The input capacitance value
determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 39.
Using the design example values, Ioutmax = 0.5 A, Cin = 4.4μF, ƒsw = 500 kHz, yields an input voltage ripple of
57 mV and a rms input ripple current of 0.223A.
Copyright © 2010–2011, Texas Instruments Incorporated
33
TPS54060-Q1
SLVSA25A – JANUARY 2010 – REVISED MARCH 2011
Icirms = Iout ´
Vout
Vin min
www.ti.com
(Vin min
- Vout )
Vin min
(38)
Iout max ´ 0.25
ΔVin =
Cin ´ ¦ sw
(39)
Table 1. Capacitor Types
VENDOR
VALUE (μF)
1.0 to 2.2
1.0 to 4.7
Murata
1.0
1.0 to 2.2
1.0 10 1.8
1.0 to 1.2
Vishay
1.0 to 3.9
1.0 to 1.8
1.0 to 2.2
TDK
1.5 to 6.8
1.0. to 2.2
1.0 to 3.3
1.0 to 4.7
AVX
1.0
1.0 to 4.7
1.0 to 2.2
EIA Size
1210
1206
2220
2225
1812
1210
1210
1812
VOLTAGE
DIALECTRIC
100 V
COMMENTS
GRM32 series
50 V
100 V
GRM31 series
50 V
50 V
100 V
VJ X7R series
50 V
100 V
100 V
50 V
100 V
50 V
X7R
C series C4532
C series C3225
50 V
100 V
50 V
X7R dielectric series
100 V
Slow Start Capacitor
The slow start capacitor determines the minimum amount of time it will take for the output voltage to reach its
nominal programmed value during power up. This is useful if a load requires a controlled voltage slew rate. This
is also used if the output capacitance is large and would require large amounts of current to quickly charge the
capacitor to the output voltage level. The large currents necessary to charge the capacitor may make the
TPS54060 reach the current limit or excessive current draw from the input power supply may cause the input
voltage rail to sag. Limiting the output voltage slew rate solves both of these problems.
The slow start time must be long enough to allow the regulator to charge the output capacitor up to the output
voltage without drawing excessive current. Equation 40 can be used to find the minimum slow start time, tss,
necessary to charge the output capacitor, Cout, from 10% to 90% of the output voltage, Vout, with an average
slow start current of Issavg. In the example, to charge the 47μF output capacitor up to 3.3V while only allowing
the average input current to be 0.125A would require a 1 ms slow start time.
Once the slow start time is known, the slow start capacitor value can be calculated using Equation 6. For the
example circuit, the slow start time is not too critical since the output capacitor value is 47μF which does not
require much current to charge to 3.3V. The example circuit has the slow start time set to an arbitrary value of
3.2ms which requires a 0.01 μF capacitor.
Cout ´ Vout ´ 0.8
Tss >
Issavg
(40)
Bootstrap Capacitor Selection
A 0.1-μF ceramic capacitor must be connected between the BOOT and PH pins for proper operation. It is
recommended to use a ceramic capacitor with X5R or better grade dielectric. The capacitor should have a 10V
or higher voltage rating.
34
Submit Documentation Feedback
Product Folder Link(s): TPS54060-Q1
TPS54060-Q1
www.ti.com
Under Voltage Lock Out Set Point
The Under Voltage Lock Out (UVLO) can be adjusted using an external voltage divider on the EN pin of the
TPS54060. The UVLO has two thresholds, one for power up when the input voltage is rising and one for power
down or brown outs when the input voltage is falling. For the example design, the supply should turn on and start
switching once the input voltage increases above 8.9V (enabled). After the regulator starts switching, it should
continue to do so until the input voltage falls below 7.9V (UVLO stop).
The programmable UVLO and enable voltages are set using a resistor divider between Vin and ground to the EN
pin. Equation 2 through Equation 3 can be used to calculate the resistance values necessary. For the example
application, a 332kΩ between Vin and EN and a 56.2kΩ between EN and ground are required to produce the 8.9
and 7.9 volt start and stop voltages.
Output Voltage and Feedback Resistors Selection
For the example design, 10.0 kΩ was selected for R2. Using Equation 1, R1 is calculated as 31.25 kΩ. The
nearest standard 1% resistor is 31.6 kΩ. Due to current leakage of the VSENSE pin, the current flowing through
the feedback network should be greater than 1 μA in order to maintain the output voltage accuracy. This
requirement makes the maximum value of R2 equal to 800 kΩ. Choosing higher resistor values will decrease
quiescent current and improve efficiency at low output currents but may introduce noise immunity problems.
Compensation
There are several methods used to compensate DC/DC regulators. The method presented here is easy to
calculate and ignores the effects of the slope compensation that is internal to the device. Since the slope
compensation is ignored, the actual cross over frequency will usually be lower than the cross over frequency
used in the calculations. This method assume the crossover frequency is between the modulator pole and the
esr zero and the esr zero is at least 10 times greater the modulator pole. Use SwitcherPro software for a more
accurate design.
To get started, the modulator pole, fpmod, and the esr zero, fz1 must be calculated using Equation 41 and
Equation 42. For Cout, use a derated value of 40 μf. Use equations Equation 43 and Equation 44, to estimate a
starting point for the crossover frequency, fco, to design the compensation. For the example design, fpmod is
603 Hz and fzmod is 796 kHz. Equation 43 is the geometric mean of the modulator pole and the esr zero and
Equation 44 is the mean of modulator pole and the switching frequency. Equation 43 yields 21.9 kHz and
Equation 44 gives 12.3 kHz. Use the lower value of Equation 43 or Equation 44 for an initial crossover frequency.
For this example, fco is 12.3kHz. Next, the compensation components are calculated. A resistor in series with a
capacitor is used to create a compensating zero. A capacitor in parallel to these two components forms the
compensating pole.
Ioutmax
¦p mod =
2 × p × Vout × Cout
(41)
1
¦ z mod =
2 ´ p ´ Resr × Cout
(42)
fco =
f p mod ´ f z mod
fco =
f p mod ´
(43)
f sw
2
(44)
To determine the compensation resistor, R4, use Equation 45. Assume the power stage transconductance,
gmps, is 1.9A/V. The output voltage, Vo, reference voltage, VREF, and amplifier transconductance, gmea, are
3.3V, 0.8V and 92μA/V, respectively. R4 is calculated to be 72.6 kΩ, use the nearest standard value of 73.2kΩ.
Use Equation 46 to set the compensation zero to the modulator pole frequency. Equation 46 yields 3600pF for
compensating capacitor C7, a 3300pF is used on the board.
ö
æ 2 ´ p ´ fco ´ Cout ö æ
Vout
R4 = ç
÷´ç
gmps
è
ø è Vref ´ gmea ø
(45)
1
C7 =
2 ´ p ´ R4 ´ f p m od
(46)
35
TPS54060-Q1
www.ti.com
Use the larger value of Equation 47 and Equation 48 to calculate the C8, to set the compensation pole.
Equation 48 yields 8.7pF so the nearest standard of 10pF is used.
C ´ Re sr
C8 = o
R4
(47)
C8 =
1
R4 ´ f sw ´ p
(48)
Discontinuous Mode and Eco Mode Boundary
With an input voltage of 34V, the power supply enters discontinuous mode when the output current is less than
60mA. The power supply enters EcoMode when the output current is lower than 38mA.
The input current draw at no load is 228μA.
APPLICATION CURVES
36
Figure 52. Load Transient
Figure 53. Startup With VIN
Figure 54. Output Ripple CCM
Figure 55. Output Ripple, DCM
TPS54060-Q1
www.ti.com
Figure 56. Output Ripple, PSM
Figure 57. Input Ripple CCM
90
80
70
Efficiency - %
60
50
VIN = 34 V
VIN = 24 V
VIN = 18 V
VIN = 12 V
VIN = 42
40
30
VOUT = 3.3 V
Figure 58. Input Ripple DCM
0.05
0.10
0.15
0.20 0.25 0.30 0.35
0.40
0.45
0.50
Figure 59. Efficiency vs Load Current
100
60
90
150
40
80
100
Phase
Vin = 18 V
50
Vin = 12 V
Vin = 24 V
Vin = 34 V
40
30
Gain
Phase - o
50
60
Gain - dB
Efficiency - %
70
-50
Vin = 42 V
-20
-100
VOUT = 3.3 V
10
0.02
0.04
0.06
0.08
Figure 60. Light Load Efficiency
0.10
-60
100
1-103
1-104
f - Frequency - Hz
1-105
1-106
Figure 61. Overall Loop Frequency Response
37
TPS54060-Q1
www.ti.com
0.1
0.1
0.06
0.06
0.04
0.04
0.02
0.02
-0.04
-0.04
-0.06
-0.06
-0.08
-0.08
-0.1
0.00
IO = 0.25 A
0.08
VI = 34 V
Regulation (%)
Regulation (%)
0.08
-0.1
0.25
0.1
0.15
0.2
0.25
0.3
0.35
0.4
0.45
0.5
10
15
25
30
35
40
45
50
55
60
Load Current - A
Figure 62. Regulation vs Load Current
38
Figure 63. Regulation vs Input Voltage
TPS54060-Q1
www.ti.com
Power Dissipation Estimate
The following formulas show how to estimate the IC power dissipation under continuous conduction mode (CCM)
operation. These equations should not be used if the device is working in discontinuous conduction mode (DCM).
The power dissipation of the IC includes conduction loss (Pcon), switching loss (Psw), gate drive loss (Pgd) and
supply current (Pq).
Vout
Pcon = Io2 ´ RDS(on) ´
Vin
(49)
Psw = Vin 2 ´ ¦ sw ´ lo ´ 0.25 ´ 10-9
Pgd = Vin ´ 3 ´ 10
Pq = 116 ´ 10
-6
-9
(50)
´ ¦ sw
(51)
´ Vin
(52)
Where:
IOUT is the output current (A).
RDS(on) is the on-resistance of the high-side MOSFET (Ω).
VOUT is the output voltage (V).
VIN is the input voltage (V).
fsw is the switching frequency (Hz).
So
Ptot = Pcon + Psw + Pgd + Pq
(53)
For given TA,
TJ = TA + Rth ´ Ptot
(54)
For given TJMAX = 150°C
TAmax = TJmax - Rth ´ Ptot
(55)
Where:
Ptot is the total device power dissipation (W).
TA is the ambient temperature (°C).
TJ is the junction temperature (°C).
Rth is the thermal resistance of the package (°C/W).
TJMAX is maximum junction temperature (°C).
TAMAX is maximum ambient temperature (°C).
There will be additional power losses in the regulator circuit due to the inductor ac and dc losses, the catch diode
and trace resistance that will impact the overall efficiency of the regulator.
39
TPS54060-Q1
www.ti.com
Layout
Layout is a critical portion of good power supply design. There are several signals paths that conduct fast
changing currents or voltages that can interact with stray inductance or parasitic capacitance to generate noise
or degrade the power supplies performance. To help eliminate these problems, the VIN pin should be bypassed
to ground with a low ESR ceramic bypass capacitor with X5R or X7R dielectric. Care should be taken to
minimize the loop area formed by the bypass capacitor connections, the VIN pin, and the anode of the catch
diode. See Figure 64 for a PCB layout example. The GND pin should be tied directly to the power pad under the
IC and the power pad.
The power pad should be connected to any internal PCB ground planes using multiple vias directly under the IC.
The PH pin should be routed to the cathode of the catch diode and to the output inductor. Since the PH
connection is the switching node, the catch diode and output inductor should be located close to the PH pins,
and the area of the PCB conductor minimized to prevent excessive capacitive coupling. For operation at full rated
load, the top side ground area must provide adequate heat dissipating area. The RT/CLK pin is sensitive to noise
so the RT resistor should be located as close as possible to the IC and routed with minimal lengths of trace. The
additional external components can be placed approximately as shown. It may be possible to obtain acceptable
performance with alternate PCB layouts, however this layout has been shown to produce good results and is
meant as a guideline.
Vout
Output
Capacitor
Topside
Ground
Area
Input
Bypass
Capacitor
Vin
UVLO
Adjust
Resistors
Slow Start
Capacitor
Output
Inductor
Route Boot Capacitor
Trace on another layer to
provide wide path for
topside ground
BOOT
Catch
Diode
PH
VIN
GND
EN
COMP
SS/TR
VSENSE
RT/CLK
PWRGD
Frequency
Set Resistor
Compensation
Network
Resistor
Divider
Thermal VIA
Signal VIA
Figure 64. PCB Layout Example
Estimated Circuit Area
The estimated printed circuit board area for the components used in the design of Figure 51 is 0.55 in2. This area
does not include test points or connectors.
40
TPS54060-Q1
www.ti.com
VIN
CIN
Cboot
0.1mF
Lo150 mH
BOOT
VIN
Cd
1 mF
PH
R1
14 kW
GND
R2
1kW
TPS54060
GND
+ Co
2x15 mF
VOUT
VSENSE
EN
SS/TR
COMP
RT/CLK
Css
0.1 mF
RT
237 kW
Rcomp
52.3 kW
Czero
27 nF
Cpole
82 pF
Figure 65. +24V to –12V Inverting Power Supply from SLVA317 Application Note
41
PACKAGE OPTION ADDENDUM
www.ti.com
9-Aug-2016
PACKAGING INFORMATION
Orderable Device
Status
(1)
TPS54060QDGQRQ1
OBSOLETE
Package Type Package Pins Package
Drawing
Qty
MSOPPowerPAD
DGQ
10
Eco Plan
Lead/Ball Finish
MSL Peak Temp
(2)
(6)
(3)
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-3-260C-168 HR
Op Temp (°C)
Device Marking
(4/5)
-40 to 125
5406Q
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability
information and additional product content details.
TBD: The Pb-Free/Green conversion plan has not been defined.
Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that
lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes.
Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between
the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above.
Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight
in homogeneous material)
(3)
MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature.
(4)
There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device.
(5)
Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation
of the previous line and the two combined represent the entire Device Marking for that device.
(6)
Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish
value exceeds the maximum column width.
Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information
provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and
continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals.
TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release.
In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis.
Addendum-Page 1
Samples
www.ti.com
9-Aug-2016
OTHER QUALIFIED VERSIONS OF TPS54060-Q1 :
• Catalog: TPS54060
• Enhanced Product: TPS54060-EP
NOTE: Qualified Version Definitions:
• Catalog - TI's standard catalog product
• Enhanced Product - Supports Defense, Aerospace and Medical Applications
Addendum-Page 2
PACKAGE MATERIALS INFORMATION
www.ti.com
10-Aug-2016
TAPE AND REEL INFORMATION
*All dimensions are nominal
Device
TPS54060QDGQRQ1
Package Package Pins
Type Drawing
MSOPPower
PAD
DGQ
10
SPQ
Reel
Reel
A0
Diameter Width (mm)
(mm) W1 (mm)
330.0
12.4
Pack Materials-Page 1
5.3
B0
(mm)
K0
(mm)
P1
(mm)
3.3
1.3
8.0
W
Pin1
(mm) Quadrant
12.0
Q1
www.ti.com
10-Aug-2016
Device
Package Type
Package Drawing
Pins
SPQ
Length (mm)
Width (mm)
Height (mm)
TPS54060QDGQRQ1
MSOP-PowerPAD
DGQ
10
355.0
55.0
Pack Materials-Page 2
IMPORTANT NOTICE
Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other
changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest
issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and
complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale
supplied at the time of order acknowledgment.
TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms
and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary
to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily
performed.
TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and
applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide
adequate design and operating safeguards.
TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or
other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information
published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or
endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the
third party, or a license from TI under the patents or other intellectual property of TI.
Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration
and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered
documentation. Information of third parties may be subject to additional restrictions.
Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service
voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice.
TI is not responsible or liable for any such statements.
Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements
concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support
that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which
anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause
harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use
of any TI components in safety-critical applications.
In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to
help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and
requirements. Nonetheless, such components are subject to these terms.
No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties
have executed a special agreement specifically governing such use.
Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in
military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components
which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and
regulatory requirements in connection with such use.
TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of
non-designated products, TI will not be responsible for any failure to meet ISO/TS16949.
Products
Applications
Audio
www.ti.com/audio
Automotive and Transportation
www.ti.com/automotive
Amplifiers
amplifier.ti.com
Communications and Telecom
www.ti.com/communications
Data Converters
dataconverter.ti.com
Computers and Peripherals
www.ti.com/computers
DLP® Products
www.dlp.com
Consumer Electronics
www.ti.com/consumer-apps
DSP
dsp.ti.com
Energy and Lighting
www.ti.com/energy
Clocks and Timers
www.ti.com/clocks
Industrial
www.ti.com/industrial
Interface
interface.ti.com
Medical
www.ti.com/medical
Logic
logic.ti.com
Security
www.ti.com/security
Power Mgmt
power.ti.com
Space, Avionics and Defense
www.ti.com/space-avionics-defense
Microcontrollers
microcontroller.ti.com
Video and Imaging
www.ti.com/video
RFID
www.ti-rfid.com
OMAP Applications Processors
www.ti.com/omap
TI E2E Community
e2e.ti.com
Wireless Connectivity
www.ti.com/wirelessconnectivity
Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265
Copyright © 2016, Texas Instruments Incorporated
