AS3665-ZWLT-500
AS3665-ZWLT-500
    AMSOSRAM(艾迈斯半导体)
    25-UFBGA,WLCSP
    LED 驱动器 IC 9 输出 DC DC 稳压器 开关电容器(充电泵) I²C 调光 20mA 25-WLCSP(2.5x2.5)
AS3665-ZWLT-500 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com AS3665 Datasheet, Confidential 9 Channel Advanced Command Driven RGB/White LED Driver 1 General Description 2 Key Features High efficiency capacitive 150mA charge pump with 1:1, 1:1.5 and 1:2 modes with automatic mode switching; 1:2 mode can be disabled 9 Channel High Side 20mA Current sources - Less than 50mV at 10mA dropout voltage - LED7,8,9 either powered by VBAT or VCP Advanced Command based Pattern Generator - 96 x 16 bits program memory - Dedicated lighting commands like logarithmic fade - Programming control and conditional jumps Audio Controlled Lighting with internal digital filters 3 Sequencers - Dynamically mapped to 9 PWM generators - Internal/External Synchronization 9 PWM generators (12 bit resolution) - Automatic RGB Color Correction by TAMB 2 I C interface with dedicated EN pin Available in WL-CSP-25 (2.610x2.675mm) 0.5mm pitch al id The AS3665 is a capacitive low noise charge pump with 9 current sources. The charge pump automatically switches between 1:1 and 1:1.5 modes. The connected current sources have a very low voltage compliance to improve efficiency of the whole system. Three current sources have the possibility to operate either from VBAT or VCP (especially useful for red LEDs). am lc s on A te G nt st il lv The internal control is done by command based pattern generators implemented by three sequencers. These commands are optimized for lighting applications (e.g. ramp up brightness logarithmically). It includes high level commands like conditionals jumps and variables. Any of the three sequencers can be dynamically mapped to any of the 9 PWM generators for the LEDs. The AS3665 supports an audio input and sophisticated light patterns can be controlled by internal digital filters. 2 The AS3665 is controlled by I C mode. Synchronization over several AS3665 is possible by the TRIG pin. The AS3665 is available in a space-saving WL-CSP-25 (2.610x2.675mm) 0.5mm pitch and operates over the 30ºC to +85ºC temperature range. 3 Applications Figure 1. Typical Operating Circuit RGB/White Fun or Event LED for mobile phones or portable devices; Lighting Management Unit 2 3 450$2 2 3 450$2 ; ;       ! " ca  :  ni  012 ch   Te >> >   012 www.austriamicrosystems.com (ptr) ./ 012 * "  '$ * *6  #  #$%&' *4 "($'" %%$  $% ) *  =6= >#< # ?/#.@#
AS3665-ZWLT-500 价格&库存
很抱歉,暂时无法提供与“AS3665-ZWLT-500”相匹配的价格&库存,您可以联系我们找货
