RP509Z331B-E2-F
RP509Z331B-E2-F
    NISSHINBO(日清纺)
    6-WFBGA,WLCSP
    降压 开关稳压器 IC 正 固定 3.3V 1 输出 1A 6-WFBGA,WLCSP
RP509Z331B-E2-F 数据手册
RP509x Series 0.5A/1A PWM/VFM Step-down DC/DC Converter with Synchronous Rectifier No. EA-362-220819 OUTLINE The RP509x is a low supply current PWM/VFM step-down DC/DC converter with synchronous rectifier featuring 0.5 A/1 A output current(1). Internally, a single converter consists of a reference voltage unit, an error amplifier, a switching control circuit, a mode control circuit, a soft-start circuit, an undervoltage lockout (UVLO) circuit, a thermal shutdown circuit, and switching transistors. The RP509x is employing synchronous rectification for improving the efficiency of rectification by replacing diodes with built-in switching transistors. Using synchronous rectification not only increases circuit performance but also allows a design to reduce parts count. Output voltage controlling method is selectable between a PWM/VFM auto-switching control type and a forced PWM control type, which further reduces noise than a normal PWM control under a light load, and these types can be set by the MODE pin. Output voltage type is selectable between an internally fixed output voltage type and an externally adjustable output voltage type. Protection circuits in the RP509x is current limit circuit and thermal shutdown circuit. LX current limit value (Typ.) is selectable between 1.6 A and 1.0 A. The RP509Z is available in WLCSP-6-P6 which achieves high-density mounting on boards. Using capacitor of 0402-/1005-size (inch/mm) and inductor of 0603-/1608-size (inch/mm) as external parts help to save space for devices. The RP509N is available in SOT-23-6. FEATURES • • Input Voltage Range (Maximum Rating) ···························· 2.3 V to 5.5 V (6.5 V) Output Voltage Range (Fixed Output Voltage Type) ············· 0.6 V to 3.3 V, settable in 0.1 V steps (Adjustable Output Voltage Type) ······· 0.6 V to 5.5 V • • • • • • Output Voltage Accuracy (Fixed Output Voltage Type) ·········· ±1.5% (VSET( 2) ≥ 1.2 V), ±18 mV (VSET < 1.2 V) • • • • • Standby Current ··························································· Typ. 0 µA Feedback Voltage Accuracy (Adjustable Output Voltage Type) ···· ±9 mV (VFB = 0.6 V) Output Voltage/Feedback Voltage Temperature Coefficient ···· ±100 ppm/°C Selectable Oscillator Frequency ······································ Typ. 6.0 MHz Oscillator Maximum Duty ··············································· Min. 100% Built-in Driver ON Resistance (VIN = 3.6 V) ························· Typ. Pch. 0.175 Ω, Nch. 0.155 Ω (RP509Z) Typ. Pch. 0.195 Ω, Nch. 0.175 Ω (RP509N) UVLO Detector Threshold ·············································· Typ. 2.0 V Soft-start Time ····························································· Typ. 0.15 ms Inductor Current Limit Circuit··········································· Typ. 1.6 A/1.0 A, selectable Current Limit Package ····························································· WLCSP-6-P6 ( 1.28 mm x 0.88 mm x 0.69 mm ) SOT-23-6 ( 2.9 mm x 2.8 mm x 1.1 mm ) (1) (2) This is an approximate value. The output current is dependent on conditions and external components. VSET = Set Output Voltage 1 RP509x No. EA-362-220819 APPLICATIONS • • Portable Communication Equipment: Mobiles/Smartphones, Digital Cameras and Note-PCs Li-ion Battery-used Equipment SELECTION GUIDE The set output voltage, the output voltage type, the auto-discharge function(1), and the LX current limit for the ICs are user-selectable options. Selection Guide Product Name RP509ZxxX$-E2-F RP509NxxX$-TR-FE Package Quantity per Reel Pb Free Halogen Free WLCSP-6-P6 5,000 pcs Yes Yes SOT-23-6 3,000 pcs Yes Yes xx: Specify the set output voltage (VSET) Fixed Output Voltage Type: 06 to 33 (0.6 V to 3.3 V, 0.1 V steps) The voltage in 0.05 V step is shown as follows. 1.05 V: RP509Z101B5 1.15 V: RP509N111x5 Adjustable Output Voltage Type: 00 only X: Specify the LX Current Limit (ILXLIM) Typ. 1.6 A: 1 Typ. 1.0 A: 2 $: Specify the version Version Output Voltage Type A Fixed B C Adjustable D (1) Auto-discharge No Yes No Yes Oscillator Frequency 6.0 MHz VSET 0.6 V to 3.3 V 0.6 V to 5.5 V Auto-discharge function quickly lowers the output voltage to 0 V, when the chip enable signal is switched from the active mode to the standby mode, by releasing the electrical charge accumulated in the external capacitor. 2 RP509x No. EA-362-220819 BLOCK DIAGRAM RP509ZxxXA/RP509ZxxXB, RP509NxxXA/RP509NxxXB (Fixed Output Voltage Type) UVLO MODE Thermal Protection Hi Side Current Detector Mode Control Slope Generator Vref VOUT Soft Start Amp. On Time Control Switching Control LX Comp. Low Side Current Detector CE VIN GND Enable Control RP509xxxXA Block Diagram UVLO MODE Thermal Protection Hi Side Current Detector Mode Control Slope Generator Vref VOUT Soft Start Amp. On Time Control Switching Control LX Comp. Low Side Current Detector CE VIN GND Enable Control RP509xxxXB Block Diagram 3 RP509x No. EA-362-220819 RP509Z00XC/RP509Z00XD, RP509N00XC/RP509N00XD (Adjustable Output Voltage Type) UVLO MODE Thermal Protection Hi Side Current Detector Mode Control Slope Generator Vref VFB Soft Start Amp. On Time Control Switching Control LX Comp. Low Side Current Detector CE VIN GND Enable Control RP509x00XC Block Diagram UVLO MODE Thermal Protection Hi Side Current Detector Mode Control Slope Generator Vref VFB Soft Start Amp. On Time Control Switching Control LX Comp. Low Side Current Detector CE VIN GND Enable Control RP509x00XD Block Diagram 4 RP509x No. EA-362-220819 PIN DESCRIPTION Top View Bottom View 2 2 1 1 A B C 6 C WLCSP-6 Pin Configurations A1 MODE B1 C1 A2 B2 C2 LX VOUT/VFB VIN CE GND SOT-23-6 Pin Description Pin No. Symbol 1 CE 2 GND 3 VIN 4 MODE 5 6 LX VOUT/VFB 4 (mark side) B A 1 WLCSP-6 Pin Description Pin No. Symbol 5 2 3 SOT-23-6 Pin Configurations Description Mode Control Pin (High: Forced PWM Control, Low: PWM/VFM Auto-switching Control) Switching Pin Output/Feedback Voltage Pin Input Voltage Pin Chip Enable Pin, Active-high Ground Pin Description Chip Enable Pin, Active-high Ground Pin Input Voltage Pin Mode Control Pin (High: Forced PWM Control, Low: PWM/VFM Auto-switching Control) Switching Pin Output/Feedback Voltage Pin 5 RP509x No. EA-362-220819 ABSOLUTE MAXIMUM RATINGS Absolute Maximum Ratings Symbol VIN VLX VCE VMODE VOUT/VFB ILX (GND = 0 V) Item Input Voltage LX Pin Voltage CE Pin Voltage MODE Pin Voltage VOUT/VFB Pin Voltage LX Pin Output Current WLCSP6-P6 Rating −0.3 to 6.5 −0.3 to VIN +0.3 −0.3 to 6.5 −0.3 to 6.5 −0.3 to 6.5 1.6 Unit V V V V V A 910 mW 892 mW JEDEC STD. 51-9 Test Land Pattern JEDEC STD. 51-7 Test Land Pattern PD Power Dissipation(1) Tj Junction Temperature −40 to 125 °C Storage Temperature Range −55 to 125 °C Tstg SOT-23-6 ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS Symbol VIN Ta Item Input Voltage Operating Temperature Range Rating 2.3 to 5.5 −40 to 85 Unit V °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) Refer to POWER DISSIPATION for detailed information. 6 RP509x No. EA-362-220819 ELECTRICAL CHARACTERISTICS Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. RP509Zxx1A/RP509Zxx1B, RP509Nxx1A/RP509Nxx1B Electrical Characterisitcs Symbol Item Conditions Output Voltage VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN =VCE =VSET +1 V (VSET > 2.6 V) Output Voltage Temperature Coefficient −40 °C ≤ Ta ≤ 85 °C fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, “Closed Loop Control” IDD Supply Current VIN = VCE = VOUT = 3.6 V, VMODE = 0 V VOUT ∆VOUT/ ∆Ta ISTANDBY Min. Typ. (Ta = 25°C) Max. Unit VSET ≥ 1.2 V x 0.985 x 1.015 VSET< 1.2 V +0.018 −0.018 ppm/ °C ±100 4.8 6.0 V 7.2 15 MHz µA Standby Current VIN = 5.5 V,VCE = 0 V 0 5 µA ICEH CE "High" Input Current VIN = VCE = 5.5 V −1 0 1 µA ICEL CE "Low" Input Current VIN = 5.5 V,VCE = 0 V −1 0 1 µA IMODEH MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR On-resistance for Auto Discharger(1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V ILXLEAKL 40 −1 0 5 µA 0 1 µA LX "Low" Leakage Current VIN = 5.5 V, VCE = VLX = 0 V −5 VCEH CE ”High” Input Voltage VIN = 5.5 V 1.0 VCEL CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VIN = VCE = 2.3 V RONP On-resistance of Pch. transistor RONN On-resistance of Nch. transistor Maxduty RP509Z RP509N RP509Z RP509N Ω V 0.4 1.0 V 0.4 0.175 Ω 0.195 Ω VIN = 3.6 V, ILX = −100 mA 0.155 Ω 0.175 Ω Maximum Duty Cycle 100 % Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN =VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN =VCE = VSET + 1 V (VSET > 2.6 V) 1200 1600 VIN = VCE, Falling 1.85 2.00 2.20 VIN = VCE, Rising 1.90 2.05 2.25 VUVLO2 TTSD TTSR UVLO Threshold Voltage Thermal Shutdown Threshold Temperature V VIN = 3.6 V, ILX = −100 mA tSTART VUVLO1 V 150 300 µs mA V V Tj, Rising 140 °C Tj, Falling 100 °C All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). (1) RP509xxx1B only 7 RP509x No. EA-362-220819 Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. RP509Z001C/RP509Z001D, RP509N001C/RP509N001D Electrical Characterisitcs Symbol VFB ∆VFB/ ∆Ta Item Feedback Voltage Conditions VIN = VCE = 3.6 V (Ta = 25°C) Min. Typ. Max. 0.591 0.600 0.609 Unit V Feedback Voltage Temperature Coefficient −40 °C ≤ Ta ≤ 85 °C fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, “Closed Loop Control” IDD Supply Current VIN = VCE = VOUT = 3.6V, VMODE = 0V 15 Standby Current VIN = 5.5 V,VCE = 0 V 0 5 µA ICEH CE "High" Input Current VIN = VCE = 5.5 V −1 0 1 µA ICEL CE "Low" Input Current VIN = 5.5 V,VCE = 0 V −1 0 1 µA IMODEH MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR On-resistance for Auto Discharge(1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V ILXLEAKL ISTANDBY ±100 4.8 µA Ω 5 µA 0 1 µA VIN = 5.5 V, VCE = VLX = 0 V −5 VIN = 5.5 V 1.0 VCEL CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VIN = VCE = 2.3 V RONP On-resistance of Pch. Transistor RP509Z RONN On-resistance of Nch. Transistor RP509Z V 0.4 1.0 V V 0.4 V VIN = 3.6 V, ILX = −100 mA 0.175 Ω 0.195 Ω VIN = 3.6 V, ILX = −100 mA 0.155 Ω 0.175 Ω Maximum Duty Cycle 100 % tSTART Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN =VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN =VCE = VSET + 1 V (VSET > 2.6 V) 1200 1600 VIN = VCE, Falling 1.85 2.00 2.20 V VIN = VCE, Rising 1.90 2.05 2.25 V VUVLO1 VUVLO2 TTSD UVLO Threshold Voltage Thermal Shutdown Threshold Temperature Tj, Rising 150 300 µs mA 140 TTSR Tj, Falling 100 All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). (1) MHz 0 CE "High" Input Voltage Maxduty 7.2 −1 LX "Low" Leakage Current RP509N 6.0 40 VCEH RP509N ppm/ °C °C °C RP509x001D only 8 RP509x No. EA-362-220819 Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. RP509Zxx2A/RP509Zxx2B, RP509Nxx2A/RP509Nxx2B Electrical Characterisitcs Symbol Item Conditions (Ta = 25°C) Min. Typ. Max. Unit Output Voltage VIN = VCE = 3.6 V VSET ≥ 1.2 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V VSET < 1.2 V (VSET > 2.6 V) Output Voltage Temperature Coefficient −40 °C ≤ Ta ≤ 85 °C fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, “Closed Loop Control” IDD Supply Current VIN = VCE = VOUT = 3.6V, VMODE = 0V 15 Standby Current VIN = 5.5 V,VCE = 0 V 0 5 µA ICEH CE "High" Input Current VIN = VCE = 5.5 V −1 0 1 µA ICEL CE "Low" Input Current VIN = 5.5 V,VCE = 0 V −1 0 1 µA IMODEH MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR On-resistance for Auto Discharger(1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V −1 0 5 µA ILXLEAKL LX "Low" Leakage Current VIN = 5.5 V, VCE = VLX = 0 V −5 0 1 µA VCEH CE "High" Input Voltage VIN = 5.5 V 1.0 VCEL CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VIN = VCE = 2.3 V RONP On-resistance of Pch. transistor RP509Z RONN On-resistance of Nch. transistor RP509Z VOUT ∆VOUT/ ∆Ta ISTANDBY Maxduty Soft-start Time ILXLIM LX Current Limit VUVLO2 TTSD TTSR RP509N UVLO Threshold Voltage Thermal Shutdown Threshold Temperature x 1.015 −0.018 +0.018 4.8 6.0 V ppm/ °C ±100 7.2 MHz µA 40 Ω V 0.4 1.0 V V 0.4 V VIN = 3.6 V, ILX = −100 mA 0.175 Ω 0.195 Ω VIN = 3.6 V, ILX = −100 mA 0.155 Ω 0.175 Ω Maximum Duty Cycle tSTART VUVLO1 RP509N x 0.985 100 VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) % 150 300 µs 600 1000 mA VIN = VCE, Falling 1.85 2.00 2.20 V VIN = VCE, Rising 1.90 2.05 2.25 V Tj, Rising 140 °C Tj, Falling 100 °C All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). (1) RP509xxx2B only 9 RP509x No. EA-362-220819 Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. RP509Z002C/RP509Z002D, RP509N002C/RP509N002D Electrical Characterisitcs Symbol VFB Item Conditions (Ta = 25°C) Min. Typ. Max. Unit 0.591 0.600 0.609 V Feedback Voltage VIN = VCE = 3.6 V Feedback Voltage Temperature Coefficient −40 °C ≤ Ta ≤ 85 °C fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, “Closed Loop Control” IDD Supply Current VIN = VCE = VOUT = 3.6V, VMODE =0V 15 Standby Current VIN = 5.5 V,VCE = 0 V 0 5 µA ICEH CE "High" Input Current VIN = VCE = 5.5 V −1 0 1 µA ICEL CE "Low" Input Current VIN = 5.5 V,VCE = 0 V −1 0 1 µA IMODEH MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR On-resistance for Auto Discharge(1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V −1 0 5 µA ILXLEAKL LX "Low" Leakage Current VIN = 5.5 V, VCE = VLX = 0 V −5 0 1 µA VCEH CE "High" Input Voltage VIN = 5.5 V 1.0 VCEL CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VIN = VCE = 2.3 V RONP On-resistance of Pch. Transistor RP509Z RONN On-resistance of Nch. Transistor RP509Z ∆VFB/ ∆Ta ISTANDBY Maxduty RP509N RP509N ppm/ °C ±100 4.8 6.0 7.2 µA 40 Ω V 0.4 1.0 V V 0.4 V VIN = 3.6 V, ILX = −100 mA 0.175 Ω 0.195 Ω VIN = 3.6 V, ILX = −100 mA 0.155 Ω 0.175 Ω Maximum Duty Cycle 100 % tSTART Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET +1 V (VSET > 2.6 V) 600 1000 VIN = VCE, Falling 1.85 2.00 2.20 V VIN = VCE, Rising 1.90 2.05 2.25 V VUVLO1 VUVLO2 TTSD UVLO Threshold Voltage Thermal Shutdown Threshold Temperature Tj, Rising 150 300 µs mA 140 TTSR Tj, Falling 100 All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). (1) MHz °C °C RP509x002D only 10 RP509x No. EA-362-220819 Electrical Characteristics by Different Output Voltage RP509ZxxXA/RP509ZxxXB, RP509NxxXA/RP509NxxXB (Fixed Output Voltage Type) VOUT [V] Product Name Min. Typ. RP 5 09x 0 6 X A RP 5 09x 0 6 X B 0.582 0.600 RP 5 09x 0 7 X A RP 5 09x 0 7 X B 0.682 0.700 RP 5 09x 0 8 X A RP 5 09x 0 8 X B 0.782 0.800 RP 5 09x 0 9 X A RP 5 09x 0 9 X B 0.882 0.900 RP 5 09x 1 0 X A RP 5 09x 1 0 X B 0.982 1.000 RP 5 09x 11 X A RP 5 09x 11 X B 1.082 1.100 RP 5 09x 1 2 X A RP 5 09x 1 2 X B 1.182 1.200 RP 5 09x 1 3 X A RP 5 09x 1 3 X B 1.281 1.300 RP 5 09x 1 4 X A RP 5 09x 1 4 X B 1.379 1.400 RP 5 09x 1 5 X A RP 5 09x 1 5 X B 1.478 1.500 RP 5 09x 1 6 X A RP 5 09x 1 6 X B 1.576 1.600 RP 5 09x 1 7 X A RP 5 09x 1 7 X B 1.675 1.700 RP 5 09x 1 8 X A RP 5 09x 1 8 X B 1.773 1.800 RP 5 09x 1 9 X A RP 5 09x 1 9 X B 1.872 1.900 RP 5 09x 2 0 X A RP 5 09x 2 0 X B 1.970 2.000 RP 5 09x 2 1 X A RP 5 09x 2 1 X B 2.069 2.100 RP 5 09x 2 2 X A RP 5 09x 2 2 X B 2.167 2.200 RP 5 09x 2 3 X A RP 5 09x 2 3 X B 2.266 2.300 RP 5 09x 2 4 X A RP 5 09x 2 4 X B 2.364 2.400 RP 5 09x 2 5 X A RP 5 09x 2 5 X B 2.463 2.500 RP 5 09x 2 6 X A RP 5 09x 2 6 X B 2.561 2.600 RP 5 09x 2 7 X A RP 5 09x 2 7 X B 2.660 2.700 RP 5 09x 2 8 X A RP 5 09x 2 8 X B 2.758 2.800 RP 5 09x 2 9 X A RP 5 09x 2 9 X B 2.857 2.900 RP 5 09x 3 0 X A RP 5 09x 3 0 X B 2.955 3.000 RP 5 09x 3 1 X A RP 5 09x 3 1 X B 3.054 3.100 RP 5 09x 3 2 X A RP 5 09x 3 2 X B 3.152 3.200 RP 5 09x 3 3 X A RP 5 09x 3 3 X B 3.251 3.300 RP 5 09 Z1 0 1 B5 1.032 1.050 RP 5 09 N 111 A5 RP 5 09 N 111 B5 1.132 1.150 RP 5 09 Z11 2 B5 1.132 1.150 RP 5 09x 1 3 X B5 1.330 1.350 (Ta = 25°C) Max. 0.618 0.718 0.818 0.918 1.018 1.118 1.218 1.319 1.421 1.522 1.624 1.725 1.827 1.928 2.030 2.131 2.233 2.334 2.436 2.537 2.639 2.740 2.842 2.943 3.045 3.146 3.248 3.349 1.068 1.168 1.168 1.370 11 RP509x No. EA-362-220819 OPERATING DESCRIPTIONS Soft-start Time Starting-up with CE Pin The IC starts to operate when the CE pin voltage (VCE) exceeds the threshold voltage. The threshold voltage is preset between CE “H” input voltage (VCEH) and CE “Low” input voltage (VCEL). After the start-of the start-up of the IC, soft-start circuit starts to operate. Then, after a certain period of time, the reference voltage (VREF) in the IC gradually increases up to the specified value. Notes: Soft start time (tSTART)(1) is not always equal to the turn-on speed of the step-down DC/DC converter. Please note that the turn-on speed could be affected by the power supply capacity, the output current, the inductance value and the COUT value. CE Pin Input Voltage (VCE) IC Internal Reference Voltage (VREF) LX Voltage (VLX) VCEH Threshold Level VCEL Soft-start Time (tSTART) Soft-start Circuit operation starts. Output Voltage (VOUT) Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with CE Pin Starting-up with Power Supply After the power-on, when VIN exceeds the UVLO released voltage (VUVLO2), the IC starts to operate. Then, softstart circuit starts to operate and after a certain period of time, VREF gradually increases up to the specified value. Notes: Please note that the turn-on speed of VOUT could be affected by the power supply capacity, the output current, the inductance value, the COUT value and the turn-on speed of VIN determined by CIN. VUVLO2 Input Voltage (VIN) Soft-start Time (tSTART) IC Internal Reference Voltage (VREF) LX Voltage (VLX) VSET Output Voltage (VOUT) Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with Power Supply (1) Soft-start time (tSTART) indicates the duration until the reference voltage (VREF) reaches the specified voltage after softstart circuit’s activation. 12 RP509x No. EA-362-220819 Undervoltage Lockout (UVLO) Circuit If VIN becomes lower than VSET, the step-down DC/DC converter stops the switching operation and ON duty becomes 100%, and then VOUT gradually drops according to VIN. If the VIN drops more and becomes lower than the UVLO detector threshold (VUVLO1), the UVLO circuit starts to operate, VREF stops, and Pch. and Nch. built-in switch transistors turn “OFF”. As a result, VOUT drops according to the COUT capacitance value and the load. To restart the operation, VIN needs to be higher than VUVLO2. The timing chart below shows the voltage shifts of VREF, VLX and VOUT when VIN value is varied. Notes: Falling edge (operating) and rising edge (releasing) waveforms of VOUT could be affected by the initial voltage of COUT and the output current of VOUT. Input Voltage (VIN) VSET VUVLO2 VUVLO1 Soft-start Time (tSTART) IC Internal Reference Voltage (VREF) LX Voltage (VLX) Output Voltage (VOUT) VSET Depending on Power Supply, Load Current, External Components Timing Chart with Variations in Input Voltage (VIN) 13 RP509x No. EA-362-220819 Current Limit Circuit Current limit circuit supervises the inductor peak current (the peak current flowing through Pch. Tr.) in each switching cycle, and if the current exceeds the LX current limit (ILXLIM), it turns off Pch. Tr. ILXLIM of the RP509x is set to Typ.1.6 A or Typ.1.0 A. Notes: ILXLIM could be easily affected by self-heating or ambient environment. If the VIN drops dramatically or becomes unstable due to short-circuit, protection operation could be affected. Over Current Protection LX Current Limit (ILXLIM) LX Current Pch. Tr. Current LX Voltage (VLX) Over-Current Protection Operation 14 RP509x No. EA-362-220819 Operation of Step-down DC/DC Converter and Output Current The step-down DC/DC converter charges energy in the inductor when LX Tr. turns “ON”, and discharges the energy from the inductor when LX Tr. turns “OFF” and controls with less energy loss, so that a lower output voltage (VOUT) than the input voltage (VIN) can be obtained. The operation of the step-down DC/DC converter is explained in the following figures. IL i1 VIN VOUT L Pch. Tr Nch. Tr i2 ILMAX ILMIN i1 i2 tOPEN CL GND tON tOFF T=1/fOSC Basic Circuit Inductor Current (IL) flowing through Inductor (L) Step1. Pch. Tr. turns “ON” and IL (i1) flows, L is charged with energy. At this moment, i1 increases from the minimum inductor current (ILMIN), which is 0 A, and reaches the maximum inductor current (ILMAX) in proportion to the on-time period (tON) of Pch. Tr. Step2. When Pch. Tr. turns “OFF”, L tries to maintain IL at ILMAX, so L turns Nch Tr. “ON” and IL (i2) flows into L. Step3. i2 decreases gradually and reaches ILMIN after the open-time period (tOPEN) of Nch. Tr., and then Nch. Tr. turns “OFF”. This is called discontinuous current mode. As the output current (IOUT) increases, the off-time period (tOFF) of Pch. Tr. runs out before IL reaches ILMIN. The next cycle starts, and Pch. Tr. turns “ON” and Nch. Tr. turns “OFF”, which means IL starts increasing from ILMIN. This is called continuous current mode. In PWM mode, VOUT is maintained by controlling ton. The oscillator frequency (fOSC) is maintained constant during PWM mode. When the step-down DC/DC operation is constant, ILMIN and ILMAX during ton of Pch. Tr. would be same as during tOFF of Pch. Tr. The current differential between ILMAX and ILMIN is described as ∆I, as the following equation 1. ∆I = ILMAX − ILMIN = VOUT × tOPEN / L = (VIN − VOUT) × tON / L ·················································· Equation 1 The above equation is predicated on the following requirements. T = 1 / fOSC = tON + tOFF duty (%) = tON / T × 100 = tON × fOSC × 100 tOPEN ≤ tOFF In Equation 1, “VOUT × tOPEN / L” shows the amount of current change in "OFF" state. Also, “(VIN − VOUT) × tON / L” shows the amount of current change at "ON" state. 15 RP509x No. EA-362-220819 Discontinuous Mode and Continuous Mode As illustrated in Figure A., when IOUT is relatively small, tOPEN < tOFF. In this case, the energy charged into L during tON will be completely discharged during tOFF, as a result, ILMIN = 0. This is called discontinuous mode. When IOUT is gradually increased, eventually tOPEN = tOFF and when IOUT is increased further, eventually ILMIN > 0 as illustrated in Figure B. This is called continuous mode. IL ILMAX IL ILMAX ILMIN ILMIN tOPEN t tON ICONST tOFF tON T=1/fOSC Figure A. Discontinuous Mode t tOFF T=1/fOSC Figure B. Continuous Mode In the continuous mode, the solution of Equation 1 is described as tONC. tONC = T × VOUT / VIN ···································································································· Equation 2 When tON < tONC, it is discontinuous mode, and when tON = tONC, it is continuous mode. 16 RP509x No. EA-362-220819 Forced PWM Mode and VFM Mode Output voltage controlling method is selectable between a forced PWM control type and a PWM/VFM autoswitching control type, and can be set by the MODE pin. The forced PWM control switches at fixed frequency rate in order to reduce noise in low output current. The PWM/VFM auto-switching control automatically switches from PWM mode to VFM mode in order to achieve high efficiency in low output current. Forced PWM Mode By setting the MODE pin to “H”, the IC switches the frequency at the fixed rate to reduce noise even when the output load is light. Therefore, when IOUT is ∆IL/2 or less, ILMIN becomes less than “0”. That is, the accumulated electricity in CL is discharged through the IC side while IL is increasing from ILMIN to “0” during ton, and also while IL is decreasing from “0” to ILMIN during tOFF. VFM Mode By setting the MODE pin to “Low”, in low output current, the IC automatically switches into VFM mode in order to achieve high efficiency. In VFM mode, ton is determined depending on VIN and VOUT. ILMAX IL ILMAX IL ΔIL IOUT 0 0 ILMIN tON t tOFF T=1/fOSC Forced PWM Mode ILMIN t tON tOFF VFM Mode 17 RP509x No. EA-362-220819 APPLICATION INFORMATION Typical Application Circuits MODE = High: Forced PWM Control, MODE = Low: PWM/VFM Auto-switching Control VIN VIN VOUT LX L RP509xxxXA/B MODE CIN VOUT COUT GND CE RP509xxxXA/RP509xxxXB (Fixed Output Voltage Type) MODE = High: Forced PWM Control, MODE = Low: PWM/VFM Auto-switching Control VIN VIN LX RP509x00XC/D CIN MODE VOUT L R1 C1 VFB COUT R2 CE GND RP509x00XC/RP509x00XD ( Adjustable Output Voltage Type) Recommended External Components Symbol CIN COUT L Descriptions 4.7 μF and more, Ceramic Capacitor, See the table of “Input Voltage vs. Capacitance” in the following page. 10 µF, Ceramic Capacitor, See the table of “Set Output Voltage (VSET) vs. Capacitance” in the following page. 0.47 µH to 0.56 µH, See the table of “Inductance Range vs. PWM Frequency” in the following page. 18 RP509x No. EA-362-220819 Input Voltage vs. Capacitance Size VIN [V] [mm] 1005 Up to 4.5 Rated Voltage [V] 6.3 6.3 4.7 6.3 10 6.3 10 6.3 4.7 6.3 10 6.3 1608 1005 Up to 5.5 CIN [μF] 4.7 10 1608 Set Output Voltage (VSET) vs. Capacitance Version VSET [V] COUT [μF] Rated Voltage [V] 10 4 10 6.3 10 6.3 10 4 10 6.3 1608 10 6.3 1608 10 6.3 Size [mm] 1005 0.6 to 1.8 RP509xxxXA RP509xxxXB or RP509x00XC RP509x00XD 1608 1005 1.9 to 3.3 RP509x00XC RP509x00XD 3.4 to 4.5 Model JMK105BBJ475MV (Taiyo Yuden) C1005X5R0J106M050BC (TDK) GRM188R60J475ME84 (Murata) GRM188R60J475ME19 (Murata) C1608X5R0J475M080AB (TDK) JMK107BJ475MA (Taiyo Yuden) GRM188R60J106ME47 (Murata) C1608X5R0J106M080AB (TDK) JMK107ABJ106MA (Taiyo Yuden) C1005X5R0J106M050BC (TDK) GRM188R60J475ME84 (Murata) GRM188R60J475ME19 (Murata) JMK107BJ475MA (Taiyo Yuden) GRM188R60J106ME47 (Murata) C1608X5R0J106M080AB (TDK) JMK107ABJ106MA (Taiyo Yuden) Model GRM155R60G106ME44 (Murata) C1005X5R0G106M050BB (TDK) AMK105CBJ106MV (Taiyo Yuden) C1005X5R0J106M050BC (TDK) GRM188R60J106ME47 (Murata) C1608X5R0J106M080AB (TDK) JMK107ABJ106MA (Taiyo Yuden) GRM155R60G106ME44(Murata) C1005X5R0G106M050BB (TDK) AMK105CBJ106MV (Taiyo Yuden) C1005X5R0J106M050BC (TDK) GRM188R60J106ME47 (Murata) C1608X5R0J106M080AB (TDK) JMK107ABJ106MA (Taiyo Yuden) GRM188R60J106ME47 (Murata) C1608X5R0J106M080AB (TDK) JMK107ABJ106MA (Taiyo Yuden) 19 RP509x No. EA-362-220819 Inductance Range vs. PWM Frequency PWM Size Height(Max) Frequency Version [mm] [mm] [MHz] 1608 RP509xxxXA RP509xxxXB or RP509x00XC RP509x00XD 6.0 2012 L [μH] 0.95 0.47 1.0 0.5 0.56 0.47 0.54 0.47 0.47 0.47 Rdc (Typ) [mΩ] Model 110 90 60 65 70 65 60 48 75 MDT1608-CHR47M (TOKO) MDT1608-CRR47M (TOKO) MIPSZ2012D0R5 (FDK) MDT2012-CRR56N (TOKO) MLP2012HR47MT (TDK) MLP2012HR54MT (TDK) CKP2012NR47M-T (Taiyo Yuden) BRL2012TR47M6 (Taiyo Yuden) LQM21PNR47MG0 (Murata) Precautions for the Selection of External Parts • • • • Choose a low ESR ceramic capacitor. The capacitance of CIN between VIN and GND should be more than or equal to 4.7 µF. The capacitance of a ceramic capacitor (COUT) should be 10 µF. Also, choose the capacitor with consideration for bias characteristics and input/output voltages. See the above tables of “Input Voltage vs. Capacitance” and “Set Output Voltage vs. Capacitance”. The phase compensation of this device is designed according to the COUT and L values. The inductance range of an inductor should be between 0.47µH to 0.56 µH in order to gain stability. See the above table of “Inductance Range vs. PWM Frequency”. Choose an inductor that has small DC resistance, has enough permissible current and is hard to cause magnetic saturation. If the inductance value of the inductor becomes extremely small under the load conditions, the peak current of LX may increase along with the load current. As a result, over current protection circuit may start to operate when the peak current of LX reaches to LX limit current. Therefore, choose an inductor with consideration for the value of ILXMAX. See the following page of “Calculation Conditions of LX Pin Maximum Output Current (ILXMAX)”. As for the adjustable output voltage type (RP509x00XC/RP509x00XD), the set output voltage (VSET) can be arbitrarily set by changing the vales of R1 and R2 using the following equation: VSET = VFB × (R1 + R2) / R2 Refer to the following table for the recommended values for R1, R2 and C1. Set Output Voltage (VSET) vs. R1/R2/C1 (Adjustable Output Voltage Type) VSET [V] R1 [kΩ] R2 [kΩ] 0. 6 0 220 0. 6 < VSET ≤ 0 .9 220 0. 9 < VSET ≤ 1 .8 220 1. 8 < VSET ≤ 2 .1 150 2. 1 < VSET ≤ 2 .4 R1 = (VSET / VFB -1 ) x R2 100 2. 4 < VSET ≤ 2 .7 68 2. 7 < VSET ≤ 3 .0 47 3. 0 < VSET ≤ V I N 47 C1 [pF] Open 47 33 10 10 10 10 6.8 20 RP509x No. EA-362-220819 Calculation Conditions of LX Pin Maximum Output Current (ILXMAX) The following equations explain the relationship to determine ILXMAX at the ideal operation of the ICs in continuous mode. Ripple Current P-P value is described as IRP, ON resistance of Pch. Tr. is described as RONP, ON resistance of Nch. Tr. is described as RONN, and DC resistor of the inductor is described as RL. First, when Pch. Tr. is “ON”, Equation 1 is satisfied. VIN = VOUT + (RONP + RL) × IOUT + L × IRP / tON ·································································· Equation 1 Second, when Pch. Tr. is "OFF" (Nch. Tr. is "ON"), Equation 2 is satisfied. L × IRP / tOFF = RONN × IOUT + VOUT + RL × IOUT ·································································· Equation 2 Put Equation 2 into Equation 1 to solve ON duty of Pch. Tr. (DON = tON / (tOFF + tON)): DON = (VOUT + RONN × IOUT + RL × IOUT) / (VIN + RONN × IOUT − RONP × IOUT) ······························· Equation 3 Ripple Current is described as follows: IRP = (VIN − VOUT − RONP × IOUT − RL × IOUT) × DON / fOSC / L ················································· Equation 4 Peak current that flows through L, and LX Tr. is described as follows: ILXMAX = IOUT + IRP / 2 ································································································· Equation 5 21 RP509x No. EA-362-220819 TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed its rated voltage, rated current or rated power. When designing a peripheral circuit, please be fully aware of the following points. • Set the external components as close as possible to the IC and minimize the wiring between the components and the IC. Especially, place a capacitor (CIN) as close as possible to the VIN pin and GND. • Ensure the VIN and GND lines are sufficiently robust. If their impedance is too high, noise pickup or unstable operation may result. • The VIN line, the GND line, the VOUT line, an inductor, and LX should make special considerations for the large switching current flows. • The wiring between the VOUT pin and an inductor (L) (RP509xxxXA/RP509xxxXB) or between a resistor for setting output voltage (R1) and L (RP509x00XC/RP509x00XD) should be separated from the wiring between L and Load. • Over current protection circuit may be affected by self-heating or power dissipation environment. • For any setting type of output voltage, the input/output voltage ratio must meet the following requirement to achieve a stable VFM mode at light load when the MODE pin is “Low” (at PWM/VFM Auto Switching): VOUT / VIN < 0.7 VMODE = Low, PWM/VFM Auto Switching Input Voltage VIN (V) 5.5 Adjustable Output 4.7 Voltage Type Fixed Output Voltage Type 3.9 3.1 2.3 0.6 1.2 1.8 2.4 3.0 3.6 4.2 Output Voltage VOUT (V) Available Voltage Area with Stable VFM Mode 22 RP509x No. EA-362-220819 PCB LAYOUT Fixed Output Voltage Type (RP509ZxxXA/B) Top Layer Bottom Layer Adjustable Output Voltage Type (RP509Z00XC/D) Top Layer Bottom Layer 23 RP509x No. EA-362-220819 Adjustable Output Voltage Type (RP509N00XC/D) Top Layer Bottom Layer 24 RP509x No. EA-362-220819 TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Efficiency vs. Output Current (RP509Z) VOUT = 1.0 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.2 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 3.3 V (Fixed Output Voltage Type) VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.8 V VMODE = "H" Forced PWM Mode L = MIPSZ2012D0R5 25 RP509x No. EA-362-220819 Efficiency vs. Output Current (RP509N) VOUT = 1.0 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.2 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 3.3 V (Fixed Output Voltage Type) VMODE = "L" PWM/VFM Auto Switching L = MIPSZ2012D0R5 VOUT = 1.8 V VMODE = "H" Forced PWM Mode L = MIPSZ2012D0R5 26 RP509x No. EA-362-220819 Small Mount Solution (RP509Z) VOUT = 1.0 V VMODE = "L" PWM/VFM Auto Switching L = MDT1608-CRR47M VOUT = 1.2 V VMODE = "L" PWM/VFM Auto Switching L = MDT1608-CRR47M VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching L = MDT1608-CRR47M VOUT = 3.3 V (Fixed Output Voltage Type) VMODE = "L" PWM/VFM Auto Switching L = MDT1608-CRR47M VOUT = 1.8 V VMODE = "H" Forced PWM Mode L = MDT1608-CRR47M 27 RP509x No. EA-362-220819 2) Output Voltage vs. Output Current (RP509Z) VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching Output Voltage vs. Output Current (RP509N) VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching 3) Oscillator Frequency vs. Input Voltage IOUT = 1.0 mA VMODE = "L" PWM/VFM Auto Switching VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 1.0 mA VMODE = "H" Forced PWM Mode 28 RP509x No. EA-362-220819 IOUT = 500 mA VMODE = "H" Forced PWM Mode 4) Load Transient Response Waveform VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 1.0 -> 500 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 500 -> 1.0 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 1.0 -> 500 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 500 -> 1.0 mA 29 RP509x No. EA-362-220819 VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 300 -> 600 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 600 -> 300 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 300 -> 600 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 600 -> 300 mA 5) Mode Switching Waveform VIN = 3.6 V, VOUT = 1.8 V IOUT = 1.0 mA VMODE = "L" -> "H" VIN = 3.6 V, VOUT = 1.8 V IOUT = 1.0 mA VMODE = "H" -> "L" 30 RP509x No. EA-362-220819 6) Output Voltage Waveform VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 1.0 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 1.0 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "L" PWM/VFM Auto Switching IOUT = 500 mA VIN = 3.6 V, VOUT = 1.8 V VMODE = "H" Forced PWM Mode IOUT = 500 mA 31 POWER DISSIPATION WLCSP-6-P6 Ver. C The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-9. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 101.5 mm x 114.5 mm x 1.6 mm Copper Ratio Outer Layers (First and Fourth Layers): 60% Inner Layers (Second and Third Layers): 100% Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 910 mW Thermal Resistance (θja) θja = 109°C/W θja: Junction-to-Ambient Thermal Resistance 1200 114.5 910 800 600 101.5 Power Dissipation (mW) 1000 400 200 0 0 25 50 75 85 100 Ambient Temperature (°C) 125 Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS WLCSP-6-P6 DM-WLCSP-6-P6-JE-B WLCSP-6-P6 Package Dimensions (Unit: mm) i PART MARKINGS RP509Z MK-RP509Z-JE-D : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number  WLCSP-6-P6 Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. i PART MARKINGS RP509Z MK-RP509Z-JE-D RP509Zxx1A/RP509Zxx2A (Fixed Output Voltage Type) Part Marking List    Product Name Product Name  VSET RP 5 09 Z0 6 1 A 1 Lot No. RP 5 09 Z0 6 2 A 1 Lot No. 0.6 V RP 5 09 Z0 7 1 A 1 Lot No. RP 5 09 Z0 7 2 A 1 Lot No. 0.7 V RP 5 09 Z0 8 1 A 1 Lot No. RP 5 09 Z0 8 2 A 1 Lot No. 0.8 V RP 5 09 Z0 9 1 A 1 Lot No. RP 5 09 Z0 9 2 A 1 Lot No. 0.9 V RP 5 09 Z1 0 1 A 1 Lot No. RP 5 09 Z1 0 2 A 1 Lot No. 1.0 V RP 5 09 Z111 A 1 Lot No. RP 5 09 Z11 2 A 1 Lot No. 1.1 V RP 5 09 Z1 2 1 A 1 Lot No. RP 5 09 Z1 2 2 A 1 Lot No. 1.2 V RP 5 09 Z1 3 1 A 1 Lot No. RP 5 09 Z1 3 2 A 1 Lot No. 1.3 V RP 5 09 Z1 4 1 A 1 Lot No. RP 5 09 Z1 4 2 A 1 Lot No. 1.4 V RP 5 09 Z1 5 1 A 1 Lot No. RP 5 09 Z1 5 2 A 1 Lot No. 1.5 V RP 5 09 Z1 6 1 A 1 Lot No. RP 5 09 Z1 6 2 A 1 Lot No. 1.6 V RP 5 09 Z1 7 1 A 1 Lot No. RP 5 09 Z1 7 2 A 1 Lot No. 1.7 V RP 5 09 Z1 8 1 A 1 Lot No. RP 5 09 Z1 8 2 A 1 Lot No. 1.8 V RP 5 09 Z1 9 1 A 1 Lot No. RP 5 09 Z1 9 2 A 1 Lot No. 1.9 V RP 5 09 Z2 0 1 A 1 Lot No. RP 5 09 Z2 0 2 A 1 Lot No. 2.0 V RP 5 09 Z2 11 A 1 Lot No. RP 5 09 Z2 1 2 A 1 Lot No. 2.1 V RP 5 09 Z2 2 1 A 1 Lot No. RP 5 09 Z2 2 2 A 1 Lot No. 2.2 V RP 5 09 Z2 3 1 A 1 Lot No. RP 5 09 Z2 3 2 A 1 Lot No. 2.3 V RP 5 09 Z2 4 1 A 1 Lot No. RP 5 09 Z2 4 2 A 1 Lot No. 2.4 V RP 5 09 Z2 5 1 A 1 Lot No. RP 5 09 Z2 5 2 A 1 Lot No. 2.5 V RP 5 09 Z2 6 1 A 1 Lot No. RP 5 09 Z2 6 2 A 1 Lot No. 2.6 V RP 5 09 Z2 7 1 A 1 Lot No. RP 5 09 Z2 7 2 A 1 Lot No. 2.7 V RP 5 09 Z2 8 1 A 1 Lot No. RP 5 09 Z2 8 2 A 1 Lot No. 2.8 V RP 5 09 Z2 9 1 A 1 Lot No. RP 5 09 Z2 9 2 A 1 Lot No. 2.9 V RP 5 09 Z3 0 1 A 1 Lot No. RP 5 09 Z3 0 2 A 1 Lot No. 3.0 V RP 5 09 Z3 11 A 1 Lot No. RP 5 09 Z3 1 2 A 1 Lot No. 3.1 V RP 5 09 Z3 2 1 A 1 Lot No. RP 5 09 Z3 2 2 A 1 Lot No. 3.2 V RP 5 09 Z3 3 1 A 1 Lot No. RP 5 09 Z3 3 2 A 1 Lot No. 3.3 V ii PART MARKINGS RP509Z MK-RP509Z-JE-D RP509Zxx1B/RP509Zxx2B (Fixed Output Voltage Type) Part Marking List    Product Name Product Name  VSET RP 5 09 Z0 6 1 B 1 Lot No. RP 5 09 Z0 6 2 B 1 Lot No. 0.6 V RP 5 09 Z0 7 1 B 1 Lot No. RP 5 09 Z0 7 2 B 1 Lot No. 0.7 V RP 5 09 Z0 8 1 B 1 Lot No. RP 5 09 Z0 8 2 B 1 Lot No. 0.8 V RP 5 09 Z0 9 1 B 1 Lot No. RP 5 09 Z0 9 2 B 1 Lot No. 0.9 V RP 5 09 Z1 0 1 B 1 Lot No. RP 5 09 Z1 0 2 B 1 Lot No. 1.0 V RP 5 09 Z111 B 1 Lot No. RP 5 09 Z11 2 B 1 Lot No. 1.1 V RP 5 09 Z1 2 1 B 1 Lot No. RP 5 09 Z1 2 2 B 1 Lot No. 1.2 V RP 5 09 Z1 3 1 B 1 Lot No. RP 5 09 Z1 3 2 B 1 Lot No. 1.3 V RP 5 09 Z1 4 1 B 1 Lot No. RP 5 09 Z1 4 2 B 1 Lot No. 1.4 V RP 5 09 Z1 5 1 B 1 Lot No. RP 5 09 Z1 5 2 B 1 Lot No. 1.5 V RP 5 09 Z1 6 1 B 1 Lot No. RP 5 09 Z1 6 2 B 1 Lot No. 1.6 V RP 5 09 Z1 7 1 B 1 Lot No. RP 5 09 Z1 7 2 B 1 Lot No. 1.7 V RP 5 09 Z1 8 1 B 1 Lot No. RP 5 09 Z1 8 2 B 1 Lot No. 1.8 V RP 5 09 Z1 9 1 B 1 Lot No. RP 5 09 Z1 9 2 B 1 Lot No. 1.9 V RP 5 09 Z2 0 1 B 1 Lot No. RP 5 09 Z2 0 2 B 1 Lot No. 2.0 V RP 5 09 Z2 11 B 1 Lot No. RP 5 09 Z2 1 2 B 1 Lot No. 2.1 V RP 5 09 Z2 2 1 B 1 Lot No. RP 5 09 Z2 2 2 B 1 Lot No. 2.2 V RP 5 09 Z2 3 1 B 1 Lot No. RP 5 09 Z2 3 2 B 1 Lot No. 2.3 V RP 5 09 Z2 4 1 B 1 Lot No. RP 5 09 Z2 4 2 B 1 Lot No. 2.4 V RP 5 09 Z2 5 1 B 1 Lot No. RP 5 09 Z2 5 2 B 1 Lot No. 2.5 V RP 5 09 Z2 6 1 B 1 Lot No. RP 5 09 Z2 6 2 B 1 Lot No. 2.6 V RP 5 09 Z2 7 1 B 1 Lot No. RP 5 09 Z2 7 2 B 1 Lot No. 2.7 V RP 5 09 Z2 8 1 B 1 Lot No. RP 5 09 Z2 8 2 B 1 Lot No. 2.8 V RP 5 09 Z2 9 1 B 1 Lot No. RP 5 09 Z2 9 2 B 1 Lot No. 2.9 V RP 5 09 Z3 0 1 B 1 Lot No. RP 5 09 Z3 0 2 B 1 Lot No. 3.0 V RP 5 09 Z3 11 B 1 Lot No. RP 5 09 Z3 1 2 B 1 Lot No. 3.1 V RP 5 09 Z3 2 1 B 1 Lot No. RP 5 09 Z3 2 2 B 1 Lot No. 3.2 V RP 5 09 Z3 3 1 B 1 Lot No. RP 5 09 Z3 3 2 B 1 Lot No. 3.3 V - - - RP 5 09 Z1 0 1 B5 1 Lot No. 1.05 V - - - RP 5 09 Z11 2 B5 1 Lot No. 1.15 V RP 5 09 Z1 3 1 B5 1 Lot No. RP 5 09 Z1 3 2 B5 1 Lot No. 1.35 V iii PART MARKINGS RP509Z MK-RP509Z-JE-D RP509Z00XC/RP509Z00XD (Adjustable Output Voltage Type) Part Marking List Product Name   RP 5 09 Z0 0 1C 1 Lot No. - RP 5 09 Z0 0 2C 1 Lot No. - RP 5 09 Z0 0 1D 1 Lot No. - RP 5 09 Z0 0 2D 1 Lot No. - Product Name   VSET iv PRODUCT-SPECIFIC ELECTRICAL CHARACTERISTICS RP509Z PE-RP509Z-JAEA-1.60 RP509ZxxXA/RP509ZxxXB (Fixed Output Voltage Type) Product-specific Electrical Characteristics (Ta = 25°C) VOUT [V] Product Name Min. Typ. Max. RP 5 09 Z0 6 X A RP 5 09 Z0 6 X B 0.582 0.600 0.618 RP 5 09 Z0 7 X A RP 5 09 Z0 7 X B 0.682 0.700 0.718 RP 5 09 Z0 8 X A RP 5 09 Z0 8 X B 0.782 0.800 0.818 RP 5 09 Z0 9 X A RP 5 09 Z0 9 X B 0.882 0.900 0.918 RP 5 09 Z1 0 X A RP 5 09 Z1 0 X B 0.982 1.000 1.018 RP 5 09 Z11 X A RP 5 09 Z11 X B 1.082 1.100 1.118 RP 5 09 Z1 2 X A RP 5 09 Z1 2 X B 1.182 1.200 1.218 RP 5 09 Z1 3 X A RP 5 09 Z1 3 X B 1.281 1.300 1.319 RP 5 09 Z1 4 X A RP 5 09 Z1 4 X B 1.379 1.400 1.421 RP 5 09 Z1 5 X A RP 5 09 Z1 5 X B 1.478 1.500 1.522 RP 5 09 Z1 6 X A RP 5 09 Z1 6 X B 1.576 1.600 1.624 RP 5 09 Z1 7 X A RP 5 09 Z1 7 X B 1.675 1.700 1.725 RP 5 09 Z1 8 X A RP 5 09 Z1 8 X B 1.773 1.800 1.827 RP 5 09 Z1 9 X A RP 5 09 Z1 9 X B 1.872 1.900 1.928 RP 5 09 Z2 0 X A RP 5 09 Z2 0 X B 1.970 2.000 2.030 RP 5 09 Z2 1 X A RP 5 09 Z2 1 X B 2.069 2.100 2.131 RP 5 09 Z2 2 X A RP 5 09 Z2 2 X B 2.167 2.200 2.233 RP 5 09 Z2 3 X A RP 5 09 Z2 3 X B 2.266 2.300 2.334 RP 5 09 Z2 4 X A RP 5 09 Z2 4 X B 2.364 2.400 2.436 RP 5 09 Z2 5 X A RP 5 09 Z2 5 X B 2.463 2.500 2.537 RP 5 09 Z2 6 X A RP 5 09 Z2 6 X B 2.561 2.600 2.639 RP 5 09 Z2 7 X A RP 5 09 Z2 7 X B 2.660 2.700 2.740 RP 5 09 Z2 8 X A RP 5 09 Z2 8 X B 2.758 2.800 2.842 RP 5 09 Z2 9 X A RP 5 09 Z2 9 X B 2.857 2.900 2.943 RP 5 09 Z3 0 X A RP 5 09 Z3 0 X B 2.955 3.000 3.045 RP 5 09 Z3 1 X A RP 5 09 Z3 1 X B 3.054 3.100 3.146 RP 5 09 Z3 2 X A RP 5 09 Z3 2 X B 3.152 3.200 3.248 RP 5 09 Z3 3 X A RP 5 09 Z3 3 X B 3.251 3.300 3.349 RP 5 09 Z1 0 1 B5 1.032 1.050 1.068 RP 5 09 Z11 2 B5 1.132 1.150 1.168 RP 5 09 Z1 3 X B 5 1.330 1.350 1.370 i Visual Inspection Criteria WLCSP VI-160823 No. 1 Inspection Items Package chipping 2 Si surface chipping 3 No bump Marking miss 4 Inspection Criteria Figure A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected And, Package chipping to Si surface and to bump is rejected. A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected But, even if A≥0.2mm, B≤0.1mm is acceptable. No bump is rejected. To reject incorrect marking, such as another product name marking or 5 6 7 No marking Reverse direction of marking Defective marking 8 Scratch 9 Stain and Foreign material another lot No. marking. To reject no marking on the package. To reject reverse direction of marking character. To reject unreadable marking. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by scratch. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by stain and foreign material. (Microscope: X15/ White LED/ Viewed from vertical direction) i POWER DISSIPATION SOT-23-6-D PD-SOT-23-6-(85125)-D-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes φ 0.3 mm × 7 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 892 mW Thermal Resistance (θja) θja = 112°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 800 Power Dissipation PD (mW) 700 892 600 500 400 300 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS SOT-23-6 DM-SOT-23-6-JE-B 2.9±0.2 +0.2 1.1-0.1 1.9±0.2 4 1 2 0 to 0.1 0.2MIN. 5 +0.2 1.6-0.1 6 0.8±0.1 (0.95) 2.8±0.3 (0.95) 3 +0.1 0.4-0.2 +0.1 0.15-0.05 Unit : mm SOT-23-6 Package Dimensions (Unit: mm) i PART MARKINGS RP509N MK-RP509N-JE-C : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number 6 5 4 ① ② ③ ④ ⑤ 1 2 3 SOT-23-6 Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. i PART MARKINGS RP509N MK-RP509N-JE-C RP509Nxx1A/RP509Nxx2A (Fixed Output Voltage Type) Part Marking List    Product Name Product Name  VSET RP509N061A C06 Lot No. RP509N062A D06 Lot No. 0.6 V RP509N071A C07 Lot No. RP509N072A D07 Lot No. 0.7 V RP509N081A C08 Lot No. RP509N082A D08 Lot No. 0.8 V RP509N091A C09 Lot No. RP509N092A D09 Lot No. 0.9 V RP509N101A C10 Lot No. RP509N102A D10 Lot No. 1.0 V RP509N111A C11 Lot No. RP509N112A D11 Lot No. 1.1 V RP509N121A C12 Lot No. RP509N122A D12 Lot No. 1.2 V RP509N131A C13 Lot No. RP509N132A D13 Lot No. 1.3 V RP509N141A C14 Lot No. RP509N142A D14 Lot No. 1.4 V RP509N151A C15 Lot No. RP509N152A D15 Lot No. 1.5 V RP509N161A C16 Lot No. RP509N162A D16 Lot No. 1.6 V RP509N171A C17 Lot No. RP509N172A D17 Lot No. 1.7 V RP509N181A C18 Lot No. RP509N182A D18 Lot No. 1.8 V RP509N191A C19 Lot No. RP509N192A D19 Lot No. 1.9 V RP509N201A C20 Lot No. RP509N202A D20 Lot No. 2.0 V RP509N211A C21 Lot No. RP509N212A D21 Lot No. 2.1 V RP509N221A C22 Lot No. RP509N222A D22 Lot No. 2.2 V RP509N231A C23 Lot No. RP509N232A D23 Lot No. 2.3 V RP509N241A C24 Lot No. RP509N242A D24 Lot No. 2.4 V RP509N251A C25 Lot No. RP509N252A D25 Lot No. 2.5 V RP509N261A C26 Lot No. RP509N262A D26 Lot No. 2.6 V RP509N271A C27 Lot No. RP509N272A D27 Lot No. 2.7 V RP509N281A C28 Lot No. RP509N282A D28 Lot No. 2.8 V RP509N291A C29 Lot No. RP509N292A D29 Lot No. 2.9 V RP509N301A C30 Lot No. RP509N302A D30 Lot No. 3.0 V RP509N311A C31 Lot No. RP509N312A D31 Lot No. 3.1 V RP509N321A C32 Lot No. RP509N322A D32 Lot No. 3.2 V RP509N331A C33 Lot No. RP509N332A D33 Lot No. 3.3 V RP509N111A5 J11 Lot No. - - - 1.15 V ii PART MARKINGS RP509N MK-RP509N-JE-C RP509Nxx1B/RP509Nxx2B (Fixed Output Voltage Type) Part Marking List    Product Name Product Name  VSET RP509N061B E06 Lot No. RP509N062B F06 Lot No. 0.6 V RP509N071B E07 Lot No. RP509N072B F07 Lot No. 0.7 V RP509N081B E08 Lot No. RP509N082B F08 Lot No. 0.8 V RP509N091B E09 Lot No. RP509N092B F09 Lot No. 0.9 V RP509N101B E10 Lot No. RP509N102B F10 Lot No. 1.0 V RP509N111B E11 Lot No. RP509N112B F11 Lot No. 1.1 V RP509N121B E12 Lot No. RP509N122B F12 Lot No. 1.2 V RP509N131B E13 Lot No. RP509N132B F13 Lot No. 1.3 V RP509N141B E14 Lot No. RP509N142B F14 Lot No. 1.4 V RP509N151B E15 Lot No. RP509N152B F15 Lot No. 1.5 V RP509N161B E16 Lot No. RP509N162B F16 Lot No. 1.6 V RP509N171B E17 Lot No. RP509N172B F17 Lot No. 1.7 V RP509N181B E18 Lot No. RP509N182B F18 Lot No. 1.8 V RP509N191B E19 Lot No. RP509N192B F19 Lot No. 1.9 V RP509N201B E20 Lot No. RP509N202B F20 Lot No. 2.0 V RP509N211B E21 Lot No. RP509N212B F21 Lot No. 2.1 V RP509N221B E22 Lot No. RP509N222B F22 Lot No. 2.2 V RP509N231B E23 Lot No. RP509N232B F23 Lot No. 2.3 V RP509N241B E24 Lot No. RP509N242B F24 Lot No. 2.4 V RP509N251B E25 Lot No. RP509N252B F25 Lot No. 2.5 V RP509N261B E26 Lot No. RP509N262B F26 Lot No. 2.6 V RP509N271B E27 Lot No. RP509N272B F27 Lot No. 2.7 V RP509N281B E28 Lot No. RP509N282B F28 Lot No. 2.8 V RP509N291B E29 Lot No. RP509N292B F29 Lot No. 2.9 V RP509N301B E30 Lot No. RP509N302B F30 Lot No. 3.0 V RP509N311B E31 Lot No. RP509N312B F31 Lot No. 3.1 V RP509N321B E32 Lot No. RP509N322B F32 Lot No. 3.2 V RP509N331B E33 Lot No. RP509N332B F33 Lot No. 3.3 V RP509N111B5 K11 Lot No. - - - 1.15 V RP509N131B5 K12 Lot No. RP509N132B5 K13 Lot No. 1.35 V iii PART MARKINGS RP509N MK-RP509N-JE-C RP509N00XC/RP509N00XD (Adjustable Output Voltage Type) Part Marking List Product Name   RP509N001C G01 Lot No. - RP509N002C G02 Lot No. - RP509N001D H01 Lot No. - RP509N002D H02 Lot No. - Product Name   VSET iv PRODUCT-SPECIFIC ELECTRICAL CHARACTERISTICS RP509N PE-RP509N-JAEA-1.20 RP509NxxXA/RP509NxxXB (Fixed Output Voltage Type) Product-specific Electrical Characteristics (Ta = 25°C) VOUT [V] Product Name Min. Typ. Max. RP 5 09 N 06 X A RP 5 09 N 06 X B 0.582 0.600 0.618 RP 5 09 N 07 X A RP 5 09 N 07 X B 0.682 0.700 0.718 RP 5 09 N 08 X A RP 5 09 N 08 X B 0.782 0.800 0.818 RP 5 09 N 09 X A RP 5 09 N 09 X B 0.882 0.900 0.918 RP 5 09 N 10 X A RP 5 09 N 10 X B 0.982 1.000 1.018 RP 5 09 N 11 X A RP 5 09 N 11 X B 1.082 1.100 1.118 RP 5 09 N 12 X A RP 5 09 N 12 X B 1.182 1.200 1.218 RP 5 09 N 13 X A RP 5 09 N 13 X B 1.281 1.300 1.319 RP 5 09 N 14 X A RP 5 09 N 14 X B 1.379 1.400 1.421 RP 5 09 N 15 X A RP 5 09 N 15 X B 1.478 1.500 1.522 RP 5 09 N 16 X A RP 5 09 N 16 X B 1.576 1.600 1.624 RP 5 09 N 17 X A RP 5 09 N 17 X B 1.675 1.700 1.725 RP 5 09 N 18 X A RP 5 09 N 18 X B 1.773 1.800 1.827 RP 5 09 N 19 X A RP 5 09 N 19 X B 1.872 1.900 1.928 RP 5 09 N 20 X A RP 5 09 N 20 X B 1.970 2.000 2.030 RP 5 09 N 21 X A RP 5 09 N 21 X B 2.069 2.100 2.131 RP 5 09 N 22 X A RP 5 09 N 22 X B 2.167 2.200 2.233 RP 5 09 N 23 X A RP 5 09 N 23 X B 2.266 2.300 2.334 RP 5 09 N 24 X A RP 5 09 N 24 X B 2.364 2.400 2.436 RP 5 09 N 25 X A RP 5 09 N 25 X B 2.463 2.500 2.537 RP 5 09 N 26 X A RP 5 09 N 26 X B 2.561 2.600 2.639 RP 5 09 N 27 X A RP 5 09 N 27 X B 2.660 2.700 2.740 RP 5 09 N 28 X A RP 5 09 N 28 X B 2.758 2.800 2.842 RP 5 09 N 29 X A RP 5 09 N 29 X B 2.857 2.900 2.943 RP 5 09 N 30 X A RP 5 09 N 30 X B 2.955 3.000 3.045 RP 5 09 N 31 X A RP 5 09 N 31 X B 3.054 3.100 3.146 RP 5 09 N 32 X A RP 5 09 N 32 X B 3.152 3.200 3.248 RP 5 09 N 33 X A RP 5 09 N 33 X B 3.251 3.300 3.349 RP 5 09 N 111 A5 RP 5 09 N 111 B5 1.132 1.150 1.168 RP 5 09 N 13 X B 5 1.330 1.350 1.370 i 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP509Z331B-E2-F 价格&库存
很抱歉,暂时无法提供与“RP509Z331B-E2-F”相匹配的价格&库存,您可以联系我们找货
RP509Z331B-E2-F
    • 1+1.82402
    • 200+0.70589
    • 500+0.68105
    • 1000+0.66885
    RP509Z331B-E2-F
    • 1+6.447991+0.80890
    • 10+4.5699410+0.57330
    • 25+4.1007025+0.51444
    • 100+3.58996100+0.45036
    • 250+3.34589250+0.41975
    • 500+3.19874500+0.40129
    • 1000+3.077591000+0.38609
    • 2500+2.949722500+0.37005
    库存:4768
    RP509Z331B-E2-F
    • 5000+2.872685000+0.36038
    • 10000+2.8092510000+0.35243
    • 15000+2.7775015000+0.34844
    • 25000+2.7423125000+0.34403
    库存:4768
