NC2600ZA330AE2S
NC2600ZA330AE2S
    NISSHINBO(日清纺)
    8-XFBGA,WLCSP
    降压 开关稳压器 IC 正 固定 3.3V 1 输出 2A 8-XFBGA,WLCSP
NC2600ZA330AE2S 数据手册
Datasheet NC2600 series 2A Low Quiescent Current PWM/PFM Step-down Switching Regulator FEATURES GENERAL DESCRIPTION  Input Voltage Range (Maximum Rating): 2.3 V to 5.5 V (6.5 V)  Operating Temperature Range: −40 °C to 85 °C  Output Voltage Range: Fixed Output Voltage Type: 0.6 V to 3.3 V Adjustable Output Voltage Type: 0.6 V to 5.5 V  Output Voltage Accuracy: ±1.5% (VSET ≥ 1.2 V) ±18 mV (VSET < 1.2 V)  Feedback Voltage Accuracy: ±9 mV  Quiescent Current: Typ. 17 µA  Switching Frequency: Typ.4.0 MHz (VSET = 1.8 V)  UVLO Detection Voltage: Typ.2.0 V  Soft-Start Time: Typ. 0.15 ms When CSS is open.  Thermal Shutdown Function: Detection Temperature Typ. 150 °C Release Temperature Typ. 120 °C  Auto Discharge Function  Latch Protection Function The NC2600 is a low quiescent current PWM / PFM 2A step-down switching regulator IC using CMOSbased. The NC2600 is available in WLCSP-8-P11 and DFN2020-8-GT, and it is suitable for use in wearable and IoT devices that require miniaturization and longlifetime of battery. WLCSP-8-P11 1.62 x 0.98 x 0.4 (mm) APPLICATIONS DFN2020-8-GT 2.0 x 2.0 x 0.6 (mm)  Portable Communication Devices: Mobile Phones / Smartphones  Digital Cameras and Note-PCs  Li-ion Battery-used Equipment TYPICAL APPLICATIONS EFFICIENCY TYPICAL CHARACTERISTICS L 1 μH RPG VPG 100 kΩ VIN SW NC2600xxxxx A/B/C/D PG CSS VOUT 90 MODE 4.7 μF EN COUT FB 10 μF GND Fixed Output Voltage Type RPG VPG 100 kΩ CIN 4.7 μF VIN SW NC2600xx000 A/B/C/D PG CSS MODE EN FB GND 1 μH VOUT R11 C1 R12 R0 220 kΩ CSS 0.1 μF 70 60 50 40 MODE=High MODE=Low 30 VVin=2.5V IN = 2.5 [V] VVin=3.6V IN = 3.6 [V] VVin=4.2V IN = 4.2 [V] VVin=5.0V IN = 5.0 [V] 20 L VIN 80 CSS 0.1 μF CIN 100 Efficiency [%] VIN 220 kΩ 10 pF 1 kΩ R2 220 kΩ COUT 10 μF 10 0 0.01 0.1 1 10 100 1000 10000 Output Current IOUT [mA] NC2600ZA VOUT = 1.8 [V] Adjustable Output Voltage Type (VSET = 1.8V) Ver.1.3 - 1 - Datasheet NC2600 series PRODUCT NAME INFORMATION NC2600 aa bbb c dd e Description of configuration Composition Item Description aa Package Code bbb Output Voltage c Version Indicates the package. Refer to the order information. Set Output Voltage (VSET) Adjustable Output Voltage Type (000) The internal fixed output voltage type has a lineup of main voltages in the range of 0.6 V (060) to 3.3 V (330). Indicates the selection of auto discharge function and latch protection function. dd Packing Refer to the packing specifications. e Grade Indicates the quality grade. Version c Latch Protection Function Auto Discharge Function A Yes Yes B Yes No C No Yes D No No e Applications Operating Temperature Range Test Temperature S Consumer −40 °C to 85 °C 25 °C Grade ORDER INFORMATION PRODUCT NAME PACKAGE RoHS HALOGENFREE PLATING COMPOSITION MARKING WEIGH T (mg) Quantity per Reel(pcs) NC2600ZA bbbc E2S WLCSP-8-P11 Yes Yes Sn3Ag0.5Cu Reference 1.1 5000 NC2600GT bbbc E4S DFN2020-8-GT Yes Yes Sn Reference 7.0 3000 Refer to the marking specifications for a detailed lineup of set output voltage and versions. Ver.1.3 - 2 - Datasheet NC2600 series PIN DESCRIPTIONS (NC2600ZA) Top View Bottom View 2 2 1 1 A B C D D C B A WLCSP-8-P11 Pin Configuration NC2600ZA (WLCSP-8-P11) Pin Descriptions Pin No. Pin Name I/O Description A1 VIN Power B1 SW O C1 EN I D1 PG O A2 GND - B2 CSS I C2 MODE I D2 FB I Power Supply Input Pin Switching Output Pin Internal MOSFET Drain Connect the inductor between the VOUT node and the SW pin. Enable Pin Can set the active state with the "High" input and the shutdown state with the "Low" input. Power-good Output Pin NMOS open drain output. In normal operation, "High" (pull-up voltage) is output. Ground Pin Soft-Start Adjustment Pin Soft-Start time can be adjusted by connecting a capacitor between the CSS pin and GND. Mode Control Pin High: Forced PWM Control, Low: PWM/PFM Auto Switching Control. Feedback Pin When using NC2600xx000x (adjustable output voltage type), connect an external resistor as the feedback input pin for the error amplifier and set the output voltage. When using the internal fixed output voltage type, connect it to the VOUT node as an output voltage feedback pin. For details, refer to " Typical Application Circuit " and " THEORY OF OPERATION ". Ver.1.3 - 3 - Datasheet NC2600 series PIN DESCRIPTIONS (NC2600GT) 8 7 6 5 5 6 7 8 * 1 2 3 4 4 3 2 1 DFN2020-8-GT Pin Configuration The tab on the bottom of the package is the silicon substrate level. It is recomended to connect to GND level on the board. * NC2600GT (DFN2020-8-GT) Pin Descriptions Pin No. Pin Name I/O Description 1 GND - 2 CSS I 3 MODE I Mode Control Pin High: Forced PWM Control, Low: PWM/PFM Auto Switching Control. Ground pin Soft-Start Adjustment Pin Soft-Start time can be adjusted by connecting a capacitor between the CSS pin and GND. 4 FB I Feedback Pin When using NC2600xx000x (adjustable output voltage type), connect an external resistor as the feedback input pin for the error amplifier and set the output voltage. When using the internal fixed output voltage type, connect it to the VOUT node as an output voltage feedback pin. 5 PG O Power-good Output Pin NMOS open drain output. In normal operation, "High" (pull-up voltage) is output. 6 EN I Enable Pin Can set the active state with the "High" input and the shutdown state with the "Low" input. 7 SW O Switching Output Pin Internal MOSFET Drain Connect the inductor between the VOUT node and the SW pin. 8 VIN Power Power Supply Input Pin For details, refer to " Typical Application Circuit " and " THEORY OF OPERATION ". Ver.1.3 - 4 - Datasheet NC2600 series ABSOLUTE MAXIMUM RATINGS Symbol Ratings Unit Input Voltage Parameter VIN −0.3 to 6.5 V SW pin voltage VSW −0.3 to VIN + 0.3 V EN pin voltage VEN −0.3 to 6.5 V CSS pin voltage VCSS −0.3 to 6.5 V PG pin voltage VPG −0.3 to 6.5 V MODE pin voltage FB pin voltage VMODE −0.3 to 6.5 V VFB −0.3 to 6.5 V Tj −40 to 125 °C Tstg −55 to 125 °C Junction Temperature Range *1 Storage Temperature Range ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. *1 Calculate the power consumption of the IC from the operating conditions, and calculate the junction temperature with the thermal resistance. Please refer to "THERMAL CHARACTERISTICS" for the thermal resistance under our measurement board conditions THERMAL CHARACTERISTICS Package WLCSP-8-P11 DFN2020-8-GT Parameter Measurement Result Thermal Resistance (θja) 131 Thermal Characterization Parameter (ψjt) 38 Thermal Resistance (θja) 71 Thermal Characterization Parameter (ψjt) 33 Unit °C/W θja:Junction-to-Ambient Thermal Resistance ψjt:Junction-to-Top Thermal Characterization Parameter The above values are reference data under measurement conditions based on JEDEC STD.51. ELECTROSTATIC DISCHARGE RATINGS Parameter HBM Conditions C = 100 pF, R = 1.5 kΩ Protection Voltage ±2000 V ±1000 V CDM ELECTROSTATIC DISCHARGE RATINGS The electrostatic discharge test is done based on JESD47. In the HBM method, ESD is applied using the power supply pin and GND pin as reference pins. Ver.1.3 - 5 - Datasheet NC2600 series RECOMMENDED OPERATING CONDITIONS Symbol Ratings Unit Input Voltage Parameter VIN 2.3 to 5.5 V Operating Temperature Range Ta −40 to 85 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. Ver.1.3 - 6 - Datasheet NC2600 series ELECTRICAL CHARACTERISTICS NC2600xx060x to 330x (Internal Fixed Output Voltage Type) VIN = 3.6V (VSET ≤ 2.6V) or VSET + 1 V (VSET > 2.6V) unless otherwise specified. For parameter that do not describe the temperature condition, the MIN / MAX value under the condition of −40 °C ≤ Ta ≤ 85 °C is described. Parameter Symbol Conditions Output Voltage VOUT Ta = 25 °C Switching Frequency fOSC MIN TYP MAX Unit VSET ≥ 1.2 V x 0.985 - x 1.015 VSET < 1.2 V −0.018 - +0.018 V - 4.0 - MHz - 17 25 µA - 0 5 µA Quiescent Current IQ Shutdown current ISD VMODE =3.6 V VFB = VSET × 1.05, VMODE = 0 V, no switching VIN = 5.5 V, VEN = 0 V EN "H" Input Current IENH VIN = VEN = 5.5 V −1 0 1 µA EN "L" Input Current VIN = 5.5 V, VEN = 0 V −1 0 1 µA MODE "H" Input Current IMODEH VIN = VMODE = 5.5 V −1 0 1 µA MODE "L" Input Current IMODEL VIN = 5.5 V, VMODE = 0 V −1 0 1 µA IENL VFB "H" Input Current IFBH VIN = VFB = 5.5 V, VEN = 0 V −1 0 1 µA VFB "L" Input Current IFBL VIN = 5.5 V, VEN = VFB = 0 V −1 0 1 µA - 60 - Ω On-resistance for Discharger RONDIS NC2600xxxxxA/C EN pin "H" Input Voltage VENH VIN = 5.5 V 1.0 - - V EN pin "L" Input Voltage VENL VIN = 2.3 V - - 0.4 V MODE "H" Input Voltage VMODEH VIN = 5.5 V 1.0 - - V MODE "L" Input Voltage VMODEL VIN = 2.3 V On-resistance of High Side MOSFET RONH ISW = 100 mA On-resistance of Low Side MOSFET RONL ISW = 100 mA Soft-Start Time 1 tSTART1 CSS = OPEN Soft-Start Time 2 tSTART2 CSS = 0.1 μF SW Current Limit ISWLIM Protection Delay Time UVLO Detection Voltage *1 UVLO Release Voltage *1 - 0.4 V - 0.13 - Ω NC2600GT - 0.15 - Ω NC2600ZA - 0.09 - Ω NC2600GT - 0.12 - Ω - 150 300 µs 15 30 45 ms 2.3 - 4.7 A 10 20 40 µs VUVLODET VIN = Falling 1.85 2.00 2.20 V VUVLOREL VIN = Rising 1.90 2.05 2.25 V VSET x 1.1 45 VSET x 1.2 VSET x 0.8 - Ω - V VSET x 0.9 V tPROT NC2600xxxxxA/B NC2600ZA On resistance at PG "L" Output RONPG VFB = 0 V OV Detection Voltage VOVD VFB = Rising UV Detection Voltage VUVD VFB = Falling - TSDDET Tj = Rising - 150 - °C TSDREL Tj = Falling - 120 - °C Thermal Shutdown Detection Temperature Thermal Shutdown Release Temperature All electrical characteristic parameters that specify the minimum and maximum specifications are tested under the condition of Tj ≈ Ta = 25 °C *1 Due to the circuit configuration, VUVLODET ≥ VUVLOREL does not hold. The hysteresis is Typ.0.05 V. Ver.1.3 - 7 - Datasheet NC2600 series NC2600xx000x (Adjustable Output Voltage Type) VIN = 3.6V unless otherwise specified. For parameter that do not describe the temperature condition, the MIN / MAX value under the condition of −40 °C ≤ Ta ≤ 85 °C is described. Parameter Symbol Conditions MIN TYP MAX Unit 0.591 0.600 0.609 V Feedback voltage VFB Ta = 25 °C Switching Frequency fOSC VMODE =3.6 V - 4.0 - MHz - 17 25 µA - 0 5 µA Quiescent Current IQ VFB = 0.63 V, VMODE = 0 V, no switching Shutdown current ISD VIN = 5.5 V, VEN = 0 V EN "H" Input Current IENH VIN = VEN = 5.5 V −1 0 1 µA EN "L" Input Current IENL VIN = 5.5 V, VEN = 0 V −1 0 1 µA VIN = VMODE = 5.5 V −1 0 1 µA MODE "H" Input Current IMODEH MODE "L" Input Current IMODEL VIN = 5.5 V, VMODE = 0 V −1 0 1 µA FB "H" Input Current IFBH VIN = VFB = 5.5 V, VEN = 0 V −1 0 1 µA FB "L" Input Current IFBL VIN = 5.5 V, VEN = VFB = 0 V −1 0 1 µA - 60 - Ω EN pin "H" Input Voltage VENH VIN = 5.5 V 1.0 - - V EN pin "L" Input Voltage VENL VIN = 2.3 V - - 0.4 V MODE "H" Input Voltage VMODEH VIN = 5.5 V 1.0 - - V MODE "L" Input Voltage VMODEL VIN = 2.3 V - - 0.4 V NC2600ZA - 0.13 - Ω NC2600GT - 0.15 - Ω NC2600ZA - 0.09 - Ω NC2600GT - 0.12 - Ω On-resistance for Discharger On-resistance of High Side MOSFET On-resistance of Low Side MOSFET RONDIS RONH NC2600xx000A/C ISW = 100 mA RONL ISW = 100 mA Soft-Start Time 1 tSTART1 CSS = OPEN - 150 300 µs Soft-Start Time 2 tSTART2 CSS = 0.1 μF 15 30 45 ms SW Current Limit ISWLIM 2.3 - 4.7 A Protection Delay Time UVLO Detection Voltage *1 UVLO Release Voltage *1 10 20 40 µs VUVLODET VIN = Falling 1.85 2.00 2.20 V VUVLOREL VIN = Rising 1.90 2.05 2.25 V tPROT NC2600xx000A/B On resistance at PG "L" Output RONPG VFB =0 V - 45 - Ω OV Detection Voltage VOVD VFB = Rising 0.66 0.72 - V UV Detection Voltage Thermal Shutdown Detection Temperature Thermal Shutdown Release Temperature VUVD VFB = Falling - 0.48 0.54 V TSDDET Tj = Rising - 150 - °C TSDREL Tj = Falling - 120 - °C All electrical characteristic parameters that specify the minimum and maximum specifications are tested under the condition of Tj ≈ Ta = 25 °C *1 Due to the circuit configuration, VUVLODET ≥ VUVLOREL does not hold. The hysteresis is Typ.0.05 V. Ver.1.3 - 8 - Datasheet NC2600 series PRODUCT-SPECIFIC ELECTRICAL CHARACTERISTICS PRODUCT NAME VOUT (Ta = 25 °C) TYP 0.6 NC2600xx060xxxx MIN 0.582 MAX 0.618 NC2600xx070xxxx 0.682 0.7 0.718 NC2600xx080xxxx 0.782 0.8 0.818 NC2600xx090xxxx 0.882 0.9 0.918 NC2600xx100xxxx 0.982 1.0 1.018 NC2600xx110xxxx 1.082 1.1 1.118 NC2600xx120xxxx 1.182 1.2 1.218 NC2600xx130xxxx 1.280 1.3 1.320 NC2600xx140xxxx 1.379 1.4 1.421 NC2600xx150xxxx 1.477 1.5 1.523 NC2600xx160xxxx 1.576 1.6 1.624 NC2600xx170xxxx 1.674 1.7 1.726 NC2600xx180xxxx 1.773 1.8 1.827 NC2600xx190xxxx 1.871 1.9 1.929 NC2600xx200xxxx 1.970 2.0 2.030 NC2600xx210xxxx 2.068 2.1 2.132 NC2600xx220xxxx 2.167 2.2 2.233 NC2600xx230xxxx 2.265 2.3 2.335 NC2600xx240xxxx 2.364 2.4 2.436 NC2600xx250xxxx 2.462 2.5 2.538 NC2600xx260xxxx 2.561 2.6 2.639 NC2600xx270xxxx 2.659 2.7 2.741 NC2600xx280xxxx 2.758 2.8 2.842 NC2600xx290xxxx 2.856 2.9 2.944 NC2600xx300xxxx 2.955 3.0 3.045 NC2600xx310xxxx 3.053 3.1 3.147 NC2600xx320xxxx 3.152 3.2 3.248 NC2600xx330xxxx 3.250 3.3 3.350 Unit V Above parameters are all tested under the following conditions: Tj ≈ Ta = 25 °C Ver.1.3 - 9 - Datasheet NC2600 series BLOCK DIAGRAMS PG PG Over/Under Voltage Detector Over/Under Voltage Detector High Side Current Detector OVD UVD MODE Slope Generator FB On Time Control Switching Control Comp. Soft Start Vref Slope Generator Switching Control Soft Start CSS Vref NC2600xxxxxA/C Block Diagram GND Low Side Current Detector Thermal Protection Under Voltage Lock Out SW Amp. GND Low Side Current Detector On Time Control Comp. FB Enable Control EN VIN Mode Control SW Amp. CSS UVD VIN Mode Control MODE High Side Current Detector OVD Thermal Protection EN Enable Control Under Voltage Lock Out NC2600xxxxxB/D Block Diagram THEORY OF OPERATION Enable Function Forcing above designated "High" voltage to EN pin, the NC2600 becomes active. Forcing below designated "Low" voltage to EN pin shuts down the NC2600. In shutdown condition, all functions are disabled except auto discharge function. With auto discharge option, the MOSFET to discharge the output capacitor turns on and the output is pulled down to GND. Without auto discharge option, the output becomes "Hi-Z". EN pin can accept input range voltage regardless of the input of VIN pin. Do not open the EN pin because it is not pulled up or down inside the IC. If Enable function is not necessary, tie EN pin to VIN pin or other designated "High" voltage node at start-up. Auto Discharge Function When turned off, the Vout voltage drops rapidly to near 0V by discharging the charge stored in the output capacitor through the MOSFET connected between the SW pin and GND pins. The auto discharge function is enabled when the EN pin = "low" ,UVLO detection or the thermal shutdown detection. On-resistance of MOSFET is Typ.60 Ω. Ver.1.3 - 10 - Datasheet NC2600 series Soft-Start When the input voltage (VIN) exceeds the UVLO release voltage (VUVLOREL) and the EN pin is input with a voltage higher than the EN "High" input voltage (VENH), the Soft-Start circuit starts operation. After the Soft-Start circuit starts operating and the delay time (tSTARTUP_delay) Typ.45μsec, the IC internal reference voltage (VREF) starts rising, and after the Soft-Start time (tSTART)* 1, the VREF reaches the specified value. The output of the PG pin (VPG) confirms that the output voltage (VOUT) is between the UV detection voltage (VUVD) and the OV detection voltage (VOVD), and becomes "High" after the PG delay time (tPG_delay=Typ.10µsec). VENH Soft-Start Time (tSTART) EN Pin Input Voltage (VEN) tSTARTUP_delay IC Internal Reference Voltage (VREF) Soft-Start Circuit Operation Starts SW Voltage (VSW) Output Voltage (VOUT) PG Delay Time (tPG_delay) PG Voltage (VPG) Timing Chart when Starting-up with EN pin Input Voltage (VIN) VUVLOREL Soft-Start Time (tSTART) tSTARTUP_delay IC Internal Reference Voltage (VREF) Soft-Start Circuit Operation Starts SW Voltage (VSW) VSET Output Voltage (VOUT) PG Delay Time (tPG_delay) PG Voltage (VPG) Timing Chart when Starting-up with VIN = EN The current limiting function, latch type protection function (NC2600xxxxxA/B), UVLO function, and thermal shutdown function are effective even during the Soft-Start time. When the thermal shutdown is released, the Soft-Start function is effective. When starting with a large load current or when a large capacitance is used in the COUT, the above protection functions may be activated. In such a case, adjust the CSS and increase the Soft-Start time in order to avoid such an abnormal situation. *1 Soft-Start time (tSTART) indicates the duration until the reference voltage (VREF) reaches the specified voltage after Soft-Start circuit’s activation. Ver.1.3 - 11 - Datasheet NC2600 series Soft-Start Time Adjustment Soft-Start time tSTART can be adjusted as shown in the figure below by connecting a capacitor CSS to the CSS pin. When CSS is 0.1 μF, the Soft-Start time is Typ.30 ms. If you do not need to adjust the Soft-Start time, open the CSS pin to start up with the built-in Soft-Start time (Typ.0.15 ms). Soft-Start time can be calculated using the following equation. There is no limit to the capacitance value of the CSS. CSS [μF] = tSTART [ms] x 0.0033 tSTART 30ms 15ms 3ms 0.15ms 0 470pF 0.01uF 0.047uF 0.1uF CSS CSS vs. tSTART (Typ) Under Voltage Lockout (UVLO) Circuit When VIN becomes lower than VSET, the step-down switching regulator stops its switching operation and ON duty becomes 100%, then VOUT gradually falls according to VIN. When the VIN drops below the UVLO detection voltage (VUVLODET), the UVLO operates, VREF stops, and high side MOSFET and low side MOSFET turn “OFF”. As a result, the output voltage decreases according to the capacitance value of COUT, load current, and discharge FET onresistance (NC2600xxxxxA/C). To restart the operation, VIN needs to exceed VUVLOREL. The timing chart below shows the VOUT voltage waveforms when the VIN value is changed Falling edge (detecting) and rising edge (releasing) waveforms of VOUT could be affected by the initial voltage of COUT and the output current of VOUT. Input Voltage VSET (VIN) VUVLOREL VUVLODET IC Internal Reference Soft-Start Time (tSTART) Voltage (VREF) SW Voltage (VSW) Output Voltage (VOUT) tSTARTUP_delay Timing Chart with Variations in Input Voltage (VIN) Ver.1.3 - 12 - Datasheet NC2600 series Thermal Shutdown When the junction temperature exceeds the thermal shutdown detection temperature (Typ.150°C), switching stops and self-heating is suppressed. This IC will restart when the junction temperature drops below the thermal shutdown release temperature (Typ.120°C). Then, the Soft-Start function is activated. Tj 150°C 120°C Soft-Start Time (tSTART) Reference Voltage (VREF) SW Voltage (VSW) Output Voltage (VOUT) tSTARTUP_delay Current Limit Circuit、Latch Type Protection Circuit Current limit circuit supervises the peak current flowing through the inductor in each switching cycle. If the current exceeds the SW current limit (Typ.3.4 A), High Side MOSFET is turned off and the upper limit of the inductor peak current is imposed. The latch-type protection circuit latches the built-in driver off and shuts down the switching regulator if this overcurrent condition lasts for the protection delay time (tPROT). To release the latch type protection state, restart the device by inputting "Low" signal to the EN pin or making the Input Voltage lower than UVLO detection voltage (VUVLODET). Over Current Protection SW Current limit (ISWLIM) Inductor Current SW Voltage (VSW) Over-Current Protection Operation Ver.1.3 - 13 - Datasheet NC2600 series Forced PWM Mode and PWM / PFM Auto Switching Mode Output voltage controlling method is selectable between a forced PWM mode type and PWM/PFM Auto Switching mode. The operation mode can be set by the MODE pin. The forced PWM mode operates with fixed switching frequency to reduce noise in low output current. The PWM/PFM Auto Switching mode automatically enters PFM control to achieve high efficiency at light load current. The above control types operate differently depending on the relationship between the load current (IOUT) and the current ripple (ΔIL) calculated by the following equation. ∆IL = (VIN − VOUT) × tON / L tON:ON time of high side MOSFET Do not open the MODE pin because it is not pulled up or down inside the IC. MODE = "High" (Forced PWM Mode) When a "High" signal is input to the MODE pin, the device enters a forced PWM mode in which the high side MOSFET and low side MOSFET are turned on alternately. During this operation, it operates with fixed switching frequency regardless of the load current. This reduces output voltage ripple and responds quickly to load current transitions. If IOUT 0 A. Refer to the figure below. In this way, when the MODE pin is fixed to "Low", PWM operation and PFM operation are automatically switched according to the load current. IL ILLOW ILHIGH ILLOW ΔIL ILLOW 0 t tOFF tOFF-OFF tON tPERIOD = 1/fOSC IOUT < ΔIL/2 tON tOFF tPERIOD = 1/fOSC IOUT = ΔIL/2 tON tOFF tPERIOD = 1/fOSC IOUT > ΔIL/2 PWM/PFM Auto Switching Mode Ver.1.3 - 15 - Datasheet NC2600 series Switching Frequency The minimum on-time / the minimum off-time for this product is determined by the circuit. If the on-time / the off-time calculated under the input/output voltage conditions at 4 MHz are less than the minimum on-time / minimum off-time determined by the circuit, the switching frequency falls below 4 MHz. The on-time under no load is calculated by the following equation according to the input / output voltage conditions. tON = 250 ns x VOUT / VIN Example 1: Switching frequency with minimum on-time (60 ns) under the following input / output conditions. condition1: VIN = 3.6 V, VOUT = 1.2 V 1/4 MHz × 1.2 V/3.6 V = 83 ns > minimum on-time (60 ns) Operates with 4 MHz. condition2: VIN = 5.5 V, VOUT = 1.0 V 1/4 MHz × 1.0 V/5.5 V = 55 ns < minimum on-time (60 ns) Switching frequency falls below 4 MHz. Example 2: Switching frequency with minimum off-time (50 ns) under the following input / output conditions. condition1: VIN = 5.0 V, VOUT = 3.3 V 1/4 MHz × (1 - 3.3 V/5.0 V) = 77 ns > minimum off-time (50 ns) Operates with 4 MHz. condition2: VIN = 4.0 V, VOUT = 3.3 V 1/4 MHz × (1 - 3.3 V/4.0 V) = 44 ns < minimum off-time (50 ns) Switching frequency falls below 4 MHz. Ver.1.3 - 16 - Datasheet NC2600 series Power Good Function This product has a power good (PG) function, and the output type is NMOS FET open drain. When EN = "Low" is detected, the NMOS FET turns on and sets the power good output to "Low". Figure: Refer to PG Output When EN = "Low". Also, when the IC detects Over Voltage (OV) or Under Voltage (UV), the power good output is set to "Low" as well. Figure: Refer to PG Output When OV or UV is Detected. When the IC is released from these conditions, the NMOS FET is turned off and the power good output is set to "High". The pull-up resistor (RPG) of the PG pin should be between 10 kΩ and 100 kΩ. The PG pin must be open or connected to GND if the power good function is not used. EN Pin Input Voltage (V EN) EN= ”Low” Input Voltage (V ENL) OV Detection Voltage(V OVD) Output Voltage (VOUT) UV Detection Voltage (V UVD) PG Pin Output Voltage (V PG) PG Output When EN = "Low" OV Detection Voltage (V OVD) Output Voltage (VOUT) UV Detection Voltage (VUVD) PG Pin Output Voltage (VPG ) PG Output When OV or UV is Detected Pass-Through Mode This product enters pass-through mode when the input / output voltage difference drops. In this operating state, the high side MOSFET is always on and the low side MOSFET is always off. This function helps to hold output voltage and to lengthen operation time of application longest even when battery voltage drops. In this operating state, the output voltage is calculated by the following equation using the on-resistance of the high side MOSFET(RONP) and the DC resistance of the inductor (RL). VOUT = VIN – (RONP + RL) × IOUT Ver.1.3 - 17 - Datasheet NC2600 series THERMAL CHARACTERISTICS (WLCSP-8-P11) Thermal characteristics depend on the mounting conditions. The following measurement conditions are based on JEDEC STD. 51. Measurement Conditions Parameter Measurement Conditions Measurement status Mounting on Board (Wind Velocity = 0 m/s) Board material Glass Cloth Epoxy Plastic (Four-Layer Board) Board size 101.5 mm × 114.5 mm × 1.6 mm Outer Layers (First and Fourth Layers): 60% Inner Layers (Second and Third Layers): 100% Copper Ratio Measurement Result Parameter Thermal Resistance (θja) Thermal Characterization Parameter (ψjt) Unit Measurement Result 131 °C/W 38 θja:Junction-to-Ambient Thermal Resistance ψjt:Junction-to-Top Thermal Characterization Parameter Measurement Board Pattern (WLCSP-8-P11) CALCULATION METHOD OF JUNCTION TEMPERATURE The junction temperature (Tj) can be calculated from the following equation. Tj = Ta + θja × P Tj = Tc (top) + ψjt × P Ta : Ambient temperature Tc (top) : Package mark side center temperature P : Power consumption under user’s conditions P= Ver.1.3 (100 / η – 1) × (VOUT × IOUT) – DCR × IOUT 2 η : Efficiency under user’s conditions [%] VOUT : Output Voltage [V] IOUT : Output Current [A] DCR : DC resistance of external inductor [Ω] - 18 - Datasheet NC2600 series THERMAL CHARACTERISTICS (DFN2020-8-GT) Thermal characteristics depend on the mounting conditions. The following measurement conditions are based on JEDEC STD. 51. Measurement Conditions Parameter Measurement Conditions Measurement status Board material Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) Board size 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.3 mm × 23 pcs. Copper Ratio Through hole Measurement Result Parameter Measurement Result Thermal Resistance (θja) Thermal Characterization Parameter (ψjt) Unit 71 °C/W 33 θja:Junction-to-Ambient Thermal Resistance ψjt:Junction-to-Top Thermal Characterization Parameter Measurement Board Pattern (DFN2020-8-GT) CALCULATION METHOD OF JUNCTION TEMPERATURE The junction temperature (Tj) can be calculated from the following equation. Tj = Ta + θja × P Tj = Tc (top) + ψjt × P Ta : Ambient temperature Tc (top) : Package mark side center temperature P : Power consumption under user’s conditions P= Ver.1.3 (100 / η – 1) × (VOUT × IOUT) – DCR × IOUT 2 η : Efficiency under user’s conditions [%] VOUT : Output Voltage [V] IOUT : Output Current [A] DCR : DC resistance of external inductor [Ω] - 19 - Datasheet NC2600 series MARKING SPECIFICATION (NC2600ZA) : Product Code : Lot No. … Alphanumerical Serial Number ①②③④ WLCSP-8-P11 Marking NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or distributor before attempting to use AOI. Ver.1.3 - 20 - Datasheet NC2600 series NC2600ZA Marking List Ver.1.3 Product Code   Product Code   Product Code   NC2600ZA000A A A NC2600ZA150B E P NC2600ZA250C H F NC2600ZA060A A C NC2600ZA160B E R NC2600ZA260C H G NC2600ZA070A A E NC2600ZA170B E T NC2600ZA270C H H NC2600ZA080A A F NC2600ZA180B E U NC2600ZA280C H J NC2600ZA090A A G NC2600ZA190B E V NC2600ZA290C H K NC2600ZA100A A H NC2600ZA200B E X NC2600ZA300C H L NC2600ZA110A A J NC2600ZA210B E Y NC2600ZA310C H N NC2600ZA120A A K NC2600ZA220B F A NC2600ZA320C H P NC2600ZA130A A L NC2600ZA230B F C NC2600ZA330C H R NC2600ZA140A A N NC2600ZA240B F E NC2600ZA000D J A NC2600ZA150A A P NC2600ZA250B F F NC2600ZA060D J C NC2600ZA160A A R NC2600ZA260B F G NC2600ZA070D J E NC2600ZA170A A T NC2600ZA270B F H NC2600ZA080D J F NC2600ZA180A A U NC2600ZA280B F J NC2600ZA090D J G NC2600ZA190A A V NC2600ZA290B F K NC2600ZA100D J H NC2600ZA200A A X NC2600ZA300B F L NC2600ZA110D J J NC2600ZA210A A Y NC2600ZA310B F N NC2600ZA120D J K NC2600ZA220A C A NC2600ZA320B F P NC2600ZA130D J L NC2600ZA230A C C NC2600ZA330B F R NC2600ZA140D J N NC2600ZA240A C E NC2600ZA000C G A NC2600ZA150D J P NC2600ZA250A C F NC2600ZA060C G C NC2600ZA160D J R NC2600ZA260A C G NC2600ZA070C G E NC2600ZA170D J T NC2600ZA270A C H NC2600ZA080C G F NC2600ZA180D J U NC2600ZA280A C J NC2600ZA090C G G NC2600ZA190D J V NC2600ZA290A C K NC2600ZA100C G H NC2600ZA200D J X NC2600ZA300A C L NC2600ZA110C G J NC2600ZA210D J Y NC2600ZA310A C N NC2600ZA120C G K NC2600ZA220D K A NC2600ZA320A C P NC2600ZA130C G L NC2600ZA230D K C NC2600ZA330A C R NC2600ZA140C G N NC2600ZA240D K E NC2600ZA000B E A NC2600ZA150C G P NC2600ZA250D K F NC2600ZA060B E C NC2600ZA160C G R NC2600ZA260D K G NC2600ZA070B E E NC2600ZA170C G T NC2600ZA270D K H NC2600ZA080B E F NC2600ZA180C G U NC2600ZA280D K J NC2600ZA090B E G NC2600ZA190C G V NC2600ZA290D K K NC2600ZA100B E H NC2600ZA200C G X NC2600ZA300D K L NC2600ZA110B E J NC2600ZA210C G Y NC2600ZA310D K N NC2600ZA120B E K NC2600ZA220C H A NC2600ZA320D K P NC2600ZA330D K R NC2600ZA130B E L NC2600ZA230C H C NC2600ZA140B E N NC2600ZA240C H E - 21 - Datasheet NC2600 series MARKING SPECIFICATION (NC2600GT) : Product Code : Lot No. … Alphanumerical Serial Number ①②③ ④⑤⑥ DFN2020-8-GT Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. Ver.1.3 - 22 - Datasheet NC2600 series NC2600GT Marking List Ver.1.3 Product Code NC2600GT000A  1 A 0 0 Product Code NC2600GT000B  1 B 0 0 NC2600GT060A 1 A 0 1 NC2600GT060B 1 B 0 1 NC2600GT070A 1 A 0 2 NC2600GT070B 1 B 0 2 NC2600GT080A 1 A 0 3 NC2600GT080B 1 B 0 3 NC2600GT090A 1 A 0 4 NC2600GT090B 1 B 0 4 NC2600GT100A 1 A 0 5 NC2600GT100B 1 B 0 5 NC2600GT110A 1 A 0 6 NC2600GT110B 1 B 0 6 NC2600GT120A 1 A 0 7 NC2600GT120B 1 B 0 7 NC2600GT130A 1 A 0 8 NC2600GT130B 1 B 0 8 NC2600GT140A 1 A 0 9 NC2600GT140B 1 B 0 9 NC2600GT150A 1 A 1 0 NC2600GT150B 1 B 1 0 NC2600GT160A 1 A 1 1 NC2600GT160B 1 B 1 1 NC2600GT170A 1 A 1 2 NC2600GT170B 1 B 1 2 NC2600GT180A 1 A 1 3 NC2600GT180B 1 B 1 3 NC2600GT190A 1 A 1 4 NC2600GT190B 1 B 1 4 NC2600GT200A 1 A 1 5 NC2600GT200B 1 B 1 5 NC2600GT210A 1 A 1 6 NC2600GT210B 1 B 1 6 NC2600GT220A 1 A 1 7 NC2600GT220B 1 B 1 7 NC2600GT230A 1 A 1 8 NC2600GT230B 1 B 1 8 NC2600GT240A 1 A 1 9 NC2600GT240B 1 B 1 9 NC2600GT250A 1 A 2 0 NC2600GT250B 1 B 2 0 NC2600GT260A 1 A 2 1 NC2600GT260B 1 B 2 1 NC2600GT270A 1 A 2 2 NC2600GT270B 1 B 2 2 NC2600GT280A 1 A 2 3 NC2600GT280B 1 B 2 3 NC2600GT290A 1 A 2 4 NC2600GT290B 1 B 2 4 NC2600GT300A 1 A 2 5 NC2600GT300B 1 B 2 5 NC2600GT310A 1 A 2 6 NC2600GT310B 1 B 2 6 NC2600GT320A 1 A 2 7 NC2600GT320B 1 B 2 7 NC2600GT330A 1 A 2 8 NC2600GT330B 1 B 2 8 - 23 - Datasheet NC2600 series NC2600GT Marking List Ver.1.3 Product Code NC2600GT000C  1 C 0 0 Product Code NC2600GT000D  1 D 0 0 NC2600GT060C 1 C 0 1 NC2600GT060D 1 D 0 1 NC2600GT070C 1 C 0 2 NC2600GT070D 1 D 0 2 NC2600GT080C 1 C 0 3 NC2600GT080D 1 D 0 3 NC2600GT090C 1 C 0 4 NC2600GT090D 1 D 0 4 NC2600GT100C 1 C 0 5 NC2600GT100D 1 D 0 5 NC2600GT110C 1 C 0 6 NC2600GT110D 1 D 0 6 NC2600GT120C 1 C 0 7 NC2600GT120D 1 D 0 7 NC2600GT130C NC2600GT140C 1 C 0 8 1 C 0 9 NC2600GT130D NC2600GT140D 1 D 0 8 1 D 0 9 NC2600GT150C NC2600GT160C NC2600GT170C NC2600GT180C 1 1 1 1 0 1 2 3 NC2600GT150D NC2600GT160D NC2600GT170D NC2600GT180D 1 1 1 1 NC2600GT190C 1 C 1 4 NC2600GT190D 1 D 1 4 NC2600GT200C 1 C 1 5 NC2600GT200D 1 D 1 5 NC2600GT210C 1 C 1 6 NC2600GT210D 1 D 1 6 NC2600GT220C NC2600GT230C 1 C 1 7 1 C 1 8 NC2600GT220D NC2600GT230D 1 D 1 7 1 D 1 8 NC2600GT240C 1 C 1 9 NC2600GT240D 1 D 1 9 NC2600GT250C 1 C 2 0 NC2600GT250D 1 D 2 0 NC2600GT260C 1 C 2 1 NC2600GT260D 1 D 2 1 NC2600GT270C 1 C 2 2 NC2600GT270D 1 D 2 2 NC2600GT280C 1 C 2 3 NC2600GT280D 1 D 2 3 NC2600GT290C 1 C 2 4 NC2600GT290D 1 D 2 4 NC2600GT300C 1 C 2 5 NC2600GT300D 1 D 2 5 NC2600GT310C 1 C 2 6 NC2600GT310D 1 D 2 6 NC2600GT320C 1 C 2 7 NC2600GT320D 1 D 2 7 NC2600GT330C 1 C 2 8 NC2600GT330D 1 D 2 8 C C C C 1 1 1 1 D D D D 1 1 1 1 0 1 2 3 - 24 - Datasheet NC2600 series APPLICATION NOTES Operation of Step-down Switching Regulator and Output Current The operation of the step-down switching regulator is explained. Step1. The high side MOSFET turns on and the inductor current IL = i1 flows, storing energy in the inductor and at the same time charging to the COUT. Then, the inductor current IL = i1 increases from ILLOW in proportion to the time when the high side MOSFET turns on and reaches ILHIGH. Step2. When the high side MOSFET turns off and the low side MOSFET turns on, the inductor operates to hold the inductor current IL = ILHIGH. At this time, the inductor uses the energy stored in Step 1 to flow the inductor current IL = i2. Step3. i2 gradually decreases until the low side MOSFET is turned off. When the next cycle, it returns to Step 1 again and the high side MOSFET turns on. By performing Step 1 to 3 above cyclically, an arbitrary output voltage is obtained according to the ratio of on time for one cycle. i1 L IOUT IL High Side MOSFET VIN Low Side MOSFET ILHIGH ILLOW i2 COUT ΔIL VOUT 0 tON tOFF t tPERIOD = 1/fOSC Basic Circuit of Step-down Switching Regulator Current Through Inductor When the maximum current of the inductor is ILHIGH and the minimum value is ILLOW, the difference between ILHIGH and ILLOW ΔIL is called the current ripple, ΔIL = ILHIGH - ILLOW. The current ripple ΔIL during Step 1 is shown by using tON (on-time), VIN, VOUT, and L (inductor value) as follows. ∆IL = (VIN − VOUT) × tON / L ············································································································ (2) On the other hand, during Step2, it is represented by the following equation using tOFF (off-time). ∆IL = VOUT × tOFF / L ···················································································································· (3) Since In the static state, the values of equations (2) and (3) are the same, (VIN − VOUT) × tON / L = VOUT × tOFF / L ····························································································· (4) Therefore, tON / tPERIOD is shown by following equation. tON / tPERIOD = VOUT / VIN ··············································································································· (5) Where tPERIOD is the period and is shown by the following equation. tPERIOD = tON + tOFF = 1 / fOSC ········································································································· (6) fOSC is the switching frequency. Duty is the ratio of the time that the high side MOSFET is on during one cycle and can be calculated by the following equation. Duty (%) = tON / tPERIOD × 100 = VOUT / VIN × 100 ··············································································· (7) Ver.1.3 - 25 - Datasheet NC2600 series Calculation Conditions of SW Pin Maximum Output Current (ISWMAX) The following equations explain the calculation to determine ISWMAX at the ideal operation of the ICs in continuous conduction mode. The p-p value of the ripple current is IRP, the on-resistance of the high side MOSFET and low side MOSFETs is RONP and RONN, respectively, and the DC resistance of the inductor is RL. First, define tON be the time when the high side MOSFET is on. VIN = VOUT + (RONP + RL) × IOUT + L × IRP / tON ··········································································································································· (8) Next, define tOFF be the time when the high side MOSFET is off (low side MOSFET is on). L × IRP / tOFF = RONN × IOUT + VOUT + RL × IOUT ··········································································································································· (9) Put Equation (9) into Equation (8) to solve DON = tON / (tOFF + tON) that is on-duty of high side MOSFET. DON = (VOUT + RONN × IOUT + RL × IOUT) / (VIN + RONN × IOUT − RONP × IOUT) ··········································································· (10) Ripple Current (IRP) is as follows. IRP = (VIN − VOUT − RONP × IOUT − RL × IOUT) × DON / fOSC / L ············································································································(11) The peak current flowing through the inductor and high side MOSFET can be calculated by the following equation. ISWMAX = IOUT + IRP / 2 ··························································································································································································· (12) Ver.1.3 - 26 - Datasheet NC2600 series Typical Application Circuit L VIN RPG VPG VIN SW NC2600xxxxx A/B/C/D CSS PG MODE CIN EN VOUT CSS COUT FB GND NC2600xxxxx (Fixed Output Voltage Type) L VIN RPG VPG CIN VIN SW NC2600xx000 A/B/C/D CSS PG MODE EN CSS FB VOUT R11 C1 R12 R0 COUT R2 GND NC2600xx000 (Adjustable Output Voltage Type) Recommended external parts Ver.1.3 Symbol Capacitance Tolerance Protection Voltage Temperature characteristics CIN 4.7 µF ±20% 6.3 V X5R COUT 10 µF ±20% 6.3 V X5R CSS - ±20% 6.3 V X5R Symbol Inductance Tolerance Rated Current L 1.0 µH ±20% 2.0A - 27 - Datasheet NC2600 series External Resistor for Setting Output Voltage (NC2600xx000x) The output voltage can be set by the external resistors (R1, R2) connected to the FB pin as shown in the following equation. VSET = VFB × (R1 + R2) / R2 R1 = R11 + R12 The reference voltage (VFB) of this IC is set 0.6 V. The VFB accuracy and output voltage setting range are as follows. : 0.6 V ± 9 mV VFB Accuracy Output Voltage Setting Range : 0.6 V ≤ VSET ≤ 5.5 V Recommended values for R1, R2, and C1 are shown below. Set Output Voltage (VSET) vs. R1,R2,C1 (Adjustable Output Voltage Type) VSET [V] R1 [kΩ] R2 [kΩ] 0.6 0 220 0 . 6 < VSET ≤ 2 . 1 220 2 . 1 < VSET ≤ 4 . 0 R1 = (VSET / VFB -1) x R2 47 4 . 0 < VSET ≤ 5 . 5 33 C1 [pF] Open 10 6.8 3.3 When using R2 other than the above table, adjust C1 according to the table below and check that there is no problem with the actual application. Set Output Voltage (VSET) vs. R2/C1 (Adjustable Output Voltage Type) VSET [V] C1 [pF] 0.6 Open 0 . 6 < VSET ≤ 2 . 1 2200 / R2 [kΩ] 2 . 1 < VSET ≤ 4 . 0 319.6 / R2 [kΩ] 4 . 0 < VSET ≤ 5 . 5 108.9 / R2 [kΩ] R0 prevents against the effects of noise. Noise varies depending on the board layout. R0 is not required for optimized boards, but if you are concerned about spikes, use about 1 kΩ. Ver.1.3 - 28 - Datasheet NC2600 series Cautions for Selecting External Components • Choose a low ESR ceramic capacitor. The input capacitor (CIN) between VIN and GND should be more than 4.7 µF, and the output capacitor (COUT) should be used of 10 µF. Also, choose the capacitor with consideration for bias characteristics and input/output voltages. Even when using a capacitor other than a ceramic capacitor such as aluminum electrolytic, connect a ceramic capacitor with shortest-distance wiring. • The phase compensation of this device is designed according to the COUT and L values. The inductance value of an inductor should be 1.0 µH to gain stability. • Choose an inductor that has small DC resistance, has enough permissible current and is hard to cause magnetic saturation. If the inductance value of the inductor becomes extremely small under the load conditions, the peak current of inductor may increase along with the load current. As a result, the current limit circuit may start to operate before the peak current of inductor reaches to load current range. Therefore, choose an inductor with consideration for the value of ISWMAX. Refer to the data sheet "Calculation Conditions of SW Pin Maximum Output Current (ISWMAX)". Ver.1.3 - 29 - Datasheet NC2600 series Evaluation Board / PCB Layout NC2600ZA [WLCSP-8-P11] Ver.1.3 Layer 1 Layer 2 Layer 3 Layer 4 - 30 - Datasheet NC2600 series NC2600GT [DFN2020-8-GT] Ver.1.3 Layer 1 Layer 2 Layer 3 Layer 4 - 31 - Datasheet NC2600 series TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed a rated voltage, a rated current or a rated power. When designing a peripheral circuit, please be fully aware of the following points. • • External components must be connected as close as possible to the ICs and make wiring as short as possible and on the same side of the IC. Especially, the capacitor connected in between VIN pin and GND pin must be wiring the shortest. The VIN line, the GND line, and SW pin should make special considerations for the large switching current flows. If their impedance is high, internal voltage of the IC may shift by the switching current, and the operating may be unstable. Make the power supply and GND lines as wide and short as possible. The wiring from the SW pin to the inductor becomes a noise source, so ensure that the current capacity is secured and that the wiring is not wider or longer than necessary so that the noise does not increase. • Connect COUT to the wiring between the FB pin and the inductor(L), or between the output voltage setting resistor (R1) and L. Also, keep them as far away as possible from noise sources such as inductors to prevent noise from being mixed in. • The thermal shutdown function prevents the IC from fuming and ignition but does not ensure the IC’s reliability or keep the IC below the absolute maximum ratings. The thermal shutdown function does not operate on the heat generated by other than the normal IC operation such as latch-up and overvoltage application. The thermal shutdown function operates in a state over the absolute maximum ratings, therefore the thermal shutdown function should not be used for a system design. • The tab on the bottom side of the DFN-Package is recommended to be connected to GND. It will work even if it is open, but please note that the heat dissipation and mounting strength will decrease. Ver.1.3 - 32 - Datasheet NC2600 series TYPICAL CHARACTERISTICS Typical characteristics are intended to be used as reference data, they are not guaranteed. 1)Efficiency vs Output Current 100 100 90 90 80 80 70 70 Efficiency [%] NC2600ZA VOUT = 1.8 [V] Efficiency [%] NC2600ZA VOUT = 1.2 [V] 60 50 MODE=High MODE=Low 40 30 VVin=2.5V IN = 2.5 [V] VVin=3.6V IN = 3.6 [V] VVin=4.2V IN = 4.2 [V] VVin=5.0V IN = 5.0 [V] 20 10 0 0.01 0.1 1 10 100 1000 60 50 40 30 VVin=2.5V IN = 2.5 [V] VVin=3.6V IN = 3.6 [V] VVin=4.2V IN = 4.2 [V] VVin=5.0V IN = 5.0 [V] 20 10 0 0.01 10000 0.1 Output Current IOUT [mA] 100 90 90 80 80 70 70 50 Efficiency [%] 100 Efficiency [%] NC2600GT VOUT = 1.2 [V] MODE=High MODE=Low 40 30 20 0 0.01 0.1 1 10 100 1000 50 40 0 0.01 10000 0.1 80 70 70 60 MODE=High Vin=2.5V V IN = 2.5 [V] V Vin=3.6V IN = 3.6 [V] V Vin=4.2V IN = 4.2 [V] V Vin=5.0V IN = 5.0 [V] 10 0 0.01 0.1 1 10 100 Output Current IOUT [mA] Ver.1.3 1000 10000 Efficiency [%] 90 80 Efficiency [%] 100 90 20 1 10 100 1000 10000 Output Current IOUT [mA] 100 30 10000 Vin=2.5V VIN = 2.5 [V] Vin=3.6V VIN = 3.6 [V] Vin=4.2V VIN = 4.2 [V] VIN = 5.0 [V] Vin=5.0V 10 NC2600GT VOUT = 3.3 [V] 40 1000 MODE=High MODE=Low 30 NC2600GT VOUT = 1.8 [V] MODE=Low 100 60 Output Current IOUT [mA] 50 10 20 VIN = 4.2 [V] Vin=4.2V VIN = 5.0 [V] Vin=5.0V 10 1 Output Current IOUT [mA] NC2600ZA VOUT = 3.3 [V] 60 MODE=High MODE=Low 60 50 MODE=High MODE=Low 40 30 20 Vin=4.2V VIN = 4.2 [V] VIN = 5.0 [V] Vin=5.0V 10 0 0.01 0.1 1 10 100 1000 10000 Output Current IOUT [mA] - 33 - Datasheet NC2600 series 2)Output Voltage vs Output Current NC2600ZA VOUT = 1.8 [V] MODE = Low 2 1.818 1 1.800 0 1.782 -1 1.764 -2 0 500 1000 1.836 1.800 0 1.782 -1 1.764 -2 0 500 1.818 1 1.800 0 1.782 -1 1.764 -2 0 500 1000 1.836 1 1.800 0 1.782 -1 1.764 -2 0 500 Maximum Output Current IOUT [mA] Maximum Output Current IOUT [mA] 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 3.0 3.5 4.0 1000 -3 2000 1500 VOUT = 1.2 [V] 2200 2.5 2 Output Current IOUT [mA] 3)Maximum Output Current vs VIN MODE = High NC2600ZA VOUT = 0.6 [V] 1200 Vin=3.6V V IN = 3.6 [V] V Vin=5.0V IN = 5.0 [V] 1.818 1.746 -3 2000 1500 3 V Vin=2.5V IN = 2.5 [V] V Vin=4.2V IN = 4.2 [V] Output Voltage VOUT [%] 2 Output Voltage VOUT [V] 1.836 Vin=3.6V VIN = 3.6 [V] VIN = 5.0 [V] Vin=5.0V Output Voltage VOUT [%] Output Voltage VOUT [V] 1.854 3 Vin=2.5V VIN = 2.5 [V] VIN = 4.2 [V] Vin=4.2V Output Current IOUT [mA] 4.5 Input Voltage VIN [V] Ver.1.3 -3 2000 1500 MODE = High 1.854 2.0 1000 Output Current IOUT [mA] NC2600GT VOUT = 1.8 [V] MODE = Low 1000 2 1 Output Current IOUT [mA] 1.746 3 1.818 1.746 -3 2000 1500 VIN = 3.6 [V] Vin=3.6V VIN = 5.0 [V] Vin=5.0V Vin=2.5V VIN = 2.5 [V] VIN = 4.2 [V] Vin=4.2V Output Voltage VOUT [%] Vin=3.6V VIN = 3.6 [V] VIN = 5.0 [V] Vin=5.0V Output Voltage VOUT [V] 1.836 1.746 1.854 3 Vin=2.5V VIN = 2.5 [V] VIN = 4.2 [V] Vin=4.2V Output Voltage VOUT [%] Output Voltage VOUT [V] 1.854 MODE = High 5.0 5.5 2200 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN [V] - 34 - Datasheet NC2600 series VOUT = 3.3 [V] 2200 Maximum Output Current IOUT [mA] Maximum Output Current IOUT [mA] VOUT = 1.8 [V] 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 2200 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 5.5 2.0 2.5 2200 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.5 3.0 3.5 4.0 4.5 5.0 5.0 5.5 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN [V] VOUT = 3.3 [V] 2200 Maximum Output Current IOUT [mA] Maximum Output Current IOUT [mA] 4.5 2000 5.5 VOUT = 1.8 [V] 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.5 3.0 3.5 4.0 4.5 Input Voltage VIN [V] Ver.1.3 4.0 2200 Input Voltage VIN [V] 2.0 3.5 VOUT = 1.2 [V] Maximum Output Current IOUT [mA] Maximum Output Current IOUT [mA] NC2600GT VOUT = 0.6 [V] 2.0 3.0 Input Voltage VIN [V] Input Voltage VIN [V] 5.0 5.5 2200 2000 1800 1600 1400 Ta=-40°C Ta= 25°C Ta= 85°C 1200 1000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN [V] - 35 - Datasheet NC2600 series 4)Switching Frequency vs Input Voltage IOUT = 1 [mA] MODE = Low IOUT = 1 [mA] MODE = High 5000 35 Vout=1.2V VOUT = 1.2 [V] VOUT = 1.8 [V] Vout=1.8V VOUT = 3.3 [V] Vout=3.3V 25 4500 Frequency [kHz] Frequency [kHz] 30 20 15 10 3500 3000 2500 2000 Vout=1.2V VOUT = 1.2 [V] VOUT = 1.8 [V] Vout=1.8V VOUT = 3.3 [V] Vout=3.3V 1500 5 0 4000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 1000 5.5 2.0 2.5 Input Voltage VIN [V] 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN [V] IOUT = 1000 [mA] MODE = Low 5000 Frequency [kHz] 4500 4000 3500 3000 2500 2000 V Vout=1.2V OUT = 1.2 [V] V Vout=1.8V OUT = 1.8 [V] V OUT = 3.3 [V] Vout=3.3V 1500 1000 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN [V] 5)Load Transient Response VIN = VEN = 3.6 [V] , VOUT = 1.8 [V] MODE = Low IOUT = 1 [mA] -> 500 [mA] IOUT = 500 [mA] -> 1 [mA] 0 2.0 1.9 VOUT 1.8 1.7 1.6 -50 0 50 100 Time [µs] Ver.1.3 150 200 250 IOUT 1000 500 0 2.0 VOUT 1.9 1.8 1.7 1.6 -200 0 200 400 600 800 Output Current IOUT [mA] 500 Output Voltage VOUT [V] 1000 IOUT 1500 Output Current IOUT [mA] Output Voltage VOUT [V] 1500 1000 Time [µs] - 36 - Datasheet NC2600 series IOUT = 1 [mA] -> 1000 [mA] IOUT = 1000 [mA] -> 1 [mA] 500 0 2.0 1.9 VOUT 1.8 1.7 100 200 300 2.0 VOUT 1.9 1.8 1.7 1.6 -500 400 0 500 1000 500 1.9 VOUT 1.8 1.7 50 100 Output Voltage VOUT [V] 1000 Output Current IOUT [mA] Output Voltage VOUT [V] 1500 2.0 IOUT 1.9 VOUT 1.8 1.6 -50 0 0 2.0 1.9 VOUT 1.8 100 150 1500 Output Voltage VOUT [V] 1000 Output Current IOUT [mA] Output Voltage VOUT [V] 150 1500 1.7 Ver.1.3 100 IOUT = 1000 [mA] -> 1 [mA] 500 Time [µs] 50 Time [µs] IOUT 50 0 1.7 150 IOUT = 1 [mA] -> 1000 [mA] 0 500 2.0 Time [µs] -50 2000 1500 0 1.6 1500 IOUT = 500 [mA] -> 1 [mA] IOUT 0 1000 Time [µs] MODE = High IOUT = 1 [mA] -> 500 [mA] -50 500 0 Time [µs] 1.6 1000 Output Current IOUT [mA] 0 IOUT 1000 IOUT 500 0 2.0 VOUT 1.9 1.8 1.7 1.6 -50 0 50 100 Output Current IOUT [mA] 1.6 -100 Output Voltage VOUT [V] 1000 Output Current IOUT [mA] Output Voltage VOUT [V] IOUT Output Current IOUT [mA] 1500 1500 150 Time [µs] - 37 - Datasheet NC2600 series 6)Output Voltage Waveform VIN = VEN = 3.6 [V] , VOUT = 1.8 [V] IOUT = 1 [mA] MODE = Low MODE = High 200 0 1.84 VOUT 1.82 1.80 1.78 0 200 400 600 800 200 0 1.84 VOUT 1.82 1.80 1.78 1.76 1000 1200 0.0 0.5 Time [µs] 1400 1000 800 1.84 VOUT 1.82 1.80 1.78 0.5 1.0 1.5 Output Voltage VOUT [V] 1200 Time [µs] 1200 1000 800 1.84 VOUT 1.82 1.80 1.78 1.76 2.0 1400 ISW Inductor Current ISW [mA] Output Voltage VOUT [V] 2.0 1.5 MODE = High ISW 0.0 1.0 Time [µs] IOUT = 1000 [mA] MODE = Low 1.76 400 0.0 0.5 1.0 1.5 Inductor Current ISW [mA] 1.76 Output Voltage VOUT [V] 400 600 ISW Inductor Current ISW [mA] 600 Inductor Current ISW [mA] Output Voltage VOUT [V] ISW 2.0 Time [µs] 7)Output Voltage vs Temperature VIN = VEN = 3.6 [V] , VOUT = 1.8 [V] IOUT = 0 [mA] MODE = High 1.90 Output Voltage VOUT [V] 1.88 1.86 1.84 1.82 1.80 1.78 1.76 1.74 1.72 1.70 -50 -25 0 25 50 75 100 Temperature Ta [°C] Ver.1.3 - 38 - Datasheet NC2600 series 8)Soft-Start Waveform VOUT = 1.8 [V], MODE = High, CSS = open, IOUT = 0 [mA] VIN = 3.6 [V], VEN = 0 -> 3.6 [V] 8 VEN 2V/DIV 6 4 VOUT 1V/DIV 2 2.0 0 VPG 1.0 2V/DIV 0.0 0 200 400 600 800 Time [us] 9)Input Current vs Input Voltage MODE = Low VOUT = 2.1 [V] VOUT = 3.3 [V] 8 7 -40℃ 7 -40℃ 6 25℃ 6 25℃ 5 85℃ 5 85℃ Input Current IIN [mA] Input Current IIN [mA] 8 4 3 2 1 0 2.1 2.2 2.3 2.4 4 3 2 1 0 2.5 2.6 3.3 3.4 3.5 3.6 3.7 3.8 Input Voltage VIN [V] Input Voltage [V] VOUT = 5.0 [V] Input Current IIN [mA] 8 7 -40℃ 6 25℃ 5 85℃ 4 3 2 1 0 5.0 5.1 5.2 5.3 5.4 5.5 Input Voltage VIN [V] *Note that if the voltage difference between VIN and VOUT decreases, switching current increases regardless of IOUT. Ver.1.3 - 39 - Datasheet NC2600 series TEST CIRCUIT L VIN RPG VPG VIN SW NC2600xxxxx A/B/C/D CSS PG MODE CIN EN VOUT CSS COUT FB GND NC2600xxxxx (Fixed Output Voltage Type) Test Circuit 【Components List for Our Evaluation】 Ver.1.3 Symbol Specification Parts Number CIN 4.7 µF GRM035R60J475ME COUT 10 µF GRM155R60J106ME44 L 1.0 µH TFM201610ALM-1R0MTAA - 40 - Package Information WLCSP-8-P11 PI-WLCSP-8-P11-E-C ■ PACKAGE DIMENSIONS UNIT: mm 1.62 ±0.05 0.40 (0.21) 0.05 S S 0. 40 1 D C B A φ0.245 ±0.03 φ0.05 M S AB 0.08 ± 0.02 0.3 6 ±0.0 4 INDEX MARK 2 (0.29) B 0.98 ± 0.05 A ■ EXAMPLE OF SOLDER PADS DIMENSIONS 8 × φ0.245 0.4 0.4 Recommended Land Pattern NSMD Pad Definition Solder Mask Copper Pad Substrate NSMD Pad definition NSMD (Non-Solder Mask defined) Copper Pad Solder Mask Opening 0.245mm MIN. 0.345mm *) Pad Layout and size can modify by customers material, equipment and method. *) Please adjust pad layout according to your conditions. *) Recommended Stencil Aperture Size: 0.245mm Package Information WLCSP-8-P11 PI-WLCSP-8-P11-E-C ■ PACKING SPEC UNIT: mm 2.0 ±0.05 1.55 ±0.05 4.0 ±0.1 3. 5 ± 0.05 1. 79 ± 0.04 (E2) 4.0 ±0.1 1.15 ±0.04 0.5 ±0.05 0.2 ±0.05 8.0 Insert direction +0.3 -0.1 Carrier tape material: PS Cover tape material: PE 1 .75 ± 0.1 (1) Taping dimensions / Insert direction 0.48 ±0.03 (2) Taping state Feed direction Sealing with covering tape Trailer part Devices Leader part more than 160mm 5000pcs/reel more than 550mm Package Information WLCSP-8-P11 PI-WLCSP-8-P11-E-C (3) Reel dimensions 11.4 ±1.0 13 ±0.2 21 ±0.8 Reel material: PS 9 +1.0 -0.3 (4) Peeling strength Peeling strength of cover tape ・Peeling angle 165 to 180°degrees to the taped surface. ・Peeling speed 300mm/min ・Peeling strength 0.1 to 1.0N Cover tape 165 to 180 ° Direction to pull Feed direction Carrier tape 180 -30 60 +10 2 ±0.5 Package Information WLCSP-8-P11 PI-WLCSP-8-P11-E-C (5) Packing state Prodcut name, Quantity, Lot No, Mark 1reel Box size:185×185×20 MAX: 5reel Box size:185×185×80 Package Surface Temperature(℃) ■ HEAT-RESISTANCE PROFILES 3℃/s MAX. 255℃ 260℃ 30s MAX. 200℃ 6℃/s MAX. 217℃ 150℃ 60-150s 60-120s Time(s) Reflow profile Package Information DFN2020-8-GT PI-DFN2020-8-GT-E-A ■ PACKAGE DIMENSIONS 1.7 ±0.1 2.0 ±0.1 (0.2MIN) 0.5 A 5 8 0.3 ± 0.05 UNIT: mm 2.0 ±0.1 0.9 ± 0.1 B C0 .3 1 4 INDEX 0.05 S S 0.152TYP 0.6MAX 0.2 ±0.05 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.5 0.5 0.2 2.4 0.9 1.7 0.05 M S AB Package Information DFN2020-8-GT PI-DFN2020-8-GT-E-A ■ PACKING SPEC UNIT: mm 1.5 *Carrier tape material: PS *Cover tape material: PE +0.1 0 4.0 ±0.1 2.2 1.0 ±0.1 0.25 ±0.1 8 .0 ±0.3 4.0 ± 0.1 3 .5 ±0.05 2.0 ± 0.05 2.2 Insert direction (E4) 1.75 ± 0.1 (1) Taping dimensions / Insert direction 0.75 ±0.1 (2) Taping state Feed direction Sealing with covering tape Trailer part more than 160mm Devices Leader part 3000pcs/reel more than 400mm Package Information DFN2020-8-GT PI-DFN2020-8-GT-E-A (3) Reel dimensions 11.4 ±1.0 13 ±0.2 21 ±0.8 Reel material: PS 9 +1.0 -0.3 (4) Peeling strength Peeling strength of cover tape ・Peeling angle 165 to 180°degrees to the taped surface. ・Peeling speed 300mm/min ・Peeling strength 0.1 to 1.0N Cover tape 165 to 180 ° Direction to pull Feed direction Carrier tape 180 -30 60 +10 2 ±0.5 Package Information DFN2020-8-GT PI-DFN2020-8-GT-E-A (5) Packing state Prodcut name, Quantity, Lot No, Mark 1 reel Box size:185×185×20 MAX: 5reel Box size:185×185×80 Package Surface Temperature(℃) ■ HEAT-RESISTANCE PROFILES 3℃/s MAX. 255℃ 260℃ 30s MAX. 200℃ 6℃/s MAX. 217℃ 150℃ 60-150s 60-120s Time(s) Reflow profile Datasheet NC2600 series Revision History Date Version August 26.2022 1.0 October 18.2022 1.1 February 22.2023 1.2 March 24, 2023 1.3 Ver.1.3 Contents of Changes Initial release ・Corrected the size thickness of DFN2020-8-GT to 0.6 (mm). ・Added page for marking specification. ・In NC2600GT lineup added. ・In NC2600ZA, the mark specification was corrected (addition of NC2600ZA100B, correction of mark numbering) and the format was changed. ・In NC2600GT lineup added. ・In NC2600ZA, the mark specification was corrected (addition of NC2600ZA100B, correction of mark numbering) and the format was changed. - 41 - 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
NC2600ZA330AE2S 价格&库存
很抱歉,暂时无法提供与“NC2600ZA330AE2S”相匹配的价格&库存,您可以联系我们找货
NC2600ZA330AE2S
  • 5000+7.336325000+0.94915
  • 10000+7.1994710000+0.93145
库存:5000
NC2600ZA330AE2S
  • 1+15.051801+1.94736
  • 10+10.9955310+1.42257
  • 25+9.9898625+1.29246
  • 100+8.88410100+1.14940
  • 250+8.35767250+1.08129
  • 500+8.04004500+1.04020
  • 1000+7.991701000+1.03394
库存:5000
