RP512Z181D-TR-F
RP512Z181D-TR-F
    NISSHINBO(日清纺)
    8-XFBGA,WLCSP
    降压 开关稳压器 IC 正 固定 1.8V 1 输出 300mA 8-XFBGA,WLCSP
RP512Z181D-TR-F 数据手册
RP512x Series 0.3 µA IQ Ultra-low Quiescent Current 300 mA Buck DC/DC Converter No. EA-400-190401 OVERVIEW RP512x is a DC/DC converter featuring 0.3 μA ultra-low operating quiescent current. It is suitable for use in wearable and IoT devices that require miniaturization and long-lifetime of battery. KEY BENEFITS VFM (fSW up to 1 MHz) control achieves 0.3 μA ultra-low operating quiescent current. The wide range of VIN from 2.0 V to 5.5 V allows operation from coin cell to USB port. Total mount area including CIN, COUT, and inductor is 10.6 mm2. Selectable packages including WLCSP, DFN, and SOT. 0.4 mm-thickness WLCSP package adaptable to IC cards. KEY SPECIFICATIONS   TYPICAL CHARACTERISTICS Output Current: 300 mA Output Voltage Range: 1.0 V to 4.0 V (Settable in 0.1 V step) Output Voltage Accuracy: ±1.5% (VSET ≥ 1.2 V), ±18 mV (VSET < 1.2 V) Built-in Driver On-resistance (VIN = 3.6 V): Typ. PMOS 0.15 Ω, NMOS 0.15 Ω (RP512Z) Standby Current: 0.01 µA    TYPICAL APPLICATIONS VIN VIN 60 Vin=2.3V Vin=3.6V Vin=5.5V 40 20 0 0.001 0.01 1 10 IOUT [mA] 100 1000 Package Q’ty per Reel WLCSP-8-P1 5,000 pcs Product Name COUT RP512Zxx1$-TR-F CE 0.1 VOUT L VOUT CIN 80 SELECTION GUIDE LX RP512x VOUT = 1.8 V 100 Efficiency [%] ● ● ● ● GND RP512Kxx1$-TR DFN2527(PL)-10 RP512Hxx1$-T1-FE L: 2.2 µH, COUT: 22 µF SOT-89-5 5,000 pcs 1,000 pcs xx: Set output voltage (VSET) Fixed Output Voltage Type: 1.0 V (10) to 4.0 V (40) in 0.1 V step. PACKAGES $: Version Version WLCSP-8-P1 DFN(PL)2527-10 SOT-89-5 1.45 mm x 1.48 mm, 2.7mm x 2.5 mm, 4.5mm x 4.35mm, t=0.4mm (max.) t=0.6mm (max.) t=1.6mm (max.) Auto-discharge Function C No D Yes VSET 1.0 V to 4.0 V APPLICATIONS     Wearable equipment such as SmartWatch, SmartBand, and health monitoring Li-ion battery-used equipment, Coin cell-used equipment Low power RF such as Bluetooth® Low Energy, Zigbee, WiSun, and ANT Low power CPU, memory, sensor devices, and energy harvesting 1 RP512x No. EA-400-190401 SELECTION GUIDE The set output voltage, the output voltage type, and the auto-discharge function(1), and the package for the ICs are user-selectable options. Selection Guide Product Name RP512Zxx1$-TR-F RP512Kxx1$-TR RP512Hxx1$-T1-FE Package Quantity per Reel Pb Free Halogen Free WLCSP−8−P1 5,000 pcs Yes Yes DFN(PL)2527-10 5,000 pcs Yes Yes 1,000 pcs Yes Yes SOT-89-5 xx: Designation of the set output voltage (VSET) For Fixed Output Voltage Type(2): 1.0 V (10) to 4.0 V (40) in 0.1 V step $: Designation of Version (1) Version Auto-discharge Function C Disable D Auto-discharge VSET 1.0 V to 4.0 V Auto-discharge function quickly lowers the output voltage to 0 V, when the chip enable signal is switched from the active mode to the standby mode, by releasing the electrical charge accumulated in the external capacitor. (2) The customization of specifying in 0.05 V step is available. 2 RP512x No. EA-400-190401 BLOCK DIAGRAM RP512xxx1C Block Diagram RP512xxx1D Block Diagram 3 RP512x No. EA-400-190401 PIN DESCRIPTION Top View Bottom View 3 3 2 2 1 1 A B C C B A RP512Z (WLCSP-8-P1) Pin Configuration Top View 10 9 8 5 Bottom View 7 6 6 7 8 9 4 10 (1) 1 2 3 4 5 5 4 3 2 1 1 RP512K [DFN(PL)2527-10] Pin Configuration 1 2 3 RP512H (SOT-89-5) Pin Configuration RP512Z Pin Description  (1) Pin No. Symbol Description A1 VIN Input Pin B1 VIN Input Pin C1 LX Switching Pin A2 VOUT Output voltage Pin C2 GND Ground Pin A3 CE B3 GND Ground Pin C3 GND Ground Pin Chip Enable Pin (Active-high)  The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. 4 RP512x No. EA-400-190401 RP512K Pin Description Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 GND Ground Pin 4 LX Switching Pin 5 LX Switching Pin 6 VIN Input Pin 7 VIN Input Pin 8 NC No connection 9 CE Chip Enable Pin (Active-high) 10 NC No connection   RP512H Pin Description Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 LX Switching Pin 4 VIN Input Pin 5 CE Chip Enable Pin (Active-high)    5 RP512x No. EA-400-190401 ABSOLUTE MAXIMUM RATINGS Absolute Maximum Ratings (GND = 0 V) Symbol Parameter Rating Unit −0.3 to 6.5 V VIN Input Voltage VLX LX Pin Voltage −0.3 to VIN + 0.3 V VCE CE Pin Voltage −0.3 to 6.5 V VMODE MODE Pin Voltage −0.3 to 6.5 V VOUT VOUT Pin Voltage −0.3 to 6.5 V 650 mA WLCSP-8-P1, JEDEC STD. 51-9 1140 mW DFN(PL)2527-10, JEDEC STD. 51-7 2500 mW SOT-89-5, JEDEC STD. 51-7 2600 mW ILX LX Pin Output Current Power Dissipation(1) PD Tj Junction Temperature Range −40 to 125 C Tstg Storage Temperature Range −55 to 125 C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS Recommended Operating Conditions Symbol Parameter Rating Unit VIN Input Voltage 2.0 to 5.5 V Ta Operating Temperature Range −40 to 85 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) 6 Refer to POWER DISSIPATION for detailed information. RP512x No. EA-400-190401 ELECTRICAL CHARACTERISTICS The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. RP512x Electrical Characteristics Symbol VOUT Parameter Output Voltage Condition VIN = VCE = 3.6 V VSET ≥ 1.2 V (VSET ≤ 2.6 V), VIN = VCE = VSET +1 V VSET < 1.2 V (VSET > 2.6 V) Operating Quiescent Current VIN = VCE = VOUT = 3.6 V, VSET = 1.8 V, device not switching Standby Current VIN = 5.5 V, VCE = 0 V ICEH CE Pin Input Current, high VIN = VCE = 5.5 V ICEL CE Pin Input Current, low IVOUTH IQ Min. Typ. (Ta = 25°C) Max. Unit x 0.985 x 1.015 −0.018 +0.018 V A 0.3 0.01 0.5 A −0.025 0 0.025 A VIN = 5.5 V, VCE = 0 V −0.025 0 0.025 A VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −0.025 0 0.025 A IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −0.025 0 0.025 A RDISN Auto-discharge NMOS Onstate Resistance(1) VIN = 3.6 V, VCE = 0 V VCEH CE Pin Input Voltage, high VIN = 5.5 V VCEL CE Pin Input Voltage, low VIN = 2.0 V RONP PMOS On-state Resistance ISTANDBY RP512Z RONN NMOS On-state Resistance 60 Ω 1.0 V 0.4 VIN = 3.6 V, ILX = −100 mA 0.15 V Ω RP512K VIN = 3.6 V, ILX = −100 mA 0.19 Ω RP512H VIN = 3.6 V, ILX = −100 mA 0.19 Ω RP512Z VIN = 3.6 V, ILX = −100 mA 0.15 Ω RP512K VIN = 3.6 V, ILX = −100 mA 0.19 Ω RP512H VIN = 3.6 V, ILX = −100 mA 0.19 Ω 10 ms mA tSTART Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) 300 580 VIN = VCE, Falling 1.40 1.50 1.65 V VIN = VCE, Rising 1.55 1.65 1.80 V VUVLOF VUVLOR Undervoltage Lockout (UVLO) Threshold All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. (1) RP512xxx1D only 7 RP512x No. EA-400-190401 Product-specific Electrical Characteristics RP512xxx1x Product Name RP512x101x RP512x111x RP512x121x RP512x131x RP512x141x RP512x151x RP512x161x RP512x171x RP512x181x RP512x191x RP512x201x RP512x211x RP512x221x RP512x231x RP512x241x RP512x251x RP512x261x RP512x271x RP512x281x RP512x291x RP512x301x RP512x311x RP512x321x RP512x331x RP512x341x RP512x351x RP512x361x RP512x371x RP512x381x RP512x391x RP512x401x 8 (Ta = 25°C) Min. 0.9820 1.0820 1.1820 1.2805 1.3790 1.4775 1.5760 1.6745 1.7730 1.8715 1.9700 2.0685 2.1670 2.2655 2.3640 2.4625 2.5610 2.6595 2.7580 2.8565 2.9550 3.0535 3.1520 3.2505 3.3490 3.4475 3.5460 3.6445 3.7430 3.8415 3.9400 VOUT Typ. 1.00 1.10 1.20 1.30 1.40 1.50 1.60 1.70 1.80 1.90 2.00 2.10 2.20 2.30 2.40 2.50 2.60 2.70 2.80 2.90 3.00 3.10 3.20 3.30 3.40 3.50 3.60 3.70 3.80 3.90 4.00 Max. 1.0180 1.1180 1.2180 1.3195 1.4210 1.5225 1.6240 1.7255 1.8270 1.9285 2.0300 2.1315 2.2330 2.3345 2.4360 2.5375 2.6390 2.7405 2.8420 2.9435 3.0450 3.1465 3.2480 3.3495 3.4510 3.5525 3.6540 3.7555 3.8570 3.9585 4.0600 RP512x No. EA-400-190401 THEORY OF OPERATION Soft-start Time Starting-up with CE Pin The IC starts to operate when the CE pin voltage (VCE) exceeds the threshold voltage. The threshold voltage is preset between CE “H” input voltage (VCEH) and CE “Low” input voltage (VCEL). After the start-of the start-up of the IC, soft-start circuit starts to operate. Then, after a certain period of time, the reference voltage (VREF) in the IC gradually increases up to the specified value. Notes: Soft start time (tSTART)(1) is not always equal to the turn-on speed of the step-down DC/DC converter. Please note that the turn-on speed could be affected by the power supply capacity, the output current, the inductance value and the COUT value. VCEH Threshold Level VCEL VCE tSTART VREF Soft-start Circuit operation starts VLX VOUT Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with CE Pin Starting-up with Power Supply After the power-on, when VIN exceeds the UVLO released voltage (VUVLO2), the IC starts to operate. Then, softstart circuit starts to operate and after a certain period of time, VREF gradually increases up to the specified value. Note: Please note that the turn-on speed of VOUT could be affected by the power supply capacity, the output current, the inductance value, the COUT value and the turn-on speed of VIN determined by CIN. VIN VUVLO2 tSTART VREF VLX VSET VOUT Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with Power Supply (1) Soft-start time (tSTART) indicates the duration until the reference voltage (VREF) reaches the specified voltage after softstart circuit’s activation. 9 RP512x No. EA-400-190401 Undervoltage Lockout (UVLO) Circuit If VIN becomes lower than VSET, the step-down DC/DC converter stops the switching operation and ON duty becomes 100%, and then VOUT gradually drops according to VIN. If the VIN drops more and becomes lower than the UVLO detector threshold (VUVLO1), the UVLO circuit starts to operate, VREF stops, and PMOS and NMOS built-in switch transistors turn “OFF”. As a result, VOUT drops according to the COUT capacitance value and IOUT. As for RP512xxx1D, the discharge transistor for COUT discharges after it turns on. To restart the operation, VIN needs to be higher than VUVLO2. The timing chart below shows the voltage shifts of VREF, VLX and VOUT when VIN value is varied. Note: Falling edge (operating) and rising edge (releasing) waveforms of VOUT could be affected by the initial voltage of COUT and the output current of VOUT. VIN VSET VUVLO2 VUVLO1 tSTART VREF VLX VOUT VOUT Depending on Power Supply, Load Current, External Components Timing Chart with Variations in Input Voltage (VIN) 10 RP512x No. EA-400-190401 Operation of Step-down DC/DC Converter and Output Current The step-down DC/DC converter charges energy in the inductor when LX transistor turns “ON”, and discharges the energy from the inductor when LX transistor turns “OFF” and controls with less energy loss, so that a lower output voltage (VOUT) than the input voltage (VIN) can be obtained. The operation of the step-down DC/DC converter is explained in the following figures. IL i1 VIN PMOS Tr. NMOS Tr. VOUT L i2 ILMIN i1 i2 tOPEN CL GND Basic Circuit ILMAX tON tOFF Inductor Current (IL) flowing through Inductor (L) Step1. PMOS transistor turns “ON” and IL (i1) flows, L is charged with energy. At this moment, i1 increases from the minimum inductor current (ILMIN), which is 0 A, and reaches the maximum inductor current (ILMAX) in proportion to the on-time period (tON) of PMOS transistor. Step2. When PMOS transistor turns “OFF”, L tries to maintain IL at ILMAX, so L turns NMOS transistor “ON” and IL (i2) flows into L. Step3. i2 decreases gradually and reaches ILMIN after the open-time period (tOPEN) of NMOS transistor, and then NMOS transistor turns “OFF”. This is called discontinuous current mode. As the output current (IOUT) increases, the off-time period (tOFF) of PMOS transistor runs out before IL reaches ILMIN. The next cycle starts, and PMOS transistor turns “ON” and NMOS transistor turns “OFF”, which means IL starts increasing from ILMIN. This is called continuous current mode. When the step-down DC/DC operation is constant, ILMIN and ILMAX during ton of PMOS transistor would be same as during tOFF of PMOS transistor. The current differential between ILMAX and ILMIN is described as I, as the following equation 1. I = ILMAX − ILMIN = VOUT  tOPEN / L = (VIN − VOUT)  tON / L ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ (1) 11 RP512x No. EA-400-190401 VFM Mode A switching method is a VFM (Variable Frequency Modulation) mode to achieve a high efficiency during light load conditions. A switching frequency varies depending on values of input voltage (VIN), output voltage (VOUT), and output current (IOUT). Check the actual characteristics for concerns regarding the switching noise. A switching starts when VOUT drops below the lower-limit reference voltage (VREFL). When VOUT exceeds the upper-limit reference voltage (VREFH), a constant voltage outputs by a hysteresis control which stops the switching. In order not to exceed the rated current of inductor or to avoid using the deteriorated band frequency of DC superimposed characteristics, the operation shifts to off-cycle once when the inductor current (IL) exceeds LX current limit (ILXLIM), and then it shifts back to on-cycle again when IL drops below the valley current limit (ILXVAL). 12 No Load Light Load Medium Load Heavy Load RP512x No. EA-400-190401 APPLICATION INFORMATION Typical Application VIN VIN L RP512x VOUT CIN VOUT LX COUT GND CE RP512x Typical Application Recommended External Components Symbol CIN Descriptions 10 µF, GRM155R60J106ME44D, MURATA COUT 22 µF, JMK107BBJ226MA-T, TAIYO L 2.2 µH, DFE201610P-2R2M, TOKO Precautions for Selecting External Components ・Using ceramic capacitors with low ESR (Equivalent Series Resistance) are recommended. Select capacitors with considerations of bias characteristics and input/output voltages. ・When a built-in Lx switch is turned off, a spike-like high voltage may be generated due to an action of an inductor. Using 1.5 times or more of a set output voltage is recommended for the withstanding voltage of COUT. ・Select an inductor that has small DC resistance, has sufficient allowable current and is hard to cause magnetic saturation. 13 RP512x No. EA-400-190401 TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed a rated voltage, a rated current or a rated power. When designing a peripheral circuit, please be fully aware of the following points. Refer to PCB Layout below. ・External components must be connected as close as possible to the ICs and make wiring as short as possible. Especially, the capacitor connected in between VIN pin and GND pin must be wiring the shortest. ・If the impedance of power supply lines and GND lines is high, the internal voltage of the IC may shift by the switching current, and the operating may be unstable. Make the power supply and GND lines sufficient. ・A sufficient consideration is required due to a large switching current flows through power supply lines, GND lines, an inductor, Lx, and VOUT line. ・The wiring between VOUT pin and inductor should be separated from the wiring connected to the load. ・When an intermediate voltage other than VIN or GND is input to the CE pin, a supply current may be increased with a through current of a logic circuit in the IC. The CE pin is neither pulled up nor pulled down, therefore an operation is not stable at open. 14 RP512x No. EA-400-190401 PCB Layout RP512Zxx1x (WLCSP-8-P1) Top Layer Bottom Layer RP512Kxx1x [DFN(PL)2527-10] Top Layer Bottom Layer 15 RP512x No. EA-400-190401 RP512Hxx1x (SOT-89-5) Top Layer 16 Bottom Layer RP512x No. EA-400-190401 TYPICAL CHARACTERISTICS QuiescentCurrent IQ[uA] 1.00 0.90 Vin=3.6V 0.80 Vin=5.5V StandbyCurrent ISTANDBY[uA] Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Quiescent Current vs. Temperature 2) Standby Current vs. Temperature 0.70 0.60 0.50 0.40 0.30 0.20 0.10 0.00 -50 -25 0 25 50 Temperature Ta[℃] 75 0.10 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0.00 100 Vin=3.6V Vin=5.5V ‐50 ‐25 0 25 50 Temperature  Ta[℃] 75 100 1.980 10.0 1.944 8.0 1.908 6.0 1.872 4.0 1.836 2.0 1.800 0.0 1.764 -2.0 1.728 -4.0 1.692 -6.0 1.656 -8.0 Vout_% OutputVoltage VOUT [V] 3) Output Voltage vs. Temperature RP512x181x, VIN = 3.6 V -10.0 1.620 -50 -25 0 25 50 75 Temperature Ta[℃] 100 4) Efficiency vs. Output Current RP512x121x, Ta = 25°C RP512x181x, Ta = 25°C 100 100 90 80 80 70 70 60 50 Vin=2.0V 40 Vin=3.6V 30 Vin=4.2V 20 Vin=5.0V 10 0 0.001 0.01 0.1 1 10 100 OutputCurrent IOUT [mA] Efficiency [%] Efficiency [%] 90 60 50 Vin=2.0V Vin=2.3V Vin=3.6V Vin=4.2V Vin=5.0V 40 30 20 10 0 0.001 0.01 0.1 1 10 100 OutputCurrent IOUT [mA] 17 RP512x No. EA-400-190401 RP512x331x, Ta = 25°C 100 90 Efficiency [%] 80 70 60 50 40 Vin=3.6V 30 Vin=4.2V 20 Vin=5.0V 10 0 0.1 1 10 100 OutputCurrent IOUT [mA] Output Voltage vs. Output Current RP512x121x, Ta = 25°C 1.248 OutputVoltage VOUT [V] 5.0 Vin=2.0V Vin=3.6V Vin=4.2V Vin=5.0V 1.236 1.224 1.212 1.890 1.0 1.200 -1.0 1.188 1.176 -3.0 1.164 1.152 Vin=3.6V 1.836 Vin=4.2V 1.818 Vin=5.0V 1.800 3.0 1.0 -1.0 1.782 1.764 1.746 -3.0 1.710 -5.0 0 50 100 150 200 250 OutputCurrent IOUT [mA] 300 3.465 3.432 3.399 Vin=4.2V 3.0 Vin=5.0V 3.366 3.333 1.0 3.300 3.267 OutputVoltage_% [%] 5.0 Vin=3.6V -1.0 3.234 3.201 -3.0 3.168 3.135 -5.0 0 50 100 150 200 250 OutputCurrent IOUT [mA] 300 -5.0 0 RP512x331x, Ta = 25°C OutputVoltage VOUT [V] Vin=2.3V 1.854 5.0 1.728 1.140 18 Vin=2.0V 1.872 3.0 OutputVoltage VOUT [V] 1.260 RP512x181x, Ta = 25°C OutputVoltage_% [%] 5) 0.01 OutputVoltage_% [%] 0.001 50 100 150 200 250 300 OutputCurrent IOUT [mA] RP512x No. EA-400-190401 Ripple Voltage vs. Output Current RP512x121x, Ta = 25°C Vin=3.6V 96 162 7 Vin=5.0V 72 9 8 Vin=4.2V 84 180 6 144 126 108 60 5 48 4 36 3 24 2 12 1 0 0 0 0 50 100 150 200 250 OutputCurrent IOUT[mA] 10 Vin=2.0V Vin=2.3V Vin=3.6V Vin=4.2V Vin=5.0V 9 8 7 6 90 5 72 4 54 3 36 2 18 1 300 RippleVoltage [%] Vin=2.0V 108 OutputVoltage Vripple [mV] RP512x181x, Ta = 25°C 10 OutputVoltage Vripple [mV] 120 RippleVoltage [%] 6) 0 0 50 100 150 200 250 OutputCurrent IOUT[mA] 300 RP512x331x, Ta = 25°C 10 297 Vin=3.6V 264 Vin=4.2V 8 231 Vin=5.0V 7 9 198 6 165 5 132 4 99 3 66 2 33 1 RippleVoltage [%] OutputVoltage Vripple [mV] 330 0 0 0 50 100 150 200 250 OutputCurrent IOUT[mA] 300 7) Switching Frequency vs. Output Current RP512x121x, Ta = 25°C 400 400 Vin=2.0V 350 300 Vin=4.2V 250 Vin=5.0V Vin=2.0V Vin=2.3V Vin=3.6V Vin=4.2V Vin=5.0V 350 Vin=3.6V Vout Frequency [kHz] Vout Frequency [kHz]] RP512x181x, Ta = 25°C 200 150 100 50 300 250 200 150 100 50 0 0 0 50 100 150 200 OutputCurrent IOUT[mA] 250 300 0 50 100 150 200 250 300 OutputCurrent IOUT[mA] 19 RP512x No. EA-400-190401 RP512x331x, Ta = 25°C 400 Vin=3.6V 350 Vin=4.2V Vout Frequency [kHz] 300 Vin=5.0V 250 200 150 100 50 0 0 50 100 150 200 250 300 OutputCurrent IOUT[mA] 8) Load Transient Response RP512x181x, Ta = 25°C, VIN = 3.6 V IOUT = 0.01 mA -> 100 mA 50 0 1.82 50 1.80 100 1.78 150 1.76 200 1.74 250 1.72 300 1.70 350 0 80 160 240 Time [us] 320 400 3.0 2.0 0.4 1.0 Vout 0.0 CE -1.0 Iin -2.0 0.2 0.0 -3.0 50 1.84 0 1.82 50 1.80 100 1.78 150 1.76 200 1.74 250 1.72 300 350 0.0 0.4 0.8 1.2 Time [ms] 1.6 2.0 5.0 4.0 0.6 3.0 2.0 0.4 1.0 Vout 0.0 CE -1.0 Iin -2.0 0.2 0.0 -3.0 -4.0 -0.2 -8 -4 0 20 CE/OutputVoltage VCE/ VOUT [V] 0.6 Iout VIN = 3.6 V, VCE = 0 V -> 3.6 V, ⊿t = 10 µs InputCurrent IIN [A] CE/OutputVoltage VCE/ VOUT [V] 4.0 100 1.86 1.70 9) Soft Start Time RP512x181x, Ta = 25°C VIN = VCE =0 V -> 3.6 V, ⊿t = 10 µs 5.0 1.88 4 8 12 16 20 24 28 32 Time [ms] -4.0 -0.2 -8 -4 0 4 8 12 16 20 24 28 32 Time [ms] InputCurrent IIN [A] OutputVoltage VOUT [V] 1.84 150 Vout OutputCurrent IOUT [mA] 100 Iout 1.86 1.90 OutputVoltage VOUT [V] Vout 1.88 IOUT = 100 mA -> 0.01 mA 150 OutputCurrent IOUT [mA] 1.90 POWER DISSIPATION WLCSP-8-P1 Ver. B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-9. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 101.5 mm x 114.5 mm x 1.6 mm Copper Ratio Outer Layers (First and Fourth Layers): 60% Inner Layers (Second and Third Layers): 100% Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 1140 mW Thermal Resistance (θja) θja = 87°C/W θja: Junction-to-Ambient Thermal Resistance 1500 114.5 1140 1000 750 101.5 Power Dissipation (mW) 1250 500 250 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS WLCSP-8-P1 Ver. A WLCSP-8-P1 Package Dimensions (Unit: mm) i DFN(PL)2527-10 POWER DISSIPATION Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes  0.3 mm × 30 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 2500 mW Thermal Resistance (ja) ja = 39°C/W Thermal Characterization Parameter (ψjt) ψjt = 11°C/W ja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 3000 2500 Power Dissipation (mW) 2500 2000 1500 1000 500 0 0 25 50 75 85 100 Ambient Temperature (°C) 125 Power Dissipation vs. Ambient Temperature Measurement Board Pattern i DFN(PL)2527-10 PACKAGE DIMENSIONS Ver. A 0.20±0.1 2.70 B A 6 0.05 M AB 10 0.25±0.1 X4 0.05 0.25±0.1 1.5±0.1 2.50 2.3±0.1 φ 0.5±0.05 S 0.05 S 5 0.30±0.1 0.50 1 0.10nom. 0.05min. 0.6max. INDEX DFN(PL)2527-10 Package Dimensions ∗ The tab on the bottom of the package is substrate level (GND). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. i POWER DISSIPATION SOT-89-5 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes  0.3 mm × 13 pcs (Ta = 25°C, Tjmax = 125°C) Measurement Result Item Measurement Result Power Dissipation 2600 mW Thermal Resistance (ja) ja = 38°C/W Thermal Characterization Parameter (ψjt) ψjt = 13°C/W ja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 3000 2600 Power Dissipation PD (mW) 2500 2000 1500 1000 500 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i SOT-89-5 PACKAGE DIMENSIONS Ver. A 4.5±0.1 1.5±0.1 0.4±0.3 2 5 4.35±0.1 φ1.0 1 4 4 2.5±0.1 1.00±0.2 5 0.4±0.1 0.3±0.2 0.42±0.1 0.1 S 3 0.4±0.1 3 2 1 0.3±0.2 1.6±0.2 S 0.42±0.1 0.42±0.1 0.47±0.1 1.5±0.1 1.5±0.1 SOT-89-5 Package Dimensions i 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP512Z181D-TR-F 价格&库存
很抱歉,暂时无法提供与“RP512Z181D-TR-F”相匹配的价格&库存,您可以联系我们找货
