ZTW1R50515
ZTW1R50515
    COSEL
    DIP6 模块
    DC DC CONVERTER +/-15V
ZTW1R50515 数据手册
Ordering information DC-DC Converters PCB Mount type ZTW1R5 ZT 1 W 2 1R5 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZTW1R50512 1.56 VOLTAGE[V] t12 or +24 CURRENT[A] 0.065 ZTW1R50515 1.50 t15 or +30 0.050 ZTW1R51212 1.56 t12 or +24 0.065 ZTW1R51215 1.50 t15 or +30 0.050 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZTW1R52412 1.56 t12 or +24 0.065 ZTW1R52415 1.50 t15 or +30 0.050 ZTW1R54812 1.56 t12 or +24 0.065 ZTW1R54815 1.50 t15 or +30 0.050 Output pins can be connected in series to make a 24V/30V output. ZTW1R50512 DC4.5 - 9 0.466typ 67typ t12 (+24) ZTW1R50515 ZTW1R51212 DC9 - 18 0.448typ 0.183typ 67typ 71typ t15 (+30) t12 (+24) ZTW1R51215 ZTW1R52412 DC18 - 36 0.176typ 0.092typ 71typ 71typ t15 (+30) t12 (+24) ZTW1R52415 ZTW1R54812 DC36 - 72 0.088typ 0.046typ 71typ 71typ t15 (+30) t12 (+24) ZTW1R54815 0.044typ 71typ t15 (+30) 0.050 75max 750max 120max 150max 180max 60max 0.065 0.050 0.065 0.050 0.065 0.050 0.065 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN60950-1 Complies with IEC60950-1 28X21X10mm (WXHXD) / 15g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-30 12 5 June 29, 2011 ZTW1R5 External view ¶Recommended size for processing PCB (TOP VIEW) Case (Metal) 28 ¶Back View Name Plate 21 10.16 (0.4) 10.16 (0.4) 0.5 6-A part 4 6-º1.6 -V +V IN 2.54 S +V COM-V Case connecting OUT pin ( ) 12.7 Case (Resin) Pin 10 Conduction Area 7.62 (0.3) 1 7.62 1.2 7.62 Specification at A part Outline 2.55 10.16 10.16 1±0.1 Weight: 15g or less Tolerance: ±0.5 Case Material (Metal): Brass Case Material (Resin): PPS Pin Material: Phosphor Bronze (t=0.3) (Solder Plate) 2.54 (0.1) 12.7 (0.5) 7.62 (0.3) Dimensions : mm [inch] Div. : 0.1inch Performance data ¡STATIC CHARACTERISTICS (ZTW1R50515) ¡RISE TIME & FALL TIME (ZTW1R50515:+15V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZTW1R50515) June 29, 2011 ZU/ZT-31 Ordering information DC-DC Converters PCB Mount type ZTW3 ZT 1 W 2 3 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZTW30512 3.12 VOLTAGE[V] t12 or +24 CURRENT[A] 0.13 ZTW30515 3.00 t15 or +30 0.10 ZTW31212 3.12 t12 or +24 0.13 ZTW31215 3.00 t15 or +30 0.10 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZTW32412 3.12 t12 or +24 0.13 ZTW32415 3.00 t15 or +30 0.10 ZTW34812 3.12 t12 or +24 0.13 ZTW34815 3.00 t15 or +30 0.10 Output pins can be connected in series to make a 24V/30V output. ZTW30512 DC4.5 - 9 0.891typ 70typ t12 (+24) ZTW30515 ZTW31212 DC9 - 18 0.351typ 74typ t12 (+24) 0.857typ 70typ t15 (+30) 0.13 0.10 0.13 60max 75max 60max 600max 750max 600max 120max 120max 120max 150max 150max 150max 150max 180max 150max 50max 60max 50max 20max (Minimum input, Io=100%) ZTW31215 0.338typ 74typ t15 (+30) 0.10 75max 750max 120max 150max 180max 60max ZTW32412 DC18 - 36 0.176typ 74typ t12 (+24) 0.169typ 74typ t15 (+30) ZTW34812 DC36 - 72 0.087typ 75typ t12 (+24) 0.13 60max 600max 120max 150max 150max 50max 0.10 75max 750max 120max 150max 180max 60max 0.13 60max 600max 120max 150max 150max 50max ZTW32415 ZTW34815 0.083typ 75typ t15 (+30) 0.10 75max 750max 120max 150max 180max 60max Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN60950-1 Complies with IEC60950-1 35.5X26X10mm (WXHXD) / 25g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-32 12 5 June 29, 2011 ZTW3 External view ¶Recommended size for processing PCB (TOP VIEW) Case (Metal) 35.5 ¶Back View 10.16 (0.4) 26 Name Plate 17.78 (0.7) 6-A part 1 -V +V IN S Case connecting pin ( 1.2 7.62 2.54 ) +V COM-V OUT 20.32 Case (Resin) 10 Conduction Area Pin 7.62 (0.3) 4 0.5 6-º1.6 7.62 Specification at A part Outline 2.5 10.16 17.78 1±0.1 Weight: 25g or less Tolerance: ±0.5 Case Material (Metal): Brass Case Material (Resin): PPS Pin Material: Phosphor Bronze (t=0.3) (Solder Plate) 2.54 (0.1) 20.32 (0.8) 7.62 (0.3) Dimensions : mm [inch] Div. : 0.1inch Performance data ¡STATIC CHARACTERISTICS (ZTW30515) ¡RISE TIME & FALL TIME (ZTW30515:+15V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZTW30515) June 29, 2011 Powered by TCPDF (www.tcpdf.org) ZU/ZT-33
ZTW1R50515 价格&库存
很抱歉,暂时无法提供与“ZTW1R50515”相匹配的价格&库存,您可以联系我们找货
ZTW1R50515
  • 1+216.611371+28.02199
  • 5+208.558745+26.98026
  • 10+205.1853810+26.54386
库存:11
