RP111N101D-TR-JE
RP111N101D-TR-JE
    NISSHINBO(日清纺)
    SC-74A
    IC REG LINEAR 1V 500MA SOT23-5
RP111N101D-TR-JE 数据手册
RP111x Series AEC-Q100 Compliant Good Transient Response Low Voltage 500 mA LDO for Automotive Applications NO.EC-241-200630 OUTLINE The RP111x is a CMOS-based LDO regulator featuring 500 mA output current. The input voltage is as low as 1.4 V and the output voltage can be set from 0.7 V. Due to a built-in 0.46  (at VOUT = 2.8 V) on-resistor, RP111x can provide a low dropout voltage. RP111x also features an excellent line transient response, ripple rejection at 75 dB, and low noise. The output voltage accuracy is as high as ±0.8% and the temperature drift coefficient of output voltage is low at ±30 ppm/°C. The accuracy of the output voltage of RP111x includes the temperature characteristics and the load transient response has been improved. The typ. and max value of under/overshoot for various output current are shown in the typical characteristics, therefore the accuracy of the output voltage estimation will be easy on the actual operating cases. In addition to a fold-back protection circuit built into conventional regulators, RP111x contains a thermal shutdown circuit and an inrush current limit circuit. SOT-23-5, SOT-89-5, and HSOP-6J packages are available. FEATURES                    Input Voltage Range (Maximum Rating)ꞏꞏꞏꞏꞏꞏꞏꞏꞏ 1.4 V to 5.25 V (6.0 V) Operating Temperature ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ −40°C to 105°C Supply Current ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 80 A Standby Current ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.1 A Dropout Voltage ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.23 V (IOUT = 500 mA、VSET = 2.5 V) Ripple Rejection ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 75 dB (f = 1 kHz) Typ. 70 dB (f = 10 kHz) Output Voltage Accuracy ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ ±0.8% (VSET ≥ 1.8 V) Output Voltage Temperature Coefficient ꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. ±30 ppm/°C (VSET ≥ 1.8 V) Feedback Voltage Accuracy ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 0.7±18 mV Feedback Voltage Temperature Coefficient ꞏꞏꞏꞏ Typ. ±100 ppm/°C Line Regulation ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.02%/V Input Transient Response ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. ±1.5 mV (VINVSET + 0.5 V⇔VSET + 1.5 V (tr = tf = 5.0 s), VIN ≥ 1.4 V, IOUT = 30 mA) Packagesꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ SOT-23-5, SOT-89-5, HSOP-6J Output Voltage Range ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 0.7 V, 1.1 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V, 2.8 V, 2.85 V, 2.9 V, 3.0 V, 3.3 V, 3.4 V Contact our sales representatives for other voltages. RP111x001B/D: 0.7 V to 3.6 V (Adjustable with external resistor) Built-in Fold-back Protection Circuit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 50 mA Thermal Shutdown Temperature ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 165°C Inrush Current Limitꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 400 mA (for 180 s after start-up) Ceramic capacitors are recommended to be used with this IC ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 1.0 F or more (Internally Fixed Output Voltage) Output Noise ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 20 x VSETVrms (BW = 10 Hz to 100 kHz, VSET ≥ 1.8 V) APPLICATIONS  Power source for accessories such as car audios, car navigation systems, and ETC systems  Power source for ECUs such as EV inverter and battery charge control unit 1 RP111x NO.EC-241-200630 BLOCK DIAGRAMS Internally Fixed Output Voltage (HSOP-6J) RP111Sxx1B VDD RP111Sxx1D VOUT VDD VOUT Vref Vref Current Limit Thermal Shutdown CE Current Limit Thermal Shutdown GND CE GND Internally Fixed Output Voltage (SOT-23-5/ SOT-89-5) RP111Nxx1B / RP111Hxx1B VDD RP111Nxx1D / RP111Hxx1D VOUT VDD VOUT VFB VFB Vref Vref Current Limit Thermal Shutdown CE Current Limit Thermal Shutdown GND CE GND Externally Adjustable Output Voltage (HSOP-6J/ SOT-23-5/ SOT-89-5) RP111S001B / RP111N001B / RP111H001B VDD RP111S001D / RP111N001D / RP111H001D VOUT VDD VOUT VFB VFB Vref Vref Current Limit Thermal Shutdown CE 2 Current Limit Thermal Shutdown GND CE GND RP111x NO.EC-241-200630 SELECTION GUIDE The set output voltage, auto-discharge function*1, and package type for the IC are user-selectable. Product Name RP111Nxx1-TR-#E RP111N001-TR-#E RP111Hxx1-T1-#E RP111H001-T1-#E RP111Sxx1-E2-#E RP111S001-E2-#E Package Quantity per Reel Pb Free Halogen Free SOT-23-5 3,000 pcs Yes Yes SOT-89-5 1,000 pcs Yes Yes HSOP-6J 1,000 pcs Yes Yes RP111x001B/D: Adjustable with external resistor xx: Specify the set output voltage (VSET) 0.7 V (07), 1.1 V (11), 1.2 V (12), 1.5 V (15), 1.8 V (18), 2.5 V (25), 2.8 V (28), 2.9 V (29), 3.0 V (30), 3.3 V (33), 3.4 V (34) 2.85 V: RP111x2815 Contact our sales representatives for other voltages. : Specify the auto-discharge function at off state (B) Active-high, without auto discharge function at off state (D) Active-high, with auto discharge function at off state #: Specify Automotive Class Code Operating Temperature Range A −40°C to 105°C J −40°C to 105°C Guaranteed Specs Temperature Range 25°C −40°C to 105°C Screening High Temperature High and Low Temperature *1 Auto-discharge function quickly lowers the output voltage to 0 V by releasing the electrical charge in the external capacitor when the chip enable signal is switched from the active mode to the standby mode. 3 RP111x NO.EC-241-200630 PIN DESCRIPTIONS SOT-23-5 5 4 SOT-89-5 5 HSOP-6J 4 6 5 4 3 1 2 3 (mark side) 1 2 3 1 2 SOT-23-5 Pin No. 1 2 3 4 5 Symbol VDD GND CE VFB VOUT Description Input Pin Ground Pin Chip Enable Pin (Active-high) Feed Back Pin Output Pin The VOUT pin should be connected to the VFB pin when using RP111x as an internal fixed output voltage type. In case of using this device as an external adjustable type, refer to Adjustable Output Voltage Type Setting for detailed information. SOT-89-5 Pin No. 1 2 3 4 5 Symbol VFB GND CE VDD VOUT Description Feed Back Pin Ground Pin Chip Enable Pin (Active-high) Input Pin Output Pin The VOUT pin should be connected to the VFB pin when using RP111x as an internal fixed output voltage type. In case of using this device as an external adjustable type, refer to Adjustable Output Voltage Type Setting for detailed information. HSOP-6J Pin No. 1 2 3 4 5 6 Symbol VOUT GND GND VFB CE GND VDD Description Output Pin Ground Pin Ground Pin (Internal fixed output voltage type: RP111Sxx1B/D) Feed Back Pin (Adjustable output voltage type: RP111S001B/D) Chip Enable Pin Ground Pin Input Pin In case of using this device as an external adjustable type, refer to Adjustable Output Voltage Type Setting for detailed information. 4 RP111x NO.EC-241-200630 ABSOLUTE MAXIMUM RATINGS Symbol *1 Item Rating Unit VIN Input Voltage −0.3 to 6.0 V VCE Input Voltage (CE Pin) −0.3 to 6.0 V VOUT Output Voltage −0.3 to VIN + 0.3 V IOUT Output Current 510 mA PD Power Dissipation*1 (JEDEC STD. 51) SOT-23-5 830 SOT-89-5 3200 HSOP-6J 3400 mW Tj Junction Temperature −40 to 150 °C Tstg Storage Temperature −55 to 150 °C Refer to PACKAGE INFORMATION for detailed information. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings are not assured. RECOMMENDED OPERATING CONDITIONS Symbol *2 Item *2 VIN Input Voltage Ta Operating Temperature Rating Unit 1.4 to 5.25 V −40 to 105 °C In case of exceeding the maximum Input Voltage of 5.25 V, the device must be operated on condition that the Input Voltage is up to 5.5 V and the total operating time is within 500 hrs. RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 5 RP111x NO.EC-241-200630 ELECTRICAL CHARACTERISTICS VIN = VSET + 1.0 V (VSET > 1.5 V), VIN = 2.5 V (VSET ≤ 1.5 V), IOUT = 1 mA, CIN = COUT = 1.0 F, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at 40°C ≤ Ta ≤ 105°C. RP111xxx1D/B (-AE) (Fixed Output Voltage Type) Symbol Item (Ta = 25°C) Conditions VSET < 1.8 V Output voltage VTRLD VSET < 1.8 V Output Current VOUT/IOUT Load regulation Load Transient Response −18 VSET ≥ 1.8 V x 0.985 −40C ≤ Ta ≤ 105C IOUT Typ. VSET ≥ 1.8 V x 0.992 Ta = 25C VOUT Min. −55 Max. Unit x 1.008 V 18 mV x 1.015 V 50 mV 500 mA 1 mA ≤ IOUT ≤ 500 mA 1 −75 +45 −55 +35 COUT = 1 F IOUT: 1 mA⇔250 mA (tr = tf = 0.5 s) COUT = 2.2 F IOUT: 1 mA⇔250 mA (tr = tf = 5 s) 20 mV mV −20 +15 COUT = 1 F VDIF Dropout Voltage ISS Supply Current IOUT = 0 mA 80 125 A Standby Current VCE = 0 V 0.1 7.0 A VSET + 0.5 V ≤ VIN ≤ 5.25 V, VIN ≥ 1.4 V 0.02 0.10 %/V Istandby VOUT/VIN Line regulation ISC Short Current Limit IPD CE Pull-down Current VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" TTSD TTSR RLOW Refer to the Dropout Voltage VOUT = 0 V Thermal Shutdown Junction Temperature Detection Temperature Thermal Shutdown Junction Temperature Released Temperature LOW output Nch Tr. ON Resistance VIN = 4.0 V, VCE = 0 V (RP111xxxD only) 50 0.3 mA 0.6 1.0 A V 0.4 V 165 °C 100 °C 60  All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25C) except for Load Transient Response. 6 RP111x NO.EC-241-200630 The specifications surrounded by are guaranteed by design engineering at 40°C ≤ Ta ≤ 105°C. RP111xxx1D/B (-AE) (Fixed Output Voltage Type) Dropout Voltage Output Voltage VOUT (V) (Ta = 25°C) Dropout Voltage VDIF (V) Typ. Max. 0.7 ≤ VSET < 0.8 0.58 0.88 0.8 ≤ VSET < 0.9 0.52 0.80 0.9 ≤ VSET < 1.0 0.45 0.70 1.0 ≤ VSET < 1.2 0.42 0.64 0.35 0.53 0.31 0.48 1.8 ≤ VSET < 2.1 0.27 0.44 2.1 ≤ VSET < 2.5 0.25 0.38 2.5 ≤ VSET < 3.0 0.23 0.34 3.0 ≤ VSET ≤ 3.6 0.22 0.32 1.2 ≤ VSET < 1.4 1.4 ≤ VSET < 1.8 Condition IOUT = 500 mA 7 RP111x NO.EC-241-200630 VIN = 2.5 V, IOUT = 1 mA, CIN = COUT = 1.0 F, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at 40°C ≤ Ta ≤ 105°C. RP111x001D/B (-AE) (Adjustable Output Voltage Type) Symbol Item VFB Feedback pin output voltage VOUT IOUT Conditions Ta = 25C 0.682 0.700 0.718 0.7 3.6 Output Current 500 Load Transient Response 1 mA ≤ IOUT ≤ 500 mA IOUT: 1 mA⇔250 mA (tr = tf = 0.5 s) IOUT = 500 mA ISS Supply Current IOUT = 0 mA Standby Current VOUT/VIN Line regulation ISC Short Current Limit IPD CE Pull-down Current VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" Thermal Shutdown Detection Temperature Thermal Shutdown Released Temperature COUT = 2.2 F COUT = 1 F 20 −75 +45 −55 +35 COUT = 1 F Unit V V mA 1 IOUT: 1 mA⇔250 mA (tr = tf = 5 s) VOUT = VFB TTSR Max. Adjustable Output Voltage Range Dropout Voltage TTSD Typ. 0.750 −40C ≤ Ta ≤ 105C VDIF Istandby VOUT = VFB Min. 0.645 VOUT/IOUT Load regulation VTRLD (Ta = 25°C) mV mV −20 +15 0.88 V 80 125 A VCE = 0 V 0.1 7.0 A VOUT = VFB, 1.4 V ≤ VIN ≤ 5.25 V 0.02 0.10 %/V VOUT = VFB = 0 V 50 0.3 mA 0.6 A 1.0 V 0.4 V Junction Temperature 165 °C Junction Temperature 100 °C All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25C) except for Load Transient Response. 8 RP111x NO.EC-241-200630 VIN = VSET + 1.0 V (VSET > 1.5 V), VIN = 2.5 V (VSET ≤ 1.5 V), IOUT = 1 mA, CIN = COUT = 1.0 F, unless otherwise noted. RP111xxx1D/B (-JE) (Fixed Output Voltage Type) Symbol Item Conditions Ta = 25C VOUT Output voltage −40C ≤ Ta ≤ 105C IOUT Min. Load Transient Response Typ. Max. Unit VSET ≥ 1.8 V x 0.992 x 1.008 V VSET < 1.8 V −18 18 mV VSET ≥ 1.8 V x 0.985 x 1.015 V VSET < 1.8 V −55 50 mV Output Current VOUT/IOUT Load regulation VTRLD (−40C ≤ Ta ≤ 105C) 500 mA 1 mA ≤ IOUT ≤ 500 mA IOUT: 1 mA⇔250 mA (tr = tf = 0.5 s) IOUT: 1 mA⇔250 mA (tr = tf = 5 s) 1 20 −75 +45 −55 +35 COUT = 1 F COUT = 2.2 F mV mV −20 +15 COUT = 1 F VDIF Dropout Voltage ISS Supply Current IOUT = 0 mA 80 125 A Standby Current VCE = 0 V 0.1 7.0 A VSET + 0.5 V ≤ VIN ≤ 5.25 V, VIN ≥ 1.4 V 0.02 0.10 %/V Istandby VOUT/VIN Line regulation ISC Short Current Limit IPD CE Pull-down Current VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" TTSD TTSR RLOW Refer to the Dropout Voltage VOUT = 0 V Thermal Shutdown Junction Temperature Detection Temperature Thermal Shutdown Junction Temperature Released Temperature LOW output Nch Tr. ON Resistance VIN = 4.0 V, VCE = 0 V (RP111xxxD only) 50 0.3 mA 0.6 1.0 A V 0.4 V 165 °C 100 °C 60  All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25C) except for Load Transient Response. 9 RP111x NO.EC-241-200630 RP111xxx1D/B (-JE) (Fixed Output Voltage Type) Dropout Voltage Output Voltage VOUT (V) Dropout Voltage VDIF (V) Typ. Max. 0.7 ≤ VSET < 0.8 0.58 0.88 0.8 ≤ VSET < 0.9 0.52 0.80 0.9 ≤ VSET < 1.0 0.45 0.70 1.0 ≤ VSET < 1.2 0.42 0.64 0.35 0.53 0.31 0.48 1.8 ≤ VSET < 2.1 0.27 0.44 2.1 ≤ VSET < 2.5 0.25 0.38 2.5 ≤ VSET < 3.0 0.23 0.34 3.0 ≤ VSET ≤ 3.6 0.22 0.32 1.2 ≤ VSET < 1.4 1.4 ≤ VSET < 1.8 10 (−40C ≤ Ta ≤ 105C) Condition IOUT = 500 mA RP111x NO.EC-241-200630 VIN = 2.5 V, IOUT = 1 mA, CIN = COUT = 1.0 F, unless otherwise noted. RP111x001D/B (-JE) (Adjustable Output Voltage Type) Symbol Item VFB Feedback pin output voltage VOUT IOUT Conditions Ta = 25C 0.682 0.700 0.718 0.7 3.6 Output Current 500 Load Transient Response 1 mA ≤ IOUT ≤ 500 mA IOUT: 1 mA⇔250 mA (tr = tf = 0.5 s) IOUT = 500 mA ISS Supply Current IOUT = 0 mA Standby Current VOUT/VIN Line regulation ISC Short Current Limit IPD CE Pull-down Current VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" Thermal Shutdown Detection Temperature Thermal Shutdown Released Temperature COUT = 2.2 F COUT = 1 F 20 −75 +45 −55 +35 COUT = 1 F Unit V V mA 1 IOUT: 1 mA⇔250 mA (tr = tf = 5 s) VOUT = VFB TTSR Max. Adjustable Output Voltage Range Dropout Voltage TTSD Typ. 0.750 −40C ≤ Ta ≤ 105C VDIF Istandby VOUT = VFB Min. 0.645 VOUT/IOUT Load regulation VTRLD (−40C ≤ Ta ≤ 105C) mV mV −20 +15 0.88 V 80 125 A VCE = 0 V 0.1 7.0 A VOUT = VFB, 1.4 V ≤ VIN ≤ 5.25 V 0.02 0.10 %/V VOUT = VFB = 0 V 50 0.3 mA 0.6 A 1.0 V 0.4 V Junction Temperature 165 °C Junction Temperature 100 °C All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25C) except for Load Transient Response. 11 RP111x NO.EC-241-200630 TYPICAL APPLICATIONS Internally Fixed Output Voltage RP111N/H VDD VOUT VOUT RP111N/H C1 C2 VFB 1.0 µF CE Control 1.0 µF CE GND RP111S VDD VOUT VOUT RP111S C1 C2 1.0 µF CE Control 1.0 µF CE GND Externally Adjustable Output Voltage RP111x VDD RP111x C1 C2 R2 CE 12 R1 VFB 1.0 µF CE Control VOUT VOUT GND 4.7 µF RP111x NO.EC-241-200630 TECHNICAL NOTES Phase Compensation In this device, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a 1.0 μF or more capacitor C2. In case of using a tantalum capacitor, and its ESR is large, the output may be unstable. Therefore, select C2 carefully considering its frequency characteristics. When using the Adjustable Output Voltage Type, set 4.7 μF or more of the output capacitor C2 as close as possible to the device, and make wiring as short as possible. PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0 μF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the device, and make wiring as short as possible (Refer to TYPICAL APPLICATIONS). Transient Response When using the Adjustable Output Voltage Type, the transient response could be affected by the external resistors. Evaluate the circuit taking the actual conditions of use into account. 13 RP111x NO.EC-241-200630 TYPICAL APPLICATION FOR IC CHIP BREAKDOWN PREVENTION Internally Fixed Output Voltage RP111N/H VDD VOUT VOUT RP111N/H C1 C2 VFB CE D1 GND CE Control RP111S VDD VOUT VOUT RP111S C1 C2 CE D1 GND CE Control Externally Adjustable Output Voltage RP111x VDD RP111x C1 VOUT VOUT R1 C2 VFB D1 R2 CE Control CE GND When a sudden surge of electrical current travels along the VOUT pin and GND due to a short-circuit, electrical resonance of a circuit involving an output capacitor (C2) and a short circuit inductor generates a negative voltage and may damage the device or the load devices. Connecting a schottky diode (D1) between the VOUT pin and GND has the effect of preventing damage to them. 14 RP111x NO.EC-241-200630 ADJUSTABLE OUTPUT VOLTAGE SETTING Output Voltage Setting RP111x is capable of adjusting the output voltage by using the external divider resistors. If the VFB voltage fixed in the device is described as setVFB, the output voltage can be set by using the following formulas. I1 = IIC + I2 ..................................................................................................................... (1) I2 = setVFB / R2 .............................................................................................................. (2) Thus, I1 = IIC + setVFB / R2 ...................................................................................................... (3) Therefore, VOUT = setVFB + R1 x I1 .................................................................................................. (4) Put formula (3) into formula (4), then VOUT = setVFB + R1 x (IIC + setVFB / R2) = setVFB x (1 + R1/R2) + R1 x IIC ........................................................................... (5) In formula (5), R1x IIC is the error-causing factor in VOUT. As for IIC, IIC = setVFB / RIC ............................................................................................................. (6) Therefore, the error-causing factor R1x IIC can be described as follows. R1 x IIC = R1 x setVFB / RIC = setVFB x R1 / RIC ............................................................................................ (7) For better accuracy, choosing R1 (
RP111N101D-TR-JE 价格&库存
很抱歉,暂时无法提供与“RP111N101D-TR-JE”相匹配的价格&库存,您可以联系我们找货
RP111N101D-TR-JE
  • 3000+6.842163000+0.85835
  • 6000+6.695336000+0.83993
  • 9000+6.621839000+0.83071
