S-1702RBF00-I6T1U
S-1702RBF00-I6T1U
    ABLIC(艾普凌科)
    SMD6
    IC REG CONV BATTERY 1OUT SNT6A
S-1702RBF00-I6T1U 数据手册
S-1702 Series www.ablicinc.com Rev.2.2_02 © ABLIC Inc., 2008-2015 The S-1702 Series, developed based on CMOS technology, is a 150 mA output positive voltage regulator with a low dropout voltage, a high-accuracy output voltage, and low current consumption. The S-1702 Series includes a voltage regulator with high-accuracy output voltage of 1.0% allowing to use a ceramic capacitor of 1.0 F or more, and a voltage detector that monitors the output/input voltage of the regulator. It also includes an overcurrent protection circuit that prevents the output current from exceeding the current capacitance of the output transistor and an output forcible discharge circuit for the regulator operation off. Small SNT-6A package is available for the S-1702 Series. And an external small capacitor can be used, enabling high-density mounting. Its super-low current consumption makes the S-1702 Series ideal for mobile devices. Features Regulator block Output voltage: Output voltage accuracy: Current consumption: Output current: Built-in overcurrent protection circuit: Built-in ON / OFF forcible discharge circuit: Ripple rejection: 1.5 V to 5.5 V, selectable in 0.05 V step 1.0% Current consumption of regulator block: 9 A typ., 16 A max. Possible to output 150 mA (VIN VOUT(S) 1.0 V)*1 Limits overcurrent of output transistor. 70 dB typ. (f = 1.0 kHz) Detector block Detection voltage: Built-in high-accuracy voltage detection circuit: External reset input: 1.3 V to 5.2 V, selectable in 0.05 V step 1.0% Monitoring output/input or monitoring external input by option (detector output) Forcible assertion of detector output by external reset pin (RESX) input Overall Correlation temperature gradient in the regulator and the detector blocks Current consumption: During operation*2: 10 A typ., 18 A max. Operation temperature range: Ta = 40°C to 85°C Lead-free (Sn 100%), halogen-free *1. *2. Attention should be paid to the power dissipation of the package when the output current is large. Excluding current flowing in pull-up and pull-down resistors connected to the ON / OFF or RESX pins Applications Wireless power supply circuit block for cellular phone Power supply circuit block for health care product Power supply circuit block for various mobile device Package SNT-6A 1 S-1702 Series Rev.2.2_02 Block Diagrams 1. S-1702 Series A type to H type ON / OFF VOUT ON/OFF circuit Reference voltage circuit RESX Reset circuit Logic circuit VSS VIN Reference voltage circuit Voltage detector Delay circuit Output circuit A B C D E F G H VDOUT Figure 1 2. S-1702 Series J type and K type (external input detection type) ON / OFF VOUT J ON/OFF circuit K Reference voltage circuit SENSE Reset circuit Logic circuit VSS VIN Reference voltage circuit Voltage detector Delay circuit Output circuit Figure 2 2 VDOUT VOUT VOUT VOUT VOUT VIN VIN VIN VIN Rev.2.2_02 3. S-1702 Series S-1702 Series L type to N type, P type (external delay type) ON / OFF VOUT L M N P ON/OFF circuit Reference voltage circuit CD Reset circuit VOUT VOUT VIN VIN Logic circuit VSS VIN Reference voltage circuit Voltage detector Delay circuit Output circuit VDOUT Figure 3 3 S-1702 Series Rev.2.2_02 Product Name Structure 1. Product name S-1702 x x x xx - I6T1 U Environmental code U : Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications *1 I6T1: SNT-6A, tape product Output voltage value of regulator and detection voltage value of detector *2 00 and 01 (two-digit numeric option code) Input type of RESX and ON / OFF pins*3 A to H, J (one-digit alphabetical option code) *4 Output type of VDOUT pin A to H, J (one-digit alphabetical option code) Product type*5 A to H, J to N, P (one-digit alphabetical option code) *1. *2. *3. *4. *5. 4 Refer to the tape drawing. Refer to Table 4 of “2. Function list according to product type”. Refer to Table 3 of “2. Function list according to product type”. Refer to Table 2 of “2. Function list according to product type”. Refer to Table 1 of “2. Function list according to product type”. Rev.2.2_02 2. S-1702 Series Function list according to product type Table 1 Option Code A B C D E F G H J K L M N P ON / OFF Pin Application ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF ON / OFF RESX RESX RESX RESX RESX RESX RESX RESX SENSE SENSE CD CD CD CD Table 2 Option Code A B C D E F G H J RESX Pin Application Product Types Delay Type Internal Internal Internal Internal Internal Internal Internal Internal Internal Internal External External External External Detector Monitor Voltage VOUT VOUT VOUT VOUT VIN VIN VIN VIN VSENSE VSENSE VOUT VOUT VIN VIN Discharge Shunt Function Control by Control by ON / OFF Pin RESX Pin – – – – – – Output Types of VDOUT Pin Output Type Nch open drain output CMOS output (VOUT drive) CMOS output (VIN drive) Nch open drain output CMOS output (VOUT drive) CMOS output (VIN drive) Nch open drain output CMOS output (VOUT drive) CMOS output (VIN drive) Hysteresis 5.0% 5.0% 5.0% 2.5% 2.5% 2.5% None None None 5 S-1702 Series Rev.2.2_02 Table 3 Option Code A B C D E F G H J Table 4 RESX Pin No pull-up/pull-down resistor No pull-up/pull-down resistor No pull-up/pull-down resistor Pull-up Pull-up Pull-up Pull-down Pull-down Pull-down Remark Output Voltage 3.1 V 1.0% 3.1 V 1.0% No pull-up/pull-down resistor Pull-up Pull-down No pull-up/pull-down resistor Pull-up Pull-down No pull-up/pull-down resistor Pull-up Pull-down Detection Voltage 2.75 V 1.0% 2.60 V 1.0% Please contact our sales office for products with an output voltage or detection voltage other than those specified above. Package Package Name SNT-6A 6 ON / OFF Pin Output Voltage Values of Regulator and Detection Voltage Values of Detector Option Code 00 01 3. Input Types of RESX and ON / OFF Pins Package PG006-A-P-SD Drawing Code Tape Reel PG006-A-C-SD PG006-A-R-SD Land PG006-A-L-SD Rev.2.2_02 S-1702 Series Pin Configuration 1. SNT-6A Table 5 Top view 1 2 3 6 5 4 Pin No. 1 2 Symbol VIN ON / OFF RESX Figure 4 3 CD SENSE 4 5 6 VSS VDOUT VOUT Description Input voltage pin ON / OFF pin External reset pin (S-1702Axx to Hxx) External delay capacitor connection pin (S-1702Lxx to Nxx, Pxx) Detector SENSE pin (S-1702Jxx, Kxx) GND pin Detector output voltage pin Regulator output voltage pin 7 S-1702 Series Rev.2.2_02 Absolute Maximum Ratings Table 6 Item (Ta = 25°C unless otherwise specified) Absolute Maximum Rating Unit VSS 0.3 to VSS 7.0 V VSS 0.3 to VIN 0.3 V VSS 0.3 to VIN 0.3 V VSS 0.3 to VIN 0.3 V VSS 0.3 to VSS 7.0 V VSS 0.3 to VIN 0.3 V VSS 0.3 to VSS 7.0 V VSS 0.3 to VIN 0.3 V 400*1 mW 40 to 85 °C 40 to 125 °C Symbol VIN VON / OFF VRESX VCD VSENSE VOUT Input voltage Regulator output voltage Nch open drain output Detector output VDOUT voltage CMOS output Power dissipation PD Operation ambient temperature Topr Storage temperature T stg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm 76.2 mm t1.6 mm (2) Board name : JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 500 400 300 200 100 0 0 50 100 150 Ambient temperature (Ta) [°C] Figure 5 8 Power Dissipation of Package Rev.2.2_02 S-1702 Series Electrical Characteristics 1. Common to series (S-1702Axx to Hxx, Jxx to Nxx, Pxx) Table 7 (1 / 2) Entire circuit Item Symbol Current consumption during operation*1 ISS (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit Condition VIN = VOUT(S) 1.0 V – 10 18 Min. Typ. Max. A 2 Regulator block Item Symbol Condition Output voltage *2 VOUT(E) VIN = VOUT(S) Output current *3 IOUT VIN > VOUT(S) Dropout voltage *4 Vdrop 1.0 V, IOUT = 30 mA 1.0 V 1.5 V < VOUT(S) 2.0 V < VOUT(S) IOUT = 100 mA 2.5 V < VOUT(S) 3.0 V < VOUT(S) 3.3 V < VOUT(S) 2.0 V 2.5 V 3.0 V 3.3 V 5.5 V VOUT(S) 0.5 V < VIN < 6.5 V, IOUT = 30 mA Line regulation VOUT(S) VOUT(S) 0.99 150*8 – – 0.54 – 0.23 – 0.2 – 0.15 – 0.14 Unit Test Circuit VOUT(S) 1.01 – 0.58 0.35 0.3 0.23 0.21 V 1 mA V V V V V 3 1 1 1 1 1 – 0.05 0.2 %/V 1 – 20 40 mV 1 – 100 300 ppm/ °C 1 – 9 16 2 – 6.5 V – VIN VIN = VOUT(S) 1.0 V, 10 A < IOUT < 100 mA VIN = VOUT(S) 1.0 V, IOUT = 30 mA, 40°C Ta 85°C*9 VIN = VOUT(S) 1.0 V, RESX and ON / OFF pins enabled for operation, no load – VSH1 VIN = VOUT(S) 1.0 V, RL = 1.0 k 1.2 – – V 4 VSL1 VIN = VOUT(S) 1.0 V, RL = 1.0 k – – 0.3 V 4 ON / OFF pin input current “H” ISH1 VIN = 6.5 V, VON / OFF = 6.5 V ON / OFF pin input current “L” ISL1 VIN = 6.5 V, VON / OFF = 0 V 0.1 0.1 0.1 0.1 0.1 0.1 – – – – – – 0.1 0.1 0.1 0.1 0.1 0.1 – 70 – – Load regulation Output voltage temperature coefficient *5 Current consumption during operation*1 Input voltage ON / OFF pin input voltage “H” ON / OFF pin input voltage “L” Ripple rejection Short-circuit current VOUT2 ISS1 RR ISHORT S-1702xxA S-1702xxD S-1702xxG S-1702xxA S-1702xxD S-1702xxG VIN = VOUT(S) 1.0 V, 1.5 V VOUT(S) < 3.1 V f = 1.0 kHz, Vrip = 0.5 Vrms, 3.1 V VOUT(S) 5.5 V IOUT = 30 mA VIN = VOUT(S) 1.0 V, ON / OFF pin enabled for operation, VOUT = 0 V A 2 A A A A A A 4 4 4 4 4 4 – dB 5 65 – dB 5 300 – mA 5 9 S-1702 Series Rev.2.2_02 Table 7 (2 / 2) Detector block (Ta = 25°C unless otherwise specified) Item Symbol Detection voltage*6 Condition VDET Min. VDET(S) 0.99 VDET 0.035 VDET 0.01 – S-1702xAx, S-1702xBx, S-1702xCx Hysteresis width VHYS S-1702xDx, S-1702xEx, S-1702xFx Input voltage Detection voltage temperature *7 coefficient 1.3 V 2.3 V VIN VIN = VDET(S) VIN = 5.5 V VIN = VDET(S) VDET(S) < 5.2 V VIN = 5.5 V – VDET(S) < 2.3 V Ta = 40°C to 85°C 1.5 V 1.5 V Max. – 0 – – – – 0.8 2.4 2.6 2.2 2.3 – VDET(S) 1.01 VDET 0.065 VDET 0.04 VDET 0.015 4.0 4.5 3.5 4.0 6.5 – 100 400 S-1702xGx, S-1702xHx, S-1702xJx Current consumption ISS2 *1 during operation Typ. *9 VDET(S) VDET 0.05 VDET 0.025 *1. Excluding current flowing in pull-up and pull-down resistors connected to the ON / OFF or RESX pins *2. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) Unit Test Circuit V 6 V 6 V 6 V 6 A A A A V 2 2 2 2 – ppm/ °C 6 1.0 V *3. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *4. Vdrop = VIN1 (VOUT3 0.98) VOUT3 is the output voltage when VIN = VOUT(S) 1.0 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *5. A change in the temperature of the regulator output voltage [mV/°C] is calculated using the following equation. VOUT Ta *1. *2. *3. *6. *7. [mV/°C]*1 = VOUT(S) [V]*2 VOUT [ppm/°C]*3 ÷ 1000 Ta VOUT Change in temperature of output voltage Set output voltage Output voltage temperature coefficient VDET(S) : Set detection voltage VDET : Actual detection voltage A change in the temperature of the detector detection voltage [mV/°C] is calculated using the following equation. VDET Ta *1. *2. *3. [mV/°C]*1 = VDET(S) (Typ.) [V]*2 VDET Ta VDET [ppm/°C]*3 ÷ 1000 Change in temperature of detection voltage Set detection voltage Detection voltage temperature coefficient *8. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. *9. Since products are not screened at high and low temperatures, the specification for this temperature range is guaranteed by design, not tested in production. 10 Rev.2.2_02 S-1702 Series Table 8 Item Symbol “L” output, Nch on resistor 3. RLOW Condition VDS = 0.5 V, VGS = 6.5 V (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit – 100 – 3 Detector output circuit (VDOUT pin) Table 9 Nch open drain output (S-1702xAx, xDx, xGx) Item Symbol Condition Output transistor: Nch, VDS = 0.5 V, VDD = 1.2 V Output transistor: Nch, Leakage current I LEAK VDS = 5.5 V, VDD = 5.5 V CMOS output (S-1702xBx, xCx, xEx, xFx, xHx, xJx) Output current IDOUT1 Item Symbol IDOUT2 Output current IDOUT3 4. Condition Output transistor: Nch, VDS = 0.5 V, VIN = 1.2 V Output transistor: Pch, VDS = 0.5 V, VIN = 5.5 V (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 1.36 2.55 – mA 7 – – 100 nA 7 Min. Typ. Max. Unit Test Circuit 1.36 2.55 – mA 7 1.71 2.76 – mA 8 RESX pin (S-1702Axx, Bxx, Cxx, Dxx, Exx, Fxx, Gxx, Hxx) Table 10 Item RESX pin input voltage “H” RESX pin input voltage “L” Symbol *1 VSH2 VSL2 RESX pin input current “H” ISH2 RESX pin input current “L” I SL2 *1. Condition VIN = VOUT(S) VIN = VOUT(S) 1.0 V, RL = 1.0 k 1.0 V, RL = 1.0 k S-1702xxA VIN = 6.5 V, VRESX = 6.5 V S-1702xxB S-1702xxC S-1702xxA VIN = 6.5 V, VRESX = 0 V S-1702xxB S-1702xxC (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 1.2 – – V 4 – – 0.3 V 4 0.1 – 0.1 A 4 0.1 – 0.1 A 4 0.1 – 0.1 A 4 0.1 – 0.1 A 4 0.1 – 0.1 A 4 0.1 – 0.1 A 4 VOUT(S): set output voltage value Table 11 Item Pull-up / pull-down resistor Symbol RPULL Condition – (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit – 2.0 – M 4 11 S-1702 Series 6. Rev.2.2_02 Response time Table 12 Internal delay type (S-1702Axx, Bxx, Cxx, Dxx, Exx, Fxx, Gxx, Hxx, Jxx, Kxx) (Ta = 25°C unless otherwise specified) Item Response time Symbol TPLH1 Condition Min. Typ. Max. – – – 90 Condition Min. Typ. Max. – 30 – Unit s Test Circuit 6 External delay type (S-1702Lxx, Mxx, Nxx, Pxx) Item Response time 12 Symbol TPLH2 CD = 4.7 nF Test Circuit ms 9 Unit Rev.2.2_02 S-1702 Series Test Circuits 1. 2. The portion enclosed by dotted lines is not required for CMOS output products. The portion enclosed by dotted lines is not required for CMOS output products. Figure 6 Figure 7 3. 4. The portion enclosed by dotted lines is not required for CMOS output products. The portion enclosed by dotted lines is not required for CMOS output products. Figure 8 Figure 9 5. 6. The portion enclosed by dotted lines is not required for CMOS output products. The portion enclosed by dotted lines is not required for CMOS output products. Figure 10 7. Figure 11 8. Figure 12 Figure 13 9. The portion enclosed by dotted lines is not required for CMOS output products. Figure 14 13 S-1702 Series Rev.2.2_02 Standard Circuits 1. S-1702Axx, Bxx, Cxx, Dxx, Exx, Fxx, Gxx, Hxx Input R*3 VR output VD output CIN *1 CL *2 GND Single GND *1. *2. *3. CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 F or more can be used for CL. R is not required for a CMOS output product. Figure 15 2. S-1702Jxx, Kxx Input R*3 VR output VD output CIN *2 CL *1 GND Single GND *1. *2. *3. CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 F or more can be used for CL. R is not required for a CMOS output product. Figure 16 3. S-1702Lxx, Mxx, Nxx, Pxx Input R*3 VR output VD output *1 CIN CL *2 Single GND *1. *2. *3. GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 F or more can be used for CL. R is not required for a CMOS output product. Figure 17 Caution The above connection diagrams and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 14 Rev.2.2_02 S-1702 Series Condition of Application Input capacitor (CIN): 1.0 F or more Output capacitor (CL): 1.0 F or more ESR of output capacitor: 10 Caution or less Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used. Selection of VIN Input and VOUT Output Capacitors (CIN, CL) The S-1702 Series requires an output capacitor (CL) between the VOUT and VSS pins for phase compensation. A ceramic capacitor with a capacitance of 1.0 F or more provides a stable operation in all temperature ranges. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, a capacitance must be 1.0 F or more, and the ESR must be 10 or less. The output overshoot and undershoot values, which are transient response characteristics, vary depending on the output capacitor value. The required capacitance value for the input capacitor differs depending on the application. The recommended application values are C IN 1.0 F and CL 1.0 F; however, perform thorough evaluation using the actual device, including evaluation of temperature characteristics. 15 S-1702 Series Rev.2.2_02 Explanation of Terms 1. Regulator block 1. 1 Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 1. 2 Low ESR A capacitor whose ESR (Equivalent Series Resistance) is low. The S-1702 Series enables use of a low ESR capacitor, such as a ceramic capacitor, for the output-side capacitor (CL). A capacitor whose ESR is 10 or less can be used. 1. 3 Output voltage (VOUT) The accuracy of the output voltage is ensured at 1.0% under the specified conditions of fixed input voltage *1, fixed output current, and fixed temperature. *1. Differs depending on the product. Caution If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data)” for details. 1. 4 Line regulation VOUT 1 VIN VOUT Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 1. 5 Load regulation ( VOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 1. 6 Dropout voltage (Vdrop) Indicates the difference between input voltage (V IN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (V OUT3), which is at VIN = VOUT(S) 1.0 V. Vdrop = VIN1 16 (VOUT3 0.98) Rev.2.2_02 1. 7 S-1702 Series Output voltage temperature coefficient VOUT Ta VOUT The shaded area in Figure 18 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is 100 ppm/°C change of the output voltage [mV/°C]). (Refer to *5 of Table 7 for how to calculate the temperature Example of VOUT = 3.0 V typ. product VOUT [V] 0.30 mV/ C *1 VOUT(E) 0.30 mV/ C 40 *1. 25 85 Ta [ C] VOUT(E) is the value of the output voltage measured at Ta = 25 C. Figure 18 17 S-1702 Series 2. Rev.2.2_02 Detector block 2. 1 Detection voltage ( VDET) The detection voltage ( VDET) is a voltage when the detector output voltage (VDOUT) switches to low. This detection voltage varies slightly depending on products even having the same specification. The range between the minimum ( VDET) value and the maximum ( VDET) value due to variation is called the range of detection voltage (refer to Figure 19). e.g. In a product with VDET = 3.0 V, the detection voltage is a value in the range of 2.97 V ( VDET) 3.03 V. This means that some products have 2.97 V for VDET and some have 3.03 V. VOUT Detection voltage ( VDET) max. Range of detection voltage ( VDET) min. VDOUT Remark This is the case when the regulator output voltage (VOUT) is monitored by the detector. Figure 19 2. 2 Detection Voltage ( VDET) Release voltage ( VDET) The release voltage ( VDET) is a voltage when the detector output voltage (VDOUT) switches to high. This release voltage varies slightly depending on products even having the same specification. The range between the minimum ( VDET) value and the maximum ( VDET) value due to variation is called the range of release voltage (refer to Figure 20). e.g. In a product with VDET = 3.0 V and hysteresis width of 5%, the release voltage is a value in the range of 3.074 V ( VDET) 3.227 V. This means that some products have 3.074 V for VDET and some have 3.227 V. VOUT Release voltage ( VDET) max. ( VDET) min. Range of release voltage VDOUT Delay time Remark This is the case when the regulator output voltage (V OUT) is monitored by the detector. Figure 20 18 Release Voltage ( VDET) Rev.2.2_02 2. 3 S-1702 Series Hysteresis width (VHYS) The hysteresis width is the difference between the detection voltage and the release voltage. Setting the hysteresis width prevents malfunction caused by noise on the input voltage. The hysteresis width is internally fixed and varies depending on the product type for details, refer to “Table 2 Output Types of VDOUT Pin”. 2. 4 Delay time (tD) The delay time (tD) is a period from the input voltage flowing to the detector block has exceeded the release voltage ( VDET), until the detector output voltage (VDOUT) inverts. The internal delay type products (S-1702Axx, Bxx, Cxx, Dxx, Exx, Fxx, Gxx, Hxx, Jxx, Kxx) have delay time which is internally fixed. In external delay type products (S-1702Lxx, Mxx, Nxx, Pxx), the delay time (t D) can be changed by controlling the capacitance value of the capacitor (CD) connected between the CD (RESX) and VSS pins. For how to set the delay time (t D), refer to “3. 2 Delay circuit” in “3. Detector block” in “ Operation”. V VOUT When tD = 30 ms VDET When tD = 90 s VDOUT t tD tD Remark This is the case when the regulator output voltage (VOUT) is monitored by the detector. Figure 21 2. 5 Through-type current This is the current that flows instantaneously when the voltage detector detects and releases a voltage. A large through-type current flows in CMOS output products (S-1702xBx, xCx, xEx, xFx, xHx, xJx). A small through-type current flows in Nch open drain products (S-1702xAx, xDx, xGx). 19 S-1702 Series 2. 6 Rev.2.2_02 Oscillation In applications where a resistor is connected to the input side (Figure 22), the through-type current which is generated when the detector output voltage (V DOUT) goes from low to high (release) causes a voltage drop equal to Through-type current Input resistance across the resistor. When the input voltage drops below the detection voltage as a result, the detector output voltage (VDOUT) goes from high to low. In this state, the through-type current stops, its resultant voltage drop disappears, and the detector output voltage (V DOUT) goes from low to high. The through-type current is then generated again, a voltage drop appears, and repeating the process finally induces oscillation. VIN Ra S-1702 VD block VIN VDOUT Rb VSS Figure 22 Example of Bad Implementation of Detection Voltage Changer 2. 7 Detection voltage temperature characteristics The shaded area in Figure 23 is the range where VDET varies within the operation temperature range when the detection voltage temperature coefficient is 100 ppm/ C (Refer to *7 of Table 7 for how to calculate the temperature change of the detection voltage [mV/°C]). Example of VDET = 3.0 V typ. product VDET [V] 0.30 mV/°C 3.000 0.30 mV/°C 40 25 85 Ta [°C] Figure 23 2. 8 Release voltage temperature characteristics The temperature change VDET of the release voltage is calculated by the temperature change Ta VDET Ta of the detection voltage as follows: VDET Ta VDET VDET VDET Ta The temperature changes of the release voltage and the detection voltage consequently have the same sign. 2. 9 Hysteresis voltage temperature characteristics The temperature change of the hysteresis voltage is expressed as V DET Ta 20 V DET Ta V HYS V DET V DET Ta V DET Ta V DET and is calculated as follows: Ta Rev.2.2_02 S-1702 Series Operation 1. Control of S-1702 Series by using ON / OFF and RESX pins 1. 1 Starting and stopping regulator block The regulator block can be started and stopped according to the combination of the ON / OFF and RESX pins. The regulator block switches off the output transistor between the VIN pin and VOUT pin and reduces current consumption significantly. The detector block is operating during this period, so only the amount of current consumed by the detector block flows in the S-1702 Series. 1. 2 Regulator output (VOUT) control: discharge shunt function *1 The regulator output (VOUT) can be controlled by combining the ON / OFF and RESX pins. In the product types having a discharge shunt circuit *1 (Axx, Bxx, Cxx, Exx, Fxx, Gxx, Jxx, Lxx, Nxx), this circuit forcibly sets the regulator output (VOUT ) the VSS level*1. In the product types that do not have a discharge shunt circuit*1 (Dxx, Hxx, Kxx, Mxx, Pxx), the regulator output (VOUT) is set at the VSS level by a division resistor of several M between the VOUT pin and VSS pin. *1. For details of a discharge shunt circuit, refer to “2. 2. 2 Block”. 1. 3 Discharge shunt function” in “2. Regulator Detector output voltage (VDOUT) control: forcible assertion function The detector output voltage (VDOUT) is forcibly asserted to the VSS level by combining the ON / OFF and RESX pins. When the forcible assertion function is not being used, the result of detection by the detector (release status: “H”, detection status: “L”) is output from the VDOUT pin. 21 S-1702 Series 1. 4 Rev.2.2_02 Operation of each function according to ON / OFF and RESX pins The following shows the operation of each function according to the combination of the ON / OFF and RESX pin. Table 13 S-1702Axx, Exx ON / OFF Pin RESX Pin “L” “L” “H” “H” “L” “H” “L” “H” Regulator Block Stops Stops Stops Starts Regulator Output (VOUT) Forcibly discharged Forcibly discharged Forcibly discharged Set value Detector Output (VDOUT) VSS potential VSS potential VSS potential “H” or “L” Regulator Output (VOUT) Forcibly discharged Forcibly discharged Set value Set value Detector Output (VDOUT) VSS potential VSS potential VSS potential “H” or “L” Regulator Output (VOUT) Forcibly discharged Not forcibly discharged Forcibly discharged Set value Detector Output (VDOUT) VSS potential S-1702Bxx, Fxx ON / OFF Pin RESX Pin “L” “L” “H” “H” “L” “H” “L” “H” Regulator Block Stops Stops Starts Starts S-1702Cxx, Gxx ON / OFF Pin RESX Pin Regulator Block “L” “L” Stops “L” “H” Stops “H” “H” “L” “H” Stops Starts “H” or “L” VSS potential “H” or “L” S-1702Dxx, Hxx ON / OFF Pin RESX Pin Regulator Block “L” “L” Stops “L” “H” Stops Regulator Output (VOUT) Not forcibly discharged Not forcibly discharged Detector Output (VDOUT) VSS potential “H” or “L” “H” “L” Starts Set value VSS potential “H” “H” Starts Set value “H” or “L” Regulator Output (VOUT ) Forcibly discharged Set value Detector Output (VDOUT) VSS potential “H” or “L” S-1702Jxx, Lxx, Nxx ON / OFF Pin “L” “H” Regulator Block Stops Starts S-1702Kxx, Mxx, Pxx ON / OFF Pin 22 Regulator Block “L” Stops “H” Starts Regulator Output (VOUT) Not forcibly discharged Set value Detector Output (VDOUT) “H” or “L” “H” or “L” Rev.2.2_02 1. 5 S-1702 Series Equivalent circuits of ON / OFF and RESX pins The ON / OFF and RESX pins are internally fixed to any one of three states; pulled-up (via a pull-up resistor), pulled-down (via a pull-down resistor), or neither pulled-up nor pulled-down (no down pull-up / pull-down resistor). For details, refer to “Table 3 Input Types of RESX and ON / OFF Pins”. The equivalent circuits are shown below. VIN VIN VIN ON / OFF or RESX VIN ON / OFF or RESX VSS VSS With pull-up resistor Figure 24 Caution VIN VIN VIN VSS VSS ON / OFF or RESX VSS VSS VSS With pull-down resistor Without pull-up / pull-down resistor Equivalent Circuits of ON / OFF and RESX Pins In product without pull-up / pull-down resistor, do not use the ON / OFF and RESX pins in a floating status. Note that applying voltage of 0.3 V to 1.2 V may increase current consumption. 23 S-1702 Series 2. Rev.2.2_02 Regulator block 2. 1 Basic operation Figure 25 shows a block diagram of the regulator block. The error amplifier compares the reference voltage (V ref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. The regulator output voltage (VOUT) of the S-1702 Series can be selected from a value between 1.5 V and 5.5 V. Output circuit VIN VIN Output transistor *1 Current supply Error amplifier VOUT VOUT Vref Rf Discharge shunt circuit Vfb Rs VSS VSS *1. Parasitic diode Figure 25 2. 2 Output circuit The output circuit of the regulator block consists of an output transistor and a discharge shunt circuit. The discharge shunt function is enabled or disabled for the VOUT pin. Refer to “Table 1 Product Types” for details. The equivalent circuits are shown below. VIN VIN *1 *1 VOUT VOUT Vfb Rf Rf Vfb Rs Rs VSS VSS VSS Discharge shunt function: enabled VSS VSS VSS VSS Discharge shunt function: disabled *1. Parasitic diode Figure 26 Equivalent Circuits of VOUT Pin 24 VOUT VOUT Rev.2.2_02 2. 2. 1 S-1702 Series Output transistor The S-1702 Series regulator block uses a low on-resistance Pch MOS FET transistor as the output transistor. Caution Be sure that VOUT does not exceed VIN 0.3 V to prevent the voltage regulator from being damaged due to inverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 2. 2. 2 Discharge shunt function The discharge shunt function is enabled in the S-1702Axx, Bxx, Cxx, Exx, Fxx, Gxx, Jxx, Lxx, and Nxx. When the regulator block is stopped, the output transistor is turned off and the discharge shunt circuit is turned on according to the combination of the ON / OFF and the RESX pins. This operation causes the charge in the output capacitor (CL) to be discharged, and forcibly sets the VOUT pin the VSS level. The VOUT pin is set at the VSS level in a shorter time than the S-1702Dxx, Hxx, Kxx, Mxx, and Pxx, because they disable the discharge shunt function. S-1702 Series Output transistor: OFF *1 VIN VOUT VIN Vref VOUT Current flow Rf Reference voltage circuit ON / OFF Vfb Rs ON ON / OFF circuit Logic circuit RESX CL *1 Output capacitor Reset circuit VSS GND *1. Parasitic diode Figure 27 Discharge Shunt Function 25 S-1702 Series 3. Rev.2.2_02 Detector block 3. 1 Basic operation Figure 28 shows a block diagram of the detector block. SENSE VIN VSENSE VIN Current supply Ra Vref Delay circuit VDOUT Output circuit VDOUT Rb N1 Rc CD VSS CD VSS VSS Figure 28 (1) (2) (3) When the SENSE voltage (VSENSE) is the release voltage ( VDET) or more, the VDOUT pin outputs “H”. ((1) in Figure 29) In this case, the transistor (N1) is off and the input voltage to the comparator is (Rb Rc) VSENSE . Ra Rb Rc Although the SENSE voltage (VSENSE) drops to the release voltage ( VDET) or less, the VDOUT pin outputs “H” when the SENSE voltage (VSENSE) is the detection voltage ( VDET) or more. If the SENSE voltage (VSENSE) is the detection voltage ( VDET) or less (refer to point A in Figure 29), the VDOUT pin outputs “L” ((2) in Figure 29). The transistor (N1) is turned on and the input voltage to the comparator is Rb VSENSE . Ra Rb If the VIN input voltage (VIN) further drops to the lowest operating voltage of the S-1702 Series, the VDOUT pin is sets in high impedance. If the VDOUT pin is pulled up to the regulator output voltage (V OUT), the VDOUT pin outputs VOUT (“H”) ((3) in Figure 29). (4) If the VIN input voltage (VIN) rises to the lowest operating voltage or more, the VDOUT pin outputs “L”. Although the SENSE voltage (VSENSE ) excceds the detection voltage ( VDET), it is the release voltage ( VDET) or less, the VDOUT pin outputs “L” ((4) in Figure 29). (5) If the SENSE voltage (VSENSE) rises to the release voltage ( VDET) or more (see point B in Figure 29), the VDOUT pin outputs “H”. The VDOUT pin outputs “H” after it is delayed for tD by the delay circuit ((5) in Figure 29). In the S-1702 Series, the detection voltage (VDOUT) can be set within the range of 1.3 V to 5.2 V (operating voltage range: VIN = 0.8 V to 6.5 V). 26 Rev.2.2_02 S-1702 Series (2) (1) (3) (4) (5) VDD B Hysteresis width (VHYS) Release voltage ( VDET) A Detection voltage (–V DET) *1 VSENSE (VIN) Lowest operating voltage VSS VDOUT VSS *1. tD When the SENSE pin is connected to the VIN pin. Figure 29 3. 1. 1 Operation Regulator output voltage (VOUT) detection types (S-1702Axx, Bxx, Cxx, Dxx, Lxx, Mxx) Each detector block of S-1702Axx, Bxx, Cxx, Dxx, Lxx, and Mxx detects the regulator output voltage (V OUT). VOUT VIN VIN Current supply Ra Vref Delay circuit VDOUT Output circuit VDOUT Rb N1 Rc CD *1 VSS CD VSS VSS *1. S-1702Lxx and S-1702Mxx only Figure 30 Block Diagram (Regulator Output Voltage (VOUT) Detection Type) Caution If the input voltage or load current changes transiently, undershoot or overshoot occurs in the regulator output voltage (VOUT). In the product types that the regulator output voltage is detected by the detector, if the output voltage reaches the detection voltage or less due to undershoot, the detector operates so that a reset signal may be output. To prevent this, set the value of the capacitor so that the value of undershoot is the minimum, or set the voltage range in which the difference of the output voltage and the detection voltage is undershoot or more. 27 S-1702 Series 3. 1. 2 Rev.2.2_02 Input voltage (VIN) detection types (S-1702Exx, Fxx, Gxx, Hxx, Nxx, Pxx) Each detector block of S-1702Exx, Fxx, Gxx, Hxx, Nxx, and Pxx detects the input voltage (VIN). VIN VIN Current supply Ra Vref Delay circuit VDOUT Output circuit VDOUT Rb N1 Rc CD *1 VSS CD VSS VSS *1. S-1702Nxx and S-1702Pxx only Figure 31 Block Diagram (Input Voltage (V IN) Detection Type) 3. 1. 3 SENSE voltage (VSENSE) detection types (S-1702Jxx, Kxx) Each detector block of S-1702Jxx and Kxx detects the SENSE voltage (VSENSE). VSENSE SENSE VIN VIN Current supply Ra Vref Delay circuit VDOUT Output circuit VDOUT Rb N1 Rc VSS VSS Figure 32 Block Diagram (SENSE Voltage (VSENSE) Detection Type) Caution Use the SENSE pin as an input pin when detecting the external power supply voltage. If applying an input voltage (VIN) while a potential is being applied to the SENSE pin, an error occurs in the release voltage of the detector. Apply a voltage to the SENSE pin after applying the input voltage (VIN). 28 Rev.2.2_02 3. 2 S-1702 Series Delay circuit 3. 2. 1 Internal delay types (S-1702Axx, Bxx, Cxx, Dxx, Exx, Fxx, Gxx, Hxx, Jxx, Kxx) In the internal delay types, when VSENSE is turned on, the delay circuit makes a certain delay, after the point when VSENSE has reached the release voltage ( VDET), and sets the VDOUT pin to output an output signal (refer to point B in Figure 29). The delay circuit does not make delay when V SENSE is the detection voltage ( VDET) or less (refer to point A in Figure 29). The delay time (tD) is fixed in the internal circuit of internal delay types. 3. 2. 2 External delay types (S-1702Lxx, Mxx, Nxx, Pxx) In the external delay types, the delay time of the detection signal can be set by connecting a capacitor (C D) between the CD and VSS pins. The delay time (tD) is determined according to the built-in constant current, approx. 100 nA (typ.), and the time constant of the external capacitor (CD), and can be calculated by the following equation. tD [ms] = Delay constant CD [nF] The delay constant (Ta = 25°C) is as follows. Delay constant: 5.3 (min.), 6.3 (typ.), 7.3 (max.) Figure 33 shows the equivalent circuit of the CD pin (external delay type). VIN VIN CD CD VSS VSS VSS Figure 33 Equivalent Circuit of CD Pin (External Delay Type) Caution 1. Design the board so that a current will not flow into or flow out from the CD (RESX) pin, because this pin’s impedance is high. (Otherwise that may provide incorrect delay time.) 2. There is no limit for the capacitance of the external capacitor (C D) as long as the leakage current of the capacitor can be ignored against the built-in constant current value. Leakage current causes deviation in delay time. When the leakage current is the built-in constant current or more, the IC does not release. 29 S-1702 Series 3. 3 Rev.2.2_02 Output Circuit Either Nch open drain output, CMOS output (VOUT drive), or CMOS output (VIN drive) is used for the VDOUT pin. For details, refer to “Table 2 Output Types of VDOUT Pin”. The equivalent circuits are shown below. VOUT VIN *1 VDOUT VDOUT *1 VDOUT VDOUT VSS VSS Nch open drain output *1. VDOUT VDOUT VSS VSS CMOS output (VOUT drive) Parasitic diode Figure 34 Equivalent Circuits of VDOUT Pin 30 VSS VSS CMOS output (VIN drive) Rev.2.2_02 4. S-1702 Series Relation of temperature coefficients of detector and regulator blocks The S-1702 Series has a detector and a regulator in it, and each reference voltage circuit has the same structure so that both temperature coefficients of detector detection voltage and regulator output interlock. 4. 1 Positive temperature coefficient of regulator output If the temperature coefficient of regulator output is positive, so is that of detector detection voltage (Figure 35). VDET [V] 40 25 85 Ta [°C] Figure 35 4. 2 Relation of Temperature Coefficients of Detector and Regulator (When They Are Positive) Negative temperature coefficient of regulator output If the temperature coefficient of regulator output is negative, so is that of detector detection voltage (Figure 36). VDET [V] 40 25 85 Ta [°C] Figure 36 Relation of Temperature Coefficients of Detector and Regulator (When They Are Negative) 31 S-1702 Series Rev.2.2_02 Precautions Wiring patterns for the VIN pin, VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (C L) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. Note that gernerally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1702 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Input capacitor (CIN): Output capacitor (CL): Equivalent series resistance (ESR): 1.0 F or more 1.0 F or more 10 or less The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. In determining the output current, attention should be paid to the output current value specified in Table 7 in “ Electrical Characteristics” and footnote *8 of the table. ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 32 Rev.2.2_02 S-1702 Series Characteristics (Typical Data) 1. Entire circuit Current consumption during operation*1 vs. Input voltage (Ta = 25°C) VOUT = 1.5 V VOUT = 3.1 V 12 12 10 10 8 8 6 6 Ta = 85”C Ta = 25”C Ta = n40”C 4 2 4 Ta = 85”C Ta = 25”C Ta = n40”C 2 0 0 0 1 2 3 4 VIN [V] 5 6 7 0 1 2 3 4 VIN [V] 5 6 7 VOUT = 5.5 V 12 10 8 6 4 Ta = 85”C Ta = 25”C Ta = n40”C 2 0 0 *1. 1 2 3 4 VIN [V] 5 6 7 Excluding current flowing in pull-up and pull-down resistors connected to the ON / OFF or RESX pins 33 S-1702 Series 2. Rev.2.2_02 Regulator block 2. 1 Output voltage vs. Output current (when load current increases) (Ta = 25°C) VOUT = 1.5 V VOUT = 3.1 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VIN = 3.4 V VIN = 4.0 V VIN = 5.0 V VIN = 6.5 V 0 50 100 150 200 250 300 350 400 450 IOUT [mA] VOUT = 5.5 V Remark In determining the output current, attention should be paid to the followings. (1) The minimum output current value and footnote *8 in Table 7 in “ Electrical Characteristics”. (2) Power dissipation of package 6 5 VIN = 5.8 V VIN = 6.0 V VIN = 6.5 V 4 3 2 1 0 2. 2 0 50 100 150 200 250 300 350 400 450 IOUT [mA] Output voltage vs. Input voltage (Ta = 25°C) VOUT = 1.5 V 1.6 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2.5 1.5 1.4 IOUT = n1 mA IOUT = n30 mA IOUT = n100 mA 1.3 1.2 1.1 1.0 1.0 1.5 2.0 2.5 VIN [V] 3.0 3.5 VOUT = 5.5 V 5.6 5.5 5.4 5.3 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 IOUT = n1 mA IOUT = n30 mA IOUT = n100 mA 4.5 34 5.0 5.5 VIN [V] VOUT = 3.1 V 6.0 6.5 IOUT = n1 mA IOUT = n30 mA IOUT = n100 mA 2.5 3.0 3.4 4.0 VIN [V] 4.5 5.0 Rev.2.2_02 2. 3 S-1702 Series Dropout voltage vs. Output current VOUT = 1.5 V VOUT = 3.1 V 0.5 0.30 0.4 0.25 0.20 0.3 0.15 0.2 Ta = 85”C Ta = 25”C Ta = n40”C 0.1 0 0 25 50 100 75 IOUT [mA] 125 0.10 Ta = 85”C Ta = 25”C Ta = n40”C 0.05 0 0 150 25 50 100 75 IOUT [mA] 125 150 VOUT = 5.5 V 0.25 0.20 0.15 0.10 Ta = 85”C Ta = 25”C Ta = n40”C 0.05 0 0 2. 4 25 50 100 75 IOUT [mA] 125 150 Output voltage vs. Ambient temperature VOUT = 1.5 V 1.50 1.45 1.40 1.35 1.30 1.25 1.20 1.15 1.10 VOUT = 3.1 V 3.30 3.25 3.20 3.15 3.10 3.05 3.00 2.95 2.90 n40 n25 0 25 Ta [”C] 50 75 85 n40 n25 0 25 Ta [”C] 50 75 85 VOUT = 5.5 V 5.70 5.65 5.60 5.55 5.50 5.45 5.40 5.35 5.30 n40 n25 0 25 Ta [”C] 50 75 85 35 S-1702 Series 2. 5 Rev.2.2_02 Current consumption during operation at regulator block*1 vs. Input voltage VOUT = 1.5 V VOUT = 3.1 V 10 10 8 8 6 6 4 4 Ta = 85”C Ta = 25”C Ta = n40”C 2 0 0 1 2 Ta = 85”C Ta = 25”C Ta = n40”C 2 0 3 4 VIN [V] 5 6 1 0 7 2 3 4 VIN [V] 5 6 7 VOUT = 5.5 V 10 8 6 4 Ta = 85”C Ta = 25”C Ta = n40”C 2 0 0 *1. 2. 6 1 2 3 4 VIN [V] 5 6 7 Excluding current flowing in pull-up and pull-down resistors connected to the ON / OFF or RESX pins Ripple rejection ratio (Ta = 25°C) VOUT = 1.5 V, VIN = 2.5 V, CL = 1.0 F VOUT = 3.1 V, VIN = 4.1 V, CL = 1.0 F 100 100 80 80 60 60 40 40 IOUT = 1 mA IOUT = 30 mA IOUT = 150 mA 20 0 10 100 1k 10k Frequency [Hz] 0 100k 1M VOUT = 5.5 V, VIN = 6.0 V, CL = 1.0 F 100 80 60 40 IOUT = 1 mA IOUT = 30 mA IOUT = 150 mA 20 0 10 36 100 1k 10k Frequency [Hz] IOUT = 1 mA IOUT = 30 mA IOUT = 150 mA 20 100k 1M 10 100 1k 10k Frequency [Hz] 100k 1M Rev.2.2_02 3. S-1702 Series Detector block 3. 1 Detection voltage vs. Ambient temperature VDET = 1.3 V 1.50 1.45 1.40 1.35 1.30 1.25 1.20 1.15 1.10 VDET = 2.75 V 3.0 2.9 VDET VDET 2.8 nVDET nVDET 2.7 2.6 2.5 2.4 n40 n25 0 25 Ta [”C] 50 75 85 n40 n25 0 25 Ta [”C] 50 75 85 VDET = 5.2 V 5.5 5.4 VDET 5.3 5.2 5.1 nVDET 5.0 n40 n25 3. 2 0 25 Ta [”C] 50 75 85 Hysteresis width vs. Ambient temperature VDET = 1.3 V VDET = 2.75 V 6 6 5 5 4 4 3 3 2 2 1 1 0 0 n40 n25 0 25 Ta [”C] 50 75 85 n40 n25 0 25 Ta [”C] 50 75 85 VDET = 5.2 V 6 5 4 3 2 1 0 n40 n25 0 25 Ta [”C] 50 75 85 37 S-1702 Series 3. 3 Rev.2.2_02 Current consumption during operation at detector block*1 vs. Input voltage VDET = 1.3 V 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VDET = 2.75 V 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 Ta = 85”C Ta = 25”C Ta = n40”C 0 1 2 5 3 4 VIN [V] 6 6.5 Ta = 85”C Ta = 25”C Ta = n40”C 0 2 1 5 3 4 VIN [V] 6 6.5 VDET = 5.2 V 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 Ta = 85”C Ta = 25”C Ta = n40”C 0 *1. 3. 4 1 2 3 4 VIN [V] 5 Excluding current flowing in pull-up and pull-down resistors connected to the ON / OFF or RESX pins Detector output voltage vs. Nch transistor characteristics (ID vs. VDS characteristics) 30 15 2 3 VDS [V] VIN = 1.5 V 0 4 5 6 0 1 2 3 VDS [V] 4 5 6 Detector output voltage vs. Input voltage CMOS output Nch open drain output 6 0.6 5 0.5 4 0.4 Ta = 85”C Ta = 25”C Ta = n40”C 3 2 0.3 Ta = 85”C Ta = 25”C Ta = n40”C 0.2 1 0.1 0 0 0 38 VIN = 2.0 V 5 VIN = 1.3 V 1 VIN = 3.0 V 10 VIN = 2.0 V 0 VIN = 4.0 V 15 VIN = 3.0 V 0 VIN = 5.0 V 20 VIN = 4.0 V 5 Detector output voltage vs. Pch transistor characteristics (ID vs. VDS characteristics) 25 20 10 3. 5 30 VIN = 5.0 V 25 3. 6 6 6.5 0.2 0.4 0.6 0.8 VIN [V] 1.0 1.2 1.4 0 0.2 0.4 0.6 0.8 VIN [V] 1.0 1.2 1.4 Rev.2.2_02 S-1702 Series Reference Data 1. Input transient response characteristics (Ta = 25°C) IOUT = 30 mA, tr = tf = 5.0 s, CL = 1.0 F, CIN = 1.0 F 3.5 V VOUT = 1.5 V, VIN = 2.5 V IOUT = 30 mA, t r = tf = 5.0 s, CL = 1.0 F, CIN = 1.0 F 5.1 V VOUT = 3.1 V, VIN = 4.1 V 1.60 1.58 1.56 1.54 1.52 1.50 1.48 1.46 1.44 3.35 3.30 3.25 3.20 3.15 3.10 3.05 3.00 2.95 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 t [™s] 2. 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 t [™s] Load transient response characteristics (Ta = 25°C) VIN = 2.5 V, CL = 1.0 F, CIN = 1.0 F VOUT = 1.5 V, IOUT = 50 mA 100 mA 1.70 1.65 1.60 1.55 1.50 1.45 1.40 1.35 VIN = 4.0 V, CL = 1.0 F, CIN = 1.0 F VOUT = 3.1 V, IOUT = 50 mA 100 mA 150 100 50 0 n50 n100 n150 n200 t [™s] 3.30 3.25 3.20 3.15 3.10 3.05 3.00 2.95 150 100 50 0 n50 n100 n150 n200 t [™s] VIN = 6.0 V, CL = 1.0 F, CIN = 1.0 F VOUT = 5.5 V, IOUT = 50 mA 100 mA 6.40 6.20 6.00 5.80 5.60 5.40 5.20 5.00 150 100 50 0 n50 n100 n150 n200 t [™s] 39 S-1702 Series 3. Rev.2.2_02 ON/OFF pin transient response characteristics (Ta = 25°C) VIN = 2.5 V, CL = 1.0 F, CIN = 1.0 F, IOUT = 100 mA VOUT = 1.5 V, VON / OFF = 0 V 2.5 V 5.0 3.0 10.0 6.0 4.0 2.0 8.0 4.0 3.0 1.0 6.0 2.0 2.0 0 4.0 0 1.0 n1.0 2.0 n2.0 0 n2.0 0 n4.0 n1.0 n3.0 n2.0 n100 0 100 200 t [™s] 300 400 500 n100 VIN = 6.0 V, CL = 1.0 F, CIN = 1.0 F, IOUT = 100 mA VOUT = 5.5 V, VON / OFF = 0 V 6.5 V 14.0 12.0 10.0 8.0 6.0 4.0 2.0 0 n2.0 n100 40 VIN = 4.0 V, CL = 1.0 F, CIN = 1.0 F, IOUT = 100 mA VOUT = 3.1 V, VON / OFF = 0 V 4.0 V 0 100 200 t [™s] 300 400 500 8.0 6.0 4.0 2.0 0 n2.0 n4.0 n6.0 n8.0 0 100 200 300 t [™s] 400 500 n6.0 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. 14. For more details on the information described herein, contact our sales office. 2.2-2018.06 www.ablic.com
S-1702RBF00-I6T1U 价格&库存
很抱歉,暂时无法提供与“S-1702RBF00-I6T1U”相匹配的价格&库存,您可以联系我们找货
