SLG5NT1594VTR
SLG5NT1594VTR
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN4
    SILEGO PMOS GREENFET3, WITHOUT D
SLG5NT1594VTR 数据手册
SLG5NT1594V Ultra-small 28.5 mΩ, 1.0 A Integrated Power Switch General Description Pin Configuration ON 1 Features VIN 2 • One 1.0 A MOSFET • Ultra Low Quiescent Current • Low RDSON • 28.5 mΩ @ 5.0 V • 36.4 mΩ @ 3.3 V • 44.3 mΩ @ 2.5 V • 60.8 mΩ @ 1.8 V • 77.6 mΩ @ 1.5 V • VIN = 1.5 V to 5.5 V • Pb-Free / Halogen-Free / RoHS compliant • STDFN 4L, 1.0 x 1.0 x 0.55 mm SLG5NT1594V The SLG5NT1594V is designed for load switching applications with ultra low quiescent current. The part comes with one 28.5 mΩ 1.0 A rated P-channel MOSFET controlled by a single ON control pin. The product is packaged in an ultra-small 1.0 x 1.0 mm package. 4 GND 3 VOUT 4-pin STDFN (Top View) Block Diagram VOUT VIN 1.0 A ON Silego Technology, Inc. 000-005NT1594-100 Fixed Slew Rate Control Rev 1.00 Revised December 29, 2016 SLG5NT1594V Pin Description Pin # Pin Name Type Pin Description 1 ON Input Turns on MOSFET. 2 VIN MOSFET 3 VOUT MOSFET 4 GND GND Power MOSFET input Power MOSFET output Ground Ordering Information Part Number Type Production Flow SLG5NT1594V STDFN 4L Industrial, -40 °C to 85 °C SLG5NT1594VTR STDFN 4L (Tape and Reel) Industrial, -40 °C to 85 °C 000-005NT1594-100 Page 2 of 10 SLG5NT1594V Absolute Maximum Ratings Parameter Description VIN Power Supply TS Storage Temperature ESDHBM WDIS ESD Protection Conditions Human Body Model Min. Typ. Max. Unit -- -- 6 V -65 -- 140 °C 2000 -- -- V -- -- 0.5 W -- -- 1.5 A Package Power Dissipation MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter VIN IDD ION_LKG RDSON RDSON IDS TON_Delay TTotal_ON Description Power Supply Voltage Power Supply Current (PIN 2) Conditions -40 °C to 85 °C Static Drain to Source ON Resistance @ TA 85°C Operating Current ON pin Delay Time Total Turn On Time 000-005NT1594-100 Typ. Max. Unit 1.5 -- 5.5 V when OFF, VIN = 5.5 V, No load -- 0.02 1 μA when ON = VIN, No load -- 0.05 0.5 μA -- -- 0.1 μA @ 5.5 V -- 28.5 32.0 mΩ @ 3.3 V -- 36.4 40.0 mΩ @ 2.5 V -- 44.3 49.0 mΩ @ 1.8 V -- 60.8 65.0 mΩ @ 1.5 V -- 77.6 82.0 mΩ @ 5.5 V -- 34.0 36.0 mΩ @ 3.3 V -- 43.8 46.0 mΩ @ 2.5 V -- 53.3 56.0 mΩ @ 1.8 V -- 72.2 76.0 mΩ @ 1.5 V -- 90.7 94.0 mΩ VIN = 1.5 V to 5.5 V -- -- 1.0 A 50% ON to Ramp Begin VIN = 5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 10 15 27 μs 50% ON to Ramp Begin VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 17 31 40 μs 50% ON to Ramp Begin VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 44 69 96 μs 50% ON to 90% VOUT VIN = 5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 114 122 134 μs 50% ON to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 146 156 176 μs 50% ON to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 292 332 399 μs ON Pin Input Leakage Static Drain to Source ON Resistance @ TA 25°C Min. Page 3 of 10 SLG5NT1594V TA = -40 °C to 85 °C (unless otherwise stated) Parameter TRISE Description Rise Time Conditions Min. Typ. Max. Unit 10% VOUT to 90% VOUT VIN = 5.0 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 92 97 107 μs 10% VOUT to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 116 120 131 μs 10% VOUT to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 228 253 296 μs ON_VIH Initial Turn On Voltage 0.85 -- VIN V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V 6.2 6.5 7.0 μs TDelay_OFF OFF Delay Time 000-005NT1594-100 50% ON to VOUT Fall, VIN = 5 V, RL =10 Ω Page 4 of 10 SLG5NT1594V VIN vs. Max IDS, Safe Operation Area Safe Operation Area VIN vs. Max IDS 8 7 6 5 VIN 4 SOA Boundary 3 2 1 0 0 0.5 1 1.5 2 Max IDS TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_DELAY 90% VOUT VOUT 90% VOUT TON_DELAY 10% VOUT 10% VOUT TRISE TFALL TTotal_ON 000-005NT1594-100 Page 5 of 10 SLG5NT1594V SLG5NT1594V Power-Up/Power-Down Sequence Considerations A nominal power-up sequence is to apply VIN and toggle the ON pin LOW-to-HIGH after VIN is at least 90% of its final value. A nominal power-down sequence is the power-up sequence in reverse order. If VIN ramp is too fast, a voltage glitch may appear on the output pin at VOUT. To prevent glitches at the output, it is recommended to connect at least 0.1uF capacitor from the VOUT pin to GND and to keep the VIN ramp time less than 2 ms. SLG5NT1594V Layout Suggestion 800 Recommended Land Pattern 210 Unit: μm 410 810 190 Exposed Pad 200 1800 000-005NT1594-100 Page 6 of 10 SLG5NT1594V Package Top Marking System Definition Pin 1 Identifier 000-005NT1594-100 XX Serial Number Page 7 of 10 SLG5NT1594V Package Drawing and Dimensions 4 Lead STDFN Package 1.0 x 1.0 mm 000-005NT1594-100 Page 8 of 10 SLG5NT1594V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 4L 1x1mm 0.4P FC Green 4 1.0 x 1.0 x 0.55 8000 8000 178 / 60 200 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 200 400 8 Part Pitch [mm] 2 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 4L 1x1mm 0.4P FC Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.16 1.16 0.63 4 2 1.5 1.75 3.5 8 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.55 mm3 (nominal). More information can be found at www.jedec.org. 000-005NT1594-100 Page 9 of 10 SLG5NT1594V Revision History Date Version 12/29/2016 1.00 000-005NT1594-100 Change Production Release Page 10 of 10
SLG5NT1594VTR 价格&库存
很抱歉,暂时无法提供与“SLG5NT1594VTR”相匹配的价格&库存,您可以联系我们找货
