BOS1901CQT
BOS1901CQT
    BOREAS
    WFQFN20
    BOS1901CQ CUT TAPE
BOS1901CQT 数据手册
Complete Product DataSheet can be downloaded from the Boréas web site using the following link: https://www.boreas.ca/products/bos1901-piezo-hapticdriver#specifications BOS1901 Product Brief Datasheet BOS1901 Piezo Haptic Driver with Digital Front End 1 Features 3 Description • The BOS1901 is a single-chip piezo actuator driver with energy recovery, based on a patented CapDrive™ technology. It can drive actuators with up to 190 Vpk-pk waveforms while operating from a 3 to 5.5 V supply voltage. The input digital stream is written in the internal FIFO over the digital interface to generate the desired output waveform. Low power and small size make it ideal for a variety of applications requiring minimal power consumption and heat dissipation. The BOS1901 uses a high-speed SPI in its digital front end. It enables the device to share a common communication bus for multi-actuator systems and allows the user to query various data such as the actuator voltage for sensing applications (e.g. piezo buttons). The differential driver achieves low distortion waveforms and quiet actuator operation. All settings are adjustable through the digital front end to reduce the BOM. Only 7 passive discrete components are required. The BOS1901 can be operated with a wide selection of COTS inductors. In systems that cannot handle reverse current flow in the power delivery network, the BOS1901 features a Unidirectional Power Input (UPI). When the UPI mode is activated, the driver behaves as a resistive load without reducing power efficiency. Typical start-up time of less than 300 µs makes the BOS1901 latency negligible in most systems. Safety systems protect the device from damage in case of a fault. • • • • • High-Voltage Low Power Piezo Driver o Drives 100 nF at 190 Vpk-pk and 300 Hz with only 350 mW o Drives Capacitive Load up to 820 nF o Energy Recovery o Differential Output o Small Solution Footprint, QFN & WLCSP o Low BOM cost Integrated Digital Front End with SPI o 64 samples Internal FIFO Interface o 1.8 V to 5.0 V Digital I/O Supply Piezo Sensing Fast Start Up Time, < 300 µs Unidirectional Power Input option Wide Supply Voltage Range, 3 to 5.5 V 2 Applications Mobile Phones and Tablets Portable Computers Keyboards and Mice Gaming Controllers Wearables Electronic Cooling CVDD 3.0 V to 5.5 V SPI CVDDIO L1 Rsense CREG CHV RM RP SW VDD VBUS HV SCLK CS SDI SDO VDDIO REG BOS1901 • • • • • • OUT+ load OUT - PUMP GND Table 1: Ordering information CPUMP PRODUCT BOS1901Q BOS1901W DESCRIPTION QFN 20L 4x4x0.8 mm 0.5P WLCSP 25L 2.1x2.2x0.6 mm 0.4P Under development Figure 1: Simplified schematic BOS1901CPB01.0 © All rights reserved 2019 Boréas Technologies Inc 1 BOS1901 Datasheet Product Brief Information relating to products and circuits furnished herein by Boréas Technologies Inc. is believed to be reliable. However, Boréas Technologies assumes no liability for errors that may appear in this document, or for liability otherwise arising from the application or use of any such information which may result from such application or use. The products, their specifications and the information appearing in the document are subject to change by Boréas Technologies without notice. Trademarks and registered trademarks are the property of their respective owners. Boréas Technologies Datasheet Status: Advance Information Datasheet: Design Data Preliminary Information Datasheet: Prototype information Datasheet without notification: Production information © 2019 Boréas Technologies Inc. BOS1901BPB01.1 © All rights reserved 2019 Boréas Technologies Inc 2
BOS1901CQT 价格&库存
很抱歉,暂时无法提供与“BOS1901CQT”相匹配的价格&库存,您可以联系我们找货
