GT105N10T
GT105N10T
    GOFORD(谷峰)
    TO-220-3
    通孔 N 通道 100 V 55A(Tc) 74W(Tc) TO-220
GT105N10T 数据手册
GT105N10T N-Channel Enhancement Mode Power MOSFET Description The GT105N10T uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) RDS(ON) (at VGS = 4.5V) 100% Avalanche Tested < < 100V 55A 10.5mΩ 15mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-220 Ordering Information Device Package Marking Packaging GT105N10T TO-220 GT105N10 50psc/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 100 V ID 55 A IDM 220 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 74 W EAS 72 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 78 ºC/W Maximum Junction-to-Case RthJC 1.6 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1542) GT105N10T Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 100 -- -- V IDSS VDS = 100V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 1.0 1.7 2.5 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 20A -- 8.5 10.5 VGS = 4.5V, ID = 20A -- 10.5 15 Forward Transconductance gFS VGS = 5V, ID = 20A -- 59 -- -- 1625 -- -- 665 -- -- 14 -- -- 54 -- -- 10 -- -- 14 -- -- 13 -- -- 10 -- -- 30 -- -- 8 -- Static Parameters mΩ S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 50V, f = 1.0MHz VDD = 50V, ID = 20A, VGS = 10V VDD = 50V, ID = 20A, RG = 1.6Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 55 A Body Diode Voltage VSD TJ = 25ºC, ISD = 20A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 95 -- nC Reverse Recovery Time Trr IF = 20A, VGS = 0V di/dt=100A/us -- 45 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1542) GT105N10T Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1542) GT105N10T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics 10V 6V ID, Drain Current (A) 100 120 5V 4.5V VDS= 5V ID, Drain Current (A) 120 Figure 2. Transfer Characteristics 4V 80 60 40 VGS= 3V 80 60 40 25℃ 20 20 0 100 0 1 2 3 0 4 0 VDS, Drain-to-Source Voltage (V) Vgs Gate-Source Voltage(V) RDS(on),On-Resistance(mΩ) 16 14 VGS= 4.5V 10 8 VGS= 10V 6 4 2 0 0 10 20 30 4 6 8 VGS, Gate-to-Source Voltage (V) Figure 3. Drain Source On Resistance 12 2 Figure 4. Gate Charge 10 8 6 4 2 0 40 ID-Drain Current(A) VDD = 50V, ID = 20A 0 10 20 30 40 50 60 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward Is, Reverse Drain Current (A) 3000 Capacitance(pF) 2500 2000 Ciss 1500 Coss 1000 500 Crss 0 0 10 20 30 40 50 60 VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1542) GT105N10T Typical Characteristics TJ = 25ºC, unless otherwise noted VGS = 10V, ID = 20A VGS = 4.5V, ID = 20A Figure 8. Safe Operation Area ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 1.6°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1542) GT105N10T TO-220 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1542)
GT105N10T 价格&库存
很抱歉,暂时无法提供与“GT105N10T”相匹配的价格&库存,您可以联系我们找货
