G230P06T
G230P06T
    GOFORD(谷峰)
    TO-220-3
    通孔 P 通道 60 V 60A(Tc) 115W(Tc) TO-220
G230P06T 数据手册
G230P06T P-Channel Enhancement Mode Power MOSFET Description The G230P06T uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l VDS ID (at VGS = -10V) RDS(ON) (at VGS = -10V) 100% Avalanche Tested -60V -60A < 20mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-220 Ordering Information Device Package Marking Packaging G230P06T TO-220 G230P06 50pcs/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS -60 V ID -60 A IDM -240 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 115 W EAS 81 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 60 ºC/W Maximum Junction-to-Case RthJC 1.09 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1725-V1.0) G230P06T Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = -250µA -60 -- -- V IDSS VDS = -60V, VGS = 0V -- -- -1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = -250µA -2 -2.6 -4 V Drain-Source On-Resistance RDS(on) VGS = -10V, ID = -10A -- 18 20 mΩ Forward Transconductance gFS VDS = -5V,ID = -10A -- 13 -- S -- 4499 -- -- 241 -- -- 230 -- -- 62 -- -- 9 -- -- 16 -- -- 20 -- -- 18 -- -- 55 -- -- 35 -- Static Parameters Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = -30V, f = 1.0MHz VDD = -30V, ID = -10A, VGS = -10V VDD = -30V, ID = -10A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- -60 A Body Diode Voltage VSD TJ = 25ºC, ISD = -10A, VGS = 0V -- -- -1.2 V Reverse Recovery Charge Qrr -- 71 -- nC Reverse Recovery Time Trr -- 49 -- ns IF = -10A, VGS = 0V di/dt=-100A/us Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1725-V1.0) G230P06T Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1725-V1.0) G230P06T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics 70 70 -ID, Drain Current (A) -6V -10V 60 -ID, Drain Current (A) Figure 2. Transfer Characteristics -5.5V 50 40 -5V 30 20 -4.5V 50 40 25℃ 30 20 10 10 0 VDS= -5V 60 VGS= -4V 0 1 2 0 3 4 0 -VDS, Drain-to-Source Voltage (V) -Vgs Gate-Source Voltage(V) RDS(on), On-Resistance (mΩ) 35 30 VGS= -10V 15 10 5 0 0 5 10 15 6 8 10 Figure 4. Gate Charge 40 20 4 -VGS, Gate-to-Source Voltage (V) Figure 3.Drain Source On Resistance 25 2 10 8 6 4 2 0 20 -ID-Drain Current (A) VDD = -30V, ID = -10A 0 20 40 60 80 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward Ciss 5000 Capacitance(pF) -Is, Reverse Drain Current (A) 6000 4000 3000 2000 1000 0 Coss Crss 0 10 20 30 40 50 60 -VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 -VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1725-V1.0) G230P06T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 10. Safe Operation Area VGS = -10V, ID = -10A -ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance ZthJC, Thermal Impedance (ºC/W) TJ, Junction Temperature (ºC) -VDS, Drain-Source Voltage(V) Figure 9. Normalized Maximum Transient Thermal Impedance Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1725-V1.0) G230P06T TO-220 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1725-V1.0)
G230P06T 价格&库存
很抱歉,暂时无法提供与“G230P06T”相匹配的价格&库存,您可以联系我们找货
G230P06T
  • 1+15.893891+2.05446
  • 50+7.5613950+0.97739
  • 100+6.74749100+0.87219
  • 500+5.31783500+0.68739
  • 1000+4.857751000+0.62792
  • 2000+4.470822000+0.57790
  • 5000+4.052175000+0.52379
  • 10000+3.7935510000+0.49036
库存:53
G230P06T
  • 1+3.45600
  • 10+2.71080
  • 50+2.30040
  • 100+1.90080
  • 500+1.72800
  • 1000+1.62000
库存:9
