G75P04T
P-Channel Enhancement Mode Power MOSFET
Description
The G75P04T uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-40V
-80A
< 7mΩ
< 9mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
G75P04T
TO-220
G75P04
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-40
V
ID
-80
A
IDM
-320
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
115
W
EAS
306
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
55
ºC/W
Maximum Junction-to-Case
RthJC
1.08
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1758-V1.1)
G75P04T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-40
V
IDSS
VDS = -40V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1.0
-1.7
-2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -20A
5.2
7.0
VGS = -4.5V, ID = -20A
6.8
9.0
Forward Transconductance
gFS
VDS = -5V,ID = -20A
42
6985
761
698
106
22
27
15
12
70
18
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -20V,
f = 1.0MHz
VDD = -20V,
ID = -20A,
VGS = -10V
VDD = -20V,
ID = -20A,
RG = 1Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-80
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -20A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
50
nC
Reverse Recovery Time
Trr
53
ns
IF = -20A, VGS = 0V
di/dt=-100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-40V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G75P04T
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G75P04T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
120
120
-4.5V
-10V
VDS = -5V
-4V
100
-ID, Drain Current (A)
Figure 2. Transfer Characteristics
-3.5V
80
60
-3V
40
80
60
25℃
40
VGS = -2.5V
2
3
-VDS, Drain-to-Source Voltage (V)
2
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
10
8
4
VGS = -10V
2
8
Figure 4. Gate Charge
12
VGS = -4.5V
6
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
6
4
10
6
4
2
-ID-Drain Current (A)
VDD = -20V
ID = -20A
8
60
80
100
120
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
8000
-Is, Reverse Drain Current (A)
9000
Ciss
7000
6000
5000
4000
3000
2000
Coss
1000
Crss
40
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G75P04T
Figure 10. Safe Operation Area
VGS = -10V
ID = -20A
VGS = -4.5V
ID = -20A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G75P04T
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G75P04T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.40200
- 10+2.67840
- 50+2.36520
- 100+1.97640
- 500+1.80360
- 1000+1.69560
