G58N06F
G58N06F
    GOFORD(谷峰)
    TO-220-3
    通孔 N 通道 60 V 35A(Tc) 44W(Tc) TO-220F
G58N06F 数据手册
G58N06F N-Channel Enhancement Mode Power MOSFET Description The G58N06F uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) RDS(ON) (at VGS = 4.5V) 100% Avalanche Tested 60V 35A < 13mΩ < 15mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters G D S TO-220F Ordering Information Device Package Marking Packaging G58N06F TO-220F G58N06 50pcs/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 60 V ID 35 A IDM 140 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 44 W EAS 100 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 60 ºC/W Maximum Junction-to-Case RthJC 2.8 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1633) G58N06F Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 60 -- -- V IDSS VDS =60V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 1 1.9 2.4 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 30A -- 10 13 VGS = 4.5V, ID = 25A -- 12 15 Forward Transconductance gFS VGS = 5V, ID = 30A -- 83 -- -- 3006 -- -- 161 -- -- 143 -- -- 75 -- -- 13.5 -- -- 19.5 -- -- 60 -- -- 21 -- -- 69 -- -- 48 -- Static Parameters mΩ S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 30V, f = 1.0MHz VDD = 30V, ID = 30A, VGS = 10V VDD = 30V, ID = 30A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 35 A Body Diode Voltage VSD TJ = 25ºC, ISD = 30A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 147 -- nC Reverse Recovery Time Trr IF = 30A, VGS = 0V di/dt=100A/us -- 87 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1633) G58N06F Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1633) G58N06F Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics Figure 2. Transfer Characteristics 120 120 10V VDS= 5V 5V ID, Drain Current (A) ID, Drain Current (A) 100 4.5V 80 60 4V 40 3.5V 20 0 1 2 80 60 25℃ 40 20 VGS= 3V 0 100 3 0 4 0 VDS, Drain-to-Source Voltage (V) 4 6 8 VGS, Gate-to-Source Voltage (V) Vgs Gate-Source Voltage(V) Figure 3. Drain Source On Resistance RDS(on),On-Resistance(mΩ) 2 VGS= 4.5V VGS= 10V Figure 4. Gate Charge 10 8 6 4 2 0 ID-Drain Current(A) VDD = 30V, ID = 30A 0 20 40 60 80 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward Capacitance(pF) 3500 Is, Reverse Drain Current (A) 4000 Ciss 3000 2500 2000 1500 1000 Coss 500 0 Crss 0 10 20 30 40 50 60 VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1633) G58N06F Typical Characteristics TJ = 25ºC, unless otherwise noted VGS = 10V, ID = 30A VGS = 4.5V, ID = 25A Figure 8. Safe Operation Area ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) TJ(MAX)=150℃ TC=25℃ VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 2.8°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1633) G58N06F TO-220F Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1633)
G58N06F 价格&库存
很抱歉,暂时无法提供与“G58N06F”相匹配的价格&库存,您可以联系我们找货
