GT042P06T
P-Channel Enhancement Mode Power MOSFET
Description
The GT042P06T uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-60V
-160A
< 4.5mΩ
< 7.0mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
GT042P06T
TO-220
GT042P06
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-60
V
ID
-160
A
IDM
-640
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
280
W
EAS
900
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
62
ºC/W
Maximum Junction-to-Case
RthJC
0.45
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1762-V1.0)
GT042P06T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-60
V
IDSS
VDS = -60V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1.3
-2.3
-2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -15A
3.7
4.5
VGS = -4.5V, ID = -15A
5.5
7.0
Forward Transconductance
gFS
VDS = -5V,ID = -15A
42
9151
1468
365
305
33
82
24
36
301
80
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -30V,
f = 1.0MHz
VDD = -30V,
ID = -15A,
VGS = -10V
VDD = -30V,
ID = -15A,
RG = 1.6Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-160
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -15A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
352
nC
Reverse Recovery Time
Trr
95
ns
IF = -15A, VGS = 0V
di/dt=-100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GT042P06T
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT042P06T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
-ID, Drain Current (A)
90
80
100
-5V
-10V
-5.5V
70
60
-4V
50
40
30
2
80
70
60
50
25℃
40
30
VGS = -3.5V
VDS = -5V
90
-4.5V
100
Figure 2. Transfer Characteristics
3
-VDS, Drain-to-Source Voltage (V)
2
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
7
6
VGS = -4.5V
4
VGS = -10V
2
1
10
15
8
Figure 4. Gate Charge
8
3
6
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
5
4
10
8
6
4
2
VDD = -30V,
ID = -15A
100
-ID-Drain Current (A)
150
200
250
300
350
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
10000
-Is, Reverse Drain Current (A)
12000
Ciss
8000
6000
4000
Coss
2000
Crss
40
50
25℃
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
150℃
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
GT042P06T
Figure 10. Safe Operation Area
VGS = -10V,
ID = -15A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
TJ(MAX)=150℃
TC=25℃
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT042P06T
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“GT042P06T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+36.931681+4.78331
- 50+18.7723850+2.43136
- 100+17.01309100+2.20350
- 500+13.93003500+1.80419
- 1000+12.939781000+1.67593
- 2000+12.107462000+1.56814
- 5000+11.601615000+1.50262
