GT100N12T
GT100N12T
    GOFORD(谷峰)
    TO-220-3
    通孔 N 通道 120 V 70A(Tc) 120W(Tc) TO-220
GT100N12T 数据手册
GT100N12T N-Channel Enhancement Mode Power MOSFET Description The GT100N12T uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) 100% Avalanche Tested < 120V 70A 10mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-220 Ordering Information Device Package Marking Packaging GT100N12T TO-220 GT100N12 50pcs/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 120 V ID 70 A IDM 280 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 100 W EAS 156 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 50 ºC/W Maximum Junction-to-Case RthJC 1.25 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1662) GT100N12T Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 120 -- -- V IDSS VDS = 120V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 2 3 4 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 20A -- 8 10 mΩ Forward Transconductance gFS VGS = 5V, ID = 20A -- 25 -- S -- 2825 -- -- 410 -- -- 9 -- -- 50 -- -- 17 -- -- 15 -- -- 15 -- -- 10 -- -- 34 -- -- 8 -- Static Parameters Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 60V, f = 1.0MHz VDD = 60V, ID = 20A, VGS = 10V VDD = 60V, ID = 20A, RG = 1.6Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 70 A Body Diode Voltage VSD TJ = 25ºC, ISD = 20A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 106 -- nC Reverse Recovery Time Trr IF = 20A, VGS = 0V di/dt=100A/us -- 60 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1662) GT100N12T Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1662) GT100N12T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics Figure 2. Transfer Characteristics 40 40 10V 30 ID, Drain Current (A) 5.3V 5.5V 5V 25 20 15 4.5V 10 5 0 0 1 2 3 RDS(on),On-Resistance(mΩ) 30 25 20 25℃ 15 10 0 4 0 2 4 6 8 VDS, Drain-to-Source Voltage (V) VGS, Gate-to-Source Voltage (V) Figure 3. Drain Source On Resistance Figure 4. Gate Charge 16 14 12 10 8 VGS= 10V 6 4 2 0 VDS= 5V 35 5 VGS= 4.2V Vgs Gate-Source Voltage(V) ID, Drain Current (A) 35 0 10 20 30 10 VDD = 60V ID = 20A 8 6 4 2 0 40 10 0 10 ID-Drain Current(A) 20 30 40 50 60 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward Ciss 3000 Capacitance(pF) Is, Reverse Drain Current (A) 3500 2500 2000 Coss 1500 1000 500 0 Crss 0 10 20 30 40 50 60 VDS Drain-Source Voltage(V) www.gofordsemi.com 150℃ TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1662) GT100N12T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8. Safe Operation Area VGS = 10V ID = 20A ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) TJ(MAX)=150℃ TC=25℃ VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 1.25°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1662) GT100N12T TO-220 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1662)
GT100N12T 价格&库存
很抱歉,暂时无法提供与“GT100N12T”相匹配的价格&库存,您可以联系我们找货
