GT023N10T
N-Channel Enhancement Mode Power MOSFET
Description
The GT023N10T uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
100% Avalanche Tested
100V
226A
2.7mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
GT023N10T
TO-220
GT023N10
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
100
V
ID
226
A
IDM
904
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
250
W
EAS
600
mJ
TJ, Tstg
-55 To 175
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
62
ºC/W
Maximum Junction-to-Case
RthJC
0.5
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1869-V1.1)
GT023N10T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
100
V
IDSS
VDS = 100V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
2.0
3.0
4.0
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 80A
2.3
2.7
mΩ
Forward Transconductance
gFS
VGS = 5V, ID = 80A
125
S
8139
2544
29
121
36
26
24
30
94
74
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 50V,
f = 0.3MHz
VDD = 50V,
ID = 80A,
VGS = 10V
VDD = 50V,
ID = 80A,
RG = 5Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
226
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 80A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
297
nC
Reverse Recovery Time
Trr
IF = 80A, VGS = 0V
di/dt=100A/us
94
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GT023N10T
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT023N10T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
120
120
10V
VDS = 5V
5V
80
4.8V
60
4.5V
40
2
3
RDS(on),On-Resistance(mΩ)
80
60
25℃
40
4
6
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
Figure 4. Gate Charge
5
4.5
4
3.5
3
2.5
VGS = 10V
2
1.5
1
0.5
VGS = 4V
Vgs Gate-Source Voltage(V)
ID, Drain Current (A)
100
5.3V
80
120
10
ID-Drain Current(A)
VDD = 50V,
ID = 80A
8
6
4
2
8
60
90
120
150
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Is, Reverse Drain Current (A)
12000
Capacitance(pF)
10000
Ciss
8000
6000
Coss
4000
2000
Crss
60
80
25℃
100
VDS Drain-Source Voltage(V)
www.gofordsemi.com
175℃
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GT023N10T
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ID, Drain Current(A)
VGS = 10V,
ID = 80A
Figure 8. Safe Operation Area
TJ, Junction Temperature (ºC)
TJ(MAX)=175℃
TC=25℃
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT023N10T
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“GT023N10T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.81280
- 10+7.35480
- 50+6.55560
