GC11N65F
GC11N65F
    GOFORD(谷峰)
    TO-220-3
    通孔 N 通道 650 V 11A 31.3W TO-220F
GC11N65F 数据手册
GC11N65K N-Channel Enhancement Mode Power MOSFET Description The GC11N65K uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) 100% Avalanche Tested < 650V 11A 360mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-252 Ordering Information Device Package Marking Packaging GC11N65K TO-252 GC11N65 2500pcs/Reel Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 650 V ID 11 A IDM 33 A Gate-Source Voltage VGS ±30 V Power Dissipation PD 179 W EAS 211 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 55 ºC/W Maximum Junction-to-Case RthJC 0.7 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GC11N65K Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 650 -- -- V IDSS VDS = 650V, VGS = 0V -- -- 1 μA IGSS VGS = ±30V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 2.5 -- 4 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 5.5A -- 300 360 mΩ Forward Transconductance gFS VGS = 10V, ID = 5.5A -- 8 -- S -- 901 -- -- 50 -- -- 5.5 -- -- 21 -- -- 4.5 -- -- 7 -- -- 42 -- -- 20 -- -- 123 -- -- 6.4 -- Static Parameters Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 50V, f = 1.0MHz VDD = 520V, ID = 11A, VGS = 10V VDD = 400V, ID = 11A, RG = 25Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 11 A Body Diode Voltage VSD TJ = 25ºC, ISD =11A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 2.8 -- nC Reverse Recovery Time Trr IF =5.5A, VGS = 0V di/dt=100A/us -- 280 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GC11N65K Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GC11N65K Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 2. Transfer Characteristics ID, Drain Current (A) ID, Drain Current (A) Figure 1. Output Characteristics Figure 3. Drain Source On Resistance Figure 4. Gate Charge Vgs Gate-Source Voltage(V) VGS, Gate-to-Source Voltage (V) RDS(on),On-Resistance(Ω) VDS, Drain-to-Source Voltage (V) ID-Drain Current(A) Qg Gate Charge(nC) Figure 6. Source-Drain Diode Forward Capacitance(pF) Is, Reverse Drain Current (A) Figure 5. Capacitance VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466 GC11N65K Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8. Safe Operation Area VGS = 10V, ID = 5.5A ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) TJ(MAX)=150℃ TC=25℃ VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 0.7°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GC11N65K TO-252 Package Information E c H D D1 L5 L3 b3 E1 L4 A2 b θ L A1 L2 A e (L1) COMMON DIMENSIONS SYMBOL A A1 mm MIN NOM MAX 2.20 2.30 2.40 0.00 - 0.20 A2 0.97 1.07 1.17 b 0.68 0.78 0.90 b3 5.20 5.33 5.50 c 0.43 0.53 0.63 D 5.98 6.10 6.22 D1 5.30REF E 6.40 E1 4.63 e 6.60 - 6.80 - 2.286BSC H 9.40 10.10 10.50 L 1.38 1.50 1.75 L1 L2 L3 L4 L5 θ www.gofordsemi.com 2.90REF 0.51BSC 0.88 - 1.28 0.50 - 1.00 1.65 1.80 1.95 - 8° 0° TEL:0755-29961263 FAX:0755-29961466
GC11N65F 价格&库存
很抱歉,暂时无法提供与“GC11N65F”相匹配的价格&库存,您可以联系我们找货
