G60N10T
G60N10T
    GOFORD(谷峰)
    TO-220-3
    通孔 N 通道 100 V 60A(Tc) 160W(Tc) TO-220
G60N10T 数据手册
G60N10T N-Channel Enhancement Mode Power MOSFET Description The G60N10T uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) RDS(ON) (at VGS = 4.5V) 100% Avalanche Tested < < 100V 60A 17mΩ 19mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-220 Ordering Information Device Package Marking Packaging G60N10T TO-220 G60N10 50pcs/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 100 V ID 60 A IDM 240 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 132 W EAS 100 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 40 ºC/W Maximum Junction-to-Case RthJC 0.94 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1442) G60N10T Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 100 -- -- V IDSS VDS = 100V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 0.8 1.7 2.5 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 20A -- 14 17 VGS = 4.5V, ID = 20A -- 15 19 Forward Transconductance gFS VGS = 5V, ID = 20A -- 32 -- -- 5986 -- -- 176 -- -- 164 -- -- 146 -- -- 29 -- -- 57 -- -- 17 -- -- 13 -- -- 55 -- -- 16 -- Static Parameters mΩ S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 50V, f = 1.0MHz VDD = 50V, ID = 20A, VGS = 10V VDD = 50V, ID = 20A, RG = 2.5Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 60 A Body Diode Voltage VSD TJ = 25ºC, ISD = 20A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 58 -- nC Reverse Recovery Time Trr IF = 20A, VGS = 0V di/dt=100A/us -- 35 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1442) G60N10T Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1442) G60N10T Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics 120 10V 100 VDS= 5V 4.5V ID, Drain Current (A) 120 4V 80 3.8V 60 3.5V 40 VGS= 3.3V 0 0 1 2 3 RDS(on),On-Resistance(mΩ) 80 60 25℃ 40 0 4 0 2 4 6 VDS, Drain-to-Source Voltage (V) VGS, Gate-to-Source Voltage (V) Figure 3. Drain Source On Resistance Figure 4. Gate Charge 30 25 20 VGS= 4.5V 15 10 VGS= 10V 5 0 100 20 20 0 10 20 30 Vgs Gate-Source Voltage(V) ID, Drain Current (A) Figure 2. Transfer Characteristics 10 ID-Drain Current(A) VDD = 50V, ID = 20A 8 6 4 2 0 40 8 0 50 100 150 200 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward Capacitance(pF) 7000 Is, Reverse Drain Current (A) 8000 Ciss 6000 5000 4000 3000 2000 Coss 1000 0 Crss 0 10 20 30 40 50 60 VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1442) G60N10T Typical Characteristics TJ = 25ºC, unless otherwise noted VGS = 10V, ID = 20A VGS = 4.5V, ID = 20A Figure 8. Safe Operation Area ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 0.94°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1442) G60N10T TO-220 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1442)
G60N10T 价格&库存
很抱歉,暂时无法提供与“G60N10T”相匹配的价格&库存,您可以联系我们找货
G60N10T
  • 1+3.72600
  • 10+2.92680
  • 50+2.48400
  • 100+2.05200
  • 500+1.86840
  • 1000+1.74960
库存:30
