G700P06J
G700P06J
    GOFORD(谷峰)
    TO-251-3
    通孔 P 通道 60 V 23A(Tc) 50W(Tc) TO-251
G700P06J 数据手册
G700P06J P-Channel Enhancement Mode Power MOSFET Description The G700P06J uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l l VDS ID (at VGS = -10V) RDS(ON) (at VGS = -10V) RDS(ON) (at VGS = -4.5V) 100% Avalanche Tested -60V -23A < 70mΩ < 85mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-251 Ordering Information Device Package Marking Packaging G700P06J TO-251 G700P06 75pcs/Tube Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS -60 V ID -23 A IDM -92 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 50 W EAS 25 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 50 ºC/W Maximum Junction-to-Case RthJC 2.5 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1668) G700P06J Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = -250µA -60 -- -- V IDSS VDS = -60V, VGS = 0V -- -- -1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = -250µA -1 -1.7 -3 V Drain-Source On-Resistance RDS(on) VGS = -10V, ID = -6A -- 60 70 VGS = -4.5V, ID = -5A -- 70 85 Forward Transconductance gFS VDS = -6V,ID = -4A -- 10 -- -- 1465 -- -- 68 -- -- 63 -- -- 23 -- -- 4 -- -- 5 -- -- 8 -- -- 4 -- -- 32 -- -- 7 -- Static Parameters mΩ S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = -30V, f = 1.0MHz VDD = -30V, ID = -6A, VGS = -10V VDD = -30V, ID = -6A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- -23 A Body Diode Voltage VSD TJ = 25ºC, ISD = -6A, VGS = 0V -- -- -1.2 V Reverse Recovery Charge Qrr -- 31 -- nC Reverse Recovery Time Trr -- 25 -- ns IF = -6A, VGS = 0V di/dt=-100A/us Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1668) G700P06J Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1668) G700P06J Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics Figure 2. Transfer Characteristics 30 -4.5V -10V 25 VDS= -5V -ID, Drain Current (A) -ID, Drain Current (A) 30 -4V 20 -3.5V 15 10 -3V 5 0 1 2 20 15 25℃ 10 5 VGS= -2.5V 0 25 3 0 4 0 -VDS, Drain-to-Source Voltage (V) 2 -Vgs Gate-Source Voltage(V) RDS(on), On-Resistance (mΩ) 120 100 VGS= -4.5V 60 VGS= -10V 20 0 0 2 4 6 8 10 8 Figure 4. Gate Charge 140 40 6 -VGS, Gate-to-Source Voltage (V) Figure 3.Drain Source On Resistance 80 4 10 8 6 4 2 0 12 -ID-Drain Current (A) VDD = -30V, ID = -6A 0 5 10 15 20 25 Qg Gate Charge(nC) Figure 5. Capacitance Figure 6. Source-Drain Diode Forward 1800 Ciss 1600 Capacitance(pF) -Is, Reverse Drain Current (A) 2000 1400 1200 1000 800 600 400 Coss 200 0 Crss 0 10 20 30 40 50 60 -VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 -VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1668) G700P06J Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 10. Safe Operation Area VGS = -10V, ID = -6A VGS = -4.5V, ID = -5A -ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance ZthJC, Thermal Impedance (ºC/W) TJ, Junction Temperature (ºC) TJ(MAX)=150℃ TC=25℃ -VDS, Drain-Source Voltage(V) Figure 9. Normalized Maximum Transient Thermal Impedance 2.5°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1668) G700P06J TO-251 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1668)
G700P06J 价格&库存
很抱歉,暂时无法提供与“G700P06J”相匹配的价格&库存,您可以联系我们找货
