G70N04T
N-Channel Enhancement Mode Power MOSFET
Description
The G70N04T uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
100% Avalanche Tested
40V
70A
7mΩ
9mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
G70N04T
TO-220
G70N04
50psc/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
40
V
ID
70
A
IDM
280
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
104
W
EAS
56
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
15
ºC/W
Maximum Junction-to-Case
RthJC
1.2
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1334)
G70N04T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
40
V
IDSS
VDS = 40V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1.1
1.7
2.4
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 30A
6
7
VGS = 4.5V, ID = 20A
7.5
9
Forward Transconductance
gFS
VGS = 5V, ID = 30A
89
2169
179
159
50
12
13
11
10
38
11
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 20V,
f = 1.0MHz
VDD = 20V,
ID = 30A,
VGS = 10V
VDD = 20V,
ID = 30A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
70
A
VSD
TJ = 25ºC, ISD = 30A, VGS = 0V
1.2
V
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=40V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G70N04T
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G70N04T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
120
10V
6V
5V
100
4.5V
ID, Drain Current (A)
120
Figure 2. Transfer Characteristics
4V
80
60
40
VGS= 3.5V
VDS= 5V
100
80
60
40
25℃
2
3
VDS, Drain-to-Source Voltage (V)
2
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
9
8
VGS= 4.5V
VGS= 10V
5
4
40
50
8
Figure 4. Gate Charge
10
6
6
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
7
4
10
8
6
4
2
ID-Drain Current(A)
VDD = 20V
ID = 20
40
50
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Ciss
2500
Capacitance(pF)
Is, Reverse Drain Current (A)
3000
2000
1500
1000
Coss
500
Crss
40
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G70N04T
VGS = 10V
ID = 30A
Figure 8. Safe Operation Area
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.2°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G70N04T
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G70N04T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.588181+1.63331
- 50+5.9063450+0.76635
- 100+5.24980100+0.68116
- 500+4.09622500+0.53148
- 1000+3.724781000+0.48329
- 2000+3.412262000+0.44274
- 5000+3.074135000+0.39887
- 10000+2.8651910000+0.37176
