G300P06T
P-Channel Enhancement Mode Power MOSFET
Description
The G300P06T uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
100% Avalanche Tested
-60V
-40A
< 30mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
G300P06T
TO-220
G300P06
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-60
V
ID
-40
A
IDM
-160
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
50
W
EAS
110
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
62.5
ºC/W
Maximum Junction-to-Case
RthJC
2.5
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1606)
G300P06T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-60
V
IDSS
VDS = -60V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-2
-2.5
-3
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -12A
25
30
mΩ
Forward Transconductance
gFS
VDS = -5V,ID = -12A
13
S
2736
178
153
49
10
13
15
12
38
15
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -30V,
f = 1.0MHz
VDD = -30V,
ID = -12A,
VGS = -10V
VDD = -30V,
ID = -12A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-40
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -12A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
53
nC
Reverse Recovery Time
Trr
47
ns
IF = -12A, VGS = 0V
di/dt=-100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G300P06T
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G300P06T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
80
80
-10V
-7V
60
-6V
50
-5.5V
40
30
-5V
VGS= -4.5V
10
-ID, Drain Current (A)
70
2
VDS= -5V
70
60
50
40
25℃
30
3
-VDS, Drain-to-Source Voltage (V)
2
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
50
40
VGS= -10V
8
12
16
Ciss
2500
2000
1500
1000
Coss
Crss
10
40
50
4
2
40
50
60
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
6
-Is, Reverse Drain Current (A)
Capacitance(pF)
3500
Figure 6. Source-Drain Diode Forward
4000
VDD = -30V
ID = -12A
Qg Gate Charge(nC)
Figure 5. Capacitance
500
10
10
-ID-Drain Current (A)
3000
8
Figure 4. Gate Charge
60
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
30
4
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G300P06T
Figure 10. Safe Operation Area
VGS = -10V
ID = -12A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
2.5°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G300P06T
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G300P06T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.13200
- 10+2.47320
- 50+2.11680
- 100+1.76040
- 500+1.60920
- 1000+1.51200
