MMBT5550 / MMBT5551
High Voltage Transistors NPN Silicon
Package outline
Features
0.020 (0.50)
(B)
0.012 (0.30)
0.045 (1.15)
.084(2.10)
.068(1.70)
0.120 (3.04)
0.110 (2.80)
(BV CEO = 140V~ 160V@I C=1mA)
This device is designed for general purpose high voltage
amplifiers and gas discharge display driving .
Epitaxial planar die construction .
Lead-free parts for green partner, exceeds environmental
standards of MIL-STD-19500 /228
Suffix "-H" indicates Halogen-free part, ex.MMBT5550-H.
0.034 (0.85)
SOT-23
• High collector-emitterbreakdien voltage.
(C)
(A)
0.063 (1.60)
0.027 (0.67)
0.013 (0.32)
0.047 (1.20)
0.108 (2.75)
Mechanical data
0.051 (1.30)
0.003 (0.09)
• Epoxy:UL94-V0 rated flame retardant
• Case : Molded plastic, SOT-23
• Terminals : Solder plated, solderable per
0.007 (0.18)
0.083 (2.10)
0.035 (0.89)
MIL-STD-750, Method 2026
• Mounting Position : Any
Dimensions in inches and (millimeters)
Maximum ratings (AT T =25 C unless otherwise noted)
o
A
PARAMETER
Symbol
MMBT5550
Collector-base voltage
V CBO
160
180
V
Collector-emitter voltage
V CEO
140
160
V
Emitter-base voltage
V EBO
6.0
V
Collector current - continuous
IC
600
mA
MMBT5551
UNIT
Thermal characteristics
Symbol
Max
Collector Power Dissipation
Pc
300
Thermal resistance From Junction to ambient
Operating junction temperature range
R θJA
Storage temperature range
Characteristics
http://www.anbonsemi.com
TEL:+86-755-23776891
FAX:+86-755-81482812
Page 1
UNIT
mW
O
416
C/W
TJ
-55 to +150
o
C
T STG
-55 to +150
o
C
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3140018
2003/03/08
2021/07/19
E
5
MMBT5550 / MMBT5551
Electrical characteristics (AT T =25 C unless otherwise noted)
o
A
Off characteristics
PARAMETER
Collector-base breakdown voltage
Collector-emitter breakdown voltage(3)
Emitter-base breakdown voltage
Collector cutoff current
CONDITIONS
I C = 100μA, I E = 0
V (BR)CBO
I C = 1.0mA, I B = 0
V (BR)CEO
V (BR)EBO
I E = 10μA, I C = 0
V CB = 100V, I E = 0
I CBO
V CB = 120V, I E = 0
Emitter cutoff current
Symbol
I EBO
V EB = 4.0V, I C = 0
Types
UNIT
Max.
Min.
MMBT5550
160
MMBT5551
180
MMBT5550
140
MMBT5551
160
Both Types
6.0
MMBT5550
100
MMBT5551
50
Both Types
50
nA
Min.
Max.
UNIT
MMBT5550
60
MMBT5551
80
MMBT5550
60
300
MMBT5551
100
300
MMBT5550
MMBT5551
30
Both Types
0.15
MMBT5550
0.25
MMBT5551
0.20
Both Types
1.0
MMBT5550
1.2
MMBT5551
1.0
50
100
V
V
V
nA
On characteristics
PARAMETER
CONDITIONS
Symbol
I C = 1.0mA, V CE = 5.0V
DC current gain
I C = 10mA, V CE = 5.0V
h FE
I C = 50mA, V CE = 5.0V
I C = 10mA, I B = 1.0mA
Collector-emitter saturation voltage
Base-emitter saturation voltage
V CE(sat)
I C = 50mA, I B = 5.0mA
I C= 10mA, I B = 1.0mA
V BE(sat)
Collector emitter cut - off
V CB= 10V
I CES
V CB= 75V
Types
Both Types
V
V
nA
3.Pulse test : pulse width <
= 300us, duty cycle <
= 2.0%.
Page 2
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3140018
2003/03/08
2021/07/19
E
5
MMBT5550 / MMBT5551
h FE , DC CURRENT GAIN (NORMALIZED)
Rating and characteristic curves
500
300
VCE = 1.0 V
VCE = 5.0 V
TJ = 125 C
200
+25 C
100
-55 C
50
30
7.0
5.0
0.1
0.2
0.3
0.5
0.7
1.0
3.0
2.0
5.0 7.0
10
I C, COLLECTOR CURRENT (mA)
50
70
100
VCE , COLLECTOR-EMITTER VOL TAGE (VOLTS)
FIG.1 DC Current Gain
1.0
0.9
TJ= 25 C
0.8
0.7
I C= 1.0 mA
0.6
10 mA
100 mA
30 mA
0.5
0.4
0.3
0.2
0.1
0.01
0.02
0.05
0.1
0.2
0.5
1.0
I B , BASE CURRENT (mA)
2.0
5.0
10
1
10
1.0
VCE= 30 V
100
TJ= 125 C
10-1
-2
10
V, VOLTAGE (VOLTS)
I C , COLLECTOR CURRENT (mA)
FIG. 2 Collector Saturation Region
I C = I CES
75 C
-3
REVERSE
-4
25 C
10
10
FORWARD
TJ= 25 C
0.8
VBE(sat )@ IC / IB = 10
0.6
0.4
0.2
VCE(sat )@ IC / I B = 10
-5
10
0.4
0.3
0.2 0.1 0
0.1 0.2 0.3 0.4 0.5
VBE, BASE-EMITTER VOLTAGE (VOLTS)
0.6
FIG. 3 Collector Cut-Off Region
0.2 0.3 0.5 1.0 2.0 3.0 5.0 10 20 30 50
100
FIG. 4 "On" Voltages
Page 3
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3140018
2003/03/08
2021/07/19
E
5
MMBT5550 / MMBT5551
θ V , TEMPERATURE COEFFICIENT(mV/ C)
2.5
2.0
TJ = - 55 C to +135 C
1.5
1.0
θ VCfor VCE(sat)
Vin
θVBfor V BE(sat)
- 1.5
t r ,t f 10 ns
Vin
DUTY CYCLE = 1.0%
- 2.0
- 2.5
0.1
0.20.3 0.5 1.0 2.0 3.0 5.0 10 20 30 50
I C , COLLECT OR CURRENT (mA)
100
100
70
50
3.0 k
RB
RC
Vout
5.1 k
1N914
100
Values Shown are for IC @ 10 mA
FIG. 6 Switching Time Test Circuit
FIG.5 Temperature Coefficients
1000
TJ= 25 C
(ns)
t , TIME
Cibo
7.0
5.0
t r @ VCC = 120 V
300
200
t r@ VCC= 30 V
100
Cobo
3.0
I C/ I B = 10
TJ = 25 C
500
30
50
t d@ VEB(off) = 1.0 V
30
VCC= 120 V
1.0
0.2 0.3
0.5 0.7 1.0
2.0 3.0
5.0 7.0 10
VR, REVERSE VOLTAGE (VOLTS)
10
0.20.3 0.5
1.0 2.03.0 5.0 10
FIG. 8 Turn-On T ime
FIG. 7 Capacitances
5000
t f @ VCC = 120 V
3000
2000
I C / IB = 10
TJ = 25 C
t f @ VCC = 30 V
t , TIME (ns)
C, CAP ACITANCE (pF)
100
0.25uF
10ms
INPUT PULSE
- 0.5
VCC
30 V
VBB
-8.8V
10.2 V
0.5
1000
500
300
t s@ VCC = 120 V
200
100
50
0.2 0.3 0.5
1.0 2.0 3.0 5.0 10 20 30 50 100 200
FIG.9 Turn-Off Time
Page 4
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3140018
2003/03/08
2021/07/19
E
5
MMBT5550 / MMBT5551
Pinning information
Pin
Simplified outline
Symbol
C
PinB
PinC
PinE
C
Base
Collector
Emitter
B
E
B
E
Marking
Type number
Marking code
MMBT5550
MMBT5551
M1F
G1
Suggested solder pad layout
SOT-23
0.037(0.95)
0.037(0.95)
0.079(2.0)
0.035(0.90)
0.031(0.80)
Page 5
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3140018
2003/03/08
2021/07/19
E
5
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.168753000+0.02183
- 6000+0.148886000+0.01926
- 9000+0.138729000+0.01794
- 15000+0.1272715000+0.01646
- 21000+0.1204821000+0.01558
- 30000+0.1138730000+0.01473
- 国内价格 香港价格
- 1+0.885511+0.11452
- 10+0.5473110+0.07079
- 100+0.33265100+0.04302
- 500+0.23856500+0.03086
- 1000+0.207951000+0.02690
- 国内价格
- 20+0.11410
- 200+0.09470
- 600+0.08393
- 3000+0.06906
- 9000+0.06341
- 21000+0.06033
