GT035N06T
N-Channel Enhancement Mode Power MOSFET
Description
The GT035N06T uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
l
Schematic Diagram
VDS
60V
ID (at VGS = 10V)
170A
RDS(ON) (at VGS = 10V)
< 3.5mΩ
RDS(ON) (at VGS = 4.5V)
< 4.5mΩ
100% Avalanche Tested
l RoHS Compliant
Marking and pin assignment
Application
l Power switch
l DC/DC converters
l Synchronous Rectification
TO-220
Device
Package
Marking
Packaging
GT035N06T
TO-220
GT035N06
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
60
V
ID
170
A
IDM
300
A
VGS
±20
V
EAS
256
mJ
PD
215
W
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Case
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
0.58
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Gate-Source Voltage
Single pulse avalanche energy
(note3)
Power Dissipation
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466 (A1485)
GT035N06T
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
60
V
IDSS
VDS = 60V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1.2
1.6
2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 20A
2.5
3.5
VGS = 4.5V, ID = 20A
3.0
4.5
Forward Transconductance
gFS
VDS = 5V,ID = 20A
60
5064
1100
48
70
21
16
16
9
36
11
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 30V,
f = 1.0MHz
VDD = 30V,
ID = 20A,
VGS = 10V
VDD = 30V,
ID = 50A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
125
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 20A, VGS = 0V
1.2
V
Reverse Recovery Chrage
Qrr
150
nC
Reverse Recovery Time
Trr
30
ns
IF=20A, di/dt=500A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
IAS = 20A, VDD = 40V, RG = 25Ω, Starting TJ = 25°C
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GT035N06T
Gate Charge Test Circuit
EAS Test Circuit
Switch Time Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT035N06T
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
180
180
10V
8V
6V
5V
4.5V
140
120
100
VGS=3.3V
80
60
40
VDS=5V
160
ID, Drain Current (A)
160
Figure 2. Transfer Characteristics
140
120
100
80
60
25 ºC
40
2
3
4
VDS, Drain-to-Source Voltage (V)
1
2
3
4
5
6
VGS, Gate-to-Source Voltage (V)
Figure 4. Drain Source On Resistance
RDS(on),On-Resistance(mΩ)
Vgs Gate-Source Voltage(V)
Figure 3. Gate Charge
Qg Gate Charge(nC)
5
4.5
4
VGS=4.5V
3.5
3
2.5
VGS=10V
2
1.5
1
40
ID-Drain Current(A)
Figure 5. Capacitance vs Vds
Figure 6. Source-Drain Diode Forward
6000
Capacitance(pF)
Is, Reverse Drain Current (A)
ciss
5000
4000
coss
3000
2000
1000
crss
40
50
60
Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GT035N06T
Figure 8. Safe Operation Area
VGS=10V
ID=20A
VGS=4.5V
ID=20A
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT035N06T
TO-220 Package Information
Dimensions in Millimeters
Symbol
A
A1
A2
b
b2
c
D
D1
D2
E
e
e1
H1
L
L1
∅ P
Q
www.gofordsemi.com
MIN.
4.37
1.25
2.2
0.7
1.7
0.45
15.1
8.8
5.5
9.7
6.25
12.75
3.4
2.6
NOM.
4.57
1.3
2.4
0.8
1.27
0.5
15.6
9.1
MAX.
4.7
1.4
2.6
0.95
1.47
0.6
16.1
9.4
10
2.54BSC
5.08BSC
6.5
13.5
3.1
3.6
2.8
10.3
TEL:0755-29961263
6.85
13.8
3.4
3.8
3
很抱歉,暂时无法提供与“GT035N06T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.586611+3.57343
- 50+13.7001450+1.77465
- 100+12.34704100+1.59938
- 500+9.97672500+1.29234
- 1000+9.214851000+1.19365
- 2000+8.574412000+1.11069
- 5000+7.881845000+1.02098
- 10000+7.8122310000+1.01196
- 国内价格
- 1+6.93360
- 10+5.76720
- 50+4.93560
