TSC5988CT A3G
TSC5988CT A3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO92-3
    TRANSISTOR NPN TO92
TSC5988CT A3G 数据手册
TSC5988 NPN Silicon Planar Medium Power Transistor TO-92 Pin Definition: 1. Emitter 2. Base 3. Collector PRODUCT SUMMARY BVCBO 150V BVCEO 60V IC 6A VCE(SAT) Ordering Information Features ● Excellent gain characteristics specified up to 10A Structure ● 0.55V @ IC / IB = 6A / 300mA Epitaxial Planar Type Part No. Package Packing TSC5988CT B0G TSC5988CT A3G TO-92 TO-92 1,000pcs / Bulk 2,000pcs / Ammo ed Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Symbol Limit Unit VCBO VCEO VEBO 150 60 6 5 20 1.0 +150 - 55 to +150 V V V nd Collector-Base Voltage Collector-Emitter Voltage Emitter-Base Voltage mm e DC Pulse Collector Current IC PTOT TJ TSTG eco Total Power Dissipation Operating Junction Temperature Operating Junction and Storage Temperature Range A W C o C o Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions IC =100uA, IE =0 IC =10mA, IB =0 IE =100uA, IC =0 VCB =120V, IE =0 VCB =120V, TA =100ºC VEB =6V, IC =0 IC =100mA, IB =5mA IC =1A, IB =50mA IC =2A, IB =50mA IC =5A, IB =200mA IC =4A, IB =200mA VCE =1V, IC =4A VCE =1V, IC =10mA VCE =1V, IC =2A VCE =1V, IC =5A VCE =1V, IC =10A VCE =10V, IC=100mA VCB =10V, f=1MHz No tR Collector-Base Breakdown Voltage Collector-Emitter Breakdown Voltage Emitter-Base Breakdown Voltage Collector Cutoff Current Emitter Cutoff Current Collector-Emitter Saturation Voltage Base-Emitter Saturation Voltage Base-Emitter on Voltage DC Current Transfer Ratio Transition Frequency Output Capacitance Document Number: DS_P0000234 1 Symbol Min Typ Max Unit BVCBO BVCEO BVEBO 150 60 6 ---------100 120 75 ---- 170 70 8 ---20 50 125 260 920 840 -200 140 70 130 72 ---50 1 10 50 100 150 350 1050 950 -300 ----- V V V nA uA nA ICBO IEBO VCE(SAT) 1 VCE(SAT) 2 VCE(SAT) 3 VCE(SAT) 4 VBE(SAT) VBE(ON) hFE 1 hFE 2 hFE 3 hFE 4 fT Cob mV mV mV MHz pF Version: F15 TSC5988 NPN Silicon Planar Medium Power Transistor Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) Figure 2. VCE(SAT) vs. Collector Current de d Figure 1. DC Current Gain vs. Collector Current Figure 4. fT vs. Emitter Current No tR e co mm en Figure 3. VBE(SAT) vs. Collector Current Figure 5. Cob vs. Collector-Base Voltage Document Number: DS_P0000234 Figure 6. Cib vs. Emitter-Base Voltage 2 Version: F15 TSC5988 NPN Silicon Planar Medium Power Transistor Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) Figure 8. Derating Curve No tR e co mm en de d Figure 7. Safety Operation Area Document Number: DS_P0000234 3 Version: F15 TSC5988 NPN Silicon Planar Medium Power Transistor TO-92 Mechanical Drawing No tR e co mm en de A B C D E F G H d DIM TO-92 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 4.30 4.70 0.169 0.185 4.30 4.70 0.169 0.185 14.30(typ) 0.563(typ) 0.43 0.49 0.017 0.019 1.18 1.28 0.046 0.050 3.30 3.70 0.130 0.146 1.27 1.31 0.05 0.051 0.37 0.43 0.015 0.017 Marking Diagram Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000234 4 Version: F15 TSC5988 No tR e co mm en de d NPN Silicon Planar Medium Power Transistor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000234 5 Version: F15
TSC5988CT A3G 价格&库存
很抱歉,暂时无法提供与“TSC5988CT A3G”相匹配的价格&库存,您可以联系我们找货
