TSC873CT A3G
TSC873CT A3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO92-3
    TRANSISTOR NPN TO92
TSC873CT A3G 数据手册
TSC873 NPN Silicon Planar High Voltage Transistor TO-92 Pin Definition: SOT-223 1. Emitter 2. Collector 3. Base Pin Definition: 1. Base 2. Collector 3. Emitter PRODUCT SUMMARY BVCBO 600V BVCEO 400V IC 1A VCE(SAT) Features High BVceo, BVcbo High current gain Structure ● Ordering Information Part No. Package Packing TSC873CT B0G TSC873CT A3G TSC873CW RPG TO-92 TO-92 SOT-223 1,000pcs / Bulk 2,000pcs / Ammo 2,500pcs / 13” Reel TS C8 No 73 t R CT eco B0 mm G , en A3G de d ● ● 0.5V @ IC / IB = 500mA / 100mA Epitaxial Planar Type Note: “G” denote for Halogen Free Product Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Symbol Limit Unit Collector-Base Voltage VCBO 600 V Collector-Emitter Voltage VCEO 400 V Emitter-Base Voltage VEBO 9 V DC Collector Current Pulse o Total Power Dissipation @ TA=25 C 1 IC TO-92 1 Ptot SOT-223 Operating Junction Temperature W 1.2 TJ Operating Junction and Storage Temperature Range A 2 TSTG +150 o - 55 to +150 o C C Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Collector-Base Breakdown Voltage IC = 100uA BVCBO 600 -- -- V Collector-Emitter Breakdown Voltage IC = 1mA BVCEO 400 -- -- V Emitter-Base Breakdown Voltage IE = 100uA BVEBO 9 -- -- V Collector-Base Cutoff Current VCB=600V ICBO -- -- 100 uA Collector-Emitter Cutoff Current VCE = 400V ICEO -- -- 1 mA Emitter-Base Cutoff Current VEB=8V IEBO -- -- 100 uA Collector-Emitter Saturation Voltage IC = 500mA, IB = 100mA VCE(SAT) 1 -- -- 0.5 V Collector-Emitter Saturation Voltage IC = 1A, IB = 250mA VCE(SAT) 2 -- -- 1 V Base-Emitter Saturation Voltage IC = 500mA, IB = 100mA VBE(SAT) 1 -- -- 1 V Base-Emitter Saturation Voltage IC = 1A, IB = 250mA VBE(SAT) 2 -- -- 1.2 V DC Current Transfer Ratio VCE = 10V, IC = 250mA hFE 80 -- -- TON -- 1 -- uS TSTG -- 4 -- uS TOFF -- 0.7 -- uS Trun-on Time Storage Time Fall Time Document Number: DS_P0000231 Vcc=125V,Ic=1A, IB1=IB2=200mA 1 Version: D15 TSC873 NPN Silicon Planar High Voltage Transistor Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) Figure 2. DC Current Gain TS C8 No 73 t R CT eco B0 mm G , en A3G de d Figure 1. Static Characteristics Figure 3. VCE(SAT) v.s. IC Figure 4. VBE(sat) vs Ic Figure 5. VBE(on) vs Ic Figure 6. Safety Operation Area Document Number: DS_P0000231 2 Version: D15 TSC873 NPN Silicon Planar High Voltage Transistor TO-92 Mechanical Drawing DIM TS C8 No 73 t R CT eco B0 mm G , en A3G de d A B C D E F G H TO-92 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 4.30 4.70 0.169 0.185 4.30 4.70 0.169 0.185 14.30(typ) 0.563(typ) 0.43 0.49 0.017 0.019 1.18 1.28 0.046 0.050 3.30 3.70 0.130 0.146 1.27 1.31 0.05 0.051 0.37 0.43 0.015 0.017 Marking Diagram Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000231 3 Version: D15 TSC873 NPN Silicon Planar High Voltage Transistor SOT-223 Mechanical Drawing DIM TS C8 No 73 t R CT eco B0 mm G , en A3G de d A B C D E F G H I J K SOT-223 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 6.350 6.850 0.250 0.270 2.900 3.100 0.114 0.122 3.450 3.750 0.136 0.148 0.595 0.635 0.023 0.025 4.550 4.650 0.179 0.183 2.250 2.350 0.088 0.093 0.835 1.035 0.032 0.041 6.700 7.300 0.263 0.287 0.250 0.355 0.010 0.014 10° 16° 10° 16° 1.550 1.800 0.061 0.071 Marking Diagram Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr V =Aug S =May T =Jun U =Jul W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000231 4 Version: D15 TSC873 TS C8 No 73 t R CT eco B0 mm G , en A3G de d NPN Silicon Planar High Voltage Transistor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000231 5 Version: D15
TSC873CT A3G 价格&库存
很抱歉,暂时无法提供与“TSC873CT A3G”相匹配的价格&库存,您可以联系我们找货
