TSM4N90
Taiwan Semiconductor
N-Channel Power MOSFET
900V, 4A, 4.0Ω
FEATURES
KEY PERFORMANCE PARAMETERS
Low RDS(ON) 4Ω (Max.)
Low gate charge typical @ 25nC (Typ.)
Improve dV/dt capability
PARAMETER
VALUE
UNIT
VDS
900
V
RDS(on) (max)
4
Ω
Qg
25
nC
High efficiency switch mode power Supply
Lighting
en
de
d
APPLICATION
ITO-220
mm
TO-220
Notes: Moisture sensitivity level: level 3. Per J-STD-020
eco
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Pulsed Drain Current
TO-220 ITO-220
UNIT
VDS
900
V
VGS
±30
V
TC = 25°C
(Note 1)
tR
Continuous Drain Current
SYMBOL
4
4*
2.2
2.2*
IDM
16
16 *
A
PDTOT
123
38.7
W
ID
TC = 100°C
(Note 2)
Total Power Dissipation @ TC = 25°C
A
(Note 3)
EAS
474
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS
4
A
EAR
12.3
mJ
dV/dt
4.5
V
TJ, TSTG
- 55 to +150
°C
SYMBOL
TO-220 ITO-220
UNIT
No
Single Pulsed Avalanche Energy
(Note 2)
Repetitive Avalanche Energy
Peak Diode Recovery
(Note 7)
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
Junction to Case Thermal Resistance
RӨJC
Junction to Ambient Thermal Resistance
RӨJA
1.01
3.23
62.5
°C/W
°C/W
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000109
1
Version: C15
TSM4N90
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
MIN
TYP
MAX
UNIT
VGS = 0V, ID = 250µA
BVDSS
900
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2
4
V
Gate Body Leakage
VGS = ±30V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 900V, VGS = 0V
IDSS
10
µA
Drain-Source On-State Resistance
VGS = 10V, ID = 2.0A
RDS(on)
3.2
4.0
Ω
Forward Transconductance
VDS = 30V, ID = 2.0A
gfs
6
S
VDS = 720V, ID = 4.0A,
Dynamic
(Note 5)
Total Gate Charge
Gate-Source Charge
Gate-Drain Charge
Qg
25
Qgs
4.8
Qgd
10.2
en
VGS = 10V
d
Drain-Source Breakdown Voltage
de
Static
CONDITIONS
(Note 4)
nC
VDS = 25V, VGS = 0V,
Ciss
955
Output Capacitance
f = 1.0MHz
Coss
80
Gate Resistance
F = 1MHz, open drain
Rg
4
td(on)
49
tr
38
td(off)
146
tf
50
VSD
1.5
V
VGS = 0V, IS = 4A
trr
487
ns
dIF/dt = 100A/µs
Qrr
2.8
µC
Switching
mm
Input Capacitance
(Note 6)
Turn-On Delay Time
VDD = 450V,
Turn-On Rise Time
RGEN = 25Ω,
Turn-Off Delay Time
Source-Drain Diode
e co
ID = 4.0A, VGS = 10V,
Turn-Off Fall Time
IS = 4.0A, VGS = 0V
tR
Reverse Recovery Time
Reverse Recovery Charge
ns
Current limited by package.
No
1.
Ω
(Note 4)
Forward On Voltage
Notes:
pF
2.
Pulse width limited by the maximum junction temperature.
3.
L = 56mH, IAS = 4.0A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C.
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
7.
ISD ≤ 4A, dI/dt ≤ 200A/uS, VDD ≤ BVDSS, Starting TJ = 25 C.
o
o
2
Version: C15
TSM4N90
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSM4N90CZ C0G
TO-220
50pcs / Tube
TSM4N90CI C0G
ITO-220
50pcs / Tube
No
tR
e co
mm
en
de
d
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: C15
TSM4N90
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
Transfer Characteristics
en
de
d
Output Characteristics
Gate Charge
No
tR
e co
mm
On-Resistance vs. Drain Current
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
4
Version: C15
TSM4N90
BVDSS vs. Junction Temperature
en
de
d
Drain Current vs. Case Temperature
Capacitance vs. Drain-Source Voltage
tR
e co
mm
Maximum Safe Operating Area
No
Maximum Safe Operating Area (ITO-220)
5
Version: C15
TSM4N90
en
de
d
Normalized Thermal Transient Impedance, Junction-to-Ambient (TO-220)
No
tR
e co
mm
Normalized Thermal Transient Impedance, Junction-to-Ambient (ITO-220)
6
Version: C15
TSM4N90
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
en
de
d
TO-220
MARKING DIAGRAM
No
tR
e co
mm
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
7
Version: C15
TSM4N90
en
de
d
ITO-220
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
No
tR
e co
G
Y
WW
F
mm
MARKING DIAGRAM
8
Version: C15
TSM4N90
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
9
Version: C15
很抱歉,暂时无法提供与“TSM4N90CZ C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.534691+3.17534
