TSM160N10
Taiwan Semiconductor
N-Channel Power MOSFET
100V, 160A, 5.5mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
Advanced Trench Technology
Low RDS(ON) 5.5mΩ (Max.)
Low gate charge typical @ 154nC (Typ.)
Low Crss typical @ 260pF (Typ.)
PARAMETER
VALUE
UNIT
VDS
100
V
RDS(on) (max)
5.5
mΩ
Qg
154
nC
en
de
d
mm
TO-220
Notes: Moisture sensitivity level: level 3. Per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
eco
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
SYMBOL
LIMIT
UNIT
VDS
100
V
VGS
±20
V
tR
TC = 25°C
Continuous Drain Current
TC = 70°C
(Note 1)
TA = 25°C
160
ID
TA = 70°C
(Note 2)
No
Pulsed Drain Current
Total Power Dissipation
127
14.2
11.4
IDM
620
TC = 25°C
300
TC = 70°C
210
TA = 25°C
PDTOT
TA = 70°C
2.4
1.68
A
A
A
W
W
Single Pulsed Avalanche Energy
(Note 3)
EAS, EAR
400
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS, IAR
40
A
TJ, TSTG
- 55 to +175
°C
Operating Junction and Storage Temperature Range
Document Number: DS_P0000029
1
Version: C15
TSM160N10
THERMAL PERFORMANCE
PARAMETER
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
0.5
°C/W
Junction to Ambient Thermal Resistance
RӨJA
62.5
°C/W
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
SYMBOL
MIN
TYP
MAX
de
Static
CONDITIONS
(Note 4)
UNIT
d
PARAMETER
VGS = 0V, ID = 250uA
BVDSS
100
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2
3
4
V
Zero Gate Voltage Drain Current
VDS = 80V, VGS = 0V
IDSS
1
uA
Gate Body Leakage
VGS = ±20V, VDS = 0V
IGSS
±100
nA
Drain-Source On-State Resistance
VGS = 10V, ID = 30A
RDS(on)
4.5
5.5
mΩ
Qg
154
Qgs
35
Qgd
40
Ciss
9840
Coss
750
Crss
260
td(on)
25
tr
40
td(off)
85
tf
45
VSD
0.8
1.3
mm
Dynamic
(Note 5)
Total Gate Charge
VDS = 30V, ID = 30A,
Gate-Source Charge
VGS = 10V
Gate-Drain Charge
e co
Input Capacitance
VDS = 30V, VGS = 0V,
Output Capacitance
Reverse Transfer Capacitance
Switching
en
Drain-Source Breakdown Voltage
(Note 6)
tR
Turn-On Delay Time
F = 1.0MHz
Turn-On Rise Time
VGS = 10V, VDS = 30V,
Turn-Off Delay Time
RG = 3.3Ω
No
Turn-Off Fall Time
Source-Drain Diode
nC
pF
ns
(Note 4)
Forward Voltage
VGS=0V, IS=30A
Reverse Recovery Time
IS = 30A , TJ = 25 C
trr
120
nS
Reverse Recovery Charge
dI/dt = 100A/us
Qrr
160
nC
o
V
Notes:
1.
Current limited by package.
2.
Pulse width limited by the maximum junction temperature.
3.
L = 0.5mH, IAS = 40A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
o
2
Version: C15
TSM160N10
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSM160N10CZ C0G
TO-220
50pcs / Tube
No
tR
e co
mm
en
de
d
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: C15
TSM160N10
CHARACTERISTICS CURVES
en
de
d
Output Characteristics
Drain-Source On Resistance
No
tR
e co
mm
Gate Source On Resistance
Source-Drain Diode Forward Voltage
Drain-Source On-Resistance
4
Version: C15
TSM160N10
Drain Current vs. Junction Temperature
en
de
d
Power Derating
Transient Thermal Impedance
No
tR
e co
mm
Safe Operation Area
Capacitance
Gate Charge
5
Version: C15
TSM160N10
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
en
de
d
TO-220
mm
Marking Diagram
No
tR
e co
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
V =Aug
S =May T =Jun U =Jul
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
6
Version: C15
TSM160N10
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: C15
很抱歉,暂时无法提供与“TSM160N10CZ C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.382191+4.30937
