BUK9508-55B,127
BUK9508-55B,127
    NEXPERIA(安世)
    TO-220-3
    MOSFET N-CH 55V 75A TO220AB
BUK9508-55B,127 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BUK9508-55B N-channel TrenchMOS logic level FET Rev. 03 — 15 June 2010 Product data sheet 1. Product profile 1.1 General description Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits  Low conduction losses due to low on-state resistance  Suitable for logic level gate drive sources  Q101 compliant  Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications  12 V and 24 V loads  General purpose power switching  Automotive systems  Motors, lamps and solenoids 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 55 V ID drain current VGS = 5 V; Tmb = 25 °C; see Figure 1; see Figure 3 - - 75 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 203 W VGS = 10 V; ID = 25 A; Tj = 25 °C - 6.2 7 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 11; see Figure 12 - 7.1 8.4 mΩ [1] Static characteristics RDSon drain-source on-state resistance BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit - - 352 mJ - 16 - nC Avalanche ruggedness EDS(AL)S non-repetitive ID = 75 A; Vsup ≤ 55 V; drain-source RGS = 50 Ω; VGS = 5 V; avalanche energy Tj(init) = 25 °C; unclamped Dynamic characteristics QGD [1] gate-drain charge VGS = 5 V; ID = 25 A; VDS = 44 V; Tj = 25 °C; see Figure 13 Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate Simplified outline 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number BUK9508-55B BUK9508-55B Product data sheet Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 2 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 55 V VDGR drain-gate voltage RGS = 20 kΩ - - 55 V VGS gate-source voltage ID drain current -15 - 15 V Tmb = 100 °C; VGS = 5 V; see Figure 1 [1] - - 75 A Tmb = 25 °C; VGS = 5 V; see Figure 1; see Figure 3 [2] - - 110 A [1] - - 75 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 - - 439 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 203 W Tstg storage temperature -55 - 175 °C Tj junction temperature -55 - 175 °C [2] - - 110 A [1] - - 75 A tp ≤ 10 µs; pulsed; Tmb = 25 °C - - 439 A ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 5 V; Tj(init) = 25 °C; unclamped - - 352 mJ Source-drain diode source current IS peak source current ISM Tmb = 25 °C Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy [1] Continuous current is limited by package. [2] Current is limited by power dissipation chip rating. BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 3 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 03nn57 120 03na19 120 Capped at 75 A due to package ID (A) Pder (%) 80 80 40 40 0 0 50 100 150 0 200 0 50 100 150 Tmb (°C) Fig 1. 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 03nn55 103 Limit RDSon = VDS/ID ID (A) tp = 10 μ s 102 100 μ s Capped at 75 A due to package 1 ms DC 10 10 ms 100 ms 1 1 102 10 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 4 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 0.74 K/W Rth(j-a) thermal resistance from junction to ambient vertical in still air - 60 - K/W 03nn56 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10−1 0.1 0.05 0.02 10−2 δ= P tp T single shot t tp 10−3 10−6 T 10−5 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 5 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 55 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 50 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10 1.1 1.5 2 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10 - - 2.3 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10 0.5 - - V - - 500 µA IDSS drain leakage current VDS = 55 V; VGS = 0 V; Tj = 175 °C VDS = 55 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA IGSS gate leakage current VDS = 0 V; VGS = 15 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -15 V; Tj = 25 °C - 2 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C - - 9.3 mΩ VGS = 5 V; ID = 25 A; Tj = 175 °C; see Figure 11; see Figure 12 - - 16.8 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C - 6.2 7 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 11; see Figure 12 - 7.1 8.4 mΩ ID = 25 A; VDS = 44 V; VGS = 5 V; Tj = 25 °C; see Figure 13 - 45 - nC - 9 - nC - 16 - nC - 3960 5280 pF - 517 620 pF - 206 282 pF - 29 - ns - 123 - ns - 131 - ns RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time tf fall time LD internal drain inductance LS internal source inductance BUK9508-55B Product data sheet VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 14 VDS = 30 V; RL = 1.2 Ω; VGS = 5 V; RG(ext) = 10 Ω; Tj = 25 °C - 86 - ns from drain lead 6 mm from package to center of die ; Tj = 25 °C - 4.5 - nH from contact screw on mounting base to center of die ; Tj = 25 °C - 3.5 - nH from source lead to source bond pad ; Tj = 25 °C - 7.5 - nH All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 6 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit - 0.85 1.2 V Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 15 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C 03nn52 300 4.8 5 ID 10 69 - ns 72 - nC 03nn51 25 RDSon Label is VGS (V) (mΩ) 20 4.6 (A) - 4.4 200 4.2 15 4 3.8 100 3.4 3.2 3 2.8 2.6 0 0 Fig 5. 10 3.6 2 4 5 0 6 8 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 03ng53 10−1 ID (A) Fig 6. 0 5 10 VGS (V) 15 Drain-source on-state resistance as a function of gate-source voltage; typical values 03nn49 120 gfs 10−2 (S) min typ 80 max 10−3 10−4 40 10−5 10−6 0 0 1 2 3 0 VGS (V) Fig 7. Sub-threshold drain current as a function of gate-source voltage BUK9508-55B Product data sheet Fig 8. 25 50 75 ID (A) 100 Forward transconductance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 7 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 03nn50 100 03ng52 2.5 VGS(th) (V) ID (A) 2.0 max 75 1.5 typ 50 min 1.0 25 Tj = 175 °C 0 Fig 9. 0 1 Tj = 25 °C 2 3 VGS (V) 0.5 4 Transfer characteristics: drain current as a function of gate-source voltage; typical values 0 −60 Label is VGS (V) RDSon 60 120 180 Tj (°C) Fig 10. Gate-source threshold voltage as a function of junction temperature 03nn53 30 0 03ne89 2 a (mΩ) 3 20 3.2 1.5 3.4 3.6 3.8 4 1 5 10 0.5 10 0 0 50 100 150 200 250 ID (A) Fig 11. Drain-source on-state resistance as a function of drain current; typical values BUK9508-55B Product data sheet 0 -60 0 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 8 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 03nn48 5 03nn54 6000 VGS Ciss C (pF) (V) 4 VDD = 14 V 4000 VDD = 44 V 3 Coss 2 2000 Crss 1 0 0 10 20 30 0 10−2 40 50 Q G (nC) 10−1 1 102 10 VDS (V) Fig 13. Gate-source voltage as a function of gate charge; typical values Fig 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 03nn47 100 IS (A) 75 50 25 Tj = 175 °C 0 0.0 0.5 Tj = 25 °C 1.0 VSD (V) 1.5 Fig 15. Source current as a function of source-drain voltage; typical values BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 9 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 16. Package outline SOT78 (TO-220AB) BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 10 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK9508-55B v.3 20100615 Product data sheet - BUK95_96_9E08 v.2 Modifications: BUK95_96_9E08 v.2 (9397 750 12052) BUK9508-55B Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK9508-55B separated from data sheet BUK95_96_9E08 v.2. 20030313 Product data - All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 - © NXP B.V. 2010. All rights reserved. 11 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK9508-55B Product data sheet Suitability for use in automotive applications — This NXP Semiconductors product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the NXP Semiconductors product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. NXP Semiconductors does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 12 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BUK9508-55B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 15 June 2010 © NXP B.V. 2010. All rights reserved. 13 of 14 BUK9508-55B NXP Semiconductors N-channel TrenchMOS logic level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 15 June 2010 Document identifier: BUK9508-55B
BUK9508-55B,127 价格&库存
很抱歉,暂时无法提供与“BUK9508-55B,127”相匹配的价格&库存,您可以联系我们找货
