G700P06H
P-Channel Enhancement Mode Power MOSFET
Description
The G700P06H uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-60V
-5A
< 75mΩ
< 90mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
SOT-223
Ordering Information
Device
Package
Marking
Packaging
G700P06H
SOT-223
G700P06
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-60
V
ID
-5
A
IDM
-20
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
3.1
W
EAS
25
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJA
40.3
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Ambient
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1655-V1.1)
G700P06H
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-60
V
IDSS
VDS = -60V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1
-1.7
-2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -6A
60
75
VGS = -4.5V, ID = -5A
73
90
Forward Transconductance
gFS
VDS = -6V,ID = -4A
10
1459
62
59
15.8
2.7
3.5
8
5
32
8
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -30V,
f = 1.0MHz
VDD = -30V,
ID = -6A,
VGS = -10V
VDD = -30V,
ID = -6A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-5
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -6A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
32
nC
Reverse Recovery Time
Trr
27
ns
IF = -6A, VGS = 0V
di/dt=-100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G700P06H
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G700P06H
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
30
30
-4V
-3.5V
10
-3V
5
VDS= -5V
-4.5V
25
-ID, Drain Current (A)
-10V
1
2
25℃
10
5
VGS= -2.5V
3
-VDS, Drain-to-Source Voltage (V)
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
120
100
VGS= -4.5V
60
VGS= -10V
4
6
8
10
1400
1200
1000
800
600
4
2
10
15
-Is, Reverse Drain Current (A)
Capacitance(pF)
Ciss
Coss
200
8
Figure 6. Source-Drain Diode Forward
2000
400
VDD = -30V
ID = -6A
Qg Gate Charge(nC)
Figure 5. Capacitance
1600
8
10
-ID-Drain Current (A)
1800
6
Figure 4. Gate Charge
140
40
4
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
80
2
Crss
40
50
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G700P06H
Figure 10. Safe Operation Area
VGS = -10V
ID = -6A
VGS = -4.5V
ID = -5A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G700P06H
SOT-223 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G700P06H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.89692
- 50+1.51589
- 150+1.35260
