UMW
R
UMW 2N65
NN-沟道功率 MOS 管
TC=25
TC=25°°C)
●最大额定值(TC=25
(Tc=25
●Absolute Maximum Ratings
Ratings(
Tc=25°°C) TO-220/220F/251T/252/223
参数
PARAMETER
漏-源电压
Drain-source Voltage
栅-源电压
gate-source Voltage
漏极电流
Continuous Drain Current
TC=25℃
漏极电流
TC=100℃
最大脉冲电流
Drain Current -Pulsed
①
耗散功率
Power Dissipation
符号
SYMBOL
额定值
VALUE
单位
UNIT
VDS
650
V
VGS
±30
V
ID
2.0*
A
ID
1.25*
IDM
8.0*
VDS=650V
Ω
RDS(ON)=5.5
=5.5Ω
ID=2.0A
A
A
TO-220/220F
Ptot
TO-251T/252
W
SOT-223
最高结温
Junction Temperature
存储温度
Storage Temperature
Tj
150
°C
TSTG
-55-150
°C
单脉冲雪崩能量
Single Pulse Avalanche Energy ②
EAS
120
mJ
*Drain current limited by maximum junction temperature
SOT-223
Tc=25
●电特性(Tc=25
Tc=25°°C)
(Tc=25
Tc=25°°C)
Characteristics(
●Electronic Characteristics
参数
PARAMETER
符号
SYMBOL
测试条件
TEST CONDITION
最小值
MIN
漏-源击穿电压
Drain-source Breakdown Voltage
BVDSS
VGS=0V, ID=250µA
650
击穿电压温度系数
Breakdown Voltage Temperature
Coefficient
ΔBVDSS/
ΔTj
ID=250uA, Referenced to
25°C
栅极开启电压
Gate Threshold Voltage
VGS(TH)
VGS=VDS, ID=250µA
漏-源漏电流
Drain-source Leakage Current
跨导
Forward Transconductance
www.umw-ic.com
典型值
TYP
最大值
MAX
单位
UNIT
V
0.6
2.0
V/°C
4.0
V
VDS =650V,
VGS =0V, Tj=25°C
25
µA
VDS =520V,
VGS =0V, Tj=125°C
250
µA
IDSS
gfs
VDS =40V, ID=1A
③
1
1.5
S
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
参数
PARAMETER
符号
SYMBOL
测试条件
TEST CONDITION
栅极漏电流
Gate-body Leakage
Current (VDS = 0)
IGSS
VGS =±30V
漏-源导通电阻
Static Drain-source On
Resistance
RDS(ON)
VGS =10V, ID=1.0A
③
4.5
输入电容
Input Capacitance
Ciss
VGS = 0V, VDS = 25V
F = 1.0MHZ
311
pF
关断延迟
Turn -Off Delay Time
Td(off)
VDD=300V, ID =2.0A
RG=25Ω
③
24
ns
栅极电荷
Total Gate Charge
Qg
14.5
nC
1.8
nC
8.3
nC
栅源电荷
Gate-to-Source Charge
栅漏电荷
Gate-to-Drain Charge
二极管正向电流
Continuous Diode Forward
Current
二极管正向压降
Diode Forward Voltage
最小值
MIN
ID =2.0A, VDS = 520V
VGS = 10V
③
Qgs
Qgd
典型值
TYP
IS
Tj=25°C, Is=2.0A
VGS =0V ③
VSD
反向恢复时间
Reverse Recovery Time
trr
反向恢复电荷
Reverse Recovery Charge
Qrr
Tj=25°C,If=2.0A
di/dt=100A/μs
③
最大值
MAX
单位
UNIT
±100
nA
5.5
Ω
2.0
A
1.4
V
368
ns
1.0
uC
●热特性
Thermal Characteristics
●Thermal
参数
PARAMETER
最大值
MAX
符号
SYMBOL
热阻结-壳
Thermal Resistance Junction-case
热阻结-环境
Thermal Resistance Junction-ambient
单位
UNIT
TO-220
TO-220F
RthJC
2.31
4.46
℃/W
RthJA
62.5
62.5
℃/W
注释((Notes
Notes)):
① 脉冲宽度:以最高节温为限制
Repetitive rating: Pulse width limited by maximum junction temperature
② Starting Tj=25oC, VDD =50V, L=56mH, RG =25Ω, IAS=2.0A
③ 脉冲测试:脉冲宽度≤ 300μs ,占空比≤ 2 %
Pulse Test : Pulse width ≤ 300μs, Duty cycle ≤ 2%
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
● 特性曲线
图 1 输出特性曲线, Tc=25℃
Fig1 Typical Output Characteristics, Tc=25℃
图 2 输出特性曲线, Tc=150℃
Fig2 Typical Output Characteristics, Tc=150℃
图 3 导通电阻与温度曲线
Fig3 Normalized On-Resistance Vs.Temperature
图 4 二极管正向电压曲线
Fig4 Typical Source-Drain Diode Forward Voltage
图 5 最大漏极电流与壳温曲线
Fig5 Maximum Drain Current Vs.Case Temperature
www.umw-ic.com
3
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
● 特性曲线
图 6-1 2N65(TO-126&126S)
最大安全工作区曲线
图 6-2 2N65(TO-220)
最大安全工作区曲线
Fig6-1 Maximum Safe Operating Area
Fig6-2 Maximum Safe Operating Area
图 6-3 2N65(TO-220F)
最大安全工作区曲线
Fig6-3 Maximum Safe Operating Area
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
220 封装
TOTO-220
符号
SYMBOL
A
最小值
min
4.00
B
符号
SYMBOL
E
1.20
1.50
e
B1
1.00
1.40
F
1.10
1.45
b1
0.65
1.00
L
12.50
14.50
c
0.35
0.75
L1
3.00
D
15.00
16.50
Q
2.50
3.00
D1
5.90
6.90
Q1
2.00
3.00
φP
3.60
3.90
5
最小值
min
9.90
单位:毫米/UNIT:mm
典型值
最大值
nom
max
10.70
最大值
max
4.80
www.umw-ic.com
典型值
nom
2.54
3.50
4.00
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
TO-220F 封装
mm
单位::毫米//UNIT
UNIT:mm
最大值
典型值
max
nom
2.54
最大值
max
95
4.
4.9
符号
SYMBOL
e
最小值
min
2.30
2.90
L
12.50
14.30
b
0.45
0.90
L1
9.10
10.05
b1
1.10
1.70
L2
15.00
16.00
c
0.35
0.90
L3
3.00
4.00
D
14.50
17.00
øp
3.00
3.50
D1
6.10
9.00
Q
2.30
2.80
E
9.60
10.30
符号
SYMBOL
A
最小值
min
40
4.
4.4
A1
www.umw-ic.com
典型值
nom
6
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
T 封装机械尺寸
TO-251
TO-251T
T (IPAK) MECHANICAL DATA
TO-251
TO-251T
单位:毫米/UNIT:mm
最大值//max
符号//SYMBOL
最小值//min
A
2.10
2.50
A1
0.95
1.30
B
0.80
1.25
b
0.50
0.80
b1
0.70
0.80
c
0.45
0.70
c1
0.45
0.70
D
6.35
6.80
D1
5.10
5.50
E
5.30
6.30
e
2.25
L
7.00
9.20
H
0.35
0.45
W1
0.30
0.50
W2
0.20
0.40
典型值//nom
2.30
2.35
[S/L]
www.umw-ic.com
7
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
S 封装机械尺寸
TO-251
TO-251S
S (IPAK) MECHANICAL DATA
TO-251
TO-251S
符号//SYMBOL
最小值//min
A
2.20
2.40
b
0.60
0.85
C
0.45
D
6.50
6.70
D1
5.10
5.50
E
5.9
6.20
e
2.18
L
11.00
12.40
L1
4.8
5.3
L2
3.5
4.2
www.umw-ic.com
典型值//nom
单位:毫米/UNIT:mm
最大值//max
0.50
2.29
8
0.60
2.38
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
TO-252 封装机械尺寸
TO-252 MECHANICAL DATA
mm
单位::毫米//UNIT
UNIT:mm
最小值
最大值
min
max
0.85
1.25
符号
SYMBOL
A
最小值
min
2.10
最大值
max
2.50
符号
SYMBOL
B
b
0.50
0.80
b1
0.50
0.90
b2
0.45
0.70
C
0.45
0.70
D
6.30
6.75
D1
5.10
5.50
E
5.30
6.30
e1
2.25
2.35
L1
9.20
10.60
e2
4.45
4.75
L2
0.90
1.75
L3
0.60
1.10
K
0.00
0.23
www.umw-ic.com
9
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
TO-252 编带规格尺寸
TO-252 TAPE AND REEL DATA
mm
单位::毫米//UNIT
UNIT:mm
符号
SYMBOL
最小值
min
最大值
max
符号
SYMBOL
最小值
min
最大值
max
W
16.0-0.3
16.0+0.3
F
7.5-0.1
7.5+0.1
P0
4.0-0.1
4.0+0.1
D
1.5-0.0
1.5+0.1
P
8.0-0.1
8.0+0.1
P1
2.0-0.1
2.0+0.1
K
2.65
2.80
D1
1.5-0.0
1.5+0.1
使用供带方向/USER DIRECTION OF FEED
编带器件定位/UNIT ORIENTATION
www.umw-ic.com
10
友台半导体有限公司
UMW
R
UMW 2N65
NN-沟道功率 MOS 管
SOT-22 3 封装机械尺寸
SOT-22 3 MECHANICAL DATA
www.umw-ic.com
11
友台半导体有限公司
很抱歉,暂时无法提供与“2N65G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60795
- 100+0.40530
- 1250+0.36855
- 2500+0.33810
- 国内价格
- 5+0.72026
- 50+0.56538
- 150+0.48795
- 500+0.42995
- 2500+0.38351
- 5000+0.36018
