G1K3N10G
N-Channel Enhancement Mode Power MOSFET
Description
The G1K3N10G uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
100% Avalanche Tested
100V
5A
130mΩ
150mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
SOT-89
Ordering Information
Device
Package
Marking
Packaging
G1K3N10G
SOT-89
G1K3N10
1000pcs/Carton
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
100
V
ID
5
A
IDM
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
1.5
W
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJA
83
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Ambient
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1692-V1.0)
G1K3N10G
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
100
V
IDSS
VDS = 100V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.6
2
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 5A
110
130
VGS = 4.5V, ID = 5A
120
150
Forward Transconductance
gFS
VGS = 5V, ID = 5A
7
644
25
14
3.3
6
4
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 50V,
f = 1.0MHz
VDD = 50V,
ID = 5A,
VGS = 10V
VDD = 50V,
ID = 5A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
5
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 5A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
11
nC
Reverse Recovery Time
Trr
IF = 5A, VGS = 0V
di/dt=100A/us
22
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G1K3N10G
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G1K3N10G
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
12
12
10V
VDS= 5V
4.5V
ID, Drain Current (A)
10
8
6
3.3V
4
3.1V
2
2
3
RDS(on),On-Resistance(mΩ)
25℃
4
4
6
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
Figure 4. Gate Charge
160
150
140
130
VGS= 4.5V
120
110
100
VGS= 10V
90
80
70
60
6
Vgs Gate-Source Voltage(V)
2
VGS= 2.5V
2.8V
10
4
6
8
10
ID-Drain Current(A)
VDD = 50V,
ID = 5A
8
6
4
2
8
10
15
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Ciss
700
Capacitance(pF)
Is, Reverse Drain Current (A)
800
600
500
400
300
200
100
0 Crss
Coss
10
40
50
60
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G1K3N10G
VGS = 10V,
ID = 5A
VGS = 4.5V,
ID = 5A
Figure 8. Safe Operation Area
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
0.45°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G1K3N10G
SOT-89 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G1K3N10G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+1.772521000+0.23039
- 3000+1.515983000+0.19704
- 国内价格
- 5+0.94274
- 50+0.75093
- 150+0.65502
- 1000+0.58310
- 2000+0.52553
- 5000+0.49680
- 国内价格 香港价格
- 1+6.531171+0.84890
- 10+4.0510310+0.52654
- 50+2.9546150+0.38403
- 100+2.59988100+0.33792
- 500+1.97419500+0.25660
