PBSS4440D115
PBSS4440D115
    NEXPERIA(安世)
    SC74,SOT457
    NEXPERIA PBSS4440D - SMALL SIGNA
PBSS4440D115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBSS4440D 40 V NPN low VCEsat (BISS) transistor Rev. 02 — 11 December 2009 Product data sheet 1. Product profile 1.1 General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT457 (SC-74) SMD plastic package. PNP complement: PBSS5440D. 1.2 Features „ „ „ „ „ Ultra low collector-emitter saturation voltage VCEsat 4 A continuous collector current capability IC (DC) Up to 15 A peak current Very low collector-emitter saturation resistance High efficiency due to less heat generation 1.3 Applications „ „ „ „ „ „ Power management functions Charging circuits DC-to-DC conversion MOSFET gate driving Power switches (e.g. motors, fans) Thin Film Transistor (TFT) backlight inverter 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VCEO collector-emitter voltage open base [1] IC collector current (DC) ICM peak collector current t = 1 ms or limited by Tj(max) RCEsat collector-emitter saturation resistance IC = 6 A; IB = 600 mA [2] Min Typ Max Unit - - 40 V - - 4 A - - 15 A - 55 75 mΩ [1] Device mounted on a ceramic Printed-Circuit Board (PCB), AL2O3, standard footprint. [2] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 collector 2 collector 3 base 4 emitter 5 collector 6 collector Simplified outline 6 5 Symbol 4 1, 2, 5, 6 3 1 2 3 4 sym014 3. Ordering information Table 3. Ordering information Type number PBSS4440D Package Name Description Version SC-74 plastic surface mounted package; 6 leads SOT457 4. Marking Table 4. Marking codes Type number Marking code PBSS4440D 61 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VCBO collector-base voltage open emitter - 60 V VCEO collector-emitter voltage open base - 40 V VEBO emitter-base voltage open collector - 5 V - 4 A - 15 A - 0.8 A [1] IC collector current (DC) ICM peak collector current IB base current (DC) IBM peak base current tp ≤ 300 μs total power dissipation Tamb ≤ 25 °C Ptot t = 1 ms or limited by Tj(max) PBSS4440D_2 Product data sheet Min Max Unit - 2 A [2] - 360 mW [3] - 600 mW [4] - 750 mW [1] - 1.1 W [2][5] - 2.5 W © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 2 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tstg Conditions Min Max Unit storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C [1] Device mounted on a ceramic PCB, AL2O3, standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [4] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [5] Operated under pulsed conditions: Duty cycle δ ≤ 10% and pulse width tp ≤ 10 ms. 006aaa270 1600 Ptot (mW) 1200 800 (1) (2) (3) 400 0 −75 (4) −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, AL2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, mounting pad for collector 1 cm2 (4) FR4 PCB, standard footprint Fig 1. Power derating curves PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 3 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air thermal resistance from junction to solder point Rth(j-sp) Min Typ Max Unit [1] - - 350 K/W [2] - - 208 K/W [3] - - 160 K/W [4] - - 113 K/W [1][5] - - 50 K/W - - 45 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [4] Device mounted on a ceramic PCB, AL2O3, standard footprint. [5] Operated under pulsed conditions: Duty cycle δ ≤ 10% and pulse width tp ≤ 10 ms. 006aaa271 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 0.05 10 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse time; typical values PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 4 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 006aaa272 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 1 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse time; typical values 006aaa273 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 4. Transient thermal impedance from junction to ambient as a function of pulse time; typical values PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 5 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter ICBO collector-base cut-off current Conditions Min Typ Max Unit VCB = 40 V; IE = 0 A - - 0.1 μA VCB = 40 V; IE = 0 A; Tj = 150 °C - - 50 μA ICES collector-emitter cut-off current VCE = 30 V; VBE = 0 V - - 0.1 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 0.1 μA hFE DC current gain VCE = 2 V; IC = 0.5 A VCEsat collector-emitter saturation voltage 300 - - VCE = 2 V; IC = 1 A [1] 300 - - VCE = 2 V; IC = 2 A [1] 250 - - VCE = 2 V; IC = 4 A [1] 100 - - VCE = 2 V; IC = 6 A [1] 50 - - - 35 60 IC = 0.5 A; IB = 50 mA mV IC = 1 A; IB = 50 mA - 65 110 mV IC = 2 A; IB = 200 mA - 115 180 mV IC = 4 A; IB = 400 mA [1] - 220 300 mV IC = 6 A; IB = 600 mA [1] - 330 450 mV [1] - 55 75 mΩ - 0.79 0.85 V RCEsat collector-emitter saturation resistance IC = 6 A; IB = 600 mA VBEsat base-emitter saturation voltage IC = 0.5 A; IB = 50 mA IC = 1 A; IB = 50 mA - 0.81 0.9 V IC = 1 A; IB = 100 mA [1] - 0.83 1 V IC = 4 A; IB = 400 mA [1] - 1.0 1.1 V VBEon base-emitter turn-on voltage VCE = 2 V; IC = 2 A - 0.79 1.0 V td delay time 12 - ns rise time VCC = 10 V; IC = 2 A; IBon = 0.1 A; IBoff = −0.1 A - tr - 52 - ns ton turn-on time - 64 - ns ts storage time - 390 - ns tf fall time - 120 - ns toff turn-off time - 510 - ns fT transition frequency VCE = 10 V; IC = 0.1 A; f = 100 MHz - 150 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 30 - pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 6 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 006aaa274 1000 hFE 006aaa275 1.6 VBE (V) 800 (1) 600 1.2 (2) (1) 0.8 (2) 400 (3) (3) 0.4 200 0 10−1 1 10 102 103 0 10−1 104 105 IC (mA) 1 VCE = 2 V VCE = 2 V (1) Tamb = 100 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −55 °C (3) Tamb = 100 °C Fig 5. DC current gain as a function of collector current; typical values Fig 6. 006aaa276 1 VCEsat (V) 102 10 103 104 105 IC (mA) Base-emitter voltage as a function of collector current; typical values 006aaa277 1 VCEsat (V) (1) (2) (3) 10−1 10−1 (1) (2) 10−2 10−2 (3) 10−3 10−1 1 10 102 103 104 105 IC (mA) 10−3 10−1 1 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values Fig 8. 103 104 105 IC (mA) Collector-emitter saturation voltage as a function of collector current; typical values PBSS4440D_2 Product data sheet 102 Tamb = 25 °C IC/IB = 20 Fig 7. 10 © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 7 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 006aaa344 1.6 006aaa326 103 RCEsat (Ω) VBEsat (V) 102 (1) 1.2 (2) 10 (1) 0.8 (3) (2) 1 (3) 0.4 10−1 0 10−1 1 102 10 103 104 105 IC (mA) 10−2 10−1 1 (1) Tamb = −55 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = 100 °C (3) IC/IB = 10 Base-emitter saturation voltage as a function of collector current; typical values 006aaa280 14 IC (A) 102 103 104 105 IC (A) Tamb = 25 °C IC/IB = 20 Fig 9. 10 10 8 006aaa281 103 RCEsat (Ω) IB (mA) = 400 360 320 280 240 200 160 12 Fig 10. Collector-emitter saturation resistance as a function of collector current; typical values 102 10 120 80 6 1 40 (1) (2) 4 (3) 10−1 2 0 0 0.4 0.8 1.2 1.6 2.0 VCE (V) Tamb = 25 °C 10−2 10−1 1 10 102 103 104 105 IC (mA) IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 11. Collector current as a function of collector-emitter voltage; typical values Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 8 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 (1) VCC = 10 V; IC = 2 A; IBon = 0.1 A; IBoff = −0.1 A Fig 14. Test circuit for switching times PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 9 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 9. Package outline 3.1 2.7 6 3.0 2.5 1.7 1.3 1.1 0.9 5 4 2 3 0.6 0.2 pin 1 index 1 0.40 0.25 0.95 0.26 0.10 1.9 Dimensions in mm 04-11-08 Fig 15. Package outline SOT457 (SC-74) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 3000 PBSS4440D SOT457 10000 4 mm pitch, 8 mm tape and reel; T1 -115 - -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 - -165 [1] For further information and the availability of packing methods, see Section 13. [2] T1: normal taping [3] T2: reverse taping PBSS4440D_2 Product data sheet 5000 [2] © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 10 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4440D_2 20091211 Product data sheet - PBSS4440D_1 Modifications: PBSS4440D_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • Figure 2 “Transient thermal impedance from junction to ambient as a function of pulse time; typical values”: updated • Figure 3 “Transient thermal impedance from junction to ambient as a function of pulse time; typical values”: updated • Figure 4 “Transient thermal impedance from junction to ambient as a function of pulse time; typical values”: updated • Figure 11 “Collector current as a function of collector-emitter voltage; typical values”: updated 20050421 Product data sheet - PBSS4440D_2 Product data sheet - © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 11 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PBSS4440D_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 12 of 13 PBSS4440D NXP Semiconductors 40 V NPN low VCEsat (BISS) transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 December 2009 Document identifier: PBSS4440D_2
PBSS4440D115 价格&库存
很抱歉,暂时无法提供与“PBSS4440D115”相匹配的价格&库存,您可以联系我们找货
