PSMN1R5-50YLHX
PSMN1R5-50YLHX
    NEXPERIA(安世)
    SOT-1205,LFPAK56-8
    表面贴装型 N 通道 50 V 200A(Ta) 333W(Ta) LFPAK56,Power-SO8
PSMN1R5-50YLHX 数据手册
PSMN1R5-50YLH N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E 26 January 2022 Product data sheet 1. General description 200 Amp continuous current, logic level gate drive, N-channel enhancement mode MOSFET in LFPAK56E package. Part of the ASFETs for Battery Isolation and DC Motor control family and using Nexperia’s unique “SchottkyPlus” technology delivers high efficiency and low spiking performance usually associated with MOSFETs with an integrated Schottky or Schottky-like diode but without problematic high leakage current. The ASFET is particularly suited to 36 V battery powered applications requiring strong avalanche capability, linear mode performance, use at high switching frequencies, and also safe and reliable switching at high load-current. 2. Features and benefits • • • • • • • • • • • 200 A continuous current capability Optimised for 36 V (nominal) battery powered applications LFPAK56E low-stress exposed lead-frame for ultimate reliability, optimum soldering and easy solder-joint inspection Copper-clip and solder die attach for low package inductance and resistance, and high ID (max) rating Qualified to 175 °C Avalanche rated, 100% tested Low QG, QGD and QOSS for high efficiency, especially at higher switching frequencies Superfast switching with soft body-diode recovery for low-spiking and ringing, recommended for low EMI designs Unique “SchottkyPlus” technology for Schottky-like switching performance and low IDSS leakage Narrow VGS(th) rating for easy paralleling and improved current sharing Very strong linear-mode / safe operating area characteristics for safe and reliable switching at high-current conditions 3. Applications • • • • • Brushless DC motor control Synchronous rectifier in high-power AC-to-DC applications, e.g. server power supplies Battery protection and Battery Management Systems (BMS) Load switch 10 cell lithium-ion battery applications (36 V ‒ 42 V) 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 50 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 200 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 333 W Tj junction temperature -55 - 175 °C [1] PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E Symbol Parameter Conditions Min Typ Max Unit VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 10 - 1.4 1.75 mΩ VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 10 - 1.6 2 mΩ ID = 25 A; VDS = 25 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 13 29 nC - 53 82 nC Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge [1] 200A Continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D G 1 2 3 4 mbb076 S LFPAK56E; PowerSO8 (SOT1023) 6. Ordering information Table 3. Ordering information Type number Package PSMN1R5-50YLH Name Description Version LFPAK56E; Power-SO8 plastic, single-ended surface-mounted package (LFPAK56); 4 leads; 1.27 mm pitch SOT1023 7. Marking Table 4. Marking codes Type number Marking code PSMN1R5-50YLH 1H550L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 50 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 50 V PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 2 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E Symbol Parameter Conditions VGS gate-source voltage Ptot total power dissipation Tmb = 25 °C; Fig. 1 ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 [1] Min Max Unit -20 20 V - 333 W - 200 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 200 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 1159 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 200 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 1159 A Avalanche ruggedness EDS(AL)S IAS [1] [2] ID = 50 A; Vsup ≤ 50 V; RGS = 50 Ω; non-repetitive drainsource avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped; tp = 513 µs [2] - 833 mJ ID = 25 A; Vsup ≤ 50 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped; tp = 2.5 ms [2] - 2 J [2] - 115 A non-repetitive avalanche Vsup ≤ 50 V; VGS = 10 V; Tj(init) = 25 °C; current RGS = 50 Ω 200A Continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. Protected by 100% test 03aa16 120 Pder (%) 80 aaa-032723 300 ID (A) 250 200 (1) 150 40 100 50 0 Fig. 1. 0 50 100 150 Tmb (°C) 0 200 Fig. 2. Product data sheet 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V (1) 200A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. Normalized total power dissipation as a function of mounting base temperature PSMN1R5-50YLH 0 Continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E ID (A) aaa-032724 104 103 Limit RDSon = VDS / ID tp = 10 µs 102 100 µs DC 10 1 ms 10 ms 100 ms 1 10-1 10-1 1 10 102 VDS (V) Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Min Typ Max Unit Rth(j-mb) thermal resistance from Fig. 4 junction to mounting base Conditions - 0.33 0.45 K/W Rth(j-a) thermal resistance from Fig. 5 junction to ambient Fig. 6 - 42 - K/W - 85 - K/W aaa-028225 1 Zth(j-mb) (K/W) δ = 0.5 10-1 0.2 0.1 0.05 10-2 0.02 P single shot δ= Fig. 4. 10-5 10-4 10-3 10-2 T t tp 10-3 10-6 tp T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 4 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E aaa-027933 aaa-027935 Copper area 25.4 mm square; 70 µm thick on FR4 board Fig. 5. PCB layout for thermal resistance from junction to ambient 70 µm thick copper on FR4 board Fig. 6. PCB layout with minimum footprint for thermal resistance from junction to ambient 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 50 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 45 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C 1.2 1.61 2.2 V ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 150 °C - -4.6 - mV/K IDSS drain leakage current VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.01 1 µA VDS = 40 V; VGS = 0 V; Tj = 125 °C - 3.9 - µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 10 - 1.4 1.75 mΩ VGS = 10 V; ID = 25 A; Tj = 150 °C; Fig. 11 - - 3.52 mΩ VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 10 - 1.6 2 mΩ VGS = 4.5 V; ID = 25 A; Tj = 150 °C; Fig. 11 - - 4.02 mΩ f = 1 MHz; Tj = 25 °C 0.52 1.3 3.3 Ω ID = 25 A; VDS = 25 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 53 82 nC ID = 25 A; VDS = 25 V; VGS = 10 V; Fig. 12; Fig. 13 - 117 181 nC ID = 0 A; VDS = 0 V; VGS = 10 V - 61 - nC Static characteristics V(BR)DSS IGSS RDSon RG gate leakage current drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E Symbol Parameter Conditions Min Typ Max Unit QGS gate-source charge - 17 26 nC QGS(th) pre-threshold gatesource charge ID = 25 A; VDS = 25 V; VGS = 4.5 V; Fig. 12; Fig. 13 - 11.3 17 nC QGS(th-pl) post-threshold gatesource charge - 5.4 8 nC QGD gate-drain charge - 13 29 nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 25 V; Fig. 12; Fig. 13 - 2.5 - V Ciss input capacitance - 7959 11143 pF Coss output capacitance VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 14 - 799 1119 pF Crss reverse transfer capacitance - 231 554 pF td(on) turn-on delay time - 39 - ns tr rise time - 40 - ns td(off) turn-off delay time - 68 - ns tf fall time Qoss output charge VDS = 25 V; RL = 1 Ω; VGS = 4.5 V; RG(ext) = 5 Ω - 32 - ns VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C - 42 - nC Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.75 1 V trr reverse recovery time 36 - ns recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Fig. 16 [1] - Qr - 37 - nC ta reverse recovery rise time - 21 - ns tb reverse recovery fall time - 14 - ns [1] includes capacitive recovery aaa-032725 250 10 V 4.5 V ID (A) RDSon (mΩ) 3V 200 aaa-032726 8 6 VGS = 2.8 V 150 4 100 2.6 V 2 50 2.4 V 0 Fig. 7. 0 1 2 3 VDS (V) 0 4 0 2 4 6 8 10 12 14 VGS (V) 16 Tj = 25 °C Tj = 25 °C; ID = 25 A Output characteristics; drain current as a Fig. 8. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E aaa-032727 300 ID (A) RDSon (mΩ) 240 aaa-032728 8 2.6 V 2.8 V 3V 6 180 4 120 0 150°C 0 1 Tj = 25°C 2 3 VGS (V) VGS = 10 V 0 4 VDS = 8 V Fig. 9. a 4.5 V 2 60 0 50 100 150 200 ID (A) 250 Tj = 25 °C Transfer characteristics; drain current as a function of gate-source voltage; typical values Fig. 10. Drain-source on-state resistance as a function of drain current; typical values aaa-032798 2.5 VGS (V) aaa-032729 10 2 8 1.5 6 40 V 1 25 V 4 VDS = 10 V 0.5 0 -60 2 -30 0 30 60 90 120 150 Tj (°C) 0 180 0 26 52 78 104 QG (nC) 130 Tj = 25 °C; ID = 25 A Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN1R5-50YLH Product data sheet Fig. 12. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E aaa-032730 104 C (pF) VDS Ciss ID 103 Coss VGS(pl) Crss 102 VGS(th) VGS QGS2 QGS1 QGS 10 10-1 QGD QG(tot) IS (A) 10 VDS (V) Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 003aal160 aaa-032731 103 102 VGS = 0 V; f = 1 MHz 003aaa508 Fig. 13. Gate charge waveform definitions 1 ID (A) trr 102 ta tb 0 10 0.25 IRM 150°C 1 0 0.2 0.4 Tj = 25°C 0.6 0.8 VSD (V) IRM t (s) 1 VGS = 0 V Fig. 16. Reverse recovery timing definition Fig. 15. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E 11. Package outline Plastic single-ended surface-mounted package (LFPAK56E); 4 leads A E SOT1023 E1 A b1 b2 (3x) c1 mounting base H D1 D L 1 2 3 4 b e A1 w A X c C θ Lp detail X 0 2.5 mm 5 mm scale Dimensions Unit y C A A1 b b1 b2 c c1 D(1) D1(1) E(1) E1(1) max 1.10 0.15 0.50 4.41 0.25 0.30 4.70 4.45 5.30 nom 0.85 min 0.95 0.00 0.35 3.62 0.19 0.24 4.45 4.95 3.7 3.5 e 1.27 H L Lp 6.2 1.3 0.85 5.9 0.8 0.40 w y 0.25 0.1 θ 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm per side are not included. Outline version sot1023_po References IEC JEDEC JEITA European projection Issue date 13-03-05 17-07-31 SOT1023 Fig. 17. Package outline LFPAK56E; Power-SO8 (SOT1023) PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E 12. Soldering 4.7 4.2 0.25 (2×) 0.9 (3×) 0.25 (2×) 0.6 (4×) 3.45 0.6 (3×) 2 3.5 2.55 0.25 (2×) SR opening = Cu + 0.075 1.1 2.15 3.3 SP opening = Cu - 0.050 0.7 (4×) 1.27 3.81 solder lands solder paste 125 µm stencil solder resist occupied area sot1023_fr Fig. 18. Reflow soldering footprint for LFPAK56E; Power-SO8 (SOT1023) PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E 13. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PSMN1R5-50YLH Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 PSMN1R5-50YLH Nexperia N-channel 50 V, 1.7 mOhm, 200 A continuous, logic level Application Specific MOSFET in LFPAK56E Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Package outline.......................................................... 9 12. Soldering................................................................... 10 13. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 January 2022 PSMN1R5-50YLH Product data sheet All information provided in this document is subject to legal disclaimers. 26 January 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
PSMN1R5-50YLHX
物料型号:PSMN1R5-50YLH
器件简介:这是一个N通道50V、1.7毫欧姆、200安培连续电流、逻辑电平应用特定MOSFET,采用LFPAK56E封装。它使用了Nexperia独特的“SchottkyPlus”技术,提供高效率和低尖峰性能,适用于36V电池供电应用。
引脚分配:文档提供了详细的引脚信息表,其中1、2、3引脚为源极(S),4引脚为栅极(G),mb表示安装底座,连接到漏极(D)。
参数特性:包括200A的连续电流能力、优化用于36V电池供电应用、LFPAK56E低应力外露引线框架、铜夹和焊料芯片粘合提供低封装电感和电阻、175°C的合格测试、雪崩额定、100%测试、低QG、QGD和QOSS、超快开关与软体二极管恢复等。
功能详解:该MOSFET适用于无刷直流电机控制、高功率AC到DC应用的同步整流器、电池保护和电池管理系统(BMS)、负载开关以及10节锂离子电池应用(36V - 42V)。
应用信息:特别适用于需要强雪崩能力、线性模式性能、在高开关频率下使用以及在高负载电流下安全、可靠开关的应用。
封装信息:LFPAK56E塑料单端表面安装封装,4个引脚,SOT1023。
PSMN1R5-50YLHX 价格&库存
很抱歉,暂时无法提供与“PSMN1R5-50YLHX”相匹配的价格&库存,您可以联系我们找货
PSMN1R5-50YLHX
  • 1+40.590861+5.27489
  • 10+26.7628610+3.47791
  • 50+20.8142350+2.70487
  • 100+18.89844100+2.45590
  • 500+16.14343500+2.09788
库存:2595
PSMN1R5-50YLHX
  • 1500+9.902881500+1.28691
  • 4500+8.948924500+1.16294
库存:2595
