E3M0060065K
E3M0060065K
    WOLFSPEED
    TO-247-4
    通孔 N 通道 650 V 37A(Tc) 131W(Tc) TO-247-4L
E3M0060065K 数据手册
E3M0060065K Silicon Carbide Power MOSFET E-Series Automotive N-Channel Enhancement Mode Features • • • • • • • • Package 3rd generation SiC MOSFET technology Optimized package with separate driver source pin 8mm of creepage distance between drain and source High blocking voltage with low on-resistance High-speed switching with low capacitances Fast intrinsic diode with low reverse recovery (Qrr) Halogen free, RoHS compliant Automotive Qualified (AEC-Q101) and PPAP Capable Tab Drain Benefits • • • • • Reduce switching losses and minimize gate ringing Higher system efficiency Reduce cooling requirements Increase power density Increase system switching frequency 1 2 3 4 Gate (Pin 4) Driver Source (Pin 3) Applications • • Drain (Pin 1, TAB) EV Battery Chargers High Voltage DC/DC Converters Power Source (Pin 2) Part Number Package Marking E3M0060065K TO-247-4L E3M0060065K Maximum Ratings (TC = 25 ˚C unless otherwise specified) Symbol Parameter Value Unit Note VDSmax Drain - Source Voltage 650 V VGSmax Gate - Source Voltage -8/+19 V Note: 1 A Fig. 19 Note: 2 ID ID(pulse) PD TJ , Tstg Continuous Drain Current, VGS = 15 V TC = 25˚C 37 TC = 100˚C 26 Pulsed Drain Current, Pulse width tP limited by Tjmax 99 A Fig. 22 Power Dissipation, TC=25˚C, TJ = 175 ˚C 131 W Fig. 20 Note: 2 -40 to +175 ˚C Operating Junction and Storage Temperature TL Solder Temperature, 1.6mm (0.063”) from case for 10s 260 ˚C Md Mounting Torque , M3 or 6-32 screw 1 8.8 Nm lbf-in Note (1): Recommended turn off / turn on gate voltage VGS - 4V...0V / +15V Note (2): Verified by design Rev. 1, JUNE 2022 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 2 Electrical Characteristics (TC = 25˚C unless otherwise specified) Symbol V(BR)DSS VGS(th) Parameter Drain-Source Breakdown Voltage Gate Threshold Voltage Min. Typ. Max. Unit V VGS = 0 V, ID = 100 μA 2.8 3.6 V VDS = VGS, ID = 3.6 mA V VDS = VGS, ID = 3.6 mA, TJ = 175ºC 650 1.8 2.2 Test Conditions IDSS Zero Gate Voltage Drain Current 1 50 μA VDS = 650 V, VGS = 0 V IGSS Gate-Source Leakage Current 10 250 nA VGS = 15 V, VDS = 0 V 60 79 RDS(on) Drain-Source On-State Resistance 83 9 mΩ gfs Transconductance Ciss Input Capacitance Coss Output Capacitance 72 Crss Reverse Transfer Capacitance 6 Eoss Coss Stored Energy 14 μJ Co(er) Effective Output Capacitance (Energy Related) 85 pF Co(tr) Effective Output Capacitance (Time Related) 122 pF EON Turn-On Switching Energy (External Diode) 29 9 S VGS = 15 V, ID = 13.2 A VGS = 15 V, ID = 13.2 A, TJ = 175ºC VDS= 20 V, IDS= 13.2 A VDS= 20 V, IDS= 13.2 A, TJ = 175ºC pF VGS = 0 V, VDS = 0V to 600 V F = 1 Mhz Fig. 17, 18 VGS = 0 V, VDS = 0... 400V Note: 3 VDS = 400 V, VGS = -4 V/15 V, ID = 13.2A, RG(ext) = 2.5 Ω, L= 135 μH, TJ = 175ºC Fig. 25 12 FWD = External SiC DIODE EON Turn-On Switching Energy (Body Diode FWD) 40 VDS = 400 V, VGS = -4 V/15 V, ID = 13.2A, RG(ext) = 2.5 Ω, L= 135 μH, TJ = 175ºC EOFF Turn-Off Switching Energy (Body Diode FWD) 11 td(on) Turn-On Delay Time 9 Rise Time 10 Turn-Off Delay Time 16 Fall Time 8 Internal Gate Resistance 4 Qgs Gate to Source Charge 16 Qgd Gate to Drain Charge 16 Qg Total Gate Charge 49 μJ RG(int) Fig. 7 Fig. 16 Turn Off Switching Energy (External Diode) tf Fig. 4, 5, 6 VAC = 25 mV EOFF td(off ) Fig. 11 1170 μJ tr Note Fig. 25 FWD = Internal Body Diode ns VDD = 400 V, VGS = -4 V/15 V ID = 13.2 A, RG(ext) = 2.5 Ω, Timing relative to VDS Inductive load Ω f = 1 MHz, VAC = 25 mV nC VDS = 400 V, VGS = -4 V/15 V ID = 13.2 A Per IEC60747-8-4 pg 21 Fig. 26 Fig. 12 Note (3): Co(er), a lumped capacitance that gives same stored energy as Coss while Vds is rising from 0 to 400V Co(tr), a lumped capacitance that gives same charging time as Coss while Vds is rising from 0 to 400V Rev. 1, JUNE 2022 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 3 Reverse Diode Characteristics (TC = 25˚C unless otherwise specified) Symbol VSD IS Parameter Typ. Max. Unit Test Conditions 4.6 V VGS = -4 V, ISD = 6.6 A, TJ = 25 °C 4.1 V VGS = -4 V, ISD = 6.6 A, TJ = 175 °C Diode Forward Voltage Continuous Diode Forward Current 23 A VGS = -4 V, TC = 25˚C IS, pulse Diode pulse Current 99 A VGS = -4 V, pulse width tP limited by Tjmax trr Reverse Recover time 12 ns Qrr Reverse Recovery Charge 173 nC Irrm Peak Reverse Recovery Current 28 A trr Reverse Recover time 15 ns Qrr Reverse Recovery Charge 122 nC Irrm Peak Reverse Recovery Current 13 A Note Fig. 8, 9, 10 VGS = -4 V, ISD = 13.2 A, VR = 400 V dif/dt = 4770 A/µs, TJ = 175 °C VGS = -4 V, ISD = 13.2 A, VR = 400 V dif/dt = 2200 A/µs, TJ = 175 °C Thermal Characteristics Symbol RθJC Parameter Typ. Max. Unit Thermal Resistance from Junction to Case 1.02 1.14 °C/W Rev. 1, JUNE 2022 Test Conditions Note Fig. 21 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 4 Typical Performance 100 60 VGS = 11V 40 20 VGS = 9V VGS = 15V Conditions: Tj = 25 °C tp = < 200 µs 80 VGS = 13V Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) 80 100 VGS = 15V Conditions: Tj = -40 °C tp = < 200 µs VGS = 13V 60 VGS = 11V 40 VGS = 9V 20 VGS = 7V VGS = 7V 0 0.0 2.0 4.0 6.0 8.0 10.0 0 12.0 0.0 2.0 4.0 Figure 1. Output Characteristics TJ = -40 ºC 80 Drain-Source Current, IDS (A) 2.0 Conditions: Tj = 175 °C tp = < 200 µs 8.0 10.0 12.0 Figure 2. Output Characteristics TJ = 25 ºC 1.8 VGS = 15V VGS = 13V 1.6 On Resistance, RDS On (P.U.) 100 6.0 Drain-Source Voltage, VDS (V) Drain-Source Voltage, VDS (V) VGS = 11V 60 VGS = 9V 40 20 VGS = 7V Conditions: IDS = 13.2 A VGS = 15 V tp < 200 µs 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 0.0 2.0 4.0 6.0 8.0 10.0 0.0 12.0 -50 -25 0 Drain-Source Voltage, VDS (V) 100 Tj = 175 °C 80 Tj = -40 °C 60 Tj = 25 °C 40 20 0 0 10 20 30 40 Drain-Source Current, IDS (A) Figure 5. On-Resistance vs. Drain Current For Various Temperatures Rev. 1, JUNE 2022 75 100 125 150 175 Conditions: IDS = 13.2 A tp < 200 µs 160 On Resistance, RDS On (mOhms) On Resistance, RDS On (mOhms) 180 Conditions: VGS = 15 V tp < 200 µs 120 50 Figure 4. Normalized On-Resistance vs. Temperature Figure 3. Output Characteristics TJ = 175 ºC 140 25 Junction Temperature, Tj (°C) 50 60 140 120 100 VGS = 11 V 80 VGS = 13 V 60 VGS = 15 V 40 20 0 -50 -25 0 25 50 75 100 Junction Temperature, Tj (°C) 125 150 175 Figure 6. On-Resistance vs. Temperature For Various Gate Voltage 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 5 Typical Performance 60 50 TJ = 175 °C 40 TJ = -40 °C TJ = 25 °C -8 30 20 -6 -4 -2 0 VGS = -4 V Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) -10 Conditions: VDS = 20 V tp < 200 µs -20 VGS = 0 V VGS = -2 V -40 -60 10 0 0 2 4 6 8 10 12 -4 Figure 8. Body Diode Characteristic at -40 ºC -2 0 VGS = -4 V 0 -20 VGS = 0 V VGS = -2 V -40 -60 Conditions: Tj = 25°C tp < 200 µs Drain-Source Voltage VDS (V) -10 -8 0 0 -20 VGS = 0 V -40 VGS = -2 V -60 Conditions: Tj = 175°C tp < 200 µs -100 Drain-Source Voltage VDS (V) -80 -100 Figure 10. Body Diode Characteristic at 175 ºC 16 2.5 2.0 1.5 1.0 Conditions: IDS = 13.2 A IGS = 50 mA VDS = 400 V TJ = 25 °C 12 Gate-Source Voltage, VGS (V) 3.0 Threshold Voltage, Vth (V) -2 -80 Conditons VGS = VDS IDS = 3.64 mA 3.5 -4 VGS = -4 V Figure 9. Body Diode Characteristic at 25 ºC 4.0 -6 Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) -6 -100 Drain-Source Voltage VDS (V) Figure 7. Transfer Characteristic for Various Junction Temperatures -8 -80 Conditions: Tj = -40°C tp < 200 µs Gate-Source Voltage, VGS (V) -10 0 8 4 0 0.5 0.0 -50 -25 0 25 50 75 100 Junction Temperature TJ (°C) 125 Figure 11. Threshold Voltage vs. Temperature Rev. 1, JUNE 2022 150 175 -4 0 10 20 30 40 50 Gate Charge, QG (nC) Figure 12. Gate Charge Characteristics 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 6 Typical Performance -8 -6 -2 -4 0 Drain-Source Current, IDS (A) VGS = 0 V 0 -20 VGS = 5 V -40 VGS = 10 V VGS = 15 V -60 -10 -8 -4 -2 0 -40 VGS = 10 V VGS = 15 V -60 -80 Conditions: Tj = 25 °C tp < 200 µs -100 Drain-Source Voltage VDS (V) 20 0 18 -20 VGS = 5 V -40 VGS = 10 V VGS = 15 V -60 Stored Energy, EOSS (µJ) 16 VGS = 0 V Drain-Source Current, IDS (A) -20 Figure 14. 3rd Quadrant Characteristic at 25 ºC 14 12 10 8 6 4 Conditions: Tj = 175 °C tp < 200 µs Drain-Source Voltage VDS (V) -80 2 0 -100 0 100 Figure 15. 3rd Quadrant Characteristic at 175 ºC 10000 1 0 50 100 Drain-Source Voltage, VDS (V) 150 Figure 17. Capacitances vs. Drain-Source Voltage (0 - 200V) Rev. 1, JUNE 2022 400 500 600 10000 Capacitance (pF) Crss 10 300 Drain to Source Voltage, VDS (V) 700 200 100 Coss 10 Crss 1 Conditions: TJ = 25 °C VAC = 25 mV f = 1 MHz Ciss 1000 Coss 100 200 Figure 16. Output Capacitor Stored Energy Conditions: TJ = 25 °C VAC = 25 mV f = 1 MHz Ciss 1000 Capacitance (pF) 0 VGS = 5 V Figure 13. 3rd Quadrant Characteristic at -40 ºC -6 0 VGS = 0 V -100 Drain-Source Voltage VDS (V) -8 -2 -4 -80 Conditions: Tj = -40 °C tp < 200 µs -10 -6 Drain-Source Current, IDS (A) -10 0 100 200 300 400 Drain-Source Voltage, VDS (V) 500 600 Figure 18. Capacitances vs. Drain-Source Voltage (0 - 650V) 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 7 Typical Performance 140 Conditions: TJ ≤ 175 °C 35 Maximum Dissipated Power, Ptot (W) Drain-Source Continuous Current, IDS (DC) (A) 40 30 25 20 15 10 5 0 -50 -25 0 25 50 75 100 Case Temperature, TC (°C) 125 150 Conditions: TJ ≤ 175 °C 120 100 80 60 40 20 0 175 -50 0.5 0.3 0.1 100E-3 50 75 100 125 150 0.05 0.02 Limited by RDS On 175 10 µs 100 µs 1 1 ms Conditions: TC = 25 °C D = 0, Parameter: tp 0.01 SinglePulse 1E-6 0.1 10E-6 100E-6 1E-3 Time, tp (s) 10E-3 100E-3 1 0.1 100 Conditions: TJ = 25 °C VDD = 400 V RG(ext) = 2.5 Ω VGS = -4/+15 V FWD = E3M0060065K L = 504 μH 50 45 40 1 75 30 EOn 25 20 15 EOff 10 10 Drain-Source Voltage, VDS (V) 100 1000 Conditions: TJ = 25 °C VDD = 400 V RG(ext) = 2.5 Ω VGS = -4/+15 V FWD = E3M0060065K L = 135 μH ETotal 35 100 ms Figure 22. Safe Operating Area Switching Loss (uJ) 55 1 µs 10 Figure 21. Transient Thermal Impedance (Junction - Case) Switching Loss (uJ) 25 Case Temperature, TC (°C) 100 1 10E-3 0 Figure 20. Maximum Power Dissipation Derating vs. Case Temperature Drain-Source Current, IDS (A) Junction To Case Impedance, ZthJC (oC/W) Figure 19. Continuous Drain Current Derating vs. Case Temperature -25 ETotal EOn 50 25 EOff 5 0 2.00 2.25 2.50 2.75 3.00 3.25 3.50 Drain to Source Current, IDS (A) 3.75 4.00 Figure 23. Clamped Inductive Switching Energy vs. Low Drain Current (VDD = 400V) Rev. 1, JUNE 2022 4.25 0 0 5 10 15 20 Drain to Source Current, IDS (A) 25 30 Figure 24. lamped Inductive Switching Energy vs. High Drain Current (VDD = 400V) 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 8 Typical Performance 150 Switching Loss (uJ) 100 Conditions: TJ = 25 °C VDD = 400 V IDS = 13.2 A VGS = -4/+15 V FWD = E3M0060065K L = 135 μH ETotal EOn 100 50 0 5 10 15 External Gate Resistor RG(ext) (Ohms) 20 25 Conditions: TJ = 25 °C VDD = 400 V IDS = 13.2 A VGS = -4/+15 V FWD = E3M0060065K Switching Times (ns) 40 ETotal ETotal with Schottky 40 EOn EOn with Schottky 0 EOff with Schottky EOff 0 25 50 75 100 125 Junction Temperature, TJ (°C) 150 175 200 Figure 26. Clamped Inductive Switching Energy vs. Temperature Figure 25. Clamped Inductive Switching Energy vs. RG(ext) 50 60 20 EOff 0 Conditions: IDS = 13.2 A VDD = 400 V RG(ext) = 2.5 Ω VGS = -4/+15 V L = 135 μH FWD = E3M0060065K FWD = C6D10065D 80 Switching Loss (uJ) 200 td(off) tr 30 td(on) 20 tf 10 0 0 5 10 15 External Gate Resistor RG(ext) (Ohms) Figure 27. Switching Times vs. RG(ext) Rev. 1, JUNE 2022 20 25 Figure 28. Switching Times Definition 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 9 Test Circuit Schematic RG L VDC Q1 VGS= - 4 V KS CDC Q2 RG D.U.T KS Figure 29. Clamped Inductive Switching Waveform Test Circuit Rev. 1, JUNE 2022 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 10 Package Dimensions 4 3 E 12.70 E3 F 2 1 PACKAGE BURR LOCATION A A 6.35 E1 E4 B A2 W D1 D E2 S F D2 T Q 0.64 M A C B P 7.18 5 8.38 (3) 1 2 3 4 POLISH 0.1 E b5 L1 W X L2 E C b8 L b7 A1 e1 D 4x b c e b1 D 2x b3 0.25 M B A M C B SYMBOL MIN (mm) MAX (mm) A A1 A2 b b1 b3 b5 b7 b8 c D D1 D2 E E1 E2 E3 E4 e e1 L L1 L2 P Q S T W X 4.83 2.29 1.91 1.07 2.39 1.07 2.39 1.30 1.80 0.55 23.30 16.25 0.95 15.75 13.1 3.68 1.00 12.38 5.21 2.54 2.16 1.33 2.94 1.60 2.69 1.70 2.20 0.68 23.60 17.65 1.25 16.13 14.15 5.10 1.90 13.43 17.31 3.97 2.35 3.51 5.49 6.04 2.54 BSC 5.08 BSC 17.5 REF. 3.5 REF. 4 REF. 1 DRAIN 2 SOURCE 3 DRIVER SOURCE 4 GATE 5 DRAIN C NOTE: 1. ALL METAL SURFACES ARE TIN PLATED (MATTE), EXCEPT AREA OF CUT. 2. DIMENSIONING & TOLERANCING CONFORM TO ASME Y14.5M-1994. 3. ALL DIMENSIONS ARE LISTED IN MILLIMETERS. ANGLES ARE IN DEGREES. 4. BURR OR MOLD FLASH SIZE (0.5 mm) IS NOT INCLUDED IN THE DIMENSIONS 17.82 4.37 2.65 3.65 6.00 6.30 B TITLE: PACKAGE OUTLINE DRAWING: TO-247-4L A REVISION NO. Date: 05/05/22 e1 Rev. 1, JUNE 2022 4 3 SCALE:1:1 2 01 A A4 SHEET 1 OF 1 1 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K Q S T W X 5.49 6.00 6.04 6.30 17.5° REF. 3.5 ° REF. 4 ° REF. 11 RecommendedSolder Solder Pad Layout Recommended Pad Layout TITLE: Rev. 1, JUNE 2022 TO-247 4LD COMPANY ASE WEIHAI SHEET 2 OF 3 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 12 Revision history Document Version Date of release Descriptiion of changes 1.0 June-2022 Initial datasheet Rev. 1, JUNE 2022 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. E3M0060065K 13 Notes & Disclaimer This document and the information contained herein are subject to change without notice. Any such change shall be evidenced by the publication of an updated version of this document by Wolfspeed. No communication from any employee or agent of Wolfspeed or any third party shall effect an amendment or modification of this document. No responsibility is assumed by Wolfspeed for any infringement of patents or other rights of third parties which may result from use of the information contained herein. No license is granted by implication or otherwise under any patent or patent rights of Wolfspeed. Notwithstanding any application-specific information, guidance, assistance, or support that Wolfspeed may provide, the buyer of this product is solely responsible for determining the suitability of this product for the buyer’s purposes, including without limitation for use in the applications identified in the next bullet point, and for the compliance of the buyers’ products, including those that incorporate this product, with all applicable legal, regulatory, and safety-related requirements. This product has not been designed or tested for use in, and is not intended for use in, applications in which failure of the product would reasonably be expected to cause death, personal injury, or property damage, including but not limited to equipment implanted into the human body, life-support machines, cardiac defibrillators, and similar emergency medical equipment, aircraft navigation, communication, and control systems, aircraft power and propulsion systems, air traffic control systems, and equipment used in the planning, construction, maintenance, or operation of nuclear facilities. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Wolfspeed representative or from the Product Documentation sections of www.wolfspeed. com. REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact your Wolfspeed representative to ensure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. Contact info: 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 www.wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. PATENT: https://www.wolfspeed.com/legal/patents The information in this document is subject to change without notice. Rev. 1, JUNE 2022 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 | wolfspeed.com/power © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice.
E3M0060065K 价格&库存
很抱歉,暂时无法提供与“E3M0060065K”相匹配的价格&库存,您可以联系我们找货
E3M0060065K
  • 1+164.420241+21.37410
  • 30+102.0360530+13.26436
  • 60+94.6234260+12.30074
  • 120+88.39206120+11.49069
库存:440
