G12P10KE
P-Channel Enhancement Mode Power MOSFET
Description
The G12P10KE uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-100V
-12A
< 200mΩ
< 250mΩ
Schematic diagram
l RoHS Compliant
l ESD (HBM)>7.0KV
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
G12P10KE
TO-252
G12P10
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-100
V
ID
-12
A
IDM
-48
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
44.6
W
EAS
25
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
55
ºC/W
Maximum Junction-to-Case
RthJC
2.8
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1460-V1.2)
G12P10KE
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-100
V
IDSS
VDS = -100V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±10
uA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1.0
-1.7
-3.0
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -6A
178
200
VGS = -4.5V, ID = -6A
192
250
Forward Transconductance
gFS
VDS = -15V,ID = -6A
12
1652
42
41
33
4
7
52
12
38
28
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -50V,
f = 1.0MHz
VDD = -50V,
ID = -6A,
VGS = -10V
VDD = -50V,
ID = -6A,
RG = 9Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-12
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -6A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
35
nC
Reverse Recovery Time
Trr
46
ns
IF = -6A, VGS = 0V
di/dt=-500A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G12P10KE
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G12P10KE
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
-ID, Drain Current (A)
9
8
10
-4.5V
-10V
-5.5V
7
-3.5V
6
5
4
VGS=-3.3V
3
2
8
7
6
5
25℃
4
3
2
1
1
VDS= -5V
9
-4V
10
Figure 2. Transfer Characteristics
2
3
-VDS, Drain-to-Source Voltage (V)
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
250
VGS= -4.5V
VGS= -10V
100
50
4
6
8
10
VDD = -50V
ID = -6A
8
6
4
2
40
-Is, Reverse Drain Current (A)
Capacitance(pF)
6
Figure 6. Source-Drain Diode Forward
2500
Ciss
1500
1000
Qg Gate Charge(nC)
Figure 5. Capacitance
500
4
10
-ID-Drain Current (A)
2000
3
Figure 4. Gate Charge
300
150
2
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
200
1
Coss
Crss
40
50
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G12P10KE
Figure 10. Safe Operation Area
VGS = -10V
ID = -6A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
TJ(MAX)=150℃
TC=25℃
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G12P10KE
TO-252 Package Information
E
c
H
D
D1
L5
L3
b3
E1
L4
A2
b
θ
L
A1
L2
A
e
(L1)
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
2.20
2.30
2.40
0.00
0.20
A2
0.97
1.07
1.17
A
A1
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
E1
4.63
e
6.60
6.80
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
2.90REF
0.51BSC
0.88
1.28
0.50
1.00
1.65
1.80
1.95
8°
0°
TEL:0755-29961263
很抱歉,暂时无法提供与“G12P10KE”相匹配的价格&库存,您可以联系我们找货
