G12P06K
P-Channel Enhancement Mode Power MOSFET
Description
The G12P06K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-60V
-12A
< 70mΩ
< 85mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
G12P06K
TO-252
G12P06
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-60
V
ID
-12
A
IDM
-48
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
27
W
EAS
25
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
4.63
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1431-V1.1)
G12P06K
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-60
V
IDSS
VDS = -60V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1.0
-1.7
-3.0
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -6A
57
70
VGS = -4.5V, ID = -5A
69
85
Forward Transconductance
gFS
VDS = -5V,ID = -6A
15
1322
66
61
23
4
5
8
4
32
7
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -30V,
f = 1.0MHz
VDD = -30V,
ID = -6A,
VGS = -10V
VDD = -30V,
ID = -6A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-12
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -6A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
31
nC
Reverse Recovery Time
Trr
25
ns
IF = -6A, VGS = 0V
di/dt=-100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
The table shows the minimum avalanche energy, which is 64mJ when the device is tested until failure
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G12P06K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G12P06K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
25
25
-3.6V
15
-3.3V
10
-3V
5
VGS =-2.5V
2
3
-ID, Drain Current (A)
VDS = -5V
-4.5V
-10V
25℃
10
5
-VDS, Drain-to-Source Voltage (V)
2
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
90
80
VGS = -4.5V
60
50
VGS = -10V
30
4
6
8
10
8
Figure 4. Gate Charge
100
40
6
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
70
4
10
8
6
4
2
-ID-Drain Current (A)
VDD = -30V,
ID = -6A
10
15
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
-Is, Reverse Drain Current (A)
2000
1800
Capacitance(pF)
1600
Ciss
1400
1200
1000
800
600
400
200
Coss
Crss
40
50
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G12P06K
Figure 10. Safe Operation Area
VGS = -10V,
ID = -6A
VGS = -4.5V,
ID = -5A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ(MAX)=150℃
TC=25℃
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G12P06K
TO-252 Package Information
E
c
H
D
D1
L5
L3
b3
E1
L4
A2
b
θ
L
A1
L2
A
e
(L1)
COMMON DIMENSIONS
SYMBOL
A
A1
mm
MIN
NOM
MAX
2.20
2.30
2.40
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
E1
4.63
e
6.60
6.80
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
2.90REF
0.51BSC
0.88
1.28
0.50
1.00
1.65
1.80
1.95
8°
0°
TEL:0755-29961263
很抱歉,暂时无法提供与“G12P06K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.44461
- 50+1.13433
- 150+1.00138
