G110N06K
N-Channel Enhancement Mode Power MOSFET
Description
The G110N06K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
100% Avalanche Tested
60V
110A
6.4mΩ
8.4mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
G110N06K
TO-252
G110N06
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
60
V
ID
110
A
IDM
440
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
160
W
EAS
156
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
60
ºC/W
Maximum Junction-to-Case
RthJC
0.78
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1416-V1.1)
G110N06K
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
60
V
IDSS
VDS = 60V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.8
2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 20A
5.0
6.4
VGS = 4.5V, ID = 20A
6.0
8.4
Forward Transconductance
gFS
VGS = 5V, ID = 20A
334
306
122
17
27
15
13
32
27
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 30V,
f = 1.0MHz
VDD = 30V,
ID = 20A,
VGS = 10V
VDD = 30V,
ID = 20A,
RG = 2.5Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
110
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 20A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
59
nC
Reverse Recovery Time
Trr
IF = 20A, VGS = 0V
di/dt=100A/us
56
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G110N06K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G110N06K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
5V
5.5V
100
ID, Drain Current (A)
120
10V
VDS= 5V
4.5V
120
Figure 2. Transfer Characteristics
4V
80
60
40
VGS= 3.5V
80
60
25℃
40
2
3
VDS, Drain-to-Source Voltage (V)
2
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
8
VGS= 4.5V
VGS= 10V
2
8
Figure 4. Gate Charge
10
4
6
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
6
4
10
8
6
4
2
ID-Drain Current(A)
VDD = 30V
ID = 20A
50
75
100
125
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Ciss
7000
Capacitance(pF)
Is, Reverse Drain Current (A)
8000
6000
5000
4000
3000
2000
Coss
1000
Crss
40
50
60
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G110N06K
VGS = 10V
ID = 20A
VGS = 4.5V
ID = 20A
Figure 8. Safe Operation Area
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
0.78°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G110N06K
TO-252 Package Information
E
c
H
D
D1
L5
L3
b3
E1
L4
A2
b
θ
L
A1
L2
A
e
(L1)
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
2.30
2.40
A
2.20
A1
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
E1
4.63
e
6.60
6.80
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
L2
2.90REF
0.51BSC
L3
0.88
1.28
L4
0.50
1.00
L5
1.65
1.80
1.95
8°
θ
www.gofordsemi.com
0°
TEL:0755-29961263
很抱歉,暂时无法提供与“G110N06K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.96800
- 10+4.24440
- 30+3.87720
- 100+3.51000
